• Hardware
  • is anyone successfully using i2c OLED / LCD?
giuliomoro and grep linux /root/Bela/projects/OLED_test_github/* ?
/root/Bela/projects/OLED_test_github/I2C.c:#include<linux/i2c.h>
/root/Bela/projects/OLED_test_github/I2C.c:#include<linux/i2c-dev.h>
grep: /root/Bela/projects/OLED_test_github/build: Is a directory
Binary file /root/Bela/projects/OLED_test_github/oled matches
and what's the output of
dpkg -l | grep i2c
ii i2c-tools 3.1.2-3 armhf heterogeneous set of I2C tools for Linux
I did use i2cdetect earlier to check whether the display module was connected... I don't recall exactly if I installed it or if it was already there. Maybe that makes a difference?
right so the problem is on my board, where I have actually installed an extra package libi2c-dev, which causes the an error when including both files listed above. UOPS!
    🙂 let me know if I can be of any further assistance. I think it might be best for me to first work on the PD integration and after that write up a how-to.
      giuliomoro Giulio, thanks a lot for your assistance and attention! After the post 30 I was able to connect my bela on the OLED screen. crosswick will try to connect it on PD, and I'll try to connect on Sc now. we'll keep you update! I'm also up to write a documentation about it 🙂
      15 days later
      Good news - I've got an application running that can run independently from PD or SC, that translates incoming OSC messages into SSD1306 display commands.
      I've been heavily inspired by this conversation: https://forum.bela.io/d/497-how-do-i-get-two-programs-running-at-the-same-time
      Also I've read elsewhere on the forum that for starting up a second/background application like this, it should be possible to use a self-made run.sh script in the project directory.
      Two questions now that I'm having a challenge figuring out:
      - in run.sh, after starting up the OSC->OLED application, how do I resume the normal Run procedure for a PD or SC project?
      - is there a similar way to end/kill the application that is triggered by the Stop button in the IDE interface?
        Hey @crosswick & @giuliomoro
        Trying to get an OLED display to work based on the repo @giuliomoro posted in reply #30 (https://github.com/giuliomoro/bela-ssd1306) and I'm actually getting the following warnings and a runide error:
        Build finished
        In file SSD1306_OLED.c: [warning] passing 'const unsigned char *' to parameter of type 'const char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 33, line: 2419
        In file SSD1306_OLED.c: [warning] passing 'char [3]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 22, line: 2430
        In file SSD1306_OLED.c: [warning] passing 'const unsigned char *' to parameter of type 'const char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 30, line: 2442
        In file SSD1306_OLED.c: [warning] passing 'char [3]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 20, line: 2443
        In file SSD1306_OLED.c: [warning] passing 'char *' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 22, line: 2479
        In file SSD1306_OLED.c: [warning] passing 'char [4]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 26, line: 2657
        In file SSD1306_OLED.c: [warning] passing 'char [4]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 26, line: 2659
        In file SSD1306_OLED.c: [warning] passing 'char [4]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 26, line: 2661
        In file SSD1306_OLED.c: [warning] passing 'char [4]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 26, line: 2663
        In file SSD1306_OLED.c: [warning] passing 'char [2]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 24, line: 2686
        In file example_app.c: [warning] passing 'char [7]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 15, line: 261
        In file example_app.c: [warning] passing 'char [14]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 15, line: 286
        In file example_app.c: [warning] passing 'char [3]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 15, line: 293
        In file example_app.c: [warning] passing 'char [19]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 17, line: 377
        In file example_app.c: [warning] passing 'char [21]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 17, line: 379
        In file example_app.c: [warning] passing 'char [10]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 17, line: 382
        /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2419:33: warning: passing 'const unsigned char *' to parameter of type 'const char *' converts between pointers to integer types with different sign [-Wpointer-sign]
             return print(strPtr, strlen(strPtr));
        /usr/include/string.h:394:35: note: passing argument to parameter '__s' here
        extern size_t strlen (const char *__s)
        /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2430:22: warning: passing 'char [3]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
        return print_str("\r\n");
        /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2417:38: note: passing argument to parameter 'strPtr' here
        short print_str(const unsigned char *strPtr)
        /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2442:30: warning: passing 'const unsigned char *' to parameter of type 'const char *' converts between pointers to integer types with different sign [-Wpointer-sign]
        n = print(strPtr, strlen(strPtr));
        /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2443:20: warning: passing 'char [3]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
         n += print_str("\r\n");
        /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2479:22: warning: passing 'char *' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
        return print_str(str);
        /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2657:26: warning: passing 'char [4]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
        return print_str("nan");
        /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2659:26: warning: passing 'char [4]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
        return print_str("inf");
        /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2661:26: warning: passing 'char [4]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
        return print_str("ovf");  // constant determined empirically
        /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2663:26: warning: passing 'char [4]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
        /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2686:24: warning: passing 'char [2]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
        n += print_str(".");
        10 warnings generated.
        /root/Bela/projects/bela-ssd1306/example_app.c:261:15: warning: passing 'char [7]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
        print_str("scroll");
        /root/Bela/projects/bela-ssd1306/SSD1306_OLED.h:172:45: note: passing argument to parameter 'strPtr' here
        extern short print_str(const unsigned char *strPtr);
        /root/Bela/projects/bela-ssd1306/example_app.c:286:15: warning: passing 'char [14]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
        print_str("HELLO FELLAS!");
        /root/Bela/projects/bela-ssd1306/example_app.c:293:15: warning: passing 'char [3]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
        print_str("0x");
        /root/Bela/projects/bela-ssd1306/example_app.c:377:17: warning: passing 'char [19]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
        print_strln("deeplyembedded.org");
        /root/Bela/projects/bela-ssd1306/SSD1306_OLED.h:174:47: note: passing argument to parameter 'strPtr' here
        extern short print_strln(const unsigned char *strPtr);
        /root/Bela/projects/bela-ssd1306/example_app.c:379:17: warning: passing 'char [21]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
        print_strln("Author:Vinay Divakar");
        /root/Bela/projects/bela-ssd1306/example_app.c:382:17: warning: passing 'char [10]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
        print_strln("THANK YOU");
        6 warnings generated.
        Running project...
        (Main)i2c-2: Bus Connected to SSD1306
        Makefile:524: recipe for target 'runide' failed
        make: *** [runide] Error 1
        I also want to just confirm the correct pin connections and I2C bus to be using when using the files in the repo linked above. It seemed at the beginning of the thread that it made most sense to connect to the I2C1 bus, but I noticed in the terminal that it says "(Main)i2c-2: Bus Connected to SSD1306" - so I'm also wondering whether I'm connecting to the wrong bus.
        My breadboard is currently set up with a Bela Mini like this:
        Ground: P2_21
        VIN: P2_23
        SCL: P2_9
        SDA: P2_11
        Is this correct? Or should I be using I2C2? i.e.:
        Ground: P2_21
        VIN: P2_23
        SCL: P1_26
        SDA: P1_28
        Per @crosswick's note concerning the RST pin - I'm using the circuit noted here:
        http://community.axoloti.com/t/spi-i2c-oled-display/638/187
        Specifically - I've got a 10k resistor connected to the 3.3V rail, a 68nf cap connected to ground - I'm running a wire at the junction point on the terminal strip where the 10k resistor meets the 68nf cap to another terminal strip where a 100k resistor is tied to ground and I have a wire from that strip connected to the RST pin.
        Is this the correct way to deal with the RST pin? I've seen other examples where RST is connected to a GPIO pin - but there doesn't appear to be an RST pin noted in the code anywhere and it isn't mentioned in this thread explicitly either.
        Just trying to get this example code running so I can move on to some more fun visuals!
        Hi @kreiff, I also got those errors. It was explained to me by a buddy that this SSD1306 C library does things with unsigned chars which are not permitted in C++. There's apparently several different ways of solving this, amongst which macros - I solved it by editing the SSD1306_OLED.c and -.h files by simply removing the 'unsigned' bit in the relevant places.
        As far as the pinouts, I'm using the same you mention with P2_9 and P2_11.
        Here's a picture of my RST pin setup: (I'm using a dedicated I2S display now btw)
          @crosswick - Thanks for the quick reply!
          crosswick As far as the pinouts, I'm using the same you mention with P2_9 and P2_11.
          Thanks for confirming!
          crosswick Here's a picture of my RST pin setup: (I'm using a dedicated I2S display now btw)
          It's a little hard to see the connections - but this looks to be how the RST pin is set up on my breadboard.
          crosswick I solved it by editing the SSD1306_OLED.c and -.h files by simply removing the 'unsigned' bit in the relevant places.
          I tried using your approach from post 32 and downloaded your github repo. I also went through and removed the unsigned pre-cursors on the variables across the files. If I try running via SSH I do get this line in the terminal:
          (Main)i2c-1: Bus Connected to SSD1306
          But I don't have any output on the OLED...
          Alternatively - if I try running the render.cpp - I still get a ton of errors and the same runide error:
          @giuliomoro - What is runide Error 1?
            kreiff looks to me like there's something wrong with the physical connection to the display - that's when I get that runide error. I would suggest that you get a (bunch of, they're really cheap) I2C-only versions of this SSD1306 display to be sure.
            BTW like you've probably already seen, the unsigned-alteration is not yet in my github repo.
              @kreiff can you run i2cdetect -y -r 1 ? Does the display show up at the expected address?
              Thew runide failed message is a general message that the program stopped with an error
              crosswick looks to me like there's something wrong with the physical connection to the display - that's when I get that runide error. I would suggest that you get a (bunch of, they're really cheap) I2C-only versions of this SSD1306 display to be sure.
              I came to this conclusion last night as well. I think my OLED is dead. It was from Adafruit - so I figured I would just test their arduino library code to rule out the screen itself being bad...and that looks like the culprit. It doesn't even flicker following the Adafruit instructions exactly...
              I bought a two pack of I2C-only (4-pin / no reset) OLEDs from Amazon - so I'll give this another go when they arrive.
              @crosswick Sorry to be hanging on your coat tails with this - but any luck resolving the latency issue?
              I'm trying to get an Axoloti style minimal oscilliscope working - and I'm getting a ton of latency even just sending the values straight from PD. It's like the OSC messages start piling up and it ends up getting like 30 seconds behind drawing the waveshape.
              I'm wondering whether I2C is just too slow? Or if it's something to do with the driver. I've noticed that even the "demo" animation draws about twice as fast using the Adafruit library vs. the Deeply Embedded one. (granted - this is an Arduino Due running the adafruit library vs. Bela running the DE one - so not apples-to-apples - but I would expect Bela / PocketBeagle to be faster).
                crosswick Can you confirm that sending data from an external computer gives way less latency?
                Unfortunately, I'm actually experiencing the latency even sending directly from my computer. I haven't tried running the OLED code in the background yet. It might be the application though - just that I2C is too slow for an oscilloscope. Might have to find an SPI driver that I can adapt...
                I saw Paul E Long's thread (https://forum.bela.io/d/978-using-an-oled-128x128-rgb-with-belamini/35) using that nice looking RGB OLED screen - but I couldn't get his code to work and it seems like his application was using an LCD and OLED simultaneously and he was doing some GPIO voodoo to get it working.
                Honestly, I might have to wait until Giulio and the Bela team implement some native OLED drivers for SPI. My knowledge of hardware pin management / bit banging is pretty limited and I've struck out adapting all of the rPi and Arduino libraries to PocketBeagle so far.
                  kreiff I'm wondering whether I2C is just too slow? Or if it's something to do with the driver. I've noticed that even the "demo" animation draws about twice as fast using the Adafruit library vs. the Deeply Embedded one.
                  We came across an SPI library for a similar display here, where the library was written so badly that it was wasting a lot of time by writing one single word per transaction. Speed improved greatly when editing the library to write several words in a row. Maybe you have a similar case here. What library are code are using exactly?
                  Late reply:
                  crosswick Two questions now that I'm having a challenge figuring out:
                  When you do that, it's all up to you. You have to call it manually. Run the program (without run.sh) once adding AT= to the Make options in the IDE. You will then see the actual line that is called to run the program. You could copy that into your run.sh if that helps.
                  crosswick > - is there a similar way to end/kill the application that is triggered by the Stop button in the IDE interface?
                  The stop button will kill make stop, but that in turn does nothing with run.sh. I guess it would be a good idea if it did that. We can work on it, if you are interested?
                    kreiff Honestly, I might have to wait until Giulio and the Bela team implement some native OLED drivers for SPI. My knowledge of hardware pin management / bit banging is pretty limited and I've struck out adapting all of the rPi and Arduino libraries to PocketBeagle so far.
                    Happy to help, but I got a bit lost in the thread. Where are you at now exactly? Where is your code?
                    kreiff just that I2C is too slow for an oscilloscope.
                    You may have your I2c speed slower than it could be. Which I2c channel are you using?
