Hi Giulio
Here is the answer of Bela (with the command > find -type f /root/Bela/projects/pd-externals)
find:
paths must precede expression: /root/Bela/projects/pd-externals
Try 'find --help' for more information.
And the _main.pd in text :
#N canvas 266 24 740 754 10;
#X declare -path /root/Bela/projects/pd-externals;
#X obj 11 379 hsl 128 15 110 10100 0 0 empty empty empty -2 -8 0 10
#fcfcfc #000000 #000000 0 1;
#X obj 11 523 hsl 128 15 110 10100 0 0 empty empty empty -2 -8 0 10
#X text 29 377 MAX RISE TIME;
#X text 28 522 MIN RISE TIME;
#X obj 158 379 hsl 128 15 110 10100 0 0 empty empty empty -2 -8 0 10
#X obj 158 523 hsl 128 15 110 10100 0 0 empty empty empty -2 -8 0 10
#X text 176 378 MAX FALL TIME;
#X text 175 522 MIN FALL TIME;
#X obj 8 543 s MinRise;
#X obj 8 399 s MaxRise;
#X obj 155 399 s MaxFall;
#X obj 155 543 s MinFall;
#X obj 309 240 hsl 128 15 100 10100 0 0 empty empty empty -2 -8 0 10
#X obj 306 260 - 100;
#X obj 492 239 hsl 128 15 100 10100 0 0 empty empty empty -2 -8 0 10
#X obj 489 259 - 100;
#X obj 309 456 hsl 128 15 100 10100 0 0 empty empty empty -2 -8 0 10
#X obj 306 476 - 100;
#X obj 492 455 hsl 128 15 100 10100 0 0 empty empty empty -2 -8 0 10
#X obj 489 475 - 100;
#X obj 306 332 dac~ 3;
#X obj 489 331 dac~ 4;
#X obj 306 548 dac~ 5;
#X obj 489 547 dac~ 6;
#X floatatom 8 305 5 0 0 0 - - - 0;
#X obj 8 328 * 9990;
#X floatatom 8 450 5 0 0 0 - - - 0;
#X obj 8 473 * 9990;
#X floatatom 155 306 5 0 0 0 - - - 0;
#X obj 155 329 * 9990;
#X floatatom 155 450 5 0 0 0 - - - 0;
#X obj 155 473 * 9990;
#X obj 155 498 + 110;
#X obj 8 353 + 110;
#X obj 8 498 + 110;
#X obj 155 354 + 110;
#X floatatom 306 171 5 0 0 0 - - - 0;
#X obj 306 216 + 100;
#X obj 306 193 * 10000;
#X obj 306 308 *~ 1;
#X obj 489 307 *~ 1;
#X obj 306 524 *~ 1;
#X obj 489 523 *~ 1;
#X text 5 564 CONTROL TEMPS RISE-FALL STOCHASTIC;
#X floatatom 489 170 5 0 0 0 - - - 0;
#X obj 489 215 + 100;
#X obj 489 192 * 10000;
#X floatatom 306 387 5 0 0 0 - - - 0;
#X obj 306 432 + 100;
#X obj 306 409 * 10000;
#X floatatom 489 386 5 0 0 0 - - - 0;
#X obj 489 431 + 100;
#X obj 489 408 * 10000;
#X obj 8 282 r MAXRT;
#X obj 155 283 r MAXFT;
#X obj 8 426 r MINRT;
#X obj 155 427 r MINFT;
#X obj 306 148 r DEL1;
#X obj 489 147 r DEL2;
#X obj 306 364 r DEL3;
#X obj 489 363 r DEL4;
#X text 302 569 GESTION 4 ENVELOPPES ET DELAY ENTRE ENVELOPPES;
#X obj 7 178 initialise_digitals;
#N canvas 0 0 1280 778 ENV 0;
#X obj 705 340 nbx 5 14 -1e+37 1e+37 0 0 empty empty empty 0 -8 0 10
#fcfcfc #000000 #000000 0 256;
#X obj 705 359 t b f;
#X obj 705 409 pow, f 5;
#X msg 705 383 2;
#X obj 705 478 nbx 5 14 -1e+37 1e+37 0 0 empty empty empty 0 -8 0 10
#X obj 705 434 nbx 5 14 -1e+37 1e+37 0 0 empty empty empty 0 -8 0 10
#X obj 708 319 hsl 128 15 3 10 0 0 empty empty empty -2 -8 0 10 #fcfcfc
#X obj 705 453 / 16;
#X obj 539 340 nbx 5 14 -1e+37 1e+37 0 0 empty empty empty 0 -8 0 10
#X obj 539 359 t b f;
#X obj 539 409 pow, f 5;
#X msg 539 383 2;
#X obj 539 478 nbx 5 14 -1e+37 1e+37 0 0 empty empty empty 0 -8 0 10
#X obj 539 434 nbx 5 14 -1e+37 1e+37 0 0 empty empty empty 0 -8 0 10
#X obj 542 319 hsl 128 15 3 10 0 0 empty empty empty -2 -8 0 10 #fcfcfc
#X obj 539 453 / 16;
#X text 598 299 RISE SHAPE;
#X text 764 300 FALL SHAPE;
#X obj 1129 474 vline~;
#X floatatom 904 285 5 0 0 0 - - - 0;
#X floatatom 1162 284 5 0 0 0 - - - 0;
#X obj 904 537 pow~ 64;
#X obj 1129 541 pow~ 64;
#X obj 1020 667 *~;
#X obj 904 470 vline~;
#X obj 1017 259 hsl 128 15 0.01 1 0 0 empty empty empty -2 -8 0 10
#X msg 1031 436 stop;
#X text 1042 257 amplitude;
#X obj 1129 383 pack f f f;
#X obj 904 378 pack f f;
#X floatatom 1110 278 5 0 0 0 - - - 0;
#X msg 904 403 \$2 \$1 \, 0 0 \$1;
#X msg 1129 408 \$3 0 \$1 \, 0 \$2 \$1;
#X msg 912 60 1;
#X text 1203 286 ms;
#X text 942 289 ms;
#X obj 1020 693 outlet~;
#X obj 45 210 hsl 128 15 0 127 0 0 empty empty empty -2 -8 0 10 #dcdcdc
#X obj 42 184 brown 0.2;
#X floatatom 42 239 5 0 0 0 - - - 0;
#X floatatom 42 539 14 0 0 0 - - - 0;
#X floatatom 60 373 9 0 0 0 - - - 0;
#X floatatom 151 372 8 0 0 0 - - - 0;
#X obj 60 342 int;
#X obj 151 344 int;
#X obj 42 514 int;
#X text 85 539 ms RISE;
#X obj 96 403 t b f;
#X obj 96 438 max;
#X floatatom 96 462 5 0 0 0 - - - 0;
#X obj 151 309 - 100;
#X obj 60 309 - 100;
#X obj 288 210 hsl 128 15 0 127 0 0 empty empty empty -2 -8 0 10 #dcdcdc
#X obj 285 184 brown 0.2;
#X floatatom 285 239 5 0 0 0 - - - 0;
#X floatatom 285 539 14 0 0 0 - - - 0;
#X floatatom 303 374 9 0 0 0 - - - 0;
#X floatatom 394 373 8 0 0 0 - - - 0;
#X obj 303 343 int;
#X obj 394 345 int;
#X obj 285 514 int;
#X obj 339 404 t b f;
#X obj 339 439 max;
#X floatatom 339 463 5 0 0 0 - - - 0;
#X obj 394 315 - 100;
#X obj 303 310 - 100;
#X text 11 45 - si le MIN est supérieur au MAX \, alors MAX=MIN;
#X text 328 539 ms FALL;
#X obj 42 562 abs;
#X obj 285 562 abs;
#X text 10 66 - controles en logarythmique;
#X obj 221 159 metro;
#X obj 221 138 bng 15 250 50 0 empty empty empty 17 7 0 10 #fcfcfc
#000000 #000000;
#X obj 912 29 loadbang;
#X obj 166 605 expr $f1 + $f2;
#X floatatom 166 630 5 0 0 0 - - - 0;
#X text 10 88 - autres générateurs possibles ! (cf brown);
#X obj 60 283 r MaxRise;
#X obj 151 283 r MinRise;
#X obj 394 284 r MinFall;
#X obj 303 284 r MaxFall;
#X obj 166 652 expr $f1 + $f2;
#X obj 261 628 inlet;
#X floatatom 166 676 5 0 0 0 - - - 0;
#X text 573 317 0.5-64> log;
#X text 736 317 0.5-64> log;
#X obj 42 490 rescale 10 10000;
#X obj 285 490 rescale 10 10000;
#X floatatom 539 247 5 0 0 0 - - - 0;
#X obj 539 269 * 7;
#X obj 539 292 + 3;
#X floatatom 1014 185 5 0 0 0 - - - 0;
#X obj 1014 209 * 9.99;
#X obj 1014 233 + 0.01;
#X text 9 23 ---------------------------------------------;
#X floatatom 705 248 5 0 0 0 - - - 0;
#X obj 705 270 * 7;
#X obj 705 293 + 3;
#X text 10 11 GÉNÉRATEUR DE RISE/FALL STOCHASTIQUE - ENV 3;
#X obj 539 221 r RES3;
#X obj 705 222 r FES3;
#X obj 1014 161 r AMP3;
#X obj 42 602 s Rise-Time3;
#X obj 285 591 s Fall-Time3;
#X obj 539 497 s Rise-Shape3;
#X obj 705 497 s Fall-Shape3;
#X obj 904 259 r Rise-Time3;
#X obj 1162 258 r Fall-Time3;
#X obj 914 512 r Rise-Shape3;
#X obj 1136 516 r Fall-Shape3;
#X connect 0 0 1 0;
#X connect 1 0 3 0;
#X connect 1 1 2 1;
#X connect 2 0 5 0;
#X connect 3 0 2 0;
#X connect 4 0 105 0;
#X connect 5 0 7 0;
#X connect 6 0 0 0;
#X connect 7 0 4 0;
#X connect 8 0 9 0;
#X connect 9 0 11 0;
#X connect 9 1 10 1;
#X connect 10 0 13 0;
#X connect 11 0 10 0;
#X connect 12 0 104 0;
#X connect 13 0 15 0;
#X connect 14 0 8 0;
#X connect 15 0 12 0;
#X connect 18 0 22 0;
#X connect 19 0 28 0;
#X connect 19 0 29 0;
#X connect 20 0 28 1;
#X connect 21 0 23 0;
#X connect 22 0 23 0;
#X connect 23 0 36 0;
#X connect 24 0 21 0;
#X connect 25 0 28 2;
#X connect 25 0 30 0;
#X connect 25 0 29 1;
#X connect 26 0 24 0;
#X connect 26 0 18 0;
#X connect 28 0 32 0;
#X connect 29 0 31 0;
#X connect 31 0 24 0;
#X connect 32 0 18 0;
#X connect 33 0 12 0;
#X connect 33 0 4 0;
#X connect 33 0 25 0;
#X connect 37 0 39 0;
#X connect 38 0 37 0;
#X connect 39 0 86 0;
#X connect 40 0 68 0;
#X connect 41 0 48 0;
#X connect 42 0 47 0;
#X connect 42 0 86 2;
#X connect 43 0 41 0;
#X connect 44 0 42 0;
#X connect 45 0 40 0;
#X connect 47 0 48 0;
#X connect 47 1 48 1;
#X connect 48 0 49 0;
#X connect 49 0 86 1;
#X connect 50 0 44 0;
#X connect 51 0 43 0;
#X connect 52 0 54 0;
#X connect 53 0 52 0;
#X connect 54 0 87 0;
#X connect 55 0 69 0;
#X connect 56 0 62 0;
#X connect 57 0 61 0;
#X connect 57 0 87 2;
#X connect 58 0 56 0;
#X connect 59 0 57 0;
#X connect 60 0 55 0;
#X connect 61 0 62 0;
#X connect 61 1 62 1;
#X connect 62 0 63 0;
#X connect 63 0 87 1;
#X connect 64 0 59 0;
#X connect 65 0 58 0;
#X connect 68 0 74 0;
#X connect 68 0 102 0;
#X connect 69 0 74 1;
#X connect 69 0 103 0;
#X connect 71 0 38 0;
#X connect 71 0 53 0;
#X connect 72 0 71 0;
#X connect 73 0 72 0;
#X connect 73 0 33 0;
#X connect 74 0 75 0;
#X connect 75 0 81 0;
#X connect 77 0 51 0;
#X connect 78 0 50 0;
#X connect 79 0 64 0;
#X connect 80 0 65 0;
#X connect 81 0 71 1;
#X connect 81 0 83 0;
#X connect 82 0 81 1;
#X connect 86 0 45 0;
#X connect 87 0 60 0;
#X connect 88 0 89 0;
#X connect 89 0 90 0;
#X connect 90 0 14 0;
#X connect 91 0 92 0;
#X connect 92 0 93 0;
#X connect 93 0 25 0;
#X connect 95 0 96 0;
#X connect 96 0 97 0;
#X connect 97 0 6 0;
#X connect 99 0 88 0;
#X connect 100 0 95 0;
#X connect 101 0 91 0;
#X connect 106 0 19 0;
#X connect 107 0 20 0;
#X connect 108 0 21 1;
#X connect 109 0 22 1;
#X restore 306 500 pd ENV 3;
#X msg 705 383 2;
#X msg 539 383 2;
#X obj 1020 667 *~;
#X msg 912 60 1;
#X text 942 289 ms;
#X obj 60 342 int;
#X obj 151 344 int;
#X obj 42 514 int;
#X obj 96 438 max;
#X obj 303 343 int;
#X obj 394 345 int;
#X obj 285 514 int;
#X obj 339 439 max;
#X obj 42 562 abs;
#X obj 285 562 abs;
#000000 #000000;
#X obj 539 269 * 7;
#X obj 539 292 + 3;
#X obj 705 270 * 7;
#X obj 705 293 + 3;
#X text 10 11 GÉNÉRATEUR DE RISE/FALL STOCHASTIQUE - ENV 4;
#X obj 539 221 r RES4;
#X obj 705 222 r FES4;
#X obj 1014 161 r AMP4;
#X obj 42 602 s Rise-Time4;
#X obj 285 591 s Fall-Time4;
#X obj 539 497 s Rise-Shape4;
#X obj 705 497 s Fall-Shape4;
#X obj 914 512 r Rise-Shape4;
#X obj 1136 516 r Fall-Shape4;
#X obj 904 259 r Rise-Time4;
#X obj 1162 258 r Fall-Time4;
#X connect 0 0 1 0;
#X connect 1 0 3 0;
#X connect 1 1 2 1;
#X connect 2 0 5 0;
#X connect 3 0 2 0;
#X connect 5 0 7 0;
#X connect 6 0 0 0;
#X connect 7 0 4 0;
#X connect 8 0 9 0;
#X connect 106 0 21 1;
#X connect 107 0 22 1;
#X connect 108 0 19 0;
#X connect 109 0 20 0;
#X restore 489 499 pd ENV 4;
#X msg 705 383 2;
#X msg 539 383 2;
#X obj 1020 667 *~;
#X msg 912 60 1;
#X text 942 289 ms;
#X obj 60 342 int;
#X obj 151 344 int;
#X obj 42 514 int;
#X obj 96 438 max;
#X obj 303 343 int;
#X obj 394 345 int;
#X obj 285 514 int;
#X obj 339 439 max;
#X obj 42 562 abs;
#X obj 285 562 abs;
#000000 #000000;
#X obj 539 269 * 7;
#X obj 539 292 + 3;
#X obj 705 270 * 7;
#X obj 705 293 + 3;
#X text 10 11 GÉNÉRATEUR DE RISE/FALL STOCHASTIQUE - ENV 2;
#X obj 539 221 r RES2;
#X obj 705 222 r FES2;
#X obj 1014 161 r AMP2;
#X obj 539 497 s Rise-Shape2;
#X obj 705 497 s Fall-Shape2;
#X obj 904 259 r Rise-Time2;
#X obj 1162 258 r Fall-Time2;
#X obj 42 602 s Rise-Time2;
#X obj 285 591 s Fall-Time2;
#X obj 914 512 r Rise-Shape2;
#X obj 1136 516 r Fall-Shape2;
#X connect 0 0 1 0;
#X connect 1 0 3 0;
#X connect 1 1 2 1;
#X connect 2 0 5 0;
#X connect 3 0 2 0;
#X connect 4 0 103 0;
#X connect 5 0 7 0;
#X connect 6 0 0 0;
#X connect 7 0 4 0;
#X connect 8 0 9 0;
#X connect 12 0 102 0;
#X connect 68 0 106 0;
#X connect 69 0 107 0;
#X connect 104 0 19 0;
#X connect 105 0 20 0;
#X restore 489 283 pd ENV 2;
#X msg 705 383 2;
#X msg 539 383 2;
#X obj 1020 667 *~;
#X msg 912 60 1;
#X text 942 289 ms;
#X obj 60 342 int;
#X obj 151 344 int;
#X obj 42 514 int;
#X obj 96 438 max;
#X obj 303 343 int;
#X obj 394 345 int;
#X obj 285 514 int;
#X obj 339 439 max;
#X obj 42 562 abs;
#X obj 285 562 abs;
#000000 #000000;
#X obj 42 602 s Rise-Time1;
#X obj 285 591 s Fall-Time1;
#X obj 539 497 s Rise-Shape1;
#X obj 705 497 s Fall-Shape1;
#X obj 904 259 r Rise-Time1;
#X obj 1162 258 r Fall-Time1;
#X obj 1136 516 r Fall-Shape1;
#X obj 914 512 r Rise-Shape1;
#X obj 539 269 * 7;
#X obj 539 292 + 3;
#X text 10 11 GÉNÉRATEUR DE RISE/FALL STOCHASTIQUE - ENV 1;
#X obj 705 270 * 7;
#X obj 705 293 + 3;
#X obj 539 221 r RES1;
#X obj 705 222 r FES1;
#X obj 1014 161 r AMP1;
#X connect 0 0 1 0;
#X connect 1 0 3 0;
#X connect 1 1 2 1;
#X connect 2 0 5 0;
#X connect 3 0 2 0;
#X connect 4 0 84 0;
#X connect 5 0 7 0;
#X connect 6 0 0 0;
#X connect 7 0 4 0;
#X connect 8 0 9 0;
#X connect 12 0 83 0;
#X connect 39 0 94 0;
#X connect 42 0 94 2;
#X connect 49 0 94 1;
#X connect 54 0 95 0;
#X connect 57 0 95 2;
#X connect 63 0 95 1;
#X connect 68 0 81 0;
#X connect 69 0 82 0;
#X connect 75 0 89 0;
#X connect 85 0 19 0;
#X connect 86 0 20 0;
#X connect 87 0 22 1;
#X connect 88 0 21 1;
#X connect 89 0 71 1;
#X connect 89 0 91 0;
#X connect 90 0 89 1;
#X connect 94 0 45 0;
#X connect 95 0 60 0;
#X connect 97 0 98 0;
#X connect 98 0 14 0;
#X connect 99 0 100 0;
#X connect 100 0 101 0;
#X connect 101 0 25 0;
#X connect 104 0 105 0;
#X connect 105 0 106 0;
#X connect 106 0 6 0;
#X connect 107 0 96 0;
#X connect 108 0 104 0;
#X connect 109 0 99 0;
#X restore 306 284 pd ENV 1;
#N canvas 158 30 480 573 delay 0;
#X obj 32 195 select 1;
#X obj 35 305 hsl 128 15 0 127 0 0 empty empty empty -2 -8 0 10 #dcdcdc
#X obj 32 279 brown 0.2;
#X floatatom 32 327 5 0 0 0 - - - 0;
#X obj 32 232 bng 15 250 50 0 empty empty empty 17 7 0 10 #fcfcfc #000000
#000000;
#X floatatom 32 374 5 0 0 0 - - - 0;
#X obj 32 397 int;
#X floatatom 32 421 5 0 0 0 - - - 0;
#X obj 32 349 * 78.74;
#X obj 31 452 + 100;
#X floatatom 31 476 5 0 0 0 - - - 0;
#X obj 264 315 tgl 15 0 empty empty empty 17 7 0 10 #fcfcfc #000000
#000000 0 1;
#X obj 31 503 spigot;
#X obj 32 252 metro 100;
#X obj 32 107 inlet;
#X obj 31 528 outlet;
#X text 27 30 Module permettant de faire varier la durée de decay
de manière continue avec la valeur du POT de 0 à 0.99 puis de passer
en random une fois en butée (valeur 1).;
#X connect 0 0 4 0;
#X connect 0 0 11 0;
#X connect 1 0 3 0;
#X connect 2 0 1 0;
#X connect 3 0 8 0;
#X connect 4 0 13 0;
#X connect 5 0 6 0;
#X connect 6 0 7 0;
#X connect 7 0 9 0;
#X connect 8 0 5 0;
#X connect 9 0 10 0;
#X connect 10 0 12 0;
#X connect 10 0 13 1;
#X connect 11 0 12 1;
#X connect 12 0 15 0;
#X connect 13 0 2 0;
#X connect 14 0 0 0;
#X restore 359 432 pd delay stochastic;
#000000;
#X obj 32 397 int;
#000000 0 1;
#X connect 0 0 4 0;
#X connect 1 0 3 0;
#X connect 2 0 1 0;
#X connect 3 0 8 0;
#X connect 5 0 6 0;
#X connect 6 0 7 0;
#X connect 7 0 9 0;
#X connect 8 0 5 0;
#X restore 359 216 pd delay stochastic;
#000000;
#X obj 32 397 int;
#000000 0 1;
#X connect 0 0 4 0;
#X connect 1 0 3 0;
#X connect 2 0 1 0;
#X connect 3 0 8 0;
#X connect 5 0 6 0;
#X connect 6 0 7 0;
#X connect 7 0 9 0;
#X connect 8 0 5 0;
#X restore 542 215 pd delay stochastic;
#000000;
#X obj 32 397 int;
#000000 0 1;
#X connect 0 0 4 0;
#X connect 1 0 3 0;
#X connect 2 0 1 0;
#X connect 3 0 8 0;
#X connect 5 0 6 0;
#X connect 6 0 7 0;
#X connect 7 0 9 0;
#X connect 8 0 5 0;
#X restore 542 431 pd delay stochastic;
#X obj 357 332 s~ env1;
#X obj 540 331 s~ env2;
#X obj 540 547 s~ env4;
#X obj 357 548 s~ env3;
#N canvas 22 21 1215 739 LED-IT-BE 0;
#X obj 17 84 s bela_setDigital;
#X obj 17 24 loadbang;
#X msg 17 47 out 17 ~ \, out 18 ~ \, out 21 ~ \, out 13 ~ \, out 14
~ \, out 11 ~ \, out 12 ~ \, out 15 ~ \, out 16 ~ \, out 19 ~, f 79
#X text 318 21 Initialise the LED pins at signal rate;
#X obj 343 305 dac~ 17 18 21 13 14 11 12 15 16 19;
#X obj 15 148 phasor~ 2000;
#X obj 15 220 expr~ $v1 < $v2;
#X obj 117 175 abs~;
#X obj 117 196 lop~ 20;
#X obj 117 148 r~ env1;
#X obj 185 148 phasor~ 2000;
#X obj 185 220 expr~ $v1 < $v2;
#X obj 287 175 abs~;
#X obj 287 196 lop~ 20;
#X obj 355 148 phasor~ 2000;
#X obj 355 220 expr~ $v1 < $v2;
#X obj 457 175 abs~;
#X obj 457 196 lop~ 20;
#X obj 525 148 phasor~ 2000;
#X obj 525 220 expr~ $v1 < $v2;
#X obj 627 175 abs~;
#X obj 627 196 lop~ 20;
#X obj 695 148 phasor~ 2000;
#X obj 695 220 expr~ $v1 < $v2;
#X obj 797 175 abs~;
#X obj 797 196 lop~ 20;
#X obj 865 148 phasor~ 2000;
#X obj 865 220 expr~ $v1 < $v2;
#X obj 967 175 abs~;
#X obj 967 196 lop~ 20;
#X obj 287 148 r~ env2;
#X obj 457 148 r~ env3;
#X obj 627 148 r~ env4;
#X text 316 117 expr~ $v1 < $v2 <<< PWM signal with variable duty cycle
#X obj 254 426 buttons, f 58;
#X obj 254 447 sel 1;
#X obj 369 447 sel 1;
#X obj 484 447 sel 1;
#X obj 599 447 sel 1;
#X obj 254 528 tgl 15 0 empty empty empty 17 7 0 10 #fcfcfc #000000
#000000 0 1;
#X obj 272 485 delay 200;
#X obj 369 528 tgl 15 0 empty empty empty 17 7 0 10 #fcfcfc #000000
#000000 0 1;
#X obj 387 485 delay 200;
#X obj 484 528 tgl 15 0 empty empty empty 17 7 0 10 #fcfcfc #000000
#000000 0 1;
#X obj 502 485 delay 200;
#X obj 599 528 tgl 15 0 empty empty empty 17 7 0 10 #fcfcfc #000000
#000000 0 1;
#X obj 617 485 delay 200;
#X msg 272 506 0;
#X msg 387 506 0;
#X msg 502 506 0;
#X msg 617 506 0;
#X obj 171 563 s bela_digitalOut17;
#X obj 231 583 s bela_digitalOut18;
#X obj 311 563 s bela_digitalOut21;
#X obj 371 583 s bela_digitalOut13;
#X obj 451 563 s bela_digitalOut14;
#X obj 511 583 s bela_digitalOut11;
#X obj 591 563 s bela_digitalOut12;
#X obj 651 583 s bela_digitalOut15;
#X obj 731 563 s bela_digitalOut16;
#X obj 791 583 s bela_digitalOut19;
#X obj 797 148 out1;
#X obj 967 148 out2;
#X connect 1 0 2 0;
#X connect 2 0 0 0;
#X connect 5 0 6 0;
#X connect 6 0 4 0;
#X connect 7 0 8 0;
#X connect 8 0 6 1;
#X connect 9 0 7 0;
#X connect 10 0 11 0;
#X connect 11 0 4 2;
#X connect 12 0 13 0;
#X connect 13 0 11 1;
#X connect 14 0 15 0;
#X connect 15 0 4 4;
#X connect 16 0 17 0;
#X connect 17 0 15 1;
#X connect 18 0 19 0;
#X connect 19 0 4 6;
#X connect 20 0 21 0;
#X connect 21 0 19 1;
#X connect 23 0 4 8;
#X connect 24 0 25 0;
#X connect 25 0 23 1;
#X connect 26 0 27 0;
#X connect 27 0 4 9;
#X connect 28 0 29 0;
#X connect 29 0 27 1;
#X connect 30 0 12 0;
#X connect 31 0 16 0;
#X connect 32 0 20 0;
#X connect 34 0 35 0;
#X connect 34 1 36 0;
#X connect 34 2 37 0;
#X connect 34 3 38 0;
#X connect 35 0 40 0;
#X connect 35 0 39 0;
#X connect 36 0 41 0;
#X connect 36 0 42 0;
#X connect 37 0 43 0;
#X connect 37 0 44 0;
#X connect 38 0 45 0;
#X connect 38 0 46 0;
#X connect 39 0 52 0;
#X connect 40 0 47 0;
#X connect 41 0 54 0;
#X connect 42 0 48 0;
#X connect 43 0 56 0;
#X connect 44 0 49 0;
#X connect 45 0 58 0;
#X connect 46 0 50 0;
#X connect 47 0 39 0;
#X connect 48 0 41 0;
#X connect 49 0 43 0;
#X connect 50 0 45 0;
#X connect 61 0 24 0;
#X connect 62 0 28 0;
#X restore 7 226 pd LED-IT-BE;
#X text 5 248 GESTION DIVERSES;
#X obj 7 202 TOUR_DE_CONTROLE;
#X text 323 238 0-10 s delay;
#X text 506 237 0-10 s delay;
#X text 323 454 0-10 s delay;
#X text 506 453 0-10 s delay;
#X obj 366 57 declare -path /root/Bela/projects/pd-externals;
#X connect 0 0 9 0;
#X connect 1 0 8 0;
#X connect 4 0 10 0;
#X connect 5 0 11 0;
#X connect 13 0 66 0;
#X connect 15 0 65 0;
#X connect 17 0 63 0;
#X connect 19 0 64 0;
#X connect 25 0 33 0;
#X connect 27 0 34 0;
#X connect 29 0 35 0;
#X connect 30 0 31 0;
#X connect 31 0 32 0;
#X connect 32 0 5 0;
#X connect 33 0 0 0;
#X connect 34 0 1 0;
#X connect 35 0 4 0;
#X connect 36 0 38 0;
#X connect 37 0 12 0;
#X connect 39 0 20 0;
#X connect 39 0 71 0;
#X connect 40 0 21 0;
#X connect 40 0 72 0;
#X connect 41 0 22 0;
#X connect 41 0 74 0;
#X connect 42 0 23 0;
#X connect 42 0 73 0;
#X connect 44 0 46 0;
#X connect 45 0 14 0;
#X connect 46 0 45 0;
#X connect 47 0 49 0;
#X connect 48 0 16 0;
#X connect 49 0 48 0;
#X connect 50 0 52 0;
#X connect 51 0 18 0;
#X connect 52 0 51 0;
#X connect 53 0 24 0;
#X connect 54 0 28 0;
#X connect 55 0 26 0;
#X connect 56 0 30 0;
#X connect 57 0 36 0;
#X connect 57 0 68 0;
#X connect 58 0 44 0;
#X connect 58 0 69 0;
#X connect 59 0 47 0;
#X connect 59 0 67 0;
#X connect 60 0 50 0;
#X connect 60 0 70 0;
#X connect 63 0 41 0;
#X connect 64 0 42 0;
#X connect 65 0 40 0;
#X connect 66 0 39 0;
#X connect 67 0 16 0;
#X connect 68 0 12 0;
#X connect 69 0 14 0;
#X connect 70 0 18 0;
PS (Hey ! It's sunday, do you ever take a break ?)
