I now decided to gather pre-built externals here. I won't rebuild old ones, but any I will build or rebuild in the future will go there.
10 days later
Hello!
I'm trying to install the ipoke~ external. I tried the above examples for ggee and cyclone, and also helmhotz~ (thank you for these step by step!), which were successful. I tried to apply the same process for ipoke~ with its specific makefile but i cannot find the way to make it work. I'm new using Bela, i'm good with puredata but the rest... Still a bit confusing with my poor coding skills...
I got the source code here: http://puredata.info/Members/ipoke/ipoke_v.3_test1.zip/view
I tried copying the pd_linux only on pd-externals (in the IDE) but didn't made my objects work. i don't find the right way to compile it. Here is what I get when I try the "cyclone" way in the src file.
I tried to replace the parameters with LINUXFLAGS like in the helmholtz~ example, but this became very complicated.. I'm gonna try again, in between, would you have any clue? or is there another way? Thank you so much for your help!
    marylougarou I tried copying the pd_linux only on pd-externals (in the IDE) but didn't made my objects work
    that wouldn't work: it's probably a .pd_linux file for x86 architecture, not for ARM.
    marylougarou Here is what I get when I try the "cyclone" way in the src file.
    the issue here is that the -Wall and -Werror flags mean, respectively "show all warnings" and "treat all warnings as fatal errors". In turn this causes the compilation to fail. The easiest fix is to edit the Makefile and remove -Werror from LINUXCFLAGS. I would also remove them_pd.h that is in that folder and add to LINUXCFLAGS: -I/usr/local/lib/include: the PD_INCLUDE variable you are passing at the command line is ignored in this Makefile. At the end you'd have the following in LINUXCFLAGS:
    LINUXCFLAGS = -DPD -DUNIX -DICECAST -O3 -funroll-loops -fomit-frame-pointer \
        -Wall -W -Wshadow -Wstrict-prototypes -fno-strict-aliasing -I/usr/local/include/libpd \
        -Wno-unused -Wno-parentheses -Wno-switch -fPIC
    With this, it builds fine for me.
    is it possible that you pasted all the lines in one line? Then you should remove the \. like this:
    LINUXCFLAGS = -DPD -DUNIX -DICECAST -O3 -funroll-loops -fomit-frame-pointer -Wall -W -Wshadow -Wstrict-prototypes -fno-strict-aliasing -I/usr/local/include/libpd -Wno-unused -Wno-parentheses -Wno-switch -fPIC
      3 months later
      for future records, I am uploading here the externals I build, including all build instructions. If you don't find your favourite external there, hopefully the instructions I used to build the others will help you building the ones you are interested in.
      Hello giuliomoro! First of all, many thanks for your great support here!
      Please, is there a way for you to share the compiled libpd with all the Pd-l2ork externals?
      I'm pretty interested on the fluid~ object so I could play SF2 soundfonts on Bela.
      I went here https://github.com/BelaPlatform/Bela/issues/621 but I'm not sure all the externals from l2ork are there.
      Thank you in advance!
        evilplaymobil but I'm not sure all the externals from l2ork are there.
        No they are not there, only the ones I built manually.
        evilplaymobil I'm pretty interested on the fluid~ object so I could play SF2 soundfonts on Bela.
        Link to the source code for it?
        8 months later
        Hey 🙂
        Just bought a second hand Bela and look forward for it to arrive in a near future.
        So now I am doing some research.
        One thing I use a lot in pd is list-abs. But yeah not really externals, as they are all abstractions.
        List-abs work fine for Bela, right, since it's abstractions?
        Thanks!
        as long as none of those abstractions use any non-vanilla objects, i guess you should be fine 🙂
        never heard of that collection, looks interesting.
        externals work as well, i just found it a bit more involved compiling libraries - abstractions are easier to use.
        just load them into the same folder that _main.pd is in, if i recall correctly.
          yes, you can put them in the project folder, or create a dummy project pd-externals and put them all there so that they are accessible from all projects without having to duplicate them.
            Remork
            List abs are very good for list and table manipulation.
            I often use "array get" to get table data and make a list out of it and then use list-abs to do some manipulation, like reverse, invert, replace, add elements and then "array set" to put it back in the table. So many options with that library 🙂
            I did find a couple of already compiled externals, like sexy, cyclone ans else. Sexy I used to use a lot.
            But these days, I try to make everything vanilla, for ease of use.
            For reverb I really like Freeverb. I found this, but it seems like it's not compiled specifically for Bela, but "just" for Linux:
            https://github.com/noizhardware/bela-projects
            Maybe I'll try to follow the compile instructions for Bela and see if I can compile it sometime 🙂
            Thanks!
            Nice, so it works pretty much like Organelle. I think I like the common folder idea the most, which I use in both Organelle and my rpi/Pisound box.
            Thanks 🙂
            4 months later
            Hey guys 🙂
            I am using the phasorshot~ from TOF external library a lot in my patches on my Macbook. From this library:
            https://github.com/electrickery/pd-tof
            I would love to be able to use that external for Bela too. I did try to make a Vanilla version, but it just doesn't work as great as the hardcoded version from TOF library.
            I was wondering if anyone compiled it already? Or is it possible to use a Linux version? I got it for Organelle.
            If not, I guess I need to try compiling it myself, which I do not have a lot of experience with, to be honest, so if anyone already compiled I would be pretty grateful 🙂
            Thanks in advance!
            this one should work.
            Otherwise, building it from source is straightforward. I added build instructions and a binary download here
              Thanks, I think I will start with the Organelle version for simplicity and go on from there 🙂
