See the instructions above in this thread here. I am pretty sure @crosswick got it to work as a systemd
service, am I right?
is anyone successfully using i2c OLED / LCD?
giuliomoro Thank you. I've got this mostly to work. However whenever the OSC2OLED program runs for the first time when the Bela is started I am getting this error:
If it is run again the program runs fine and there is no error message. However when running it from start up it stops the other Bela program that is enabled to run on start up.
Are both your Bela program and the OSC2OLED program trying to access the same I2C device?
giuliomoro No just the OSC2LED. The Bela program is just a simple pd sketch that is sending OSC data to the screen for testing purposes at the moment.
insignificatother However when running it from start up it stops the other Bela program that is enabled to run on start up.
Can we see the .service
file? Also, what is the log of the Bela program that runs on startup, and what is the log of your program running at startup? You can achieve such logs with journalctl -fu SERVICENAME
Here is the .service file
[Unit]
Description=OSC to IC2 Screen Launcher
After=network-online.target
[Service]
ExecStart=/root/Bela/scripts/run_project.sh Screen_Test_Error
Type=simple
Restart=always
RestartSec=1
WorkingDirectory=/root/Bela/projects/Screen_Test_Error
Environment=HOME=/root
KillMode=process
[Install]
WantedBy=default.target
Here are the logs
root@bela:~# journalctl -fu bela_startup.service
Nov 03 17:16:56 bela stdbuf[293]: sigmund~ version 0.07
Nov 03 17:16:56 bela stdbuf[293]: Bela digital: channel 0 is set as input at message rate
Nov 03 17:16:56 bela stdbuf[293]: Bela digital: channel 1 is set as input at message rate
Nov 03 17:16:56 bela stdbuf[293]: Bela digital: channel 2 is set as input at message rate
Nov 03 17:16:56 bela stdbuf[293]: Bela digital: channel 3 is set as input at message rate
Nov 03 17:16:56 bela stdbuf[293]: connecting to port 7562
Nov 03 17:17:00 bela stdbuf[293]: Makefile:570: recipe for target 'runonly' failed
Nov 03 17:17:00 bela stdbuf[293]: make: *** [runonly] Terminated
Nov 03 17:17:00 bela systemd[1]: Stopping Run Bela at boot...
Nov 03 17:17:01 bela systemd[1]: Stopped Run Bela at boot.
root@bela:~# journalctl -fu custom_program
Nov 03 17:17:03 bela systemd[1]: custom_program.service: Service hold-off time over, scheduling restart.
Nov 03 17:17:03 bela systemd[1]: Stopped OSC to IC2 Screen Launcher.
Nov 03 17:17:03 bela systemd[1]: Started OSC to IC2 Screen Launcher.
Nov 03 17:17:04 bela run_project.sh[681]: Checking the board is up and running at root@192.168.7.2...Warning: Permanently added '192.168.7.2' (ECDSA) to the list of known hosts.
Nov 03 17:17:03 bela run_project.sh[681]: done
Nov 03 17:17:03 bela run_project.sh[681]: Board found at root@192.168.7.2
Nov 03 17:17:03 bela run_project.sh[681]: Running Screen_Test_Error...
Nov 03 17:17:03 bela run_project.sh[681]: Pseudo-terminal will not be allocated because stdin is not a terminal.
Nov 03 17:17:04 bela run_project.sh[681]: make: Warning: File 'libraries/UdpClient/build/UdpClient.d' has modification time 96520642 s in the future
Nov 03 17:17:05 bela run_project.sh[681]: Running /root/Bela/projects/Screen_Test_Error/Screen_Test_Error
insignificatother ExecStart=/root/Bela/scripts/run_project.sh Screen_Test_Error
run_project.sh
is going to call make stop
, thus killing the other program. You should run the program directly with /root/Bela/projects/Screen_Test_Error/Screen_Test_Error
And it's working. My noobness it showing. Thank you so much for your help and quick responses.
So here's a summary HOW-TO, for posterity:
- add this project to your Bela projects: http://github.com/giuliomoro/OSC2OLED4Bela . If you use a different project name, replace
OSC2OLED4Bela
with your project name in all the steps below. - open the project and build it. When running, it will not emit any audio, but you should be able to send it OSC messages on
bela.local:7562
from the host computer. You can run it like this for testing. - to see what messages and formats are supported, see the
parseMessage()
function inrender.cpp
. For instance, you can send/osc-test
followed by afloat
,/tr
followed by afloat
(ignored) and/or astring
,/param1
followed by afloat
. You can edit the program to change or add support for OSC messages - when you have a reliable way of sending OSC messages to it from the host, create a file
/lib/systemd/system/osc2oled.service
with this content:
[Unit]
[Service]
ExecStart=/root/Bela/projects/OSC2OLED4Bela/OSC2OLED4Bela
Type=simple
Restart=always
RestartSec=1
WorkingDirectory=/root/Bela/projects/OSC2OLED4Bela
KillMode=process
[Install]
This can be done from the terminal or by creating a file osc2oled.service
in your project (make sure the file includes only the text above and none of the automatically-generated content in the file you create) and then linking it into place by running ln -s /root/Bela/projects/OSC2OLED4Bela/osc2oled.service /lib/systemd/system/osc2oled.service
in the Bela IDE console.
- start the process in the background with
systemctl start osc2oled
, stop it withsystemctl stop osc2oled
. - while running in the background, you can visualise the process's output with
journalctl -fu osc2oled
(if executing the command from the Bela IDE console, usejournalctl -n 20 -u osc2oled | cat
instead) - once you verify it is working, you can open a different Bela project and try to send OSC to it from the Bela project instead of the host
- once you are happy, you can enable the
osc2oled
process to start automatically in the background at boot withsystemctl enable osc2oled
. Later you can disable it withsystemctl disable osc2oled
- caveat: when running at startup, the
osc2oled
service will probably start after the Bela program has started, so if you send OSC to it too early when your program starts, some content may not be visualised on the screen.
thanks for the overview! nice one.
i got everything working, up to sending OSC from a Pd patch to the background program -
but only after referencing the logs and your subsequent answer four posts up.
is it possible, for future reference for me and my fellow nitwits, to edit your post some, and have all the relevant info in this one place?
to clarify:
giuliomoro [Service]
ExecStart=/root/Bela/projects/(NAME OF PROJECT)/(NAME OF PROJECT)
Type=simple
Restart=always
RestartSec=1 (<< no need forhttp://bela.io/i think?)
WorkingDirectory=/root/Bela/projects/(OSC2OLED4Bela or NEW NAME OF PROJECT)
KillMode=process
i realise this might all be self-explanatory to some, but it's not to everybody
also
giuliomoro Bela IDE console, use journacltl -n 20 -u osc2oled | cat instead)
has a typo in journalctl, which is meh if you copy/paste.
and last,
giuliomoro systemctl enable osc2oled
doesn't seem to work with the /***** osc2oled.service *****/ header (generated in the IDE > new file) still on line 1 of the service file. had to remove that, so [unit] was the first thing in there. again, probably obvious to someone who knows what they're doing, but might save some frustration for others.
feel free to delete this post after if needed.
and thanks for walking us through this!
@Remork . Thanks for the feedback, hopefully it's fixed now.
well.. dunno?
with the risk of being pedantic
is the "http://bela.io/" supposed to be in the RestartSec line?
and
giuliomoro journalcltl
still has an L too many.
Remork is the "http://bela.io/" supposed to be in the RestartSec line?
D'OH
Remork still has an L too many.
D'OH D'OH
:face_with_rolling_eyes:
"pedantic" == reasonable in this case. Fixed now I think (again!).
can't even get the emoji to work ..
giuliomoro can't even get the emoji to work .
LOL
looks super now.
but seriously, can you pin post 84 somewhere?
add it to the Wiki maybe? i know i'll be looking for this in the future..
let's see if magic works:
@bela_robert any chance you could turn https://forum.bela.io/d/314-is-anyone-successfully-using-i2c-oled-lcd/85 into a KB page?
I certainly can. I'll get that together next week when I'll have an OLED screen to hand to test with and post here once it's up.
thanks
