giuliomoro i think so. playing a concert now, will check later. can i include a Midi_c.h from within the BELA image? i couldn't find it and included one from the bela doc wiki (found via google)
    lokki . can i include a Midi_c.h from within the BELA image? i couldn't find it and included one from the bela doc wiki (found via google)
    it's in Bela/libraries/Midi/Midi_c.h. Not sure where you find it on the wiki? You mean this one ? It' the same ...
    ok, got it too compile... as you said, it was commented, stupid me.
    when i run the plugin i get:
    root@bela:~/Bela/projects/jalv-Bela/build# ./jalv http://gareus.org/oss/lv2/fat1
    Plugin:       http://gareus.org/oss/lv2/fat1
    UI:           None
    Plugin requires 1 inputs and 1 outputs
    Sample rate:  44100 Hz
    Block length: 64 frames
    MIDI buffers: 4096 bytes
    Comm buffers: 65536 bytes
    Update rate:  25.0 Hz
    Illegal instruction
    and it aborts. not sure if the binary i installed is the reason for this. will try to compile the fat1.lv2 from source to see if it makes a difference
      lokki not sure if the binary i installed is the reason for this. will try to compile the fat1.lv2 from source to see if it makes a difference
      SIGILL (ILLEGAL INSTRUCTION) could happen if the binary was built for a different architecture, e.g.: an armv8 32bit binary will load but may fail on an instruction not present in armv7 (e.g.: NEON divide). If the binary is for armv7 then you could get a SIGILL because of some weird pointer error where you are trying to execute a portion of memory that does not contain executable data. I thought you had tried to compile the plugin yourself earlier? Where is the release from? Cannot see it on their github. You can try and run jalv inside gdb ( you'd do gdb jalv and then once you are in dorun < command line options> then when it fails you can see where (what function or even what line perhaps) it failed. You can also do disass to see the assembly and individuate the culprit instruction.
        giuliomoro got one step further. when i build the plugin without any optimisations, it runs. i get a ton of underruns, so i will now add in optimisations too see when it starts to fail :-)
        do you see a problematic one?:
        OPTIMIZATIONS="-Wall -Wno-unused-function -O3 -ffast-math -fomit-frame-pointer -fno-finite-math-only -fvisibility=hidden -fdata-sections -ffunction-sections -DNDEBUG -mfpu=neon-vfpv4 -mfloat-abi=hard -mvectorize-with-neon-quad"
        ok, with just -O3 -DNDEBUG it runs (i think)
        i get:
        UI:           None
        mode      = 0.000000
        channelf  = 0.000000
        tuning    = 440.000000
        bias      = 0.500000
        filter    = 0.100000
        corr      = 1.000000
        offset    = 0.000000
        bendrange = 2.000000
        fastmode  = 0.000000
        m00       = 1.000000
        m01       = 1.000000
        m02       = 1.000000
        m03       = 1.000000
        m04       = 1.000000
        m05       = 1.000000
        m06       = 1.000000
        m07       = 1.000000
        m08       = 1.000000
        m09       = 1.000000
        m10       = 1.000000
        m11       = 1.000000
        nmask     = 0.000000
        nset      = 0.000000
        bend      = 0.000000
        error     = 0.000000
        latency   = 0.000000
        i can change the settings via the prompt. :-)
          and i can hear my voice!! yes.
          lokki the > at the end is not visible in the code section somehow, i take it this is some kind of prompt for the plugin
          yeah, never understood what you can do with it, but it's there at the bottom of jalv the whole time. What's the CPU like? Note that if there is a "worker thread", that will not show up at /proc/xenomai/sched/stat (because it wouldn't be a Xenomai task, as it is managed by jalv or the plugin itself), and you will have to do
          top -p `pidof jalv` -H
          to see the CPU usage of all the Linux threads (this will be percentage where the total available is 100 minus the sum of what is returned by /proc/xenomai/sched/stat.
          the ">" is to change the settings. if i type m10 = 0 for example it changes that parameter in the plugin. so it is a primitive UI :-)
          CPU:
          top:
          top - 23:39:20 up 49 min,  2 users,  load average: 0.52, 0.66, 0.64
          Threads:   4 total,   0 running,   4 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.3 sy,  0.0 ni, 99.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          KiB Mem :   501464 total,   233488 free,    79792 used,   188184 buff/cache
          KiB Swap:        0 total,        0 free,        0 used.   374764 avail Mem
            PID USER      PR  NI    VIRT    RES    SHR S %CPU %MEM     TIME+ COMMAND
           6088 root      20   0   22532  19412   7336 S  0.3  3.9   0:00.05 jalv
           6090 root     -51   0   22532  19412   7336 S  0.3  3.9   0:00.14 bela-midiIn_hw:
           6085 root      20   0   22532  19412   7336 S  0.0  3.9   0:00.38 jalv
           6094 root     -96   0   22532  19412   7336 S  0.0  3.9   0:00.00 bela-audio
          xenomai stat:
          Every 0.5s: cat /proc/xenomai/sched/stat        bela: Tue Dec 17 23:40:32 2019
            0  0      0          658918     0          0     00018000   77.6  [ROOT]
            0  6085   3          4          13         0     000600c0    0.0  jalv
            0  6090   2          3          4          0     000480c0    0.0  bela-midiIn_hw:0,0,0
            0  6094   1          137640     137642     0     00048046   22.1  bela-audio
            0  0      0          315535     0          0     00000000    0.0  [IRQ16: [timer]]
            0  0      0          137647     0          0     00000000    0.2  [IRQ180: rtdm_pruss_irq_irq]
            oh. so there is no worker thread, or it's doing very little (it would be the 0.3% CPU one) ...
            great!
            lokki primitive UI :-)
            primitive? It's text-based, so it's very evolved, to the point where all the pointless frills have been removed.
              giuliomoro -mfpu=neon-vfpv4 should be -mfpu=neon
              yep, that was it. it runs with all optimisations now...
              Great. vfpv4 is for armv8. armv7 has the vfpv3.
              with all the optimisations in place it looks even better:
              Every 0.5s: cat /proc/xenomai/sched/stat        bela: Tue Dec 17 23:53:27 2019
                0  0      0          1061315    0          0     00018000   85.3  [ROOT]
                0  8067   3          4          13         0     000600c0    0.0  jalv
                0  8073   2          3          4          0     000480c0    0.0  bela-midiIn_hw:0,0,0
                0  8077   1          88810      88813      0     00048046   14.4  bela-audio
                0  0      0          405345     0          0     00000000    0.0  [IRQ16: [timer]]
                0  0      0          88819      0          0     00000000    0.2  [IRQ180: rtdm_pruss_irq_irq]
              great!
              is there a way to change the PGA gain settings from the command line when running jalv?
              giuliomoro primitive? It's text-based, so it's very evolved
              of course.
                so by tomorrow morning i want that LV2host with all added features :-) and with a nice primitive UI
                  lokki is there a way to change the PGA gain settings from the command line when running jalv?
                  no they are not exposed. An easy way to do change these is to hardcode them within jalv where the settings are set:
                  https://github.com/giuliomoro/jalv/blob/Bela/src/bela.c#L274-L286
                  add
                  settings.pgaGain[0] = 20;
                  lokki so by tomorrow morning i want that LV2host with all added features :-) and with a nice primitive UI
                  @adanlbenito had an automatic nexus-UI (or p5.hjs?) GUI generator for this host, not sure where that is gone ...
