Still perfect!
Thanks again 🙂
I did follow @lokki's advice.
And I made the same observation.
I then tried to compile iemlib with the same instructions as those detailed in post #100 (cyclone and ggee).
But still the same.
I then monitored the file contained in the bela via the terminal, and it appears a sparse_FIR~-help.pd and a sparse_FIR~.c
Then directly in the IDE folder manager, where there is only a sparse_FIR~-help.pd
Strangely, the [char2f] object started to work after turning the bela off and on again.
Oops, I'll go update it.
And check if the patch for which I am trying to install all these libraries works with the few iemlib objects that already work.
These efforts are to be able to use the AutoPreset library
https://github.com/MetaluNet/AutoPreset
It consists of a series of abstractions allowing to make presets of all the settings of the patch, and to be able to interpolate these values ​​(if float) from one preset to another.
All this to morph the presets of an i2c / midi / 8cv in / 2 audio in >>> i2c / midi / 8 cv out / 2 audio out matrix into my eurorack system + Digitakt + OTO Bam, with the Pepper.
