• Hardware
  • is anyone successfully using i2c OLED / LCD?
This is better. You see that now it is actually running the task (as you can tell from the fact that the line
(Main)i2c-1: Bus Connected to SSD1306
is printed).
I started debugging this by copying all your code to the board and trying to run the files from your repo as a stand-alone app, and that would fail at compile time. I fixed it with this.
Then, I managed to build a stand-alone program (non-Bela) and run it, but it would only display (Main)i2c-1: Bus Connected to SSD1306 and would not actually show anything on the display.
Did you see the test animation on the display?
Next thing I did was to check out the upstream code (basically, your code without your changes), which is hardcoded to use I2C-2. Once I managed to get it to build (needed the same fix as above), it ran just fine.
I also fixed a buffer overflow that was an accident waiting to happen.
I applied some minimal changes to be able to use i2c-1, without having to go through the whole renaming process you undertook.
After that, the stand-alone application works fine on i2c-1 as well.
Then I copied the files thus updated into the project, and I got to the same point you were at:
crosswick Running project...
Segmentation fault
Makefile:524: recipe for target 'runide' failed
make: *** [runide] Error 139
(note this took me over 1 hour, and I could have saved all of that time if you had sent me the code ready to test).
The compiler actually gives you a warning that is the key to solve the issue:
/root/Bela/projects/ssd/render.cpp:17:1: warning: control reaches end of non-void function [-Wreturn-type]
1 warning generated.
This means that you are supposed to return a value from setup() and you are not. If the initialization goes well, you should return true.
So this works for me:
    oledTask = Bela_createAuxiliaryTask(oledTaskFunction, 1, "oledTask", NULL);
    Bela_scheduleAuxiliaryTask(oledTask);
For the avoidance of doubt, here is a repo containing a complete Bela project where this code is working correctly. Note that the program may take a while to stop after you hit stop, because the oled_main() function takes forever to return.
    Thanks @giuliomoro. First off, to address this:
    giuliomoro (note this took me over 1 hour, and I could have saved all of that time if you had sent me the code ready to test).
    I highly value your time and enormous help on this forum... I had doublechecked that the code worked on my Bela Mini before I uploaded it to github. I just checked again and these steps work for me:
    • download the .zip from https://github.com/crosswick/SSD1306-OLED-display-driver-for-BeagleBone
    • in the Bela interface, create a new C++ project called 'OLED_test_github'
    • use 'Upload file' to add the seven relevant .h and .c files to the project
    • with Terminal and ssh root@192.168.7.2, navigate to Bela/projects/OLED_test_github
    • run gcc *.c -o oled which returns a bunch of warnings but no errors;
    • run ./oled which makes the display connected to ic2-1 perform the test animations.
    My Bela Mini is running v0.3.6b, which I believe is the latest version.
    hmm that's interesting, I am wondering if you have a very very old Bela image (circa 2016)?
    Otherwise the second of these lines in I2C.c should break
    #include<linux/i2c.h>
    #include<linux/i2c-dev.h>
    Can you run grep v0 /etc/motd on the board? What does it return?
      giuliomoro This means that you are supposed to return a value from setup() and you are not. If the initialization goes well, you should return true.
      Great! it also works for me. I can now go on to test out these display functions from within PD; my plan is to use the customRender PD example project as a starting point.
      Thank you!
      giuliomoro Can you run grep v0 /etc/motd on the board? What does it return?
      Bela image, v0.3.6b, 23 October 2018
      giuliomoro and grep linux /root/Bela/projects/OLED_test_github/* ?
      /root/Bela/projects/OLED_test_github/I2C.c:#include<linux/i2c.h>
      /root/Bela/projects/OLED_test_github/I2C.c:#include<linux/i2c-dev.h>
      grep: /root/Bela/projects/OLED_test_github/build: Is a directory
      Binary file /root/Bela/projects/OLED_test_github/oled matches
      and what's the output of
      dpkg -l | grep i2c
      ii i2c-tools 3.1.2-3 armhf heterogeneous set of I2C tools for Linux
      I did use i2cdetect earlier to check whether the display module was connected... I don't recall exactly if I installed it or if it was already there. Maybe that makes a difference?
      right so the problem is on my board, where I have actually installed an extra package libi2c-dev, which causes the an error when including both files listed above. UOPS!
        🙂 let me know if I can be of any further assistance. I think it might be best for me to first work on the PD integration and after that write up a how-to.
          giuliomoro Giulio, thanks a lot for your assistance and attention! After the post 30 I was able to connect my bela on the OLED screen. crosswick will try to connect it on PD, and I'll try to connect on Sc now. we'll keep you update! I'm also up to write a documentation about it 🙂
          15 days later
          Good news - I've got an application running that can run independently from PD or SC, that translates incoming OSC messages into SSD1306 display commands.
          I've been heavily inspired by this conversation: https://forum.bela.io/d/497-how-do-i-get-two-programs-running-at-the-same-time
          Also I've read elsewhere on the forum that for starting up a second/background application like this, it should be possible to use a self-made run.sh script in the project directory.
          Two questions now that I'm having a challenge figuring out:
          - in run.sh, after starting up the OSC->OLED application, how do I resume the normal Run procedure for a PD or SC project?
          - is there a similar way to end/kill the application that is triggered by the Stop button in the IDE interface?
            Hey @crosswick & @giuliomoro
            Trying to get an OLED display to work based on the repo @giuliomoro posted in reply #30 (https://github.com/giuliomoro/bela-ssd1306) and I'm actually getting the following warnings and a runide error:
            Build finished
            In file SSD1306_OLED.c: [warning] passing 'const unsigned char *' to parameter of type 'const char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 33, line: 2419
            In file SSD1306_OLED.c: [warning] passing 'char [3]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 22, line: 2430
            In file SSD1306_OLED.c: [warning] passing 'const unsigned char *' to parameter of type 'const char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 30, line: 2442
            In file SSD1306_OLED.c: [warning] passing 'char [3]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 20, line: 2443
            In file SSD1306_OLED.c: [warning] passing 'char *' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 22, line: 2479
            In file SSD1306_OLED.c: [warning] passing 'char [4]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 26, line: 2657
            In file SSD1306_OLED.c: [warning] passing 'char [4]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 26, line: 2659
            In file SSD1306_OLED.c: [warning] passing 'char [4]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 26, line: 2661
            In file SSD1306_OLED.c: [warning] passing 'char [4]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 26, line: 2663
            In file SSD1306_OLED.c: [warning] passing 'char [2]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 24, line: 2686
            In file example_app.c: [warning] passing 'char [7]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 15, line: 261
            In file example_app.c: [warning] passing 'char [14]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 15, line: 286
            In file example_app.c: [warning] passing 'char [3]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 15, line: 293
            In file example_app.c: [warning] passing 'char [19]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 17, line: 377
            In file example_app.c: [warning] passing 'char [21]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 17, line: 379
            In file example_app.c: [warning] passing 'char [10]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign] column: 17, line: 382
            /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2419:33: warning: passing 'const unsigned char *' to parameter of type 'const char *' converts between pointers to integer types with different sign [-Wpointer-sign]
                 return print(strPtr, strlen(strPtr));
            /usr/include/string.h:394:35: note: passing argument to parameter '__s' here
            extern size_t strlen (const char *__s)
            /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2430:22: warning: passing 'char [3]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
            return print_str("\r\n");
            /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2417:38: note: passing argument to parameter 'strPtr' here
            short print_str(const unsigned char *strPtr)
            /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2442:30: warning: passing 'const unsigned char *' to parameter of type 'const char *' converts between pointers to integer types with different sign [-Wpointer-sign]
            n = print(strPtr, strlen(strPtr));
            /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2443:20: warning: passing 'char [3]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
             n += print_str("\r\n");
            /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2479:22: warning: passing 'char *' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
            return print_str(str);
            /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2657:26: warning: passing 'char [4]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
            return print_str("nan");
            /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2659:26: warning: passing 'char [4]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
            return print_str("inf");
            /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2661:26: warning: passing 'char [4]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
            return print_str("ovf");  // constant determined empirically
            /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2663:26: warning: passing 'char [4]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
            /root/Bela/projects/bela-ssd1306/SSD1306_OLED.c:2686:24: warning: passing 'char [2]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
            n += print_str(".");
            10 warnings generated.
            /root/Bela/projects/bela-ssd1306/example_app.c:261:15: warning: passing 'char [7]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
            print_str("scroll");
            /root/Bela/projects/bela-ssd1306/SSD1306_OLED.h:172:45: note: passing argument to parameter 'strPtr' here
            extern short print_str(const unsigned char *strPtr);
            /root/Bela/projects/bela-ssd1306/example_app.c:286:15: warning: passing 'char [14]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
            print_str("HELLO FELLAS!");
            /root/Bela/projects/bela-ssd1306/example_app.c:293:15: warning: passing 'char [3]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
            print_str("0x");
            /root/Bela/projects/bela-ssd1306/example_app.c:377:17: warning: passing 'char [19]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
            print_strln("deeplyembedded.org");
            /root/Bela/projects/bela-ssd1306/SSD1306_OLED.h:174:47: note: passing argument to parameter 'strPtr' here
            extern short print_strln(const unsigned char *strPtr);
            /root/Bela/projects/bela-ssd1306/example_app.c:379:17: warning: passing 'char [21]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
            print_strln("Author:Vinay Divakar");
            /root/Bela/projects/bela-ssd1306/example_app.c:382:17: warning: passing 'char [10]' to parameter of type 'const unsigned char *' converts between pointers to integer types with different sign [-Wpointer-sign]
            print_strln("THANK YOU");
            6 warnings generated.
            Running project...
            (Main)i2c-2: Bus Connected to SSD1306
            I also want to just confirm the correct pin connections and I2C bus to be using when using the files in the repo linked above. It seemed at the beginning of the thread that it made most sense to connect to the I2C1 bus, but I noticed in the terminal that it says "(Main)i2c-2: Bus Connected to SSD1306" - so I'm also wondering whether I'm connecting to the wrong bus.
            My breadboard is currently set up with a Bela Mini like this:
            Ground: P2_21
            VIN: P2_23
            SCL: P2_9
            SDA: P2_11
            Is this correct? Or should I be using I2C2? i.e.:
            Ground: P2_21
            VIN: P2_23
            SCL: P1_26
            SDA: P1_28
            Per @crosswick's note concerning the RST pin - I'm using the circuit noted here:
            http://community.axoloti.com/t/spi-i2c-oled-display/638/187
            Specifically - I've got a 10k resistor connected to the 3.3V rail, a 68nf cap connected to ground - I'm running a wire at the junction point on the terminal strip where the 10k resistor meets the 68nf cap to another terminal strip where a 100k resistor is tied to ground and I have a wire from that strip connected to the RST pin.
            Is this the correct way to deal with the RST pin? I've seen other examples where RST is connected to a GPIO pin - but there doesn't appear to be an RST pin noted in the code anywhere and it isn't mentioned in this thread explicitly either.
            Just trying to get this example code running so I can move on to some more fun visuals!
            Hi @kreiff, I also got those errors. It was explained to me by a buddy that this SSD1306 C library does things with unsigned chars which are not permitted in C++. There's apparently several different ways of solving this, amongst which macros - I solved it by editing the SSD1306_OLED.c and -.h files by simply removing the 'unsigned' bit in the relevant places.
            As far as the pinouts, I'm using the same you mention with P2_9 and P2_11.
            Here's a picture of my RST pin setup: (I'm using a dedicated I2S display now btw)
              @crosswick - Thanks for the quick reply!
              crosswick As far as the pinouts, I'm using the same you mention with P2_9 and P2_11.
              Thanks for confirming!
              crosswick Here's a picture of my RST pin setup: (I'm using a dedicated I2S display now btw)
              It's a little hard to see the connections - but this looks to be how the RST pin is set up on my breadboard.
              crosswick I solved it by editing the SSD1306_OLED.c and -.h files by simply removing the 'unsigned' bit in the relevant places.
              I tried using your approach from post 32 and downloaded your github repo. I also went through and removed the unsigned pre-cursors on the variables across the files. If I try running via SSH I do get this line in the terminal:
              But I don't have any output on the OLED...
              Alternatively - if I try running the render.cpp - I still get a ton of errors and the same runide error:
              @giuliomoro - What is runide Error 1?
                kreiff looks to me like there's something wrong with the physical connection to the display - that's when I get that runide error. I would suggest that you get a (bunch of, they're really cheap) I2C-only versions of this SSD1306 display to be sure.
                BTW like you've probably already seen, the unsigned-alteration is not yet in my github repo.
                  @kreiff can you run i2cdetect -y -r 1 ? Does the display show up at the expected address?
                  Thew runide failed message is a general message that the program stopped with an error
                  crosswick looks to me like there's something wrong with the physical connection to the display - that's when I get that runide error. I would suggest that you get a (bunch of, they're really cheap) I2C-only versions of this SSD1306 display to be sure.
                  I came to this conclusion last night as well. I think my OLED is dead. It was from Adafruit - so I figured I would just test their arduino library code to rule out the screen itself being bad...and that looks like the culprit. It doesn't even flicker following the Adafruit instructions exactly...
                  I bought a two pack of I2C-only (4-pin / no reset) OLEDs from Amazon - so I'll give this another go when they arrive.
