Remork
List abs are very good for list and table manipulation.
I often use "array get" to get table data and make a list out of it and then use list-abs to do some manipulation, like reverse, invert, replace, add elements and then "array set" to put it back in the table. So many options with that library 🙂
I did find a couple of already compiled externals, like sexy, cyclone ans else. Sexy I used to use a lot.
But these days, I try to make everything vanilla, for ease of use.
For reverb I really like Freeverb. I found this, but it seems like it's not compiled specifically for Bela, but "just" for Linux:
https://github.com/noizhardware/bela-projects
Maybe I'll try to follow the compile instructions for Bela and see if I can compile it sometime 🙂
Thanks!
Nice, so it works pretty much like Organelle. I think I like the common folder idea the most, which I use in both Organelle and my rpi/Pisound box.
Thanks 🙂
4 months later
Hey guys 🙂
I am using the phasorshot~ from TOF external library a lot in my patches on my Macbook. From this library:
https://github.com/electrickery/pd-tof
I would love to be able to use that external for Bela too. I did try to make a Vanilla version, but it just doesn't work as great as the hardcoded version from TOF library.
I was wondering if anyone compiled it already? Or is it possible to use a Linux version? I got it for Organelle.
If not, I guess I need to try compiling it myself, which I do not have a lot of experience with, to be honest, so if anyone already compiled I would be pretty grateful 🙂
Thanks in advance!
this one should work.
Otherwise, building it from source is straightforward. I added build instructions and a binary download here
    Thanks, I think I will start with the Organelle version for simplicity and go on from there 🙂
    3 months later
    giuliomoro Sorry for jumping on this old thread, I've been trying to get the helmholtz~ external on Bela but am having some issues with removing the -Wl option. What's the best way to access the Makefile? I'm opening it from the terminal, removing the -Wl option in my text editor, saving it, but still am getting the error.
    a month later
    Hi! Thanks giuliomoro for the detailed instructions about compiling externals. I have compiled and successfully used externals like zexy and cyclone in Bela. It was easy and I had no issues following the instructions.
    Yesterday I compiled the Pure Data external timbreID (source is here: https://github.com/wbrent/timbreID) in a Bela Mini which some other people (@lokki ) found interesting. I followed the same instructions. Compilation and installation took a couple of minutes maximum.
    However I am having a bad time: Pd does not create the objects. I thought it should be similar to zexy, but it doesnt work for me.
    This is what I did and how I am testing it :
    • I compiled and installed with
    make PDINCLUDEDIR=/usr/local/include/libpd/
    (some .h files like g_canvas.h were needed so I copied them to /usr/local/include/libpd/ from https://github.com/giuliomoro/pure-data)
    make PDINCLUDEDIR=/usr/local/include/libpd/ PDLIBDIR=/root/Bela/projects/pd-externals/ install
    These are the first three lines of this _main.pd:
    #N canvas 381 151 391 472 10;
    #X declare -path ~/Bela/projects/pd-externals/timbreIDLib;
    #X obj 35 37 declare -path ~/Bela/projects/pd-externals/timbreIDLib
    When I try it, I only get in the infamous "error: ... couldn't create":
    - I tested it with the rPi binary: same result.
    - I copied timbreIDLib.pd_linux to ~/Bela/projects/pd-externals.
    - I tried with [zeroCrossing~] and [timbreIDLib/zeroCrossing~] as well as with various versions of the [declare]
    Is there anything I am not considering here?
    Thanks in advance!!
    are you 100% sure the path is [timbreIDLib/zeroCrossing~] and not something like [timbreID/zeroCrossing~]?
    just thinking out loud
    in the install.txt file included with the library, there's this line:
    C:/Users/Your Name/Documents/Pd/externals/timbreID/timbreIDLib
    and also:
    assuming timbreID is installed to the default Externals Install Directory, you can simply use the [declare] object like this:
    [declare -lib timbreID/timbreIDLib]
    which would imply that the lib object is created within a new timbreID folder.
    so you might be directing pd to a place that simply does not exist.
    maybe try [declare -lib ~/Bela/projects/pd-externals/timbreID/timbreIDLib], adding this extra folder level to the search path?
    Thanks @Remork !!
    it is weird how this had to be referenced but yes, as you suggested I had to add the /timbreID/ level in "~/Bela/projects/pd-externals" -> it worked!!
    For future people interested in timbreIDLib, this worked for me:
    • timbreIDLib.pd_linux has to be in ~/Bela/projects/pd-externals/timbreID/timbreIDLib and NOT in ~/Bela/projects/pd-externals/timbreIDLib
    • I used the following [declare] objects: [declare -path ~/Bela/projects/pd-externals/timbreID/timbreIDLib] and [declare -lib ~/Bela/projects/pd-externals/timbreID/timbreIDLib]
    • Using these [declare] objects the objects can be called directly without prefix e.g. [zeroCrossing~]
    this is the capture of the patch:
    great that you got that working!
    looks like a weird lib 🙂 what are you using it for?
      oh wow! looks great!
      a year later
      giuliomoro git clone https://github.com/giuliomoro/pure-data &&\
      cd pure-data &&\
      scp src/*h root@192.168.7.2:/usr/local/include/libpd/
      Hi and thanks so much for your help !
      Sorry abut this issue, but it seems that this first command line doesn't work.
      Link mentionne in it seems to fail.
      Also, I have this error message in my terminal (mac 10.14.6)
      xcrun: error: invalid active developer path (/Library/Developer/CommandLineTools), missing xcrun at: /Library/Developer/CommandLineTools/usr/bin/xcrun
      I try to compile and install "ggee"
      All the detailed procedure fail.
      Also need to install "iemlib" and "moonlib"
      Help needed please ?
      All the best,
      Damien
        heliopolarthing Sorry abut this issue, but it seems that this first command line doesn't work.
        git clone https://github.com/giuliomoro/pure-data should definitely work, the link is still active.
        heliopolarthing Also, I have this error message in my terminal (mac 10.14.6)
        What line do you execute that triggers this error? If you are trying to build an external on Bela, this error means that you ran some commands on your computer instead of Bela.
        I follow this procedure >
        Now I found some time to do it (Friday night, 2am, of course).
        Preparation:
        - get extra header files needed to compile Cyclone (and ggee, and others) on Bela:
        - on your computer open a terminal and:
        cd pure-data &&\
        right you may have an issue with your xcode tools installation, which apparently Apple is really good at screwing up (this is unrelated to Bela). You may want to google for that and see if you find a way to fix it helps fixes it.
        Alternatively, you can avoid the first line and instead download this zip archive and uncompress it.
          I had a further look: many libraries are already built for ARM (Bela's architecture, more precisely armv7) and are available via Deken. A possible Deken workflow to obtain pre-built libraries this way from Deken:
          • open the most recent Pd on your desktop
          • open the "Help -> Find Externals" dialog (aka Deken)
          • at the bottom click "More -> Preferences"
          • in the "Install externals to directory" section, check which one is the currently selected directory. Make a note of it somewhere else as you'll want to restore it later on. Click the ... button. create a new folder in a convenient location (e.g.: Desktop), called pd-externals-for-bela, select this and close the file picker; make sure this stays selected in the radio button selection
          • in "platform settings" make sure "hide foreign architectures" is ticked
          • in "platform settings" select "User-defined-platform" and enter (exactly) Linux-armv7-32
          • close the dialog with "OK"
          • now search for libraries you need for Bela and if a result is produced, click on it and it will "install" it in the folder you selected above. You can do this for several libraries one after the other.
          • once done, revert the settings in the "Install externals to directory" section and in "Platform settings" select "Default platform". Note that the above will not have installed those libraries in such a way that they are usable from Pd on the host. You can repeat the same procedure at the previous step to install them on the host (if you haven't already) now that you have restored the settings.
          Now, you can install these libraries on Bela with a single command:
          ssh root@bela.local mkdir -p Bela/projects/pd-externals # creates the pd-externals dummy project if needed
          scp -r root@bela.local ~/Desktop/pd-externals-for-bela/* root@bela.local:Bela/projects/pd-externals/
          (amend the path to the ~/Desktop/pd-externals-for-bela folder if you used a different one ).
          Note that you will need to use [declare -lib] and/or [declare -path] for the libraries and externals to become available on Bela. I recommend you do the same on the host (i.e.: remove any non-standard paths from Preferences->Paths and any libraries from Preferences->Startup).
          In particular, iemlib ships with a combination of abstractions and a single-file library, so you will need two declares, a -lib for externals and a -path for abstractions. If this is confusing, the official documentation tries to explain it.
          In your case:
          [declare -lib iemlib]
          [declare -path iemlib]
          [sparse_FIR~] // "external" verify it creates
          [unsig~] // "abstraction" verify it creates
          while moonlib is a multi-file library so you should just need
          [declare -path moonlib]
          [char2f] // verify it creates
          • max likes this.
          hello, and thank you very much for your quick and precious help!
          So I followed your advice by downloading the file directly. Then I used my terminal with this line:
          cd /Users/MYUSERNAME/Desktop/pure-data-Bela-master
          then
          install seems ok 🙂
          Then, I compiled as indicated the external library ggee.
          I attach here a part of the terminal return (impossible to attach a .txt or .pdf file including all of this terminal return) which contains a lot of "warning".
          However, I continued until the end.
          Do you think that these multiple "warnings" hinder the proper functioning of the operation? Or is this normal?
          (sorry for my ignorance)
          The test with the patch including the ggee/moog~ object seems ok insofar as the object appears well on the IDE and is well connected!
          Thanks again,
          Waiting for your confirmation concerning my doubt ("warnings")
          I will now try to install the other two libraries (iemlib and moonlib)
