what do you get with ls /root/Bela/pd-externals/else/above~.pd_linux ? and then find /root/Bela/pd-externals -type d ?
    With ls /root/Bela/pd-externals/else/above~.pd_linux
    i get
    ls: cannot access '/root/Bela/pd-externals/else/above~.pd_linux': No such file or directory
    and then with find /root/Bela/pd-externals -type d
    i get
    and with ls -l /root/Bela/pd-externals/else/
    i get
    total 0
    Typing ls -l /root/Bela/
    shows that Else & Cyclone libraries exists
    Typing ls -l /root/Bela/else
    shows Else objects...
    So, I tried [declare -path /root/Bela/else] in my Pd patch, but it doesn't work.
    Now i'm trying, with command lines to place Else & Cyclone libraries in /root/Bela/pd-externals
      sorry I missed a projects in my paths. Should have been:
      what do you get with ls /root/Bela/projects/pd-externals/else/above~.pd_linux ? and then find /root/Bela/projects/pd-externals -type d and then find /root/Bela/projects/pd-externals -type f | grep pd_linux?
        FatJak Now i'm trying, with command lines to place Else & Cyclone libraries in /root/Bela/pd-externals
        that should be /root/Bela/projects/pd-externals
        Thanks again @giuliomoro
        Since few hours, i feel free to make some experiences.
        - I have selected only the .pd objects in my computer Else library and made from it a folder.zip file
        - I have upload/install it in /root/Bela/pd-externals and i modified the main.pd path object to these externals
        - I have discover that there his very few objects that could't be created.
        Here is the list:
        else/fold -1 1
        else/args -
        else/swap2
        else/rand.f -1 1
        else/rescale -1 1 0 127
        s2f~
        I have tryed to make .pd abstractions from these graphical objects.
        It seems not working.
        (kind of bruteforce experimentation)
        After cleanup, reinstall as you tell me, this is what I get with
        and then
        /root/Bela/projects/pd-externals/build
        /root/Bela/projects/pd-externals/cd
        and then
        /root/Bela/projects/pd-externals/else/canvas.bounds.pd_linux
        /root/Bela/projects/pd-externals/else/rint.pd_linux
        /root/Bela/projects/pd-externals/else/zerocross~.pd_linux
        /root/Bela/projects/pd-externals/else/xselect~.pd_linux
        /root/Bela/projects/pd-externals/else/routetype.pd_linux
        /root/Bela/projects/pd-externals/else/wt~.pd_linux
        /root/Bela/projects/pd-externals/else/pluck~.pd_linux
        /root/Bela/projects/pd-externals/else/sig2float~.pd_linux
        /root/Bela/projects/pd-externals/else/lfnoise~.pd_linux
        /root/Bela/projects/pd-externals/else/hot.pd_linux
        /root/Bela/projects/pd-externals/else/suspedal.pd_linux
        /root/Bela/projects/pd-externals/else/lag~.pd_linux
        /root/Bela/projects/pd-externals/else/bl.saw2~.pd_linux
        /root/Bela/projects/pd-externals/else/float2bits.pd_linux
        /root/Bela/projects/pd-externals/else/datetime.pd_linux
        /root/Bela/projects/pd-externals/else/loadbanger.pd_linux
        /root/Bela/projects/pd-externals/else/router.pd_linux
        /root/Bela/projects/pd-externals/else/args.pd_linux
        /root/Bela/projects/pd-externals/else/decay2~.pd_linux
        /root/Bela/projects/pd-externals/else/chance~.pd_linux
        /root/Bela/projects/pd-externals/else/lorenz~.pd_linux
        /root/Bela/projects/pd-externals/else/fbsine~.pd_linux
        /root/Bela/projects/pd-externals/else/noteinfo.pd_linux
        /root/Bela/projects/pd-externals/else/ctl.in.pd_linux
        /root/Bela/projects/pd-externals/else/canvas.file.pd_linux
        /root/Bela/projects/pd-externals/else/wrap2.pd_linux
        /root/Bela/projects/pd-externals/else/gui.pd_linux
        /root/Bela/projects/pd-externals/else/highpass~.pd_linux
        /root/Bela/projects/pd-externals/else/quantizer.pd_linux
        /root/Bela/projects/pd-externals/else/op~.pd_linux
        /root/Bela/projects/pd-externals/else/keyboard.pd_linux
        /root/Bela/projects/pd-externals/else/dir.pd_linux
        /root/Bela/projects/pd-externals/else/separate.pd_linux
        /root/Bela/projects/pd-externals/else/spread.pd_linux
        /root/Bela/projects/pd-externals/else/symbol2any.pd_linux
        /root/Bela/projects/pd-externals/else/tabreader.pd_linux
        /root/Bela/projects/pd-externals/else/rescale~.pd_linux
        /root/Bela/projects/pd-externals/else/sort.pd_linux
        /root/Bela/projects/pd-externals/else/fold~.pd_linux
        /root/Bela/projects/pd-externals/else/stepnoise~.pd_linux
        /root/Bela/projects/pd-externals/else/bandstop~.pd_linux
        /root/Bela/projects/pd-externals/else/glide~.pd_linux
        /root/Bela/projects/pd-externals/else/retrieve.pd_linux
        /root/Bela/projects/pd-externals/else/imp~.pd_linux
        /root/Bela/projects/pd-externals/else/wrap2~.pd_linux
        /root/Bela/projects/pd-externals/else/asr~.pd_linux
        /root/Bela/projects/pd-externals/else/toggleff~.pd_linux
        /root/Bela/projects/pd-externals/else/dollsym.pd_linux
        /root/Bela/projects/pd-externals/else/spread~.pd_linux
        /root/Bela/projects/pd-externals/else/fold.pd_linux
        /root/Bela/projects/pd-externals/else/autofade2~.pd_linux
        /root/Bela/projects/pd-externals/else/lag2~.pd_linux
        /root/Bela/projects/pd-externals/else/fader~.pd_linux
        /root/Bela/projects/pd-externals/else/ratio2cents.pd_linux
        /root/Bela/projects/pd-externals/else/nyquist~.pd_linux
        /root/Bela/projects/pd-externals/else/messbox.pd_linux
        /root/Bela/projects/pd-externals/else/bend.out.pd_linux
        /root/Bela/projects/pd-externals/else/cents2ratio.pd_linux
        /root/Bela/projects/pd-externals/else/touch.out.pd_linux
        /root/Bela/projects/pd-externals/else/timed.gate~.pd_linux
        /root/Bela/projects/pd-externals/else/canvas.zoom.pd_linux
        /root/Bela/projects/pd-externals/else/brown~.pd_linux
        /root/Bela/projects/pd-externals/else/match~.pd_linux
        /root/Bela/projects/pd-externals/else/slew2~.pd_linux
        /root/Bela/projects/pd-externals/else/mov.avg~.pd_linux
        /root/Bela/projects/pd-externals/else/pgm.in.pd_linux
        /root/Bela/projects/pd-externals/else/pan4~.pd_linux
        /root/Bela/projects/pd-externals/else/properties.pd_linux
        /root/Bela/projects/pd-externals/else/bl.square~.pd_linux
        /root/Bela/projects/pd-externals/else/trighold~.pd_linux
        /root/Bela/projects/pd-externals/else/highshelf~.pd_linux
        /root/Bela/projects/pd-externals/else/power~.pd_linux
        /root/Bela/projects/pd-externals/else/ratio2cents~.pd_linux
        /root/Bela/projects/pd-externals/else/xselect2~.pd_linux
        /root/Bela/projects/pd-externals/else/gaussian~.pd_linux
        /root/Bela/projects/pd-externals/else/adsr~.pd_linux
        /root/Bela/projects/pd-externals/else/canvas.active.pd_linux
        /root/Bela/projects/pd-externals/else/imp2~.pd_linux
        /root/Bela/projects/pd-externals/else/crackle~.pd_linux
        /root/Bela/projects/pd-externals/else/function.pd_linux
        /root/Bela/projects/pd-externals/else/click.pd_linux
        /root/Bela/projects/pd-externals/else/rint~.pd_linux
        /root/Bela/projects/pd-externals/else/fontsize.pd_linux
        /root/Bela/projects/pd-externals/else/oscope~.pd_linux
        /root/Bela/projects/pd-externals/else/gendyn~.pd_linux
        /root/Bela/projects/pd-externals/else/note.in.pd_linux
        /root/Bela/projects/pd-externals/else/wavetable~.pd_linux
        /root/Bela/projects/pd-externals/else/cosine~.pd_linux
        /root/Bela/projects/pd-externals/else/freq.shift~.pd_linux
        /root/Bela/projects/pd-externals/else/f2s~.pd_linux
        /root/Bela/projects/pd-externals/else/median~.pd_linux
        /root/Bela/projects/pd-externals/else/pulsecount~.pd_linux
        /root/Bela/projects/pd-externals/else/sine~.pd_linux
        /root/Bela/projects/pd-externals/else/blocksize~.pd_linux
        /root/Bela/projects/pd-externals/else/biquads~.pd_linux
        /root/Bela/projects/pd-externals/else/rad2hz.pd_linux
        /root/Bela/projects/pd-externals/else/merge.pd_linux
        /root/Bela/projects/pd-externals/else/note.pd_linux
        /root/Bela/projects
        And here is the list of the "... couldn't create" objects:
        brown 0.2
        rescale 10 10000
        s2f~
        Hmmm... what would I do without this three little seeds ? Nothing, with my "work in progress" patch.
        Thanks @giuliomoro to let me dive deep into the surface of command lines.
        Even if I only understand the reflect of it.
        it seems like you are missing several externals there. This is the full list I get:
        above~.pd_linux
        add~.pd_linux
        adsr~.pd_linux
        allpass.2nd~.pd_linux
        allpass.rev~.pd_linux
        args.pd_linux
        asr~.pd_linux
        autofade2~.pd_linux
        autofade~.pd_linux
        balance~.pd_linux
        bandpass~.pd_linux
        bandstop~.pd_linux
        bend.in.pd_linux
        bend.out.pd_linux
        bicoeff.pd_linux
        bicoeff2.pd_linux
        biquads~.pd_linux
        bitnormal~.pd_linux
        bl.imp2~.pd_linux
        bl.imp~.pd_linux
        bl.saw2~.pd_linux
        bl.saw~.pd_linux
        bl.square~.pd_linux
        bl.tri~.pd_linux
        bl.vsaw~.pd_linux
        blocksize~.pd_linux
        break.pd_linux
        brown~.pd_linux
        buffer.pd_linux
        button.pd_linux
        canvas.edit.pd_linux
        canvas.gop.pd_linux
        canvas.mouse.pd_linux
        canvas.name.pd_linux
        canvas.pos.pd_linux
        canvas.setname.pd_linux
        canvas.vis.pd_linux
        ceil.pd_linux
        ceil~.pd_linux
        cents2ratio~.pd_linux
        chance.pd_linux
        chance~.pd_linux
        changed.pd_linux
        changed2~.pd_linux
        changed~.pd_linux
        click.pd_linux
        cmul~.pd_linux
        colors.pd_linux
        comb.filt~.pd_linux
        comb.rev~.pd_linux
        cosine~.pd_linux
        crackle~.pd_linux
        crossover~.pd_linux
        ctl.in.pd_linux
        ctl.out.pd_linux
        cusp~.pd_linux
        datetime.pd_linux
        db2lin~.pd_linux
        decay2~.pd_linux
        decay~.pd_linux
        default.pd_linux
        del~.pd_linux
        detect~.pd_linux
        dir.pd_linux
        dollsym.pd_linux
        downsample~.pd_linux
        drive~.pd_linux
        dust2~.pd_linux
        dust~.pd_linux
        else.pd_linux
        envgen~.pd_linux
        eq~.pd_linux
        f2s~.pd_linux
        factor.pd_linux
        fader~.pd_linux
        fbdelay~.pd_linux
        fbsine2~.pd_linux
        fbsine~.pd_linux
        fdn.rev~.pd_linux
        ffdelay~.pd_linux
        float2bits.pd_linux
        float2sig~.pd_linux
        floor.pd_linux
        floor~.pd_linux
        fold.pd_linux
        fold~.pd_linux
        fontsize.pd_linux
        format.pd_linux
        function.pd_linux
        function~.pd_linux
        gate2imp~.pd_linux
        gaussian~.pd_linux
        gbman~.pd_linux
        gcd.pd_linux
        gendyn~.pd_linux
        giga.rev~.pd_linux
        glide2~.pd_linux
        glide~.pd_linux
        gray~.pd_linux
        gui.pd_linux
        henon~.pd_linux
        highpass~.pd_linux
        highshelf~.pd_linux
        hot.pd_linux
        hz2rad.pd_linux
        ikeda~.pd_linux
        imp2~.pd_linux
        impseq~.pd_linux
        impulse2~.pd_linux
        impulse~.pd_linux
        imp~.pd_linux
        initmess.pd_linux
        keyboard.pd_linux
        lag2~.pd_linux
        lag~.pd_linux
        lastvalue~.pd_linux
        latoocarfian~.pd_linux
        lb.pd_linux
        lfnoise~.pd_linux
        limit.pd_linux
        lincong~.pd_linux
        loadbanger.pd_linux
        logistic~.pd_linux
        loop.pd_linux
        lop2~.pd_linux
        lorenz~.pd_linux
        lowpass~.pd_linux
        lowshelf~.pd_linux
        match~.pd_linux
        median~.pd_linux
        merge.pd_linux
        message.pd_linux
        messbox.pd_linux
        metronome.pd_linux
        midi.pd_linux
        mouse.pd_linux
        mov.avg~.pd_linux
        mov.rms~.pd_linux
        mtx~.pd_linux
        note.in.pd_linux
        note.out.pd_linux
        note.pd_linux
        noteinfo.pd_linux
        numbox~.pd_linux
        nyquist~.pd_linux
        openfile.pd_linux
        op~.pd_linux
        oscope~.pd_linux
        pack2.pd_linux
        pad.pd_linux
        pan2~.pd_linux
        pan4~.pd_linux
        panic.pd_linux
        parabolic~.pd_linux
        peak~.pd_linux
        pgm.in.pd_linux
        pgm.out.pd_linux
        pic.pd_linux
        pimpmul~.pd_linux
        pimp~.pd_linux
        pink~.pd_linux
        pluck~.pd_linux
        pmosc~.pd_linux
        power~.pd_linux
        properties.pd_linux
        pulsediv~.pd_linux
        pulse~.pd_linux
        quad~.pd_linux
        quantizer.pd_linux
        quantizer~.pd_linux
        rad2hz.pd_linux
        rampnoise~.pd_linux
        ramp~.pd_linux
        rand.f.pd_linux
        rand.f~.pd_linux
        rand.hist.pd_linux
        rand.i.pd_linux
        rand.i~.pd_linux
        rand.u.pd_linux
        randpulse2~.pd_linux
        randpulse~.pd_linux
        range~.pd_linux
        rec.pd_linux
        receiver.pd_linux
        rescale.pd_linux
        rescale~.pd_linux
        resonant2~.pd_linux
        resonant~.pd_linux
        retrieve.pd_linux
        rint.pd_linux
        rint~.pd_linux
        rms~.pd_linux
        rotate~.pd_linux
        route2.pd_linux
        routeall.pd_linux
        router.pd_linux
        routetype.pd_linux
        s2f~.pd_linux
        saw2~.pd_linux
        saw~.pd_linux
        schmitt~.pd_linux
        selector.pd_linux
        separate.pd_linux
        sequencer~.pd_linux
        shaper~.pd_linux
        sh~.pd_linux
        sig2float~.pd_linux
        sine~.pd_linux
        sin~.pd_linux
        slew2~.pd_linux
        slew~.pd_linux
        slice.pd_linux
        sort.pd_linux
        spread.pd_linux
        spread~.pd_linux
        square~.pd_linux
        sr~.pd_linux
        standard~.pd_linux
        status~.pd_linux
        stepnoise~.pd_linux
        susloop~.pd_linux
        suspedal.pd_linux
        svfilter~.pd_linux
        symbol2any.pd_linux
        tabplayer~.pd_linux
        tabreader.pd_linux
        tabreader~.pd_linux
        tabwriter~.pd_linux
        tempo~.pd_linux
        toggleff~.pd_linux
        touch.in.pd_linux
        touch.out.pd_linux
        trig.delay2~.pd_linux
        trig.delay~.pd_linux
        trighold~.pd_linux
        tri~.pd_linux
        trunc.pd_linux
        trunc~.pd_linux
        unmerge.pd_linux
        voices.pd_linux
        vsaw~.pd_linux
        vu~.pd_linux
        wavetable~.pd_linux
        white~.pd_linux
        wrap2.pd_linux
        wrap2~.pd_linux
        wt~.pd_linux
        xfade~.pd_linux
        xgate2~.pd_linux
        xgate~.pd_linux
        xmod2~.pd_linux
        xmod~.pd_linux
        xselect2~.pd_linux
        xselect~.pd_linux
        zerocross~.pd_linux
        (which includes compiled externals s2f~.pd_linux and rescale.pd_linux)
        and furthermore all the .pd abstraction files, which should include at least /root/Bela/projects/pd-externals/else/brown.pd.
        I am wondering what has happened there. Try the following instruction step-by-step, please:
        • from the Bela IDE, delete the project pd-externals
        • download this archive on your computer https://github.com/BelaPlatform/Bela/files/10212285/else-v1.0-rc4-93-g0c64c285.zip
        • drop it in your on top of the Bela IDE. When asked the name of the new project you want to create, type pd-externals and click "create project"
        • now create a new project and copy on it a _main.pd file with only these objects in it:
          [brown] [s2f~] [rescale]
        • run the project and verify that you get no couldn't create errors when you start it
        Note that the procedure above will put all the files in /root/Bela/projects/pd-externals and not in /root/Bela/projects/pd-externals/else. This is good enough for testing. If this works, you can move them with:
        mv /root/Bela/projects/pd-externals /tmp/else
        mkdir -p /root/Bela/projects/pd-externals
        mv /tmp/else /root/Bela/projects/pd-externals/
        then modify your _main.pd so that it contains only these objects:
        [brown]
        [s2f~]
        [rescale]
        [declare -path /root/Bela/projects/pd-externals/else]
        and verify it still runs without couldn't create errors.
          giuliomoro Thanks. There is hope !
          I don't understand where to upload the else-v1.0-rc4-93-g0c64c285.zip
          with the information "drop it in your on top of the Bela IDE".
          If it's on the top of Bela IDE, I don't know how to do it.
          In the "create new project" section, clearly, I have to select the "Pure data" type ?
          "Note that the procedure above will put all the files in /root/Bela/projects/pd-externals and not in /root/Bela/projects/pd-externals/else"
          I don't understand with which procedure I can avoid to create a else folder unzipping the else-v1.0-rc4-93-g0c64c285.zip
            FatJak I don't understand where to upload the else-v1.0-rc4-93-g0c64c285.zip
            If you drop the zip archive on the IDE you should be prompted with a dialog to create a new project from the contents of the zip archive itself.
            "drop the zip archive on the IDE"
            Crazy. I hadn't thought I had to take it literally.
            So.
            Unzipping the file gave me
            Error opening file render.cpp: file does not exist.
            But I could see objects in
            Running the _main.pd with [brown] [s2f~] [rescale]
            gave me errors:
            Building project ...
            Linking...
            ...done
            Build finished
            Running project ...
            Running Pd 0.51-4
            Audio channels in use: 2
            Analog channels in use: 8
            Digital channels in use: 16
            No MIDI device enabled
            pd 0.51.4
            bonk version 1.5
            fiddle version 1.1 TEST4
            pique 0.1 for PD version 23
            sigmund~ version 0.07
            else/args -
            error: ... couldn't create
            else/swap2
            else/rand.f -1 1
            else/fold -1 1
            error: ../pd-externals/rescale.pd_linux: /lib/arm-linux-gnueabihf/libm.so.6: version GLIBC_2.29 not found (required by ../pd-externals/rescale.pd_linux)
            rescale
              uff right. It seems that else abstractions
              FatJak else/args -
              else/swap2
              else/rand.f -1 1
              rely on having the stuff in the else/ folder.
              and this
              FatJak error: ../pd-externals/rescale.pd_linux: /lib/arm-linux-gnueabihf/libm.so.6: version GLIBC_2.29 not found (required by ../pd-externals/rescale.pd_linux)
              is because I built else with a too-new version of the board. I am going to redo it on the same version you have.
              ok I rebuilt it and it is now available . Please follow the instructions below:
                https://github.com/BelaPlatform/Bela/files/10228145/else-v1.0-rc4-93-g0c64c285.zip
              • drop it in your on top of the Bela IDE. When asked the name of the new project you want to create, type pd-else and click "create project". Wait for a few seconds while it is done.
              • when done, you will get an error "couldn't open render.cpp". That's fine, press "Cancel"
              • run the following in the console at the bottom of the Bela IDE so that the externals go in the right place:
                rm -rf projects/pd-externals;
                mkdir -p projects/pd-externals;
                mv projects/pd-else projects/pd-externals/else;
              • now create a new project and copy on it a _main.pd file with only the following objects in it:
                [brown]
                [s2f~]
                [rescale]
              • run the project and verify that you get no "couldn't create" errors when you start it
                Oh!
                No "couldn't create" errors to declare in this test !
                AND
                No "couldn't create" errors to declare in MY PATCH !!!!!!!!! !
                THANKS YOU SO MUCH @giuliomoro
                I would like to offer you a beer !
