and as i predicted i am now running into trouble because i try to use two different midi implementations... while copying everything from my lv2host render to my heavy render i get:
Bela stopped
redefinition of 'midi' with a different type: 'std::vector<Midi *>' vs 'Midi' column: 27, line: 124
no member named 'size' in 'Midi' column: 10, line: 334
no member named 'size' in 'Midi' column: 35, line: 347
type 'Midi' does not provide a subscript operator column: 8, line: 352
type 'Midi' does not provide a subscript operator column: 8, line: 353
no member named 'size' in 'Midi' column: 18, line: 393
no member named 'push_back' in 'Midi' column: 10, line: 492
type 'Midi' does not provide a subscript operator column: 8, line: 542
type 'Midi' does not provide a subscript operator column: 8, line: 552
type 'Midi' does not provide a subscript operator column: 8, line: 560
type 'Midi' does not provide a subscript operator column: 8, line: 569
type 'Midi' does not provide a subscript operator column: 8, line: 578
type 'Midi' does not provide a subscript operator column: 8, line: 588
type 'Midi' does not provide a subscript operator column: 8, line: 596
[warning] unused variable 'st' [-Wunused-variable] column: 12, line: 701
no member named 'push_back' in 'Midi' column: 9, line: 817
no member named 'size' in 'Midi' column: 41, line: 863
type 'Midi' does not provide a subscript operator column: 20, line: 864
this is of course because i use two different ways to read the midi in (the one proposed in the midi example and the one from the default heavy render) so question is, should i update the heavy_render to use the new implementation or roll back to the heavy render midi stuff for my lv2host example...
