3 months later
for future records, I am uploading here the externals I build, including all build instructions. If you don't find your favourite external there, hopefully the instructions I used to build the others will help you building the ones you are interested in.
Hello giuliomoro! First of all, many thanks for your great support here!
Please, is there a way for you to share the compiled libpd with all the Pd-l2ork externals?
I'm pretty interested on the fluid~ object so I could play SF2 soundfonts on Bela.
I went here https://github.com/BelaPlatform/Bela/issues/621 but I'm not sure all the externals from l2ork are there.
Thank you in advance!
    evilplaymobil but I'm not sure all the externals from l2ork are there.
    No they are not there, only the ones I built manually.
    evilplaymobil I'm pretty interested on the fluid~ object so I could play SF2 soundfonts on Bela.
    Link to the source code for it?
    8 months later
    Hey 🙂
    Just bought a second hand Bela and look forward for it to arrive in a near future.
    So now I am doing some research.
    One thing I use a lot in pd is list-abs. But yeah not really externals, as they are all abstractions.
    List-abs work fine for Bela, right, since it's abstractions?
    Thanks!
    as long as none of those abstractions use any non-vanilla objects, i guess you should be fine 🙂
    never heard of that collection, looks interesting.
    externals work as well, i just found it a bit more involved compiling libraries - abstractions are easier to use.
    just load them into the same folder that _main.pd is in, if i recall correctly.
      yes, you can put them in the project folder, or create a dummy project pd-externals and put them all there so that they are accessible from all projects without having to duplicate them.
        Remork
        List abs are very good for list and table manipulation.
        I often use "array get" to get table data and make a list out of it and then use list-abs to do some manipulation, like reverse, invert, replace, add elements and then "array set" to put it back in the table. So many options with that library 🙂
        I did find a couple of already compiled externals, like sexy, cyclone ans else. Sexy I used to use a lot.
        But these days, I try to make everything vanilla, for ease of use.
        For reverb I really like Freeverb. I found this, but it seems like it's not compiled specifically for Bela, but "just" for Linux:
        https://github.com/noizhardware/bela-projects
        Maybe I'll try to follow the compile instructions for Bela and see if I can compile it sometime 🙂
        Thanks!
        Nice, so it works pretty much like Organelle. I think I like the common folder idea the most, which I use in both Organelle and my rpi/Pisound box.
        Thanks 🙂
        4 months later
        Hey guys 🙂
        I am using the phasorshot~ from TOF external library a lot in my patches on my Macbook. From this library:
        https://github.com/electrickery/pd-tof
        I would love to be able to use that external for Bela too. I did try to make a Vanilla version, but it just doesn't work as great as the hardcoded version from TOF library.
        I was wondering if anyone compiled it already? Or is it possible to use a Linux version? I got it for Organelle.
        If not, I guess I need to try compiling it myself, which I do not have a lot of experience with, to be honest, so if anyone already compiled I would be pretty grateful 🙂
        Thanks in advance!
        this one should work.
        Otherwise, building it from source is straightforward. I added build instructions and a binary download here
          Thanks, I think I will start with the Organelle version for simplicity and go on from there 🙂
          3 months later
          giuliomoro Sorry for jumping on this old thread, I've been trying to get the helmholtz~ external on Bela but am having some issues with removing the -Wl option. What's the best way to access the Makefile? I'm opening it from the terminal, removing the -Wl option in my text editor, saving it, but still am getting the error.
          a month later
          Hi! Thanks giuliomoro for the detailed instructions about compiling externals. I have compiled and successfully used externals like zexy and cyclone in Bela. It was easy and I had no issues following the instructions.
          Yesterday I compiled the Pure Data external timbreID (source is here: https://github.com/wbrent/timbreID) in a Bela Mini which some other people (@lokki ) found interesting. I followed the same instructions. Compilation and installation took a couple of minutes maximum.
          However I am having a bad time: Pd does not create the objects. I thought it should be similar to zexy, but it doesnt work for me.
          This is what I did and how I am testing it :
          • I compiled and installed with
          make PDINCLUDEDIR=/usr/local/include/libpd/
          (some .h files like g_canvas.h were needed so I copied them to /usr/local/include/libpd/ from https://github.com/giuliomoro/pure-data)
          make PDINCLUDEDIR=/usr/local/include/libpd/ PDLIBDIR=/root/Bela/projects/pd-externals/ install
          These are the first three lines of this _main.pd:
          #N canvas 381 151 391 472 10;
          #X declare -path ~/Bela/projects/pd-externals/timbreIDLib;
          #X obj 35 37 declare -path ~/Bela/projects/pd-externals/timbreIDLib
          When I try it, I only get in the infamous "error: ... couldn't create":
          - I tested it with the rPi binary: same result.
          - I copied timbreIDLib.pd_linux to ~/Bela/projects/pd-externals.
          - I tried with [zeroCrossing~] and [timbreIDLib/zeroCrossing~] as well as with various versions of the [declare]
          Is there anything I am not considering here?
          Thanks in advance!!
          are you 100% sure the path is [timbreIDLib/zeroCrossing~] and not something like [timbreID/zeroCrossing~]?
          just thinking out loud
          in the install.txt file included with the library, there's this line:
          C:/Users/Your Name/Documents/Pd/externals/timbreID/timbreIDLib
          and also:
          assuming timbreID is installed to the default Externals Install Directory, you can simply use the [declare] object like this:
          [declare -lib timbreID/timbreIDLib]
          which would imply that the lib object is created within a new timbreID folder.
          so you might be directing pd to a place that simply does not exist.
          maybe try [declare -lib ~/Bela/projects/pd-externals/timbreID/timbreIDLib], adding this extra folder level to the search path?
