giuliomoro ok I rebuilt it and it is now available . Please follow the instructions below: Try the following instruction step-by-step, please: download this archive on your computer https://github.com/BelaPlatform/Bela/files/10228145/else-v1.0-rc4-93-g0c64c285.zip drop it in your on top of the Bela IDE. When asked the name of the new project you want to create, type pd-else and click "create project". Wait for a few seconds while it is done. when done, you will get an error "couldn't open render.cpp". That's fine, press "Cancel" run the following in the console at the bottom of the Bela IDE so that the externals go in the right place: rm -rf projects/pd-externals; mkdir -p projects/pd-externals; mv projects/pd-else projects/pd-externals/else; now create a new project and copy on it a _main.pd file with only the following objects in it: [brown] [s2f~] [rescale] [declare -path /root/Bela/projects/pd-externals/else] run the project and verify that you get no "couldn't create" errors when you start it
FatJak giuliomoro Oh! No "couldn't create" errors to declare in this test ! AND No "couldn't create" errors to declare in MY PATCH !!!!!!!!! ! THANKS YOU SO MUCH @giuliomoro I would like to offer you a beer !
