evilplaymobil but I'm not sure all the externals from l2ork are there.
No they are not there, only the ones I built manually.
evilplaymobil I'm pretty interested on the fluid~ object so I could play SF2 soundfonts on Bela.
Link to the source code for it?
8 months later
Hey 🙂
Just bought a second hand Bela and look forward for it to arrive in a near future.
So now I am doing some research.
One thing I use a lot in pd is list-abs. But yeah not really externals, as they are all abstractions.
List-abs work fine for Bela, right, since it's abstractions?
Thanks!
as long as none of those abstractions use any non-vanilla objects, i guess you should be fine 🙂
never heard of that collection, looks interesting.
externals work as well, i just found it a bit more involved compiling libraries - abstractions are easier to use.
just load them into the same folder that _main.pd is in, if i recall correctly.
    yes, you can put them in the project folder, or create a dummy project pd-externals and put them all there so that they are accessible from all projects without having to duplicate them.
      Remork
      List abs are very good for list and table manipulation.
      I often use "array get" to get table data and make a list out of it and then use list-abs to do some manipulation, like reverse, invert, replace, add elements and then "array set" to put it back in the table. So many options with that library 🙂
      I did find a couple of already compiled externals, like sexy, cyclone ans else. Sexy I used to use a lot.
      But these days, I try to make everything vanilla, for ease of use.
      For reverb I really like Freeverb. I found this, but it seems like it's not compiled specifically for Bela, but "just" for Linux:
      https://github.com/noizhardware/bela-projects
      Maybe I'll try to follow the compile instructions for Bela and see if I can compile it sometime 🙂
      Thanks!
      Nice, so it works pretty much like Organelle. I think I like the common folder idea the most, which I use in both Organelle and my rpi/Pisound box.
      Thanks 🙂
      4 months later
      Hey guys 🙂
      I am using the phasorshot~ from TOF external library a lot in my patches on my Macbook. From this library:
      https://github.com/electrickery/pd-tof
      I would love to be able to use that external for Bela too. I did try to make a Vanilla version, but it just doesn't work as great as the hardcoded version from TOF library.
      I was wondering if anyone compiled it already? Or is it possible to use a Linux version? I got it for Organelle.
      If not, I guess I need to try compiling it myself, which I do not have a lot of experience with, to be honest, so if anyone already compiled I would be pretty grateful 🙂
      Thanks in advance!
      this one should work.
      Otherwise, building it from source is straightforward. I added build instructions and a binary download here
        Thanks, I think I will start with the Organelle version for simplicity and go on from there 🙂
        3 months later
        giuliomoro Sorry for jumping on this old thread, I've been trying to get the helmholtz~ external on Bela but am having some issues with removing the -Wl option. What's the best way to access the Makefile? I'm opening it from the terminal, removing the -Wl option in my text editor, saving it, but still am getting the error.
        a month later
        Hi! Thanks giuliomoro for the detailed instructions about compiling externals. I have compiled and successfully used externals like zexy and cyclone in Bela. It was easy and I had no issues following the instructions.
        Yesterday I compiled the Pure Data external timbreID (source is here: https://github.com/wbrent/timbreID) in a Bela Mini which some other people (@lokki ) found interesting. I followed the same instructions. Compilation and installation took a couple of minutes maximum.
        However I am having a bad time: Pd does not create the objects. I thought it should be similar to zexy, but it doesnt work for me.
        This is what I did and how I am testing it :
        • I compiled and installed with
        make PDINCLUDEDIR=/usr/local/include/libpd/
        (some .h files like g_canvas.h were needed so I copied them to /usr/local/include/libpd/ from https://github.com/giuliomoro/pure-data)
        make PDINCLUDEDIR=/usr/local/include/libpd/ PDLIBDIR=/root/Bela/projects/pd-externals/ install
        These are the first three lines of this _main.pd:
        #N canvas 381 151 391 472 10;
        #X declare -path ~/Bela/projects/pd-externals/timbreIDLib;
        #X obj 35 37 declare -path ~/Bela/projects/pd-externals/timbreIDLib
        When I try it, I only get in the infamous "error: ... couldn't create":
        - I tested it with the rPi binary: same result.
        - I copied timbreIDLib.pd_linux to ~/Bela/projects/pd-externals.
        - I tried with [zeroCrossing~] and [timbreIDLib/zeroCrossing~] as well as with various versions of the [declare]
        Is there anything I am not considering here?
        Thanks in advance!!
        are you 100% sure the path is [timbreIDLib/zeroCrossing~] and not something like [timbreID/zeroCrossing~]?
        just thinking out loud
        in the install.txt file included with the library, there's this line:
        C:/Users/Your Name/Documents/Pd/externals/timbreID/timbreIDLib
        and also:
        assuming timbreID is installed to the default Externals Install Directory, you can simply use the [declare] object like this:
        [declare -lib timbreID/timbreIDLib]
        which would imply that the lib object is created within a new timbreID folder.
        so you might be directing pd to a place that simply does not exist.
        maybe try [declare -lib ~/Bela/projects/pd-externals/timbreID/timbreIDLib], adding this extra folder level to the search path?
        Thanks @Remork !!
        it is weird how this had to be referenced but yes, as you suggested I had to add the /timbreID/ level in "~/Bela/projects/pd-externals" -> it worked!!
        For future people interested in timbreIDLib, this worked for me:
        • timbreIDLib.pd_linux has to be in ~/Bela/projects/pd-externals/timbreID/timbreIDLib and NOT in ~/Bela/projects/pd-externals/timbreIDLib
        • I used the following [declare] objects: [declare -path ~/Bela/projects/pd-externals/timbreID/timbreIDLib] and [declare -lib ~/Bela/projects/pd-externals/timbreID/timbreIDLib]
        • Using these [declare] objects the objects can be called directly without prefix e.g. [zeroCrossing~]
        this is the capture of the patch:
        great that you got that working!
        looks like a weird lib 🙂 what are you using it for?
          oh wow! looks great!
