hmm, i get this:
Port 0 has unsupported type
Fat1.lv2 error: Host does not support urid:map
error: Unable to instantiate plugin `http://gareus.org/oss/lv2/fat1'
Segmentation fault
hmm, i get this:
Segmentation fault
Missing feature of the host. I will need to have a look. It seems that it is only used for performance reason, so maybe it is optional and there is a way to disable it in the plugin?
no it doesn't look like it can be disabled, and it is required. Maybe some simple changes to the code of the plugin would fix that. But it's definitely easier and better to implement the feature on the host!
maybe the host on the modduo devices could be used? that seems to support it.
here is the GitHub of MOD:
a fftw3 library that is optimised for mod:
https://github.com/moddevices/fftw3-duo
MOD lv2 host:
the sysmap.c
file they have is where the mapping is implemented. This, in turn, is taken from jalv
. I will see how to include it in our stuff.
giuliomoro is the plan to amend the missing features to the new host or will you try to revive your jalv-port since that would probably be easier to integrate there? let me know if/when i can test something. thanks!
I will try to have a look at adding the feature to our host next week. jalv
should still build, although maybe it needs a couple of paths changed. The downside with jalv
is that it is a single-plugin host.
giuliomoro i see. thanks for the heads up! the modduo version is multi plugin as well, ir they load several instances...
ok i have a go at compiling jalv on current bela. i could try then the plugin and see if it does even run on BELA. if not, no need to work on the new LV2host...
as you said some libraries are missing but i think i fixed the paths. (i had to manually include Midi_c.h in the src directory, because it was not found otherwise.) i now get this error on ./waf build:
[ 1/11] Compiling src/bela.c
../src/bela.c:41:1: error: unknown type name 'Midi'
Midi* midi;
../src/bela.c: In function 'render':
../src/bela.c:110:31: warning: implicit declaration of function 'Midi_availableMessages' [-Wimplicit-function-declaration]
if((availableMidiMessages = Midi_availableMessages(midi)) > 0)
../src/bela.c:136:27: warning: implicit declaration of function 'Midi_getMessage' [-Wimplicit-function-declaration]
unsigned char size = Midi_getMessage(midi, buf);
../src/bela.c: In function 'setup':
../src/bela.c:227:10: warning: implicit declaration of function 'Midi_new' [-Wimplicit-function-declaration]
midi = Midi_new(gMidiPort0);
../src/bela.c:227:8: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
../src/bela.c: In function 'cleanup':
../src/bela.c:260:3: warning: implicit declaration of function 'Midi_delete' [-Wimplicit-function-declaration]
Midi_delete(midi);
lokki that's a weird failure, as if Midi_c.h
was empty. Is the #include
still in place in src/bela.c
giuliomoro i think so. playing a concert now, will check later. can i include a Midi_c.h from within the BELA image? i couldn't find it and included one from the bela doc wiki (found via google)
ok, got it too compile... as you said, it was commented, stupid me.
when i run the plugin i get:
root@bela:~/Bela/projects/jalv-Bela/build# ./jalv http://gareus.org/oss/lv2/fat1
Plugin: http://gareus.org/oss/lv2/fat1
UI: None
Plugin requires 1 inputs and 1 outputs
Sample rate: 44100 Hz
Block length: 64 frames
MIDI buffers: 4096 bytes
Comm buffers: 65536 bytes
Update rate: 25.0 Hz
Illegal instruction
and it aborts. not sure if the binary i installed is the reason for this. will try to compile the fat1.lv2 from source to see if it makes a difference
lokki not sure if the binary i installed is the reason for this. will try to compile the fat1.lv2 from source to see if it makes a difference
SIGILL (ILLEGAL INSTRUCTION) could happen if the binary was built for a different architecture, e.g.: an armv8 32bit binary will load but may fail on an instruction not present in armv7 (e.g.: NEON divide). If the binary is for armv7 then you could get a SIGILL because of some weird pointer error where you are trying to execute a portion of memory that does not contain executable data. I thought you had tried to compile the plugin yourself earlier? Where is the release from? Cannot see it on their github. You can try and run jalv
inside gdb
( you'd do gdb jalv
and then once you are in dorun < command line options>
then when it fails you can see where (what function or even what line perhaps) it failed. You can also do disass
to see the assembly and individuate the culprit instruction.
giuliomoro got one step further. when i build the plugin without any optimisations, it runs. i get a ton of underruns, so i will now add in optimisations too see when it starts to fail :-)
do you see a problematic one?:
OPTIMIZATIONS="-Wall -Wno-unused-function -O3 -ffast-math -fomit-frame-pointer -fno-finite-math-only -fvisibility=hidden -fdata-sections -ffunction-sections -DNDEBUG -mfpu=neon-vfpv4 -mfloat-abi=hard -mvectorize-with-neon-quad"
-mfpu=neon-vfpv4
should be -mfpu=neon
ok, with just -O3 -DNDEBUG
it runs (i think)
i get:
UI: None
mode = 0.000000
channelf = 0.000000
tuning = 440.000000
bias = 0.500000
filter = 0.100000
corr = 1.000000
offset = 0.000000
bendrange = 2.000000
fastmode = 0.000000
m00 = 1.000000
m01 = 1.000000
m02 = 1.000000
m03 = 1.000000
m04 = 1.000000
m05 = 1.000000
m06 = 1.000000
m07 = 1.000000
m08 = 1.000000
m09 = 1.000000
m10 = 1.000000
m11 = 1.000000
nmask = 0.000000
nset = 0.000000
bend = 0.000000
error = 0.000000
latency = 0.000000
i can change the settings via the prompt. :-)
and i can hear my voice!! yes.
