Here is the answer of Bela (with the command > find -type f /root/Bela/projects/pd-externals)
find:
paths must precede expression:
Right sorry I wrote the line wrong. It sjould be:
find /root/Bela/projects/pd-externals -type f
Here is the line and the answer:
root@bela ~/Bela# find /root/Bela/projects/pd-externals -type f
/root/Bela/projects/pd-externals/settings.json
Right so the externals are stored in the project folder?
I can't tell it.
I made this dummy project trick "pd-externals" you did.
I create a new project, upload only the main.pd and my abstractions.
But the
main.pd patch still send "couldn't create" messages.
I think this discussion is crossing this other one:
https://forum.bela.io/d/2713-illegal-instruction-message/6
Right, so I updated else for Bela, grab this latest version: https://github.com/BelaPlatform/Bela/files/10212285/else-v1.0-rc4-93-g0c64c285.zip
I unzip it in /root/Bela/pd-externals/else, so that for instance I have /root/Bela/pd-externals/else/above~.pd_linux. For your patch to work you need to have [declare -path /root/Bela/projects/pd-externals/else] somewhere in it. I can load the patch you posted elsewhere but there are a couple of abstractions missing (e.g.: TOUR_DE_CONTROLE). I see CPU usage is already pretty high at 65% (yet with missing parts), so you may want to look at ways to improve the CPU efficiency. First off, set the project's block size to 128. Then load smaller chunks of the patch so that you can identify which ones are more CPU intensive. If at any point the IDE becomes unresponsive, briefly tap the button that is on the Bela cape (a bit complicated to do if Pepper is inside your rack) and that will stop the running program and give you back access to the IDE. Note that if you add the --high-performance-mode flag to the User Command Line Arguments: field in the project settings, you will be able to use up to 99% of the CPU for the patch, but then you definitely need to have access to the button (we can later look into how to remote that to the front panel for embedded use).
    I am trying to rebuild now with better compiler flags. Let's see whether that gives any meaningful performance improvements.
    giuliomoro Oh ! What a gift this morning ! A lot of nice informations here !
    Thanks a lot @giuliomoro
    First, about the externals.
    So, in IDE, I have:
    - deleted my previous pd-externals dummy project
    - created a new one
    - uploaded else-v1.0-rc4-93-g0c64c285.zip in it
    - typed in IDE mkdir -p /root/Bela/pd-externals/else
    cd /root/Bela/pd-externals/else && unzip /root/Bela/projects/pd-externals/else-v1.0-rc4-93-g0c64c285.zip && rm /root/Bela/projects/pd-externals/else-v1.0-rc4-93-g0c64c285.zip
    - read in console Archive: /root/Bela/projects/pd-externals/else-v1.0-rc4-93-g0c64c285.zip
    replace else/bandstop~.pd_linux? [y]es, [n]o, [A]ll, [N]one, [r]ename:
    error: invalid response [pwd]
    - typed A to replace all (because it ask me to do something with the non deleted objects !??)
    - deleted my main project
    - created a new one with (underscore)main.pd including a [declare -path /root/Bela/projects/pd-externals/else]
    - Clear the console
    - Build & run my project
    - and read this in console:
    Building project ...
    Linking...
    ...done
    Build finished
    Running project ...
    Running Pd 0.51-4
    Audio channels in use: 2
    Analog channels in use: 8
    Digital channels in use: 16
    No MIDI device enabled
    pd 0.51.4
    bonk version 1.5
    fiddle version 1.1 TEST4
    pique 0.1 for PD version 23
    sigmund~ version 0.07
    brown 0.2
    error: ... couldn't create
    brown 0.2
    rescale 10 10000
    rescale 10 10000
    s2f~
    s2f~
    brown 0.2
    brown 0.2
    rescale 10 10000
    rescale 10 10000
    s2f~
    s2f~
    brown 0.2
    brown 0.2
    rescale 10 10000
    rescale 10 10000
    s2f~
    s2f~
    brown 0.2
    brown 0.2
    rescale 10 10000
    rescale 10 10000
    s2f~
    s2f~
    brown 0.2
    brown 0.2
    brown 0.2
    brown 0.2
    out1
    out2
    Bela digital: channel 6 is set as output at message rate
    Bela digital: channel 7 is set as output at message rate
    Bela digital: channel 10 is set as output at message rate
    Bela digital: channel 2 is set as output at message rate
    Bela digital: channel 3 is set as output at message rate
    Bela digital: channel 0 is set as output at message rate
    Bela digital: channel 1 is set as output at message rate
    Bela digital: channel 4 is set as output at message rate
    Bela digital: channel 5 is set as output at message rate
    Bela digital: channel 8 is set as output at message rate
    Bela digital: channel 14 is set as input at message rate
    Bela digital: channel 15 is set as input at message rate
    Bela digital: channel 13 is set as input at message rate
    Bela digital: channel 12 is set as input at message rate
    Bela digital: channel 11 is set as input at message rate
    Bela digital: channel 9 is set as input at message rate
    Bela digital: channel 6 is set as output at signal rate
    Bela digital: channel 7 is set as output at signal rate
    Bela digital: channel 10 is set as output at signal rate
    Bela digital: channel 2 is set as output at signal rate
    Bela digital: channel 3 is set as output at signal rate
    Bela digital: channel 0 is set as output at signal rate
    Bela digital: channel 1 is set as output at signal rate
    Bela digital: channel 4 is set as output at signal rate
    Bela digital: channel 5 is set as output at signal rate
    Bela digital: channel 8 is set as output at signal rate
    Did I do something wrong ?
    I have also tried to change the [declare -path /root/Bela/projects/pd-externals/else] to [declare -path /root/Bela/pd-externals/else] because the unzip directory was /root/Bela/pd-externals/else
    But nothing change: still error "couldn't create".
    to
    But nothing change:
    still "... couldn't create" errors.
    what do you get with ls /root/Bela/pd-externals/else/above~.pd_linux ? and then find /root/Bela/pd-externals -type d ?
      With ls /root/Bela/pd-externals/else/above~.pd_linux
      i get
      ls: cannot access '/root/Bela/pd-externals/else/above~.pd_linux': No such file or directory
      and then with find /root/Bela/pd-externals -type d
      i get
      and with ls -l /root/Bela/pd-externals/else/
      i get
      total 0
      Typing ls -l /root/Bela/
      shows that Else & Cyclone libraries exists
      Typing ls -l /root/Bela/else
      shows Else objects...
      So, I tried [declare -path /root/Bela/else] in my Pd patch, but it doesn't work.
      Now i'm trying, with command lines to place Else & Cyclone libraries in /root/Bela/pd-externals
        sorry I missed a projects in my paths. Should have been:
        what do you get with ls /root/Bela/projects/pd-externals/else/above~.pd_linux ? and then find /root/Bela/projects/pd-externals -type d and then find /root/Bela/projects/pd-externals -type f | grep pd_linux?
          FatJak Now i'm trying, with command lines to place Else & Cyclone libraries in /root/Bela/pd-externals
          that should be /root/Bela/projects/pd-externals
          Thanks again @giuliomoro
          Since few hours, i feel free to make some experiences.
          - I have selected only the .pd objects in my computer Else library and made from it a folder.zip file
          - I have upload/install it in /root/Bela/pd-externals and i modified the main.pd path object to these externals
          - I have discover that there his very few objects that could't be created.
          Here is the list:
          else/fold -1 1
          else/args -
          else/swap2
          else/rand.f -1 1
          else/rescale -1 1 0 127
          s2f~
          I have tryed to make .pd abstractions from these graphical objects.
          It seems not working.
          (kind of bruteforce experimentation)
          After cleanup, reinstall as you tell me, this is what I get with
          and then
          /root/Bela/projects/pd-externals/build
          /root/Bela/projects/pd-externals/cd
          and then
          /root/Bela/projects/pd-externals/else/canvas.bounds.pd_linux
          /root/Bela/projects/pd-externals/else/rint.pd_linux
          /root/Bela/projects/pd-externals/else/zerocross~.pd_linux
          /root/Bela/projects/pd-externals/else/xselect~.pd_linux
          /root/Bela/projects/pd-externals/else/routetype.pd_linux
          /root/Bela/projects/pd-externals/else/wt~.pd_linux
          /root/Bela/projects/pd-externals/else/pluck~.pd_linux
          /root/Bela/projects/pd-externals/else/sig2float~.pd_linux
          /root/Bela/projects/pd-externals/else/lfnoise~.pd_linux
          /root/Bela/projects/pd-externals/else/hot.pd_linux
          /root/Bela/projects/pd-externals/else/suspedal.pd_linux
          /root/Bela/projects/pd-externals/else/lag~.pd_linux
          /root/Bela/projects/pd-externals/else/bl.saw2~.pd_linux
          /root/Bela/projects/pd-externals/else/float2bits.pd_linux
          /root/Bela/projects/pd-externals/else/datetime.pd_linux
          /root/Bela/projects/pd-externals/else/loadbanger.pd_linux
          /root/Bela/projects/pd-externals/else/router.pd_linux
          /root/Bela/projects/pd-externals/else/args.pd_linux
          /root/Bela/projects/pd-externals/else/decay2~.pd_linux
          /root/Bela/projects/pd-externals/else/chance~.pd_linux
          /root/Bela/projects/pd-externals/else/lorenz~.pd_linux
          /root/Bela/projects/pd-externals/else/fbsine~.pd_linux
          /root/Bela/projects/pd-externals/else/noteinfo.pd_linux
          /root/Bela/projects/pd-externals/else/ctl.in.pd_linux
          /root/Bela/projects/pd-externals/else/canvas.file.pd_linux
          /root/Bela/projects/pd-externals/else/wrap2.pd_linux
          /root/Bela/projects/pd-externals/else/gui.pd_linux
          /root/Bela/projects/pd-externals/else/highpass~.pd_linux
          /root/Bela/projects/pd-externals/else/quantizer.pd_linux
          /root/Bela/projects/pd-externals/else/op~.pd_linux
          /root/Bela/projects/pd-externals/else/keyboard.pd_linux
          /root/Bela/projects/pd-externals/else/dir.pd_linux
          /root/Bela/projects/pd-externals/else/separate.pd_linux
          /root/Bela/projects/pd-externals/else/spread.pd_linux
          /root/Bela/projects/pd-externals/else/symbol2any.pd_linux
          /root/Bela/projects/pd-externals/else/tabreader.pd_linux
          /root/Bela/projects/pd-externals/else/rescale~.pd_linux
          /root/Bela/projects/pd-externals/else/sort.pd_linux
          /root/Bela/projects/pd-externals/else/fold~.pd_linux
          /root/Bela/projects/pd-externals/else/stepnoise~.pd_linux
          /root/Bela/projects/pd-externals/else/bandstop~.pd_linux
          /root/Bela/projects/pd-externals/else/glide~.pd_linux
          /root/Bela/projects/pd-externals/else/retrieve.pd_linux
          /root/Bela/projects/pd-externals/else/imp~.pd_linux
          /root/Bela/projects/pd-externals/else/wrap2~.pd_linux
          /root/Bela/projects/pd-externals/else/asr~.pd_linux
          /root/Bela/projects/pd-externals/else/toggleff~.pd_linux
          /root/Bela/projects/pd-externals/else/dollsym.pd_linux
          /root/Bela/projects/pd-externals/else/spread~.pd_linux
          /root/Bela/projects/pd-externals/else/fold.pd_linux
          /root/Bela/projects/pd-externals/else/autofade2~.pd_linux
          /root/Bela/projects/pd-externals/else/lag2~.pd_linux
          /root/Bela/projects/pd-externals/else/fader~.pd_linux
          /root/Bela/projects/pd-externals/else/ratio2cents.pd_linux
          /root/Bela/projects/pd-externals/else/nyquist~.pd_linux
          /root/Bela/projects/pd-externals/else/messbox.pd_linux
          /root/Bela/projects/pd-externals/else/bend.out.pd_linux
          /root/Bela/projects/pd-externals/else/cents2ratio.pd_linux
          /root/Bela/projects/pd-externals/else/touch.out.pd_linux
          /root/Bela/projects/pd-externals/else/timed.gate~.pd_linux
          /root/Bela/projects/pd-externals/else/canvas.zoom.pd_linux
          /root/Bela/projects/pd-externals/else/brown~.pd_linux
          /root/Bela/projects/pd-externals/else/match~.pd_linux
          /root/Bela/projects/pd-externals/else/slew2~.pd_linux
          /root/Bela/projects/pd-externals/else/mov.avg~.pd_linux
          /root/Bela/projects/pd-externals/else/pgm.in.pd_linux
          /root/Bela/projects/pd-externals/else/pan4~.pd_linux
          /root/Bela/projects/pd-externals/else/properties.pd_linux
          /root/Bela/projects/pd-externals/else/bl.square~.pd_linux
          /root/Bela/projects/pd-externals/else/trighold~.pd_linux
          /root/Bela/projects/pd-externals/else/highshelf~.pd_linux
          /root/Bela/projects/pd-externals/else/power~.pd_linux
          /root/Bela/projects/pd-externals/else/ratio2cents~.pd_linux
          /root/Bela/projects/pd-externals/else/xselect2~.pd_linux
          /root/Bela/projects/pd-externals/else/gaussian~.pd_linux
          /root/Bela/projects/pd-externals/else/adsr~.pd_linux
          /root/Bela/projects/pd-externals/else/canvas.active.pd_linux
          /root/Bela/projects/pd-externals/else/imp2~.pd_linux
          /root/Bela/projects/pd-externals/else/crackle~.pd_linux
          /root/Bela/projects/pd-externals/else/function.pd_linux
          /root/Bela/projects/pd-externals/else/click.pd_linux
          /root/Bela/projects/pd-externals/else/rint~.pd_linux
          /root/Bela/projects/pd-externals/else/fontsize.pd_linux
          /root/Bela/projects/pd-externals/else/oscope~.pd_linux
          /root/Bela/projects/pd-externals/else/gendyn~.pd_linux
          /root/Bela/projects/pd-externals/else/note.in.pd_linux
          /root/Bela/projects/pd-externals/else/wavetable~.pd_linux
          /root/Bela/projects/pd-externals/else/cosine~.pd_linux
          /root/Bela/projects/pd-externals/else/freq.shift~.pd_linux
          /root/Bela/projects/pd-externals/else/f2s~.pd_linux
          /root/Bela/projects/pd-externals/else/median~.pd_linux
          /root/Bela/projects/pd-externals/else/pulsecount~.pd_linux
          /root/Bela/projects/pd-externals/else/sine~.pd_linux
          /root/Bela/projects/pd-externals/else/blocksize~.pd_linux
          /root/Bela/projects/pd-externals/else/biquads~.pd_linux
          /root/Bela/projects/pd-externals/else/rad2hz.pd_linux
          /root/Bela/projects/pd-externals/else/merge.pd_linux
          /root/Bela/projects/pd-externals/else/note.pd_linux
          /root/Bela/projects
          And here is the list of the "... couldn't create" objects:
          brown 0.2
          rescale 10 10000
          s2f~
          Hmmm... what would I do without this three little seeds ? Nothing, with my "work in progress" patch.
          Thanks @giuliomoro to let me dive deep into the surface of command lines.
          Even if I only understand the reflect of it.
          it seems like you are missing several externals there. This is the full list I get:
          above~.pd_linux
          add~.pd_linux
          adsr~.pd_linux
          allpass.2nd~.pd_linux
          allpass.rev~.pd_linux
          args.pd_linux
          asr~.pd_linux
          autofade2~.pd_linux
          autofade~.pd_linux
          balance~.pd_linux
          bandpass~.pd_linux
          bandstop~.pd_linux
          bend.in.pd_linux
          bend.out.pd_linux
          bicoeff.pd_linux
          bicoeff2.pd_linux
          biquads~.pd_linux
          bitnormal~.pd_linux
          bl.imp2~.pd_linux
          bl.imp~.pd_linux
          bl.saw2~.pd_linux
          bl.saw~.pd_linux
          bl.square~.pd_linux
          bl.tri~.pd_linux
          bl.vsaw~.pd_linux
          blocksize~.pd_linux
          break.pd_linux
          brown~.pd_linux
          buffer.pd_linux
          button.pd_linux
          canvas.edit.pd_linux
          canvas.gop.pd_linux
          canvas.mouse.pd_linux
          canvas.name.pd_linux
          canvas.pos.pd_linux
          canvas.setname.pd_linux
          canvas.vis.pd_linux
          ceil.pd_linux
          ceil~.pd_linux
          cents2ratio~.pd_linux
          chance.pd_linux
          chance~.pd_linux
          changed.pd_linux
          changed2~.pd_linux
          changed~.pd_linux
          click.pd_linux
          cmul~.pd_linux
          colors.pd_linux
          comb.filt~.pd_linux
          comb.rev~.pd_linux
          cosine~.pd_linux
          crackle~.pd_linux
          crossover~.pd_linux
          ctl.in.pd_linux
          ctl.out.pd_linux
          cusp~.pd_linux
          datetime.pd_linux
          db2lin~.pd_linux
          decay2~.pd_linux
          decay~.pd_linux
          default.pd_linux
          del~.pd_linux
          detect~.pd_linux
          dir.pd_linux
          dollsym.pd_linux
          downsample~.pd_linux
          drive~.pd_linux
          dust2~.pd_linux
          dust~.pd_linux
          else.pd_linux
          envgen~.pd_linux
          eq~.pd_linux
          f2s~.pd_linux
          factor.pd_linux
          fader~.pd_linux
          fbdelay~.pd_linux
          fbsine2~.pd_linux
          fbsine~.pd_linux
          fdn.rev~.pd_linux
          ffdelay~.pd_linux
          float2bits.pd_linux
          float2sig~.pd_linux
          floor.pd_linux
          floor~.pd_linux
          fold.pd_linux
          fold~.pd_linux
          fontsize.pd_linux
          format.pd_linux
          function.pd_linux
          function~.pd_linux
          gate2imp~.pd_linux
          gaussian~.pd_linux
          gbman~.pd_linux
          gcd.pd_linux
          gendyn~.pd_linux
          giga.rev~.pd_linux
          glide2~.pd_linux
          glide~.pd_linux
          gray~.pd_linux
          gui.pd_linux
          henon~.pd_linux
          highpass~.pd_linux
          highshelf~.pd_linux
          hot.pd_linux
          hz2rad.pd_linux
          ikeda~.pd_linux
          imp2~.pd_linux
          impseq~.pd_linux
          impulse2~.pd_linux
          impulse~.pd_linux
          imp~.pd_linux
          initmess.pd_linux
          keyboard.pd_linux
          lag2~.pd_linux
          lag~.pd_linux
          lastvalue~.pd_linux
          latoocarfian~.pd_linux
          lb.pd_linux
          lfnoise~.pd_linux
          limit.pd_linux
          lincong~.pd_linux
          loadbanger.pd_linux
          logistic~.pd_linux
          loop.pd_linux
          lop2~.pd_linux
          lorenz~.pd_linux
          lowpass~.pd_linux
          lowshelf~.pd_linux
          match~.pd_linux
          median~.pd_linux
          merge.pd_linux
          message.pd_linux
          messbox.pd_linux
          metronome.pd_linux
          midi.pd_linux
          mouse.pd_linux
          mov.avg~.pd_linux
          mov.rms~.pd_linux
          mtx~.pd_linux
          note.in.pd_linux
          note.out.pd_linux
          note.pd_linux
          noteinfo.pd_linux
          numbox~.pd_linux
          nyquist~.pd_linux
          openfile.pd_linux
          op~.pd_linux
          oscope~.pd_linux
          pack2.pd_linux
          pad.pd_linux
          pan2~.pd_linux
          pan4~.pd_linux
          panic.pd_linux
          parabolic~.pd_linux
          peak~.pd_linux
          pgm.in.pd_linux
          pgm.out.pd_linux
          pic.pd_linux
          pimpmul~.pd_linux
          pimp~.pd_linux
          pink~.pd_linux
          pluck~.pd_linux
          pmosc~.pd_linux
          power~.pd_linux
          properties.pd_linux
          pulsediv~.pd_linux
          pulse~.pd_linux
          quad~.pd_linux
          quantizer.pd_linux
          quantizer~.pd_linux
          rad2hz.pd_linux
          rampnoise~.pd_linux
          ramp~.pd_linux
          rand.f.pd_linux
          rand.f~.pd_linux
          rand.hist.pd_linux
          rand.i.pd_linux
          rand.i~.pd_linux
          rand.u.pd_linux
          randpulse2~.pd_linux
          randpulse~.pd_linux
          range~.pd_linux
          rec.pd_linux
          receiver.pd_linux
          rescale.pd_linux
          rescale~.pd_linux
          resonant2~.pd_linux
          resonant~.pd_linux
          retrieve.pd_linux
          rint.pd_linux
          rint~.pd_linux
          rms~.pd_linux
          rotate~.pd_linux
          route2.pd_linux
          routeall.pd_linux
          router.pd_linux
          routetype.pd_linux
          s2f~.pd_linux
          saw2~.pd_linux
          saw~.pd_linux
          schmitt~.pd_linux
          selector.pd_linux
          separate.pd_linux
          sequencer~.pd_linux
          shaper~.pd_linux
          sh~.pd_linux
          sig2float~.pd_linux
          sine~.pd_linux
          sin~.pd_linux
          slew2~.pd_linux
          slew~.pd_linux
          slice.pd_linux
          sort.pd_linux
          spread.pd_linux
          spread~.pd_linux
          square~.pd_linux
          sr~.pd_linux
          standard~.pd_linux
          status~.pd_linux
          stepnoise~.pd_linux
          susloop~.pd_linux
          suspedal.pd_linux
          svfilter~.pd_linux
          symbol2any.pd_linux
          tabplayer~.pd_linux
          tabreader.pd_linux
          tabreader~.pd_linux
          tabwriter~.pd_linux
          tempo~.pd_linux
          toggleff~.pd_linux
          touch.in.pd_linux
          touch.out.pd_linux
          trig.delay2~.pd_linux
          trig.delay~.pd_linux
          trighold~.pd_linux
          tri~.pd_linux
          trunc.pd_linux
          trunc~.pd_linux
          unmerge.pd_linux
          voices.pd_linux
          vsaw~.pd_linux
          vu~.pd_linux
          wavetable~.pd_linux
          white~.pd_linux
          wrap2.pd_linux
          wrap2~.pd_linux
          wt~.pd_linux
          xfade~.pd_linux
          xgate2~.pd_linux
          xgate~.pd_linux
          xmod2~.pd_linux
          xmod~.pd_linux
          xselect2~.pd_linux
          xselect~.pd_linux
          zerocross~.pd_linux
          (which includes compiled externals s2f~.pd_linux and rescale.pd_linux)
          and furthermore all the .pd abstraction files, which should include at least /root/Bela/projects/pd-externals/else/brown.pd.
          I am wondering what has happened there. Try the following instruction step-by-step, please:
          • from the Bela IDE, delete the project pd-externals
          • download this archive on your computer https://github.com/BelaPlatform/Bela/files/10212285/else-v1.0-rc4-93-g0c64c285.zip
          • drop it in your on top of the Bela IDE. When asked the name of the new project you want to create, type pd-externals and click "create project"
          • now create a new project and copy on it a _main.pd file with only these objects in it:
            [brown] [s2f~] [rescale]
          • run the project and verify that you get no couldn't create errors when you start it
          Note that the procedure above will put all the files in /root/Bela/projects/pd-externals and not in /root/Bela/projects/pd-externals/else. This is good enough for testing. If this works, you can move them with:
          mv /root/Bela/projects/pd-externals /tmp/else
          mkdir -p /root/Bela/projects/pd-externals
          mv /tmp/else /root/Bela/projects/pd-externals/
          then modify your _main.pd so that it contains only these objects:
          [brown]
          [s2f~]
          [rescale]
          and verify it still runs without couldn't create errors.
            giuliomoro Thanks. There is hope !
            I don't understand where to upload the else-v1.0-rc4-93-g0c64c285.zip
            with the information "drop it in your on top of the Bela IDE".
            If it's on the top of Bela IDE, I don't know how to do it.
            In the "create new project" section, clearly, I have to select the "Pure data" type ?
            "Note that the procedure above will put all the files in /root/Bela/projects/pd-externals and not in /root/Bela/projects/pd-externals/else"
            I don't understand with which procedure I can avoid to create a else folder unzipping the else-v1.0-rc4-93-g0c64c285.zip
              FatJak I don't understand where to upload the else-v1.0-rc4-93-g0c64c285.zip
              If you drop the zip archive on the IDE you should be prompted with a dialog to create a new project from the contents of the zip archive itself.
              "drop the zip archive on the IDE"
              Crazy. I hadn't thought I had to take it literally.
              So.
              Unzipping the file gave me
              Error opening file render.cpp: file does not exist.
              But I could see objects in
              Running the _main.pd with [brown] [s2f~] [rescale]
              gave me errors:
              Linking...
              ...done
              Build finished
              Running project ...
              Running Pd 0.51-4
              pd 0.51.4
              bonk version 1.5
              else/args -
              else/swap2
              else/rand.f -1 1
              else/fold -1 1
              error: ../pd-externals/rescale.pd_linux: /lib/arm-linux-gnueabihf/libm.so.6: version GLIBC_2.29 not found (required by ../pd-externals/rescale.pd_linux)
              rescale
