no it doesn't look like it can be disabled, and it is required. Maybe some simple changes to the code of the plugin would fix that. But it's definitely easier and better to implement the feature on the host!
    maybe the host on the modduo devices could be used? that seems to support it.
    the sysmap.c file they have is where the mapping is implemented. This, in turn, is taken from jalv. I will see how to include it in our stuff.
      giuliomoro is the plan to amend the missing features to the new host or will you try to revive your jalv-port since that would probably be easier to integrate there? let me know if/when i can test something. thanks!
      I will try to have a look at adding the feature to our host next week. jalv should still build, although maybe it needs a couple of paths changed. The downside with jalv is that it is a single-plugin host.
        giuliomoro i see. thanks for the heads up! the modduo version is multi plugin as well, ir they load several instances...
        4 days later
        ok i have a go at compiling jalv on current bela. i could try then the plugin and see if it does even run on BELA. if not, no need to work on the new LV2host...
        as you said some libraries are missing but i think i fixed the paths. (i had to manually include Midi_c.h in the src directory, because it was not found otherwise.) i now get this error on ./waf build:
        [ 1/11] Compiling src/bela.c
        ../src/bela.c:41:1: error: unknown type name 'Midi'
         Midi* midi;
        ../src/bela.c: In function 'render':
        ../src/bela.c:110:31: warning: implicit declaration of function 'Midi_availableMessages' [-Wimplicit-function-declaration]
           if((availableMidiMessages = Midi_availableMessages(midi)) > 0)
        ../src/bela.c:136:27: warning: implicit declaration of function 'Midi_getMessage' [-Wimplicit-function-declaration]
              unsigned char size = Midi_getMessage(midi, buf);
        ../src/bela.c: In function 'setup':
        ../src/bela.c:227:10: warning: implicit declaration of function 'Midi_new' [-Wimplicit-function-declaration]
           midi = Midi_new(gMidiPort0);
        ../src/bela.c:227:8: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
        ../src/bela.c: In function 'cleanup':
        ../src/bela.c:260:3: warning: implicit declaration of function 'Midi_delete' [-Wimplicit-function-declaration]
           Midi_delete(midi);
          lokki that's a weird failure, as if Midi_c.h was empty. Is the #include still in place in src/bela.c ?
            giuliomoro i think so. playing a concert now, will check later. can i include a Midi_c.h from within the BELA image? i couldn't find it and included one from the bela doc wiki (found via google)
              lokki . can i include a Midi_c.h from within the BELA image? i couldn't find it and included one from the bela doc wiki (found via google)
              it's in Bela/libraries/Midi/Midi_c.h. Not sure where you find it on the wiki? You mean this one ? It' the same ...
              ok, got it too compile... as you said, it was commented, stupid me.
              when i run the plugin i get:
              root@bela:~/Bela/projects/jalv-Bela/build# ./jalv http://gareus.org/oss/lv2/fat1
              Plugin:       http://gareus.org/oss/lv2/fat1
              UI:           None
              Plugin requires 1 inputs and 1 outputs
              Sample rate:  44100 Hz
              Block length: 64 frames
              MIDI buffers: 4096 bytes
              Comm buffers: 65536 bytes
              Update rate:  25.0 Hz
              Illegal instruction
              and it aborts. not sure if the binary i installed is the reason for this. will try to compile the fat1.lv2 from source to see if it makes a difference
                lokki not sure if the binary i installed is the reason for this. will try to compile the fat1.lv2 from source to see if it makes a difference
                SIGILL (ILLEGAL INSTRUCTION) could happen if the binary was built for a different architecture, e.g.: an armv8 32bit binary will load but may fail on an instruction not present in armv7 (e.g.: NEON divide). If the binary is for armv7 then you could get a SIGILL because of some weird pointer error where you are trying to execute a portion of memory that does not contain executable data. I thought you had tried to compile the plugin yourself earlier? Where is the release from? Cannot see it on their github. You can try and run jalv inside gdb ( you'd do gdb jalv and then once you are in dorun < command line options> then when it fails you can see where (what function or even what line perhaps) it failed. You can also do disass to see the assembly and individuate the culprit instruction.
                  giuliomoro got one step further. when i build the plugin without any optimisations, it runs. i get a ton of underruns, so i will now add in optimisations too see when it starts to fail :-)
                  do you see a problematic one?:
                  OPTIMIZATIONS="-Wall -Wno-unused-function -O3 -ffast-math -fomit-frame-pointer -fno-finite-math-only -fvisibility=hidden -fdata-sections -ffunction-sections -DNDEBUG -mfpu=neon-vfpv4 -mfloat-abi=hard -mvectorize-with-neon-quad"
                  ok, with just -O3 -DNDEBUG it runs (i think)
                  i get:
                  UI:           None
                  mode      = 0.000000
                  channelf  = 0.000000
                  tuning    = 440.000000
                  bias      = 0.500000
                  filter    = 0.100000
                  corr      = 1.000000
                  offset    = 0.000000
                  bendrange = 2.000000
                  fastmode  = 0.000000
                  m00       = 1.000000
                  m01       = 1.000000
                  m02       = 1.000000
                  m03       = 1.000000
                  m04       = 1.000000
                  m05       = 1.000000
                  m06       = 1.000000
                  m07       = 1.000000
                  m08       = 1.000000
                  m09       = 1.000000
                  m10       = 1.000000
                  m11       = 1.000000
                  nmask     = 0.000000
                  nset      = 0.000000
                  bend      = 0.000000
                  error     = 0.000000
                  latency   = 0.000000
                  i can change the settings via the prompt. :-)
                    and i can hear my voice!! yes.
                    lokki the > at the end is not visible in the code section somehow, i take it this is some kind of prompt for the plugin
                    yeah, never understood what you can do with it, but it's there at the bottom of jalv the whole time. What's the CPU like? Note that if there is a "worker thread", that will not show up at /proc/xenomai/sched/stat (because it wouldn't be a Xenomai task, as it is managed by jalv or the plugin itself), and you will have to do
                    top -p `pidof jalv` -H
                    to see the CPU usage of all the Linux threads (this will be percentage where the total available is 100 minus the sum of what is returned by /proc/xenomai/sched/stat.
                    the ">" is to change the settings. if i type m10 = 0 for example it changes that parameter in the plugin. so it is a primitive UI :-)
                    CPU:
                    top:
                    top - 23:39:20 up 49 min,  2 users,  load average: 0.52, 0.66, 0.64
                    Threads:   4 total,   0 running,   4 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  0.0 us,  0.3 sy,  0.0 ni, 99.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    KiB Mem :   501464 total,   233488 free,    79792 used,   188184 buff/cache
                    KiB Swap:        0 total,        0 free,        0 used.   374764 avail Mem
                      PID USER      PR  NI    VIRT    RES    SHR S %CPU %MEM     TIME+ COMMAND
                     6088 root      20   0   22532  19412   7336 S  0.3  3.9   0:00.05 jalv
                     6090 root     -51   0   22532  19412   7336 S  0.3  3.9   0:00.14 bela-midiIn_hw:
                     6085 root      20   0   22532  19412   7336 S  0.0  3.9   0:00.38 jalv
                     6094 root     -96   0   22532  19412   7336 S  0.0  3.9   0:00.00 bela-audio
                    xenomai stat:
                    Every 0.5s: cat /proc/xenomai/sched/stat        bela: Tue Dec 17 23:40:32 2019
                      0  0      0          658918     0          0     00018000   77.6  [ROOT]
                      0  6085   3          4          13         0     000600c0    0.0  jalv
                      0  6090   2          3          4          0     000480c0    0.0  bela-midiIn_hw:0,0,0
                      0  6094   1          137640     137642     0     00048046   22.1  bela-audio
                      0  0      0          315535     0          0     00000000    0.0  [IRQ16: [timer]]
                      0  0      0          137647     0          0     00000000    0.2  [IRQ180: rtdm_pruss_irq_irq]
