Can you run ifconfig
on the board (in the console at the bottom of the IDE) and show the results here? Also, run ping -c 1 192.168.7.1
in there and see what comes back
Bela C++ Code For 8x ADC to Serial
giuliomoro OK, this is what was returned:
root@bela ~/Bela# ifconfig
bash: line 6: ifconfig: command not found
and
root@bela ~/Bela# ping -c 1 192.168.7.1
PING 192.168.7.1 (192.168.7.1) 56(84) bytes of data.
64 bytes from 192.168.7.1: icmp_seq=1 ttl=64 time=1.09 ms
--- 192.168.7.1 ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 1.099/1.099/1.099/0.000 ms
sorry, instead of ifconfig do ip a
root@bela ~/Bela# ip a
1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
inet6 ::1/128 scope host
2: eth0: mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 4c:3f:d3:19:7a:91 brd ff:ff:ff:ff:ff:ff
3: wlan0: mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 1c:bf:ce:65:1a:fd brd ff:ff:ff:ff:ff:ff
4: usb0: mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether be:1a:d3:19:7a:93 brd ff:ff:ff:ff:ff:ff
inet6 fe80::bc1a:d3ff:fe19:7a93/64 scope link
5: usb1: mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether be:1a:d3:19:7a:96 brd ff:ff:ff:ff:ff:ff
inet6 fe80::bc1a:d3ff:fe19:7a96/64 scope link
violapwr if i run \example Communication/OSC-pipe/render.cpp the code runs & i'm able to receive 'osc-setup' in PD, but the 'osc-setup-reply' is not received on the Bela, with PD reporting this error send: No route to host (65)
also can you show the Pd patch?
@"giuliomoro"#p27136
PD:
this code is inside pd handshake
(shown in the 2nd image):
in pd can you use "find last error" and see where it points to?
giuliomoro PD does not seem to be able to identify the error source, strangely:
(in the back of my mind, I keep wondering if I messed up the system when trying to fix the git segmentation fault and need to flash the emmc (since flashing the SSD has not yet fixed it).... )
I don't think it's a bela problem though ...
can you try a simpler patch:
[connect 192.168.7.2 7562(
| [1 2 3 4(
[netsend -u -b]
do you get the same "no route to host" error?
giuliomoro Yes, same error. I received a successful connect (1
) when clicking connect 192.168.7.2 7562
. Clicking 1 2 3 4
resulted in the same error and a disconnect (0
Do you have a VPN enabled?
giuliomoro No... I also tried to turn off my macOS firewall, and received the same error in PD
I just tried the same experiment with my Bela Mini (and the simplified PD patch), and had the same result, which leads me to agree that the issue is perhaps not with the the Bela but on the computer end... I recently updated my macOS to 15.4... could it be a macOS issue?
Update:
I re-tried our PD test patch on my school computer & it worked without error (screenshot below). Also, more complex program (from a year back, above) is working as well. The school machine is macOS 14.7.5. So perhaps it's a macOS thing?
violapwr I just tried the same experiment with my Bela Mini (and the simplified PD patch), and had the same result, which leads me to agree that the issue is perhaps not with the the Bela but on the computer end... I recently updated my macOS to 15.4... could it be a macOS issue?
I don't know what they are doing that makes this stop working ... can you access the Bela IDE at 192.168.7.2?
giuliomoro yes, if I access 192.168.7.2 in my browser, the IDE loads fine
giuliomoro yeessss that worked!! amazing detective work!! thank so much for the help
