so i'm trying to get an SSD1327 128x128 oled to work.
updated the code on the board using the script method (again, IDE method failed).
dropped O2O .zip on IDE, adjusted setup function to
u8g2_Setup_ssd1327_midas_128x128_f
it runs, i get the ASCII Bela logo, and i can communicate with local.pd.
my problem is the display speed: if i runparameters
, lfo's
orwaveforms
from the example, everything slows down dramatically, where it feels like the display can't keep up with the data it's being sent.
e.g. waveforms
sends data every 100ms, but that data gets displayed magnitudes slower.
if i hitnumber
after one of the other functions it will eventually display a number, but only after it churns out every single change it was sent - and it seems to be chewing on that info for quite a long time.
e.g. i hadlfo's
running for about ten seconds, turned it off and hit display-text
. that text would take over a minute to appear.
i've a feeling the old OSC2OLED4BELA was faster, but maybe that's just me thinking everything was better when i was younger.
is this to do with the library? am i the first one to notice this? any way to remedy this?
i read about boosting the clock speed (post #57 of this thread) but not sure how to go about doing that, or if that is even the key to the issue. thanks!
