very strange problem I'm having...
for some reason the Bela all of a sudden had trouble communicating with PD over OSC. I wiped and reflashed the ssd but still not working (with the code above). I'm getting this error: no viable conversion from 'void (oscpkt::Message *, void *)' to 'std::function<void (oscpkt::Message *, const char *, void *)>' column: 31, line: 73
if i run \example Communication/OSC-pipe/render.cpp the code runs & i'm able to receive 'osc-setup' in PD, but the 'osc-setup-reply' is not received on the Bela, with PD reporting this error send: No route to host (65)
come to think of it, a few days ago, git (on Bela) was giving me a seg fault, so i tried to update/reinstall it using apt (which did not work)... hopefully I did not screw up anything .... 😳
any ideas?
