Hi after a long gap! I have a Bela Mini and I cannot get the bela/local to work on my MacBook Air. It works fine with the larger Bela board. Should it simply recognise a different board and run? The Bela Mini does have the 'heartbeat' flashing of its blue LED.
Updating Bela ide failed
It should just work. Did you change any of the network settings for this device in the System Preferences->Network panel? What version of the operating system are you on?
o/s is Monterey 12.1 on a Macbook Air. It still is no coming up.
Tried a Beast and it works. Is there something different one has to do for the Mini?
david I have a Bela Mini
when from? You'll need an image more recent than 20/June/2020 for it to work on macos > 10.15. If you have an old image on your BelaMini, you may need to flash a new one from here https://github.com/BelaPlatform/bela-image-builder/releases/tag/v0.3.8f
david Hi. Today I have the opposite issue - the MINI does boot but the BBB does not. I have tried rebooting the Mac, going to http://bela.local (which works for the MINI), and 192.168.6.2 or 192.168.7.2 a number of times with no success. Am I forgetting something?
david the BBB does not [boot]
Does that mean you see no flashing lights at all? Or is it that you see the "heartbeat" pattern but the network interface does not show up on the host? Does /Volume/BELABOOT
appear?
Sorry should have indicated that I have a steady and flashing blue lights on the Bela board (I have just tried again and it is the same). What is puzzling me is that the Bela Mini board comes up OK but the Bela BBB board does not. I am not familiar with /Volume/BELABOOT sorry.
david I am not familiar with /Volume/BELABOOT sorry.
If you open a finder window, on the left hand side you should see "Locations":
do you see BELABOOT there?
Additionally, can you post the output you get running each of the following commands in the terminal after the board has booted for more than one minute?
ls /dev/tty.*
ifconfig
system_profiler SPUSBDataType
ioreg -p IOUSB -w0 -l
Is there a program set to run on boot on the board?
Yes there is a BELABOOT in the finder window
There is a bootable program on the board which is working in stand-alone mode
Here are the terminal outputs (rather long ..):
dmh8@Davids-Air-10 ~ % ls /dev/tty.*
/dev/tty.Bluetooth-Incoming-Port /dev/tty.usbmodem__bela__6
dmh8@Davids-Air-10 ~ % ifconfig
inet6 ::1 prefixlen 128
stf0: flags=0<> mtu 1280
options=400<CHANNEL_IO>
ether d0:81:7a:ac:9b:e0
inet6 fe80::454:f321:d4a9:a347%en0 prefixlen 64 secured scopeid 0x4
inet 192.168.8.106 netmask 0xffffff00 broadcast 192.168.8.255
inet6 fda8:e544:6171:4300:1806:6fe3:d011:14e1 prefixlen 64 autoconf secured
media: autoselect
status: active
ether 82:18:47:e5:fa:00
status: inactive
Configuration:
ipfilter disabled flags 0x0
ifmaxaddr 0 port 5 priority 0 path cost 0
media: <unknown type>
status: inactive
p2p0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 2304
ether 02:81:7a:ac:9b:e0
media: autoselect
status: inactive
ether be:2c:ed:4a:32:0d
inet6 fe80::bc2c:edff:fe4a:320d%awdl0 prefixlen 64 scopeid 0x8
media: autoselect
status: active
inet6 fe80::bc2c:edff:fe4a:320d%llw0 prefixlen 64 scopeid 0x9
media: autoselect
status: active
inet6 fe80::fb55:c84d:976d:844b%utun0 prefixlen 64 scopeid 0xa
inet6 fe80::d6e:d5e6:78be:588b%utun1 prefixlen 64 scopeid 0xb
inet6 fe80::ce81:b1c:bd2c:69e%utun2 prefixlen 64 scopeid 0xc
utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1400
en9: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether be:1a:b7:ce:8e:3a
media: autoselect (none)
status: inactive
dmh8@Davids-Air-10 ~ % system_profiler SPUSBDataType
2022-03-02 15:07:46.145 system_profiler[2739:77219] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
2022-03-02 15:07:46.146 system_profiler[2739:77219] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
USB:
USB 3.0 Bus:
Host Controller Driver: AppleUSBXHCIWPT
PCI Device ID: 0x9cb1
PCI Revision ID: 0x0003
PCI Vendor ID: 0x8086
BRCM20702 Hub:
Product ID: 0x4500
Vendor ID: 0x0a5c (Broadcom Corp.)
Version: 1.00
Manufacturer: Apple Inc.
Location ID: 0x14300000
Bluetooth USB Host Controller:
Product ID: 0x828f
Vendor ID: 0x05ac (Apple Inc.)
Version: 1.50
Location ID: 0x14330000
Bela:
Product ID: 0x0104
Vendor ID: 0x1d6b (The Linux Foundation)
Version: 1.01
Serial Number: __bela__
Speed: Up to 480 Mb/s
Manufacturer: Augmented Instruments Ltd
Location ID: 0x14100000 / 18
Current Available (mA): 500
Current Required (mA): 500
Extra Operating Current (mA): 0
Media:
File-Stor Gadget:
Capacity: 70.6 MB (70,631,936 bytes)
Removable Media: Yes
BSD Name: disk2
Logical Unit: 0
Partition Map Type: Unknown
S.M.A.R.T. status: Verified
USB Interface: 4
dmh8@Davids-Air-10 ~ % ioreg -p IOUSB -w0 -l
+-o Root <class IORegistryEntry, id 0x100000100, retain 17>
| "IOKitBuildVersion" = "Darwin Kernel Version 21.3.0: Wed Jan 5 21:37:58 PST 2022; root:xnu-8019.80.24~20/RELEASE_X86_64"
| "OS Build Version" = "21D62"
| "OSKernelCPUSubtype" = 3
| "OSKernelCPUType" = 16777223
| "OSPrelinkKextCount" = 18
| "IORegistryPlanes" = {"IOPower"="IOPower","IOService"="IOService","IO80211Plane"="IO80211Plane","IOUSB"="IOUSB","CoreCapture"="CoreCapture","IOACPIPlane"="IOACPIPlane","IODeviceTree"="IODeviceTree"}
| "IOConsoleLocked" = No
| "IOConsoleUsers" = ({"kCGSSessionOnConsoleKey"=Yes,"kCGSSessionLoginwindowSafeLogin"=No,"kSCSecuritySessionID"=100003,"kCGSessionLongUserNameKey"="David M Howard","kCGSSessionUserIDKey"=501,"kCGSSessionSystemSafeBoot"=No,"kCGSSessionUserNameKey"="dmh8","kCGSSessionIDKey"=257,"kCGSSessionGroupIDKey"=20,"kCGSessionLoginDoneKey"=Yes,"kCGSSessionAuditIDKey"=100003})
| "IOKitDiagnostics" = {"Instance allocation"=17308552,"Container allocation"=7099433,"Pageable allocation"=1080582144,"Classes"={"IONDRVFramebuffer"=0,"AppleSNBFBUserClient"=0,"IGAccelCommandQueue"=15,"IOHIDEventServiceFastPathUserClient"=0,"IONaturalMemoryCursor"=0,"IOKitDiagnosticsClient"=0,"IOAudioClientBufferSet"=0,"DspFuncBuzzKill"=0,"AppleUSBDiagnostics"=0,"IOUSBHostHIDDevice"=0,"AppleHDAMikeyInternalCS4208"=1,"AppleUSBRequest"=1,"AppleUSBXHCIIsochronousRequestPool"=1,"IOEventLink"=0,"IGAccelSharedUserClient"=30,"AppleASMedia1042USBXHCICommandRing"=0,"AppleHDATDM_Codec"=0,"IOUSBMassStorageDriverRequestTimer"=0,"IOUserBlockStorageDevice"=0,"IOHDACodecDevice"=2,"AppleAHCIWorkLoop"=1,"IOThunderboltDeficitCommandQueue"=1,"IORegistryEntry"=91,"IOUSBMassStorageUASDriver"=0,"AppleAHCIPort"=1,"AppleHDAWorkLoop"=2,"IORTC"=1,"IOHIDevice"=0,"IOPCIEventSource"=0,"AppleThunderboltNHIType4"=0,"com_apple_driver_AppleUSBCardReaderInterfaceNub"=0,"IOThunderboltAbstractMicro"=1,"DspFuncUserClient"=0,"IO80211DriverCommandDescriptor"=0,"AppleHDAHardwareConfigDriverLoader"=0,"AppleSmartBatteryManager"=1,"IOPMGR"=0,"AppleHDATDM_CS42L81"=0,"IOThunderboltXDPropertiesDirectory"=2,"IOMemoryCursor"=1,"IOBreaker"=0,"AppleIntelFramebuffer"=3,"AppleUSBUserHCIDevice"=0,"AppleHDAFunctionGroup_80862807"=0,"IOUSBLowLatencyCommandLegacy"=0,"AppleThunderboltIPReceiveCommand"=0,"AppleUSBUserHCITransferQueue"=0,"AppleUSB20HubPort"=3,"AppleHIDKeyboardEventDriver"=0,"AIDCircularBufferShared"=0,"AppleUSB20KeyboardHub"=0,"AppleThunderboltNHIReceiveRingManager"=1,"EFIData"=92,"AppleUSBXHCIPort"=2,"IOAccelCommandQueue"=1,"DspFunc4ChOutput"=0,"com_apple_driver_AppleUSBCardReaderUMC"=1,"IGRangeAllocator"=34,"IOSurfaceSharedEventNotification"=0,"AppleHDAFunctionGroupWM8800"=0,"AppleKeyStoreUserClient"=21,"HDCPCLASS"=0,"IOSMBusRequest"=0,"IntelFBClientControl"=1,"IOThunderboltSwitchType1"=0,"IOSkywalkPacket"=1,"DspFuncBeamFormer"=0,"hv_vmx_vcpua_t"=0,"SoundflowerEngine"=2,"CSRBluetoothHostControllerUSBTransport"=1,"AppleUpstreamUserClientDriver"=3,"IOHIDResourceQueue"=1,"IOStorage"=4,"AppleACPILid"=1,"IOPMServiceInterestNotifier"=123,"IOAccelSegmentResourceList"=0,"AppleUSBRequestPool"=2,"IOSerialStreamSync"=2,"IOHIDConsumer"=0,"IO80211AWDLMulticastPeer"=1,"AppleUSBHostCompositeDevice"=1,"IOAHCIBlockStorageDevice"=1,"IOThunderboltXDPropertiesEntry"=12,"IOHIDClientData"=4,"IOSharedInterruptController"=1,"IOBluetoothMemoryDescriptorRetainer"=0,"IOGraphicsWorkLoop"=2,"hv_vmx_vm_t"=0,"AppleHSSPIController"=1,"AppleHDATDMBusManagerCS4208"=0,"IGAccelVideoContextMedia"=0,"IOTimeSyncClockManagerUserClient"=1,"OSSerializer"=46,"IOUserEthernetResourceUserClient"=0,"AppleAHCIWatchdogTimer"=1,"IOThunderboltConfigMultiReadCommand"=1,"IOPCIMessagedInterruptController"=1,"OSCollection"=5,"IOThunderboltSet"=29,"IOUSBDeviceUserClientV2"=1,"SmbusHandler"=1,"AppleHDAEngineOutput"=1,"AIDReporters"=0,"AIDInterface"=0,"IOTimeSyncUnicastUDPv4PtPPort"=0,"_IOServiceNullNotifier"=1,"IOUserNetworkRxCompletionQueue"=1,"IOSkywalkMemorySegment"=69,"com_apple_driver_eficheckuserclient"=0,"IOBluetoothHCIUserClient"=1,"hv_vioapic_t"=0,"AppleUSB20InternalIntelHubClient"=0,"com_apple_driver_pm_cpu_reporter"=1,"AppleMultitouchEventDriverV2Wrapper"=1,"IOTimeSyncPortManager"=0,"AppleDisplay"=0,"IONetworkStackUserClient"=1,"AppleAPFSUserClient"=0,"_IOServiceNotifier"=612,"AppleHDAFunctionGroupGT216"=0,"IOInterleavedMemoryDescriptor"=0,"AppleUSBLegacyInterfaceUserClient"=0,"AppleUSBUserHCIResources"=1,"IOServiceStateNotificationEventSource"=0,"AppleGraphicsDevicePolicy"=1,"IGAccel2DContext"=3,"AppleHDAFunctionGroupCS4208"=1,"IOSkywalkEthernetInterface"=2,"IGScheduler"=1,"IOTimeSyncEthernetInterfaceAdapter"=0,"DspFuncVolume_4ch"=0,"AppleUSBXHCILPTCommandRing"=1,"IOUSBHostDevice"=14,"AppleHSBluetoothInterface"=0,"IOSubMemoryDescriptor"=6,"AppleUSBRequestCompleter"=1,"IOThunderboltXDPropertiesCache"=1,"IOSKArena"=13,"IOAVBNubUserClient"=0,"AppleThunderboltNHIIntelPCI"=1,"IOAHCIPortInterface"=1,"IOThunderboltXDomainLink"=0,"AppleFDEKeyStoreUserClient"=0,"AppleMultitouchTrackpadHIDEventDriver"=1,"IOServiceUserNotification"=503,"IOThunderboltConfigPrepareToSleepCommand"=1,"IO80211ThroughputCache"=0,"AppleUSBHostResourcesTypeCBPC"=0,"IO80211PacketDescriptor"=4096,"DspFuncPreGain"=0,"IOThunderboltControllerType4"=0,"IOSkywalkNetworkBSDClient"=2,"IOHIDReportElementQueue"=0,"AirPort_BrcmNIC_InputQueue"=1,"IOAccelDevice2"=1,"com_apple_filesystems_apfs"=0,"IGHardwareBlit3DContext"=16,"DigitizerTransducer"=0,"IOAccelCLContext2"=0,"IOBluetoothL2CAPInformationFrameMemoryBlock"=0,"AppleUSBUserHCITransferStructPool"=0,"AppleHDAController"=2,"IOMbufMemoryCursor"=1,"IOSKRegionMapper"=6,"IOSKMemoryArray"=0,"AppleThunderboltDPAdapterFamily"=1,"IOCPU"=1,"IOAccelMTLEvent2"=0,"IOAccelDisplayMachine"=1,"IOAccelEventMachineFast2"=1,"OSAction_IOUserNetworkEthernet__DataAvailable"=0,"AppleACPIEventPoller"=1,"IO80211ActionFrameDescriptor"=0,"IONetworkStack"=1,"DspFuncBiquad"=0,"CCDataPipeBlob"=0,"IOTimeSyncNetworkPortUserClient"=0,"ApplePlatformEnabler"=1,"IOThunderboltTransmitQueue"=1,"IOSlaveMemory"=0,"IOSCSIPeripheralDeviceType07"=0,"ACMKeybagKernelService"=0,"AppleHDAFunctionGroupATI_RS710"=0,"AppleUSBECMDataNC"=0,"ACMRestrictedModeAnalyticsKernelService"=1,"IO80211Interface"=1,"AppleUSBUserHCIIsochronousTransferQueue"=0,"IOSimpleReporter"=286,"AppleUSBXHCILPTHB"=0,"IOModemSerialStreamSync"=0,"AppleHDATDM_CS42L83"=0,"IOUSBMassStorageCBIDriverNub"=0,"IOHDIXControllerUserClient"=0,"com_apple_AppleFSCompression_AppleFSCompressionTypeZlib"=1,"AppleHDATDMAmpMAX98706"=0,"DspFunc2Dot2Crossover"=0,"AppleAHCIEventSource"=1,"AppleThunderboltNHIType2"=1,"IOUSBInterface"=1,"IOAccelChannel2"=1,"CCFaultReporter"=1,"AppleUSBLegacyRoot"=1,"IO80211EventSource"=1,"AppleHDAPathControl"=8,"AGPMClient"=0,"AppleHDATDMAmpTAS5764L"=0,"IOSCSIPrimaryCommandsDevice"=1,"IOTimeSyncDomainUserClient"=0,"IOAccelEventFence"=0,"IOAHCIPollerInterface"=1,"AppleSMBusControllerMCP"=0,"AppleMCCSControlGibraltar"=0,"IOThunderboltConfigWriteCommand"=3,"IOHIDProviderPropertyMerger"=0,"IOUSBDevice"=1,"IOGDiagnosticUserClient"=0,"IOThunderboltCommand"=5,"IOAccelVidMemory"=0,"AppleSEPControl"=0,"AppleHDAEngineInput"=1,"IOServiceNotificationDispatchSource"=0,"IOThunderboltCallbackEventSource"=5,"IOUSBMassStorageResourceUserClient"=0,"IOAccelDisplayPipeTransaction2"=2,"IOSkywalkNetworkInterface"=1,"IOHIDKeyboard"=0,"IOTimeSyncEdgeTimeCaptureUserClient"=0,"AIDQueueEventSourceWorkItem"=0,"IOACPIPlatformDevice"=162,"IOUserService"=2,"AppleSATAExpress"=0,"_IOServiceInterestNotifier"=149,"AppleUSBHostRequestCompleter"=14,"IOBluetoothLocalUtilityEventSource"=0,"IntelAccelerator"=1,"IOFramebufferI2CInterface"=3,"IOPowerConnection"=111,"IOFBController"=1,"AppleThunderboltIPTransmitCommand"=0,"SCSITaskUserClient"=0,"IOWatchDogTimer"=0,"IOThunderboltConfigPollQuadletCommand"=0,"IOEventSource"=22,"IOUserNetworkTxCompletionQueue"=1,"IODMACommand"=85,"IOMachPort"=6316,"IOPMinformeeList"=164,"IO80211AsyncUserClientParameters"=1,"IOThunderboltReceiveQueue"=1,"IO80211LinkRecovery"=0,"AppleCredentialManager"=1,"AppleUSB30XHCITypeCPort"=0,"MEIClientList"=1,"AppleACPIPowerResource"=0,"CCLogStream"=5,"IOThunderboltXDPropertiesImmediateValue"=8,"IOPCIHostBridgeData"=1,"AGDPUserClient"=1,"AppleUSBHostControllerIsochEndpoint"=0,"IOHIDEvent"=0,"IO80211AsyncEventUserClient"=1,"DspFuncNoiseCanceller"=1,"IOAccelTask"=1,"IOAccelGLContext2"=1,"OSDictionary"=18059,"AppleUSB20InternalHub"=1,"AppleMultitouchMouseHIDEventDriver"=0,"IGInterruptBridge"=1,"AppleUSBXHCIParkingCommandRing"=1,"IOHDACodecDeviceUserClient"=0,"AppleUSBHostBulkHIDDevice"=0,"IOAGPDevice"=0,"IODisplayWrangler"=1,"IGStolenMemoryPool"=1,"AppleFDEKeyStore"=1,"AppleUSB20InternalIntelHub"=0,"IOUSBMassStorageDriverUFIDevice"=0,"AppleUSBIORequest"=70,"IOThunderboltConfigXDomainROMChangedRequestCommand"=0,"_IOUserServerCheckInCancellationHandler"=0,"IOUSBPipeV2"=0,"DspFuncFIRdirect"=0,"AppleUSBHostLegacyClient"=14,"IOUSBMassStorageResource"=1,"IO80211HistogramReporter"=0,"AppleLMUClient"=3,"AppleHDATDMSinkDevice"=0,"IOTimeSyncUnicastUDPv6PtPPort"=0,"IGAccelSurface"=9,"IOAccelKernelMappedMemory"=69,"Dont_Steal_Mac_OS_X"=1,"IOAudioTimeIntervalFilterIIR"=0,"IOHIDEventSource"=4,"GTraceBuffer"=4,"OSSet"=4237,"AppleUSBUserHCIUserClient"=0,"AppleIntelPanel"=1,"IOAccelBlockFence"=0,"DspFuncCalibrationEQ"=0,"AppleUSB30XHCICardReaderPort"=1,"IOAudioEngineUserClient"=33,"AGPMHeuristic4"=0,"IOPCIHostBridge"=1,"HDCP2CLASS"=0,"AppleHDAWidget_80862805"=0,"DspFuncChOutput"=0,"IGSemaphoreWaitBufferQueue"=60,"AppleAHCIDiskDriver"=1,"IOCommand"=112,"AppleHDAWidgetAD1984"=0,"AppleUSB30GLHub"=0,"IOTimeSyncTranslationMach"=1,"IOAudioTimerEvent"=0,"CCDataPipe"=3,"DspPatchPoint"=32,"IOSCSIProtocolInterface"=2,"AppleTDMType00"=0,"IOTimeSyncNanosecondSnapshotService"=0,"AppleUSBXHCIAR"=0,"IOPlatformIO"=0,"IOAVBNub"=1,"IOBluetoothGamepadHIDDriver"=0,"com_apple_driver_AppleUSBCardReaderSBC"=1,"AppleHDAFunctionGroupALC885"=0,"IGAccelVideoContextMain"=0,"AppleHDAFunctionGroup"=1,"AppleHDAFunctionGroupExternalControl"=1,"IOGUIDPartitionScheme"=1,"AppleHDANode"=2,"IOUSBMassStorageUFIDriverNub"=0,"OSCollectionIterator"=14,"AppleEFIRuntime"=1,"IOFilterScheme"=0,"AppleMCCSIOController"=6,"AppleUSBHostResources"=1,"AppleAHCIRequestTimer"=1,"IOApplePartitionScheme"=0,"CamelliaTcon2"=0,"IOSurfaceRootUserClient"=37,"IOSkywalkInterface"=1,"IO80211PeerExtendedStats"=0,"IODisplay"=1,"IOTimeSyncTranslationPMGR"=0,"TDMConfig"=0,"IOHIDAsyncReportQueue"=0,"IOSkywalkPacketQueue"=5,"IOUserEthernetResource"=1,"IOThunderboltSwitch"=1,"IOBasicOutputQueue"=1,"AppleHDACodec"=1,"AppleUSBHostControllerListElement"=0,"AppleSEPIntelIOP"=0,"IOThunderboltConfigReadCommand"=4,"IOAccelSharedUserClient2"=1,"AppleGPUWranglerClient"=4,"IOFramebufferSharedUserClient"=1,"IOUSBControllerIsochListElement"=0,"IOPacketQueue"=1,"IOHITabletPointer"=0,"IGAccelDisplayPipe"=3,"IOAVBAudioLoader"=0,"IO80211PeerBssSteeringManager"=1,"IOUserClient"=41,"AppleUSBHostControllerIsochListElement"=0,"AppleUSB30HubPort"=0,"IOHIDEventSystemUserClient"=1,"AppleHDAWidgetFactory"=0,"IOHDIXHDDrive"=0,"DIDeviceRequestPool"=0,"AGPM"=1,"AppleSystemPolicy"=1,"IOSurfaceDescriptor"=0,"AppleUSB30Hub"=0,"IO80211AWDLPeer"=0,"IOTimeSyncWiFiControllerAdapter"=0,"AppleIPDormancyHandler"=1,"IOAccelEventMachine2"=1,"HIDSPIQueueEventSource"=3,"IOSlaveRelayCommandPool"=0,"IGGarbageCollector"=1,"DspFunc3ChOutput"=0,"IOAccelBufferMemoryDescriptorPool2"=1,"AppleMCCSControlModule"=3,"IO80211SimpleReporter"=23,"IOAccelContextEventFence"=0,"ACMKernelService"=5,"IOUSBHostPipe"=1,"IOPolledFilePollers"=1,"CoreAnalyticsTestUserClient"=0,"AppleHSSPINub"=1,"IO80211String"=0,"IOHDIXHDDriveOutKernelUserClient"=0,"IOUSBNotification"=0,"AppleHDAWidgetSTAC9220"=0,"IOEthernetAVBController"=0,"IOThunderboltSwitchI2CCommandQueue"=1,"AppleUSBUserHCIPipe"=0,"AppleIntelPAVPEventSource"=1,"AppleHDAMikeyInternal"=1,"IOSkywalkRxSubmissionQueue"=1,"IOSkywalkNetworkKDPPoller"=0,"AppleUSBHostDeviceUserClient"=2,"IOUSBInterfaceUserClient"=1,"IOAccelGPURestartReport2"=0,"IOFramebufferParameterHandler"=3,"IOSurface"=313,"IOGatedOutputQueue"=16,"IOThunderboltLinkController"=2,"AppleUSBRootHubDevice"=1,"com_apple_filesystems_lifs"=1,"AppleHDAFunctionGroupMCP89"=0,"com_cycling74_driver_SoundflowerDevice"=1,"IOReportLegend"=0,"AppleTDMControlLUN"=0,"IOTimeSyncPseudoStreamingInterfaceAdapter"=0,"IOThunderboltConfigCompareSwapCommand"=0,"AppleUSBXHCIEndpoint"=13,"IOSurfaceMTLSharedEventFence"=0,"IOHIDEventQueue"=0,"IOAccelShared2"=30,"AppleIntelUSBXHCICommandRing"=0,"AIDService"=0,"IOSurfaceSendRight"=0,"AppleAPICInterruptController"=1,"IOSkywalkNetworkController"=0,"IOTimeSyncService"=1,"AppleSMC"=1,"AppleXsanDriver"=0,"IOCommandPool"=11,"IOBlockStorageDevice"=2,"IGHardwarePerProcessPageTable64"=31,"AGPMHeuristic"=1,"IOPMrootDomain"=1,"IOAccelFenceMachine"=1,"AppleEffaceableStorage"=0,"AppleUSBNetworkingCommandPool"=0,"IO80211VirtualInterfaceNamer"=1,"IOUSBDeviceUserClient"=1,"OSUserMetaClass"=419,"KextAuditUserClient"=1,"AirPort_BrcmNIC_Interface"=1,"IOI2CInterfaceUserClient"=0,"IOThunderboltDispatchCallback"=1,"AppleHDAFunctionGroupAD1984"=0,"DspFuncControlFreak"=0,"AppleThunderboltDPInAdapter"=1,"IOHDIXCommandQueue"=0,"_IOOpenServiceIterator"=0,"IOCommandGate"=1011,"EventElementCollection"=0,"DspParameter"=106,"IOWorkGroup"=0,"AppleUSBNetworkingHostCommandPool"=0,"IOUSBMassStorageDriver"=2,"IOPMRequestQueue"=2,"IOThunderboltSwitchType6"=0,"IOSkywalkRxCompletionQueue"=1,"AppleECSMBusController"=1,"CamelliaTcon1"=0,"IOBlockStorageDriver"=3,"IOWatchdogx86"=1,"DspFuncThermalSpeakerProtection"=0,"AppleHDAWidgetALC262"=0,"IOHIDWorkLoop"=1,"IOThunderboltArray"=5,"IOBlockStorageServices"=2,"AirPort_BrcmNIC_P2PInterface"=2,"AppleACPIACAdapter"=1,"IOUSBInterfaceIterator"=0,"AppleThunderboltPCIDownAdapter"=4,"IODTPlatformExpert"=1,"AppleHDAControllerUserClient"=0,"IOBluetoothMemoryBlock"=0,"IOMbufBigMemoryCursor"=0,"IOTimeSyncLocalClockPort"=0,"AppleUSBXHCICommandRing"=1,"AppleUSBXHCIIsochronousEndpoint"=0,"AppleUSBXHCIInterrupter"=1,"IOSlaveMemoryBuffer"=0,"IOAppleLabelScheme"=0,"IOBluetoothHostControllerTransport"=1,"AppleUSBXHCIPCI"=1,"BroadcomBluetooth20703USBTransport"=1,"IO80211Peer"=1,"RootDomainUserClient"=98,"DspFuncSplineLimiter"=1,"IOThunderboltTimerCommand"=5,"AppleAPFSContainer"=1,"AppleThunderboltIPMSMInterface"=0,"AppleSEPDiscovery"=0,"DspFuncMozartCompressorDualBand"=1,"IONDRV"=0,"AppleHSBluetoothNub"=0,"AppleSATAExpressPort"=0,"IOPCIDevice"=26,"IOThunderboltConfigCommand"=9,"AppleUSB20XHCIPort"=3,"IOBluetoothInactivityTimerEventSource"=0,"IGAccelTask"=31,"IGAccelStatistics"=1,"IOAccelMemoryAllocator2"=0,"OSNumber"=46845,"AIDUserClientLogger"=0,"IOThunderboltConfigXDomainPathTeardownRequestCommand"=0,"AppleThunderboltNHITransmitRingManager"=1,"AppleThunderboltNHIMemoryBlock"=0,"IOThunderboltIECSNub"=0,"IOAHCIDiskQueueManager"=1,"CCFaultReport"=0,"AppleHDAFunctionGroupExternalControl_VirtualGPO"=0,"AppleUSBUserHCIPort"=0,"IOTimeSyncTimedEdgeGeneratorUserClient"=0,"IOGDiagnosticGTraceClient"=1,"AppleUSBXHCI"=1,"IOTimeSyncIntervalFilter"=0,"IOTimeSyncNetworkPort"=0,"MEIEventSource"=1,"AppleThunderboltNHITransmitRing"=12,"AppleUSBHostPacketFilter"=0,"AppleIntelCNLUSBXHCI"=0,"ACMFirstResponderKernelService"=1,"AppleHDAFunctionGroup_1002AAA0"=0,"IOThunderboltConfigErrorCommand"=1,"IOTimeSyncUnicastLinkLayerPtPPort"=0,"AppleIntelPchSeriesAHCIPort"=0,"IOHIDKeyboardDevice"=0,"IOThunderboltEEPROM"=2,"IOUserNotification"=2,"IOHDAStream"=2,"AppleGPUWrangler_GPUPostStartWorkItem"=0,"AppleUSBXHCILPT"=1,"com_apple_AppleFSCompression_AppleFSCompressionTypeDataless"=1,"AGPMHeuristic3"=0,"IOSurfaceSharedEventListener"=0,"IOThunderboltControlPathListener"=5,"AppleUSBXHCITransferRing"=13,"AppleThunderboltNHI"=1,"AppleAPFSSnapshot"=1,"IOWrappedMemoryDescriptor"=0,"AppleHDAFunctionGroupATI_Broadway"=0,"IOThunderboltHopSet"=18,"IOThunderboltXDPropertiesLeafData"=0,"IOUSBHubDevice"=0,"AppleUSBHostDeviceIdler"=3,"IOPMWorkQueue"=1,"IOTimeSyncFilteredService"=0,"AppleUSBACMData"=1,"AIDImageDownloader"=0,"AIDEventLogger"=0,"AppleSMBusControllerUserClient"=0,"AppleUSB30XHCIPort"=3,"IOGuardPageMemoryDescriptor"=0,"IOThunderboltTimerCommandQueue"=1,"IOSlaveProcessorUSBHostRelay"=0,"IODeblocker"=0,"AppleRTC"=1,"AppleUSBXHCISPT"=0,"IOTimeSyncWiFiInterfaceAdapter"=0,"AppleIntelSPIDevice"=1,"AppleThunderboltIPControlCommand"=0,"IOAccelDeviceShmem"=39,"X86PlatformShim"=1,"IOSharedDataQueue"=6,"IGCanonicalRangeAllocator"=30,"IOSyncer"=0,"AppleGPUWrangler_WorkItem"=0,"AppleDeviceManagementHIDEventService"=0,"AppleThunderboltIPConnection"=0,"IGHardwareRingBuffer"=3,"AppleUSBECMData"=0,"IORangeAllocator"=3,"HDCP1CLASS"=0,"IOKitRegistryCompatibility"=1,"IOMediaBSDClient"=7,"OSBoolean"=2,"AppleSEPCommand"=0,"OSAction"=10,"AppleUSBXHCIRequest"=31,"IOAccelSubmitter2"=2,"OSAction_IOHIDEventService__SetUserProperties"=0,"IOWorkQueue"=1,"ApplePlatformEnablerUserClient"=0,"CoreAnalyticsUserClient"=1,"DspFuncAutoGainControl"=0,"AppleACPIInterruptLink"=0,"LogManagerDevice"=3,"IOHIDInterface"=4,"IOPCI2PCIBridge"=11,"IOAppleBluetoothHIDDriver"=0,"IOSurfaceRoot"=1,"com_apple_BootCache"=1,"AppleHDA8086_9D70Controller"=0,"IOUSBInterfaceUserClientV3"=2,"IOMapper"=2,"IOUSBMassStorageUFIDriver"=0,"IOUSBHostStream"=0,"IOHIDSystem"=1,"IOThunderboltConfigWriteQuadletCommand"=2,"IOHIDDeviceElementContainer"=4,"AIDReporter"=0,"IOAccelRangeAllocator"=0,"IOUSBController"=1,"AppleHIDKeyboardEventDriverV2"=1,"com_apple_driver_eficheck"=1,"IOAccelFIFOChannel2"=1,"AppleHDAFunctionGroupATI_RS730"=0,"AppleHDAWidgetATI_Park"=0,"_IOServiceStateNotification"=0,"IOThunderboltSwitchType4"=0,"AppleBacklightParameterHandler"=1,"AppleACPICPU"=4,"AppleMCCSControlFamily"=1,"IONetworkInterface"=1,"KernelRelay"=0,"IOThunderboltConfigCMOverrideCommand"=1,"IGFence"=0,"IOBluetoothACLMemoryDescriptor"=0,"IOHIDOOBReportDescriptor"=0,"AppleASMediaUSBXHCIStreamingEndpoint"=0,"IONetworkUserClient"=0,"AppleThunderboltDPOutAdapter"=0,"IOReportUserClient"=4,"AppleUserHIDEventService"=0,"DspFunc2To4Splitter"=0,"IOThunderboltConfigXDomainResponseCommand"=6,"AppleUSBXHCIPipe"=13,"DspFuncDRC"=0,"IOServiceStateNotificationDispatchSource"=0,"IOHDACodecFunction"=1,"IOSkywalkLegacyEthernet"=1,"IOCharacterDevice"=3,"IOUSBNub"=2,"AppleUSBHostMergeProperties"=1,"_IOConfigThread"=0,"IOSkywalkRing"=4,"AppleMultitouchHIDEventDriverV2"=1,"AppleHDAEngine"=2,"AppleUSBXHCIARRequest"=0,"IOTimeSyncClockManager"=1,"IO80211FlowQueueDatabase"=3,"AppleHDAWidgetGK10X"=0,"IGHardwareContext"=22,"IGHardwareResolveContext"=24,"AppleUSBHostController"=1,"IODiskImageBlockStorageDeviceOutKernel"=0,"AppleMultitouchHIDService"=0,"IOThunderboltConfigModifyQuadletCommand"=0,"IOTimeSyncFDPtPPort"=0,"MEIDriverIOEventSource"=3,"AppleSEPXART"=0,"IOUSBMassStorageDriverUFIStorageServices"=0,"IOThunderboltPath"=0,"IOCPUInterruptController"=1,"AppleHDAFunctionGroupFactory"=0,"AppleThunderboltHAL"=1,"IO80211P2PInterface"=1,"CCLogPipeUserClient"=0,"IOUserServer"=7,"IOSkywalkKernelPipeBSDClient"=0,"AppleHDAFunctionGroupALC262"=0,"AppleIPAppenderUserClient"=0,"CoreAnalyticsHub"=1,"PMHaltWorker"=0,"AppleHDATDMDevice"=0,"IGHardwarePageTable"=2,"AppleMCCSUserClient"=0,"IOUserNetworkPacket"=21760,"IGStolenMemoryDescriptor"=282,"AppleHSBluetoothHIDDriver"=0,"SCSITaskUserClientIniter"=0,"AppleUpstreamUserClient"=0,"IOSlaveCPU"=0,"IOAudioTimeIntervalFilter"=0,"AppleUSBXHCIFL1100"=0,"AppleAHCIDiskQueueManager"=1,"AppleUSBTDMMassStorageClass"=0,"IOBootFramebuffer"=0,"IOHIDResourceDeviceUserClient"=1,"IOInterruptController"=5,"DspFunc"=5,"SMCPolledInterface"=1,"AppleASMediaUSBXHCI"=0,"IOSkywalkPacketPoller"=0,"IOEthernetInterface"=3,"AppleUSBHostResourcesClient"=1,"IOSerialATARequestFIS"=68,"AppleHDAFunctionGroup_80862805"=0,"IOTimeSyncTimeLineFilter"=0,"AppleHSSPIControllerUserClient"=0,"AppleUSBXHCIARIsochronousRequest"=0,"AGDCPlugin"=1,"IOMbufLittleMemoryCursor"=0,"AppleHDATDMBusManager"=0,"AppleUSBHubPolicyMaker"=1,"IGPagePool"=4,"IOGraphicsControllerWorkLoop"=1,"IOConditionLock"=0,"IO80211WorkLoop"=1,"AppleDiskImageDevice"=0,"AppleIntelLpssSpiController"=1,"IOUSBUserClientLegacy"=1,"AppleHDAFunctionGroupGK10X"=0,"AppleUSBHostIORequestPool"=13,"IOAccel2DContext2"=1,"AppleUSBHostFrameworkClient"=0,"com_apple_driver_pm_pch_reporter"=1,"DspFuncMultiBandDRC"=0,"IOAccelerator"=1,"IGGCObject"=1,"IOUserResources"=1,"AppleAPFSVolume"=6,"IOWatchdogUserClient"=1,"IOFenceTransaction"=0,"IOSkywalkStatisticsReporter"=0,"AppleUSBXHCISparseRequest"=0,"PMTraceWorker"=1,"IOAudioControl"=3,"IOSCSIBlockCommandsDevice"=1,"AppleSMBusControllerICH"=0,"IO80211QueueCall"=1,"ACMT208ProxyKernelService"=0,"IOI2CInterface"=1,"AppleHDAWidgetCS4206"=0,"AppleHDAHDMI_DPDriver"=0,"IO80211QueueDescriptor"=3,"IOAccelStatistics2"=1,"IODTNVRAMVariables"=0,"AppleHDAFunctionGroupSTAC9220"=0,"IOUSBHostIOSource"=1,"IONetworkController"=1,"AppleIntelLpssDmac"=1,"OSString"=35220,"CCIOReporterHub"=2,"AppleUSBHub"=1,"IOThunderboltAbstractPath"=0,"IntelBDWMemoryManager"=1,"ApplePMTGraphicsInformation"=0,"IOUserIterator"=10,"DspFunc2To6Splitter"=0,"AppleMCCSParameterHandler"=3,"IOSortableConfigurationDescriptor"=0,"AppleCamIn"=1,"IOThunderboltConfigXDomainROMReadRequestCommand"=0,"AppleMobileFileIntegrityUserClient"=0,"AppleAHCI"=1,"AppleUSBXHCIIsochronousRequest"=5,"OSOrderedSet"=340,"AppleUSBNCMData"=0,"AppleUSBACMControl"=1,"IGAccelCLContext"=0,"IOThunderboltString"=36,"PMSettingHandle"=6,"AppleUSBXHCIStream"=0,"IOHIDEventDriver"=2,"DspFuncClientGainAdjust"=1,"TSNWiFiControlInterface"=0,"IOAudioStream"=5,"com_apple_driver_pm_flex_reporter"=1,"IOAccelContext2"=2,"AppleIntelPchSeriesAHCI"=0,"IOThunderboltSwitchType2"=1,"IOThunderboltIECSCommand"=0,"IOThunderboltConfigXDomainUUIDRequestCommand"=1,"AppleAPFSMedia"=1,"IOSurfaceBufferMemoryDescriptorPool"=0,"IOSerialBSDClient"=2,"APFSCryptoContext"=576,"IGAccelGLContext"=6,"IOStateReporter"=30,"IOThunderboltReceiveCommand"=16,"AGPMHeuristic2"=3,"IOBluetoothL2CAPMemoryBlock"=0,"AIDLoggerUserClient"=0,"AppleHPET"=1,"IONotifier"=4,"AppleUSBXHCIPPT"=0,"AppleUSBPipe"=0,"IOTimeSyncTimeLineFilterIIR128"=0,"IGMappedBuffer"=32,"IOThunderboltPort"=9,"IOFilterInterruptEventSource"=7,"IOThunderboltConfigNotifyAckCommand"=0,"IOLittleMemoryCursor"=0,"DspFuncGain"=0,"IOUserNetworkPacketBufferPool"=5,"IOHIDPointingDevice"=0,"IOSkywalkTxSubmissionQueue"=1,"AppleUSBXHCIWPT"=1,"_IOFramebufferNotifier"=17,"AppleSEPIntelIOPNub"=0,"IOThunderboltTunnelDriver"=2,"IGHardwareRingBufferBlit"=16,"IOBluetoothDataQueue"=0,"IOHDAController"=1,"AppleIntelSlowAdaptiveClockingManager"=1,"AppleUSBHostRequest"=2,"IODisplayAssertionUserClient"=0,"IGHardwareRingBufferVEBox"=0,"IOMedia"=8,"IOSKRegion"=59,"IGAccelMemoryMap"=1,"IO80211VirtualInterface"=1,"IOHistogramReporter"=7,"IOHIDAction"=0,"IOPlatformPluginFamilyPriv"=1,"AppleHDAFunctionGroupExternalControlFactory"=0,"IO80211AWDLPeerManager"=1,"IOPerfControlWorkContext"=35,"AppleSMBusDevice"=0,"IGHardwareGlobalPageTable"=1,"IOBluetoothMemoryBlockQueue"=1,"EndpointSecurityDriverClient"=1,"OSSymbol"=20615,"IOSurfaceSharedEventNotificationPort"=0,"AppleUserHIDDevice"=0,"IOSMBusController"=1,"IOAHCIDevice"=1,"IO80211LinkQualityMonitor"=0,"OSEntitlements"=998,"AppleACPIPlatformExpert"=1,"IORegistryPlane"=7,"AirPort_BrcmNIC_Timer"=58,"AppleUSBCDCControl"=1,"AppleUSBHostUserClient"=2,"AppleIntelUSBXHCI"=1,"IOUSBMassStorageDriverNub"=2,"IOHIDLibUserClient"=1,"IGAccelSysMemory"=1,"IOThunderboltFrameList"=19,"AppleUSBInterfaceIterator"=0,"IOSlaveEndpoint"=0,"AppleHDAFunctionGroupExternalControl_GPIO"=2,"AppleSMBusController"=0,"CCDataPipeBlobOS"=0,"AppleUSBXHCIInterrupterMSI"=3,"IOInterruptEventSource"=97,"IOSkywalkPacketBufferPool"=2,"AudioAUUCDriver"=1,"IOAccelRemoteMemory"=0,"AppleUSBUserHCI"=0,"IO80211ServiceRequestDescriptor"=0,"OSObject"=180,"IOBluetoothSerialManager"=1,"AppleHDAMikeyInternalCS8409"=0,"IGHardwarePerProcessPageTable"=1,"IOHDIXController"=1,"IOStateNotificationItem"=3,"TSNAssistedInterface"=0,"AppleMEClientController"=1,"IOMbufNaturalMemoryCursor"=1,"IOWatchdog"=1,"AppleHDAPathSet"=4,"IOKDP"=0,"CCIOReporterDataStream"=1,"IOSlaveRelayEndpoint"=0,"IOFence"=0,"IO80211AssociationJoinSnapshot"=1,"IOAccelTraceStreamConnection"=4,"IOBluetoothHIDDriver"=0,"AppleUSBNetworkingCommand"=0,"IOGraphicsDevice"=1,"IOThunderboltNumber"=175,"IOUSBControllerListElement"=0,"IOResources"=1,"AppleUSB20Hub"=1,"IGHardwarePerProcessPageTable32"=0,"IOAccelNamespace"=62,"AppleHDAWidgetAD1988"=0,"IOGraphicsSystemWorkLoop"=1,"DspFuncMultiBandCompressor"=0,"GMetricsRecorder"=0,"DIDeviceCreatorUserClient"=0,"IOSCSIPeripheralDeviceNub"=1,"RSNSupplicant"=1,"AppleUSBXHCIARRequestPool"=0,"IOSurfaceDeviceCache"=289,"IOAccelLegacyDisplayPipe"=0,"IOThunderboltConfigReadQuadletCommand"=2,"AGPMController"=1,"AppleUSBXHCIRequestPool"=2,"IOThunderboltXDLocalPropertiesCache"=1,"CoreAnalyticsPipe"=1,"AppleGraphicsDeviceControlClient"=7,"IOUSBBus"=1,"IGHardwareRingBufferMain"=61,"AppleUSBLegacyDeviceUserClient"=1,"IOServicePM"=164,"IOBigMemoryCursor"=0,"AppleBusControllerCS8409"=0,"AppleSmartBattery"=1,"TSNInterface"=0,"AppleThunderboltNHIType3"=0,"IGAccelVideoContextVEBox"=0,"ACMRestrictedModeKernelService"=1,"AppleUSB30CameraKitHub"=0,"AppleUSBHostBusCurrentPool"=0,"AppleHDAWidgetMCP89"=0,"IOMemoryDescriptor"=3,"IOTimeSyncTimeSyncTimePort"=0,"IOAccelGLDrawableUserClient"=0,"AppleTDMAKSServices"=0,"AppleIntelLpssGspi"=1,"AppleHDAFunctionGroupATI_RS780"=0,"IOHIDActionQueue"=0,"IntelBDWAccelSysMemory"=8394,"IOUSBInterfaceUserClientV2"=1,"IGAccelFIFOChannel"=78,"AppleUSBInterface"=14,"IODMAController"=0,"IOThunderboltDictionary"=12,"IOUSBControllerV3"=1,"AppleGraphicsControl"=0,"IOBluetoothSCOMemoryDescriptorRetainer"=0,"EventQueue"=1,"IOThunderboltI2CCommand"=2,"AppleHDATDMBusManagerCS8409"=0,"AGPMEventSource"=1,"IGFenceAllocator"=1,"IOSystemStateNotification"=1,"DspFuncEQ"=2,"IOCatalogue"=1,"IOWorkLoop"=70,"IOThunderboltI2CCommandQueue"=1,"AppleSEPEndpointService"=0,"AppleUSBSerialUserClient"=0,"IODataQueue"=1,"AppleAPFSMediaBSDClient"=1,"AppleUSBUserHCIRequestPool"=0,"CCIOReporterLogStream"=1,"IOHIDDevice"=2,"ACMPersistentStoreKernelService"=1,"IOHDACodecDriver"=1,"IOSkywalkNetworkPacket"=2,"AppleHDAWidgetATI_RS730"=0,"IOBluetoothL2CAPChannel"=0,"CCStream"=2,"AppleUSBHostFrameworkInterfaceClient"=0,"AppleHDAWidgetATI_RS780"=0,"IOHIDElement"=1,"AppleUSBCardReaderBlockStorageServices"=1,"IO80211InfraInterface"=1,"_IOMemoryDescriptorMixedData"=12654,"IOReportHub"=1,"AppleThunderboltIntelPCIHAL"=1,"DspFunc6ChOutput"=0,"IO80211P2PDaemonUserClient"=1,"IO80211ScanManager"=1,"IGAccelDevice"=33,"IOEthernetController"=3,"DspFuncStereoEnhancer"=0,"IOSlowAdaptiveClockingDomain"=0,"IOThunderboltConfigXDomainRequestCommand"=0,"IOTimerEventSource"=303,"IOThunderboltCommandQueue"=8,"AppleHDAFunctionGroupCS8409"=0,"CryptoBufferDescriptor"=576,"IOSerialDriverSync"=0,"IOPCIConfigurator"=1,"com_apple_filesystems_hfs_encodings"=1,"AppleUSB20InternalIntelHubPort"=0,"Stopwatch"=10,"IO80211NetBootNub"=0,"IOTimeSyncEthernetConcreteControllerAdapter"=0,"IOSlaveRelayCommand"=0,"DspFunc2WayCrossover"=0,"CCLogPipe"=4,"AppleSMCClient"=4,"IOUserNetworkMemorySegment"=340,"IGHardwareBlit2DContext"=16,"IGAccelTraceStream"=4,"AppleUSBXHCIFL1100CommandRing"=0,"AIDReporterState"=0,"AppleHDAWidgetGT216"=0,"AppleUSBECMControl"=0,"AppleTDMAKSDriver"=0,"DspFuncVolume_3ch"=0,"IOTimeSyncUserClient"=1,"IOServiceMessageUserNotification"=221,"hv_vmx_vma_t"=0,"IOReporter"=3,"AppleXsanScheme"=0,"AppleUSBHostBusCurrentClient"=4,"IOMultiMemoryDescriptor"=3867,"IOAccelDrawable2"=0,"IOPlatformPluginFamily"=1,"IOSCSILogicalUnitNub"=2,"AppleHSSPIInterface"=3,"AppleLIFSUserClient"=0,"IOTimeSyncEthernetControllerAdapter"=0,"AppleHDAWidget_80862807"=0,"CamelliaBase"=0,"IGHardwareRingBufferMedia"=1,"IOSCSIHierarchicalLogicalUnit"=0,"AppleDiskImagesController"=1,"AppleHDATDMDeviceFactory"=0,"AppleSEPDeviceService"=0,"IOTimeSyncClockMapping"=1,"AIDCircularBuffer"=0,"IOAccelAllocationInfo"=0,"KDIURL"=0,"AGPMHeuristic1"=0,"IOPanicPlatform"=0,"IODMAEventSource"=0,"IOThunderboltConnectionManager"=1,"IOSCSIMultipathedLogicalUnit"=0,"AppleCamInUserClient"=1,"IOThunderboltSwitchOS"=0,"IOPlatformDevice"=3,"AppleHDAWidgetCS4208"=36,"AppleAHCIWorkLoopLock"=1,"IOThunderboltXDDirectory"=0,"AppleHIDTransportIODataQueue"=0,"DspFuncSum"=0,"AppleUSBHostDARTDMACommand"=0,"AIDLogger"=0,"DspFuncStereoToMono"=0,"AppleHDATDMAmpSSM3515"=0,"IOUserNetworkEthernet"=5,"AppleUSBHostResourcesTypeC"=0,"AppleUSB20CameraKitHub"=0,"AppleHDAAudioSelectorControlDP"=0,"CCCapture"=0,"AppleMultitouchHIDEventService"=0,"AppleUSBHostFrameworkDeviceClient"=0,"IOSurfaceWiredSendRight"=0,"AppleThunderboltDPPathManager"=2,"IO80211RangingManager"=1,"IOThunderboltData"=0,"IOUSBMassStorageUASDriverCommand"=0,"IOThunderboltCommandGate"=4,"IOSkywalkController"=0,"IOAudioControlUserClient"=166,"DspBuffer"=5,"AppleThunderboltNHIType1"=0,"IOStateNotificationListener"=0,"IOAudioEngine"=2,"AppleThunderboltGenericHAL"=1,"OSSerialize"=1,"AppleUSBDescriptorCache"=14,"IOAudioDevice"=2,"IOSurfaceSharedEventReference"=0,"IOAccelCommandBufferPool2"=57,"OSKext"=489,"AppleHSBluetoothDevice"=0,"AppleUSBDescriptor"=128,"AppleGPUWrangler_GPU"=1,"com_apple_driver_pm_msr_reporter"=1,"AppleSMBIOS"=1,"IOTimeSyncUnicastLinkLayerEtEPort"=0,"IOSkywalkTxCompletionQueue"=1,"IGTelemetryUsage"=78,"SMCWatchDogTimer"=1,"AppleHDAFunctionGroupAD1988"=0,"AppleUSBHostBouncedDMACommand"=0,"AGDPClientControl"=1,"IO80211InterfaceMonitor"=4,"_IOServiceJob"=0,"IOPMPowerStateQueue"=1,"AppleEmbeddedHIDEventService"=0,"IOUserNetworkPacketQueue"=4,"OSIterator"=2,"hv_vcpu_t"=0,"IOAccelerationUserClient"=1,"IOBluetoothTimerEventSource"=0,"IOThunderboltJTAG"=1,"AppleUSBHostBusCurrentAllocator"=9,"IO80211RangingManagerExt"=0,"DspFuncDelay"=0,"CCDataStream"=3,"IOMemoryMap"=4514,"AppleAHCIDiskPolledInterface"=1,"IOAudioToggleControl"=12,"com_apple_driver_pmtelemetry"=1,"AppleSEPTesting"=0,"IOThunderboltStatistics"=1,"SCSITask"=0,"AppleSmartBatteryManagerUserClient"=0,"IOBluetoothL2CAPSupervisoryFrameMemoryBlock"=0,"IOThunderboltLocalNode"=1,"AppleUSBXHCIDevice"=3,"IOHDIXHDDriveOutKernel"=0,"IOUSBMassStorageCBIDriver"=0,"IOUserUserClient"=2,"IGHardwareRenderCommandStreamer5"=1,"IO80211Controller"=1,"AppleHDAEngineUserClient"=0,"AppleMobileFileIntegrity"=1,"IOTimeSyncNotifier"=0,"IGHardwareExtendedContext"=4,"X86PlatformPlugin"=1,"AppleHDAFunctionGroupMCP79"=0,"AppleICH8AHCI"=0,"IOPCIDiagnosticsClient"=0,"IOHIDParamUserClient"=4,"IOPCIBridge"=2,"AppleASMediaUSBXHCIIsochronousRequestPool"=0,"IOBluetoothPacketLogger"=1,"AppleEffaceableStorageUserClient"=0,"OSData"=3245,"IORegistryIterator"=0,"AIDReporterSimple"=0,"IOGraphicsAccelerator2"=1,"IOHDIXCommandPool"=0,"IOThunderboltFindCapabilityCommand"=1,"IOThunderboltPacketLoggerNub"=0,"TransducerState"=0,"IOOutputQueue"=1,"AppleSEPUserClient"=0,"PMAssertionsTracker"=1,"EndpointSecurityExternalClient"=0,"AppleUSBHostDMACommand"=0,"AppleEmbeddedKeyboard"=1,"IOThunderboltTransmitCommand"=3,"IGHwCsStatsTracker"=4,"HSSPIIODataQueue_AppleHSSPIController"=0,"AppleIntelFBController"=1,"DspFuncCrossover"=0,"IGAccelVideoContext"=0,"IOThunderboltXDomainPath"=0,"IOSCSIPeripheralDeviceType00"=2,"IO80211PeerManager"=1,"IOHDIXHDDriveNub"=0,"AppleKeyStoreCommand"=2,"AppleThunderboltIPService"=1,"AppleACPIPlatformUserClient"=0,"IOHIDKeyboardEventDevice"=0,"IOSkywalkLegacyEthernetInterface"=1,"IOSCSITargetDevice"=0,"AppleBacklightDisplay"=1,"IOSlaveProcessorRelay"=0,"IORootParent"=1,"AppleUSB20HostController"=0,"AppleASMedia1042USBXHCI"=0,"com_apple_driver_pm_cstate_reporter"=1,"DspFuncMozartCompressor"=1,"IO80211PeerMonitor"=1,"AIDQueueEventSource"=0,"IOThunderboltSwitchLC"=1,"PMSettingObject"=6,"IODispatchSource"=1,"AppleUSBHostPortInterruptEventSource"=9,"TSNBSDInterface"=0,"IOUserNetworkRxSubmissionQueue"=5,"AppleKeyStore"=1,"AppleACPIPCI"=1,"IOUSBHostInterfaceIterator"=0,"AppleGPUWrangler_MatchNotificationWorkItem"=0,"IOThunderboltControlPath"=1,"IOPMinformee"=112,"IOSlowAdaptiveClockingManager"=1,"IOUSBCommand"=0,"IOTimeSyncReverseSync"=0,"IOAccelLegacySurface"=0,"hv_vmx_space_t"=0,"AppleUSBHostDMABufferMemoryDescriptor"=17,"IOPMPowerSource"=1,"EndpointSecurityDriver"=1,"IOTimeSyncEdgeTimeCapture"=0,"IOUSBLog"=1,"DspFuncLimiter"=0,"CCPipeUserClient"=0,"AppleUSBHostResourcesBusPowerClient"=2,"AHCISMARTUserClient"=0,"AppleHDAMikeyInternalFactory"=0,"AppleSEPManager"=0,"AppleThunderboltIPTransmitter"=0,"IOBluetoothDevice"=1,"DspFuncWithSharedMemory"=4,"IOTimeSyncTimedEdgeGenerator"=0,"IOTimeSyncgPTPManager"=0,"IOThunderboltWorkLoop"=1,"AppleIntelPanelA"=1,"IODisplayParameterHandler"=3,"AppleIntelDisplayPath"=3,"AppleBusPowerController"=0,"IOAccelSharedNamespace2"=30,"AppleIntelLpssSpiDevice"=1,"IOBufferMemoryDescriptor"=9172,"AppleUSBXHCILPTH"=0,"AppleACPIButton"=2,"IOAccelDisplayPipe"=1,"AppleHDADriverUserClient"=0,"IOThunderboltFamilyUserClient"=0,"CCPipe"=2,"AppleHDAWidgetCS8409"=0,"AppleHDAWidgetALC885"=0,"AppleSystemPolicyUserClient"=1,"IOHIDEventServiceUserClient"=4,"DspFunc2Dot1Crossover"=0,"DspFuncBeam2"=1,"AppleUSBHostInterfaceUserClient"=2,"IOThunderboltXDomainService"=0,"AppleMultitouchHIDEventDriver"=0,"IOPolledInterface"=5,"AppleThunderboltDPOutAdapterGFXPolicy1"=0,"IGMemoryManager"=1,"IONDRVDevice"=0,"IOAccelMemory"=1,"IOTimeSyncTimeLineFilter128"=0,"IGHardwareCommandStreamer5"=4,"OSKextSavedMutableSegment"=6,"IOUserSerialUserClient"=0,"IOHIDElementContainer"=1,"AppleUSBDevice"=15,"IOPlatformExpertDevice"=1,"IOTimeSyncEthernetLegacyInterfaceAdapter"=0,"IOUSBHubPolicyMaker"=1,"IOHIPointing"=0,"IOTimeSyncFDEtEPort"=0,"AIDUserClient"=0,"IOThunderboltController"=1,"IOBluetoothHCIController"=1,"AudioAUUC"=0,"AppleAPFSContainerScheme"=1,"IONetworkData"=22,"AppleHSSPIHIDDriver"=3,"IOAudioLevelControl"=519,"IOAccelLegacyDisplayMachine"=0,"IOECStateNotifier"=0,"AppleUSBXHCISPTLP"=0,"IOUSBCommandPool"=0,"IOTimeSyncAWDLInterfaceAdapter"=0,"AppleUSBSerial"=1,"AppleAPFSVolumeBSDClient"=6,"AppleMultitouchEventServiceWrapper"=0,"IntelBDWAccelMemoryMap"=6840,"IO80211FlowQueue"=0,"AppleLMUController"=1,"AppleHDADriver"=1,"AppleImage4UserClient"=0,"OSAction_IOHIDEventService__SetLED"=0,"IOPlatformPluginDevice"=2,"AppleTDMAKSCommand"=0,"IOKernelDebugger"=0,"IODTNVRAMDiags"=0,"IOBacklightDisplay"=1,"CoreAnalyticsMessenger"=0,"IOThunderboltNHIReceiveRing"=1,"IODispatchQueue"=10,"IONetworkMedium"=2,"IODisplayConnect"=1,"AppleAHCIPortPolledAdapter"=1,"IOSkywalkCloneableNetworkPacket"=0,"AppleHDAWidgetATI_RS710"=0,"IOTimeSyncTimeLineFilterIIR"=0,"IOHIDResource"=1,"AGPMHeuristic0"=0,"IGAccelDisplayMachine"=1,"AppleNVMeTranslationSMARTUserClient"=0,"BroadcomBluetoothHostControllerUSBTransport"=1,"AppleHDAWidgetWM8800"=0,"IOTimeSyncPort"=0,"AppleSATLSMARTUserClient"=0,"AppleBSDKextStarter"=1,"AppleUSBCDCCompositeDevice"=1,"IOUSBRootHubDevice"=0,"AppleUSBXHCISparseRequestPool"=0,"AppleMultitouchInputHIDEventDriver"=1,"IOSlaveRelayActionCommand"=0,"IOHIDPointingEventDevice"=0,"IOThunderboltXDPropertiesLeafText"=2,"IOTimeSyncgPTPManagerUserClient"=0,"IOHIDDeviceShim"=0,"IGScheduler5"=1,"IGAccelEventMachine"=1,"AppleHDAWidget_1002AAA0"=0,"IOBluetoothHostControllerUARTTransport"=1,"IOAHCIPort"=1,"IOTimeSyncTimeOfDayPort"=0,"IOThunderboltConfigXDomainPathSetupRequestCommand"=0,"IOBluetoothACPIMethods"=1,"AppleUSBXHCIARIsochronousRequestPool"=0,"AppleThunderboltIPPort"=1,"KernelRelayEndpoint"=0,"DspFuncVolume"=2,"IOBluetoothObject"=1,"AppleSCSISubsystemGlobals"=1,"AppleImage4"=1,"AppleGraphicsDeviceControl"=3,"IOAccelDisplayPipeGammaTable2"=1,"OSMetaClass"=0,"CCDataPipeBlobOD"=0,"IOUSBControllerV2"=1,"IOHIDPointing"=0,"IOAccelSurface"=1,"IOAudioSelectorControl"=2,"DspFuncAudioMeter"=0,"IOUserSerial"=1,"IOUserNetworkTxSubmissionQueue"=1,"CCDataSession"=0,"IO80211P2PSteeringManager"=1,"IOThunderboltIECSCommandQueue"=1,"IOSKMapper"=1,"IOThunderboltDispatchContext"=2,"IOSCSIProtocolServices"=2,"IOLWPool"=0,"IOHIDEventDummyService"=0,"AppleEFINVRAM"=1,"IOTimeSyncDomain"=0,"IOKitDiagnostics"=1,"AppleIntelLpssDmacChannel"=0,"AirPort_BrcmNIC"=1,"AppleMultitouchDeviceUserClient"=1,"IOHIDEventServiceQueue"=5,"IODTNVRAM"=1,"com_apple_driver_pm_reporter"=8,"AppleUSBXHCITDPool"=1,"IO80211P2PDFSProxyManager"=1,"AppleUSBHostDMACommandPool"=1,"AppleThunderboltHALType4"=0,"IOSurfaceMemoryRegion"=0,"AppleACPIEC"=1,"IGSharedMappedBuffer"=471,"IOAccelDisplayPipeUserClient2"=3,"AppleRTCUserClient"=0,"IO80211SkywalkInterface"=1,"DspFuncXTC"=0,"IO80211P2PSupervisor"=1,"AppleHDAWidgetMCP79"=0,"IOBluetoothHIDChannel"=0,"hv_vatpic_t"=0,"hv_vm_t"=0,"AppleSSE"=1,"IOPMRequest"=0,"IOECTimeSyncHandler"=0,"IOAccelMemoryMap"=1,"IOHIKeyboard"=0,"AppleGPUWrangler_BusyInterestWorkItem"=0,"IOHIDUserDevice"=1,"IGAccelResource"=4346,"AppleHDATDMAmpTAS5758L"=0,"AppleMCCSControlCello"=0,"AppleHDAFunctionGroupATI_Park"=0,"AppleXsanDevice"=0,"IOSurfaceSharedEvent"=0,"IOBluetoothHostControllerPCIeTransport"=1,"IORS232SerialStreamSync"=0,"IOService"=194,"AppleIntelMEIDriver"=1,"AppleHDAWidget_10DE0014"=0,"IOBluetoothWorkLoop"=0,"ACMAccessoryCacheKernelService"=1,"IOUserServerCheckInToken"=7,"IOHIDEventRepairDriver"=0,"AppleHDAFunctionGroup_10DE0014"=0,"IOAccelBlockFencePort2"=18,"IOSKMemoryBuffer"=35,"IOTimeSyncUnicastUDPv4EtEPort"=0,"KextAudit"=1,"IOAccelSysMemory"=1,"AppleSMCFamily"=1,"HIDAlwaysNotifyingIODataQueue"=1,"AppleIPAppender"=1,"IOFramebuffer"=1,"AppleMultitouchDevice"=1,"AppleUSBXHCIIsochronousTransferRing"=0,"IOPMCompletionQueue"=1,"AppleSEPCommandPool"=0,"DspFuncVirtualization"=0,"IOBluetoothHostControllerUSBTransport"=1,"IOTimeSyncUserFilteredService"=0,"AppleHV"=1,"AppleCredentialManagerUserClient"=3,"IOThunderboltNHI"=1,"AppleFileSystemDriver"=0,"mDNSOffloadUserClient"=0,"IOUSBHostInterfaceLegacyIterator"=0,"AppleUSBHostPort"=2,"IOThunderboltConnectionManagerType5"=0,"PassthruInterruptController"=0,"CCDataPipeUserClient"=0,"AppleUSBUserHCICommandQueue"=0,"AppleHDAWidget"=1,"IOAccelMemoryInfoUserClient"=0,"IOFDiskPartitionScheme"=0,"AppleMultitouchEventDriverWrapper"=1,"com_apple_filesystems_hfs"=1,"IODataQueueDispatchSource"=8,"AppleHDAFunctionGroupCS4206"=0,"OSAction_IOHIDDevice__CompleteReport"=0,"AppleUSBUserHCIRequest"=0,"AppleTDMEffaceableNORDriver"=0,"AppleUSBXHCITR"=0,"AppleUSBXHCIStreamingEndpoint"=0,"AppleHDACodecGeneric"=1,"AppleGPUWrangler_DeferredReleaseWorkItem"=0,"AirPort_Brcm43xxSkywalkPacketBufferPool"=1,"IOUSBMassStorageInterfaceNub"=1,"AppleSSEUserClient"=0,"KernelRelayHost"=0,"IOAccelResource2"=1,"IOPMPowerSourceList"=0,"AppleHDAEngineOutputDP"=0,"OSAction_IOUserClient_KernelCompletion"=0,"AppleUSB20InternalSMSCHub"=0,"IOThunderboltNub"=2,"mDNSHandoff"=1,"AppleLPC"=1,"IOAccelTraceStream2"=1,"AppleVTDDeviceMapper"=2,"IOTimeSyncEthernetSoftDMAInterfaceAdapter"=0,"AppleHDAStream"=3,"AppleIntelLpssI2C"=0,"IOUSBPipe"=0,"AppleACPICPUInterruptController"=1,"AppleAMDUSBXHCIPCI"=0,"IGHardwareDisplayContext"=1,"IOAVBControllerHelper"=0,"AppleVTD"=1,"AppleSEPEndpoint"=0,"IOPerfControlClient"=3,"IOAHCIBlockStorageDriver"=1,"EupDSP"=0,"AppleHSSPIDevice"=1,"AppleBusControllerFactory"=0,"IOPlatformExpert"=1,"IOUserEthernetController"=0,"IOTimeSyncEthernetPort"=0,"IOAccelDisplayPipePostCSCGammaVID"=0,"IOUserSCSIPeripheralDeviceType00"=0,"com_apple_driver_pm_uncore_reporter"=1,"TSNWiFiInterface"=0,"AppleUSBController"=1,"IOTimeSyncUserFilteredServiceUserClient"=0,"IOPartitionScheme"=2,"IOTimeSyncIntervalFilter128"=0,"AppleAHCIPolledAdapter"=1,"AppleThunderboltDPInAdapterGFXPolicy1"=2,"AppleIntelSPIController"=1,"com_apple_driver_AppleUSBCardReaderDriverNub"=1,"IOSlaveFirmware"=0,"AppleASMedia3142USBXHCI"=0,"IOAccelExternalEvent"=0,"AppleHSSPICommand"=30,"IOHIDUserClient"=1,"LogManager"=1,"IOACPIPlatformExpert"=1,"IOThunderboltSwitchType3"=0,"hv_vlapic_t"=0,"IOThunderboltNHITransmitRing"=1,"IOThunderboltUserObjectExporter"=0,"IOAccelSharedEventFence"=0,"com_apple_driver_pm_cpu_mbox"=2,"IOAccelVideoContext2"=0,"IOUSBControllerIsochEndpoint"=0,"IOTimeSyncEthernetModernInterfaceAdapter"=0,"IOThunderboltConfigResetCommand"=2,"AppleIntelPAVP"=1,"AppleUSBNCMControl"=0,"DspFuncLoudness"=1,"IOSurfaceDeviceMemoryRegion"=0,"IOServiceCompatibility"=4,"AppleThunderboltDPOutAdapterUserClient"=0,"IOHIDEventService"=3,"IOAudioTimeIntervalFilterFIR"=0,"AppleASMediaUSBXHCIIsochronousRequest"=0,"AirPort_Brcm43xxSkywalkPacket"=4352,"IOAccelDisplayPipePreCSCLinearizationVID"=0,"IOUserEthernetInterface"=0,"IOTimeSyncIntervalFilterIIR128"=0,"IOAudioPort"=0,"IOThunderboltConfigXDomainLinkChangeRequestCommand"=0,"IOInterruptDispatchSource"=0,"IOSkywalkPacketBuffer"=128,"IOHIKeyboardMapper"=0,"AppleUSBBusPowerClient"=0,"IOTimeSyncUnicastUDPv6EtEPort"=0,"OSAction_IOHIDEventService__CopyEvent"=0,"ACMBridgeKernelService"=0,"KRActionCommandPool"=0,"IOUSBHostInterface"=14,"com_apple_driver_pm_msr_limits_reporter"=1,"hv_vmx_vcpu_t"=0,"IOAHCIPortMultiplier"=0,"AppleGPUWrangler"=1,"IOTimeSyncIntervalFilterIIR"=0,"OSArray"=17106,"IOGeneralMemoryDescriptor"=2955,"IOSkywalkBSDClient"=1,"IOThunderboltConfigXDomainLinkStatusRequestCommand"=0,"IOUSBIsocCommand"=0,"IOEthernetAVBInterface"=0,"STUCWorkLoopLock"=0,"IOAccelSurfaceMTL"=0,"IOThunderboltDispatchQueue"=11,"IO80211FlowQueueLegacy"=0,"IOSlaveProcessor"=0,"IGAccelSegmentResourceList"=0,"DIDeviceIOUserClient"=0,"AppleUSBHubPort"=1,"IO80211ControllerMonitor"=1,"IOTimeSyncClockTestUserClient"=0,"IOThunderboltPortMicro"=0,"IOUSBWorkLoop"=1,"AppleUSB20HubExpressCardPort"=0,"IOSurfaceClient"=365,"IOAudioEngineEntry"=0,"AppleThunderboltNHIReceiveRing"=12,"com_apple_driver_pm_ltr_reporter"=1,"IOConfigurationDescriptorOrderedSet"=0,"IOThunderboltProtocolListener"=1,"AppleBusController"=0,"AIDSerialLogger"=0,"AHCIRequest"=33,"MEICompletion"=0,"AppleGraphicsDeviceControlPlugin"=1,"IOThunderboltConfigXDomainCommand"=2,"AppleIntelICLUSBXHCI"=0,"IOCancelationWrapper"=0,"IO80211CommandQueue"=10,"DspFuncManager"=2,"IOAccelExternalEventFence"=0,"AppleUSB20XHCITypeCPort"=0,"DspFuncSplitBand"=0,"IOBootNDRV"=0,"IOHIDElementPrivate"=1372,"AppleHDAPath"=4,"AppleSSEInterface"=1,"AGDCPluginDisplayMetrics"=1,"IOHITablet"=0,"AppleTDMBlockStorageServices"=0,"AirPort_Brcm43xxLLSkywalkInterface"=1,"AppleACPIEventController"=1,"IOFramebufferUserClient"=3},"IOMalloc allocation"=104863798}
+-o AppleUSBXHCI Root Hub Simulation@14000000 <class AppleUSBRootHubDevice, id 0x10000036c, registered, matched, active, busy 0 (0 ms), retain 13>
| "idProduct" = 32775
| "bNumConfigurations" = 1
| "Built-In" = Yes
| "bDeviceClass" = 9
| "bMaxPacketSize0" = 8
| "iManufacturer" = 0
| "iProduct" = 0
| "iSerialNumber" = 0
| "USB Product Name" = "AppleUSBXHCI Root Hub Simulation"
| "IOPowerManagement" = {"DevicePowerState"=0,"CurrentPowerState"=4,"CapabilityFlags"=32768,"MaxPowerState"=4,"DriverPowerState"=4}
| "IOUserClientClass" = "AppleUSBLegacyDeviceUserClient"
| "locationID" = 335544320
| "bDeviceSubClass" = 255
| "bcdUSB" = 256
| "non-removable" = "yes"
| "IOCFPlugInTypes" = {"9dc7b780-9ec0-11d4-a54f-000a27052861"="IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle"}
| "bDeviceProtocol" = 3
| "Device Speed" = 3
| "USB Vendor Name" = "Apple Inc."
| "idVendor" = 1452
| "IOClassNameOverride" = "IOUSBRootHubDevice"
+-o BRCM20702 Hub@14300000 <class AppleUSBDevice, id 0x100000389, registered, matched, active, busy 0 (0 ms), retain 12>
| | "sessionID" = 1794934537
| | "idProduct" = 17664
| | "iManufacturer" = 1
| | "bDeviceClass" = 9
| | "bcdDevice" = 256
| | "iProduct" = 2
| | "iSerialNumber" = 0
| | "Bus Power Available" = 250
| | "USB Address" = 3
| | "Built-In" = Yes
| | "locationID" = 338690048
| | "bDeviceSubClass" = 0
| | "bcdUSB" = 512
| | "USB Product Name" = "BRCM20702 Hub"
| | "PortNum" = 3
| | "AppleUSBAlternateServiceRegistryID" = 4294968199
| | "bDeviceProtocol" = 0
| | "IOCFPlugInTypes" = {"9dc7b780-9ec0-11d4-a54f-000a27052861"="IOUSBHostFamily.kext/Contents/PlugIns/IOUSBLib.bundle"}
| | "IOPowerManagement" = {"DevicePowerState"=2,"CurrentPowerState"=3,"CapabilityFlags"=65536,"MaxPowerState"=4,"DriverPowerState"=3}
| | "kUSBCurrentConfiguration" = 1
| | "Device Speed" = 1
| | "idVendor" = 2652
| | "IOGeneralInterest" = "IOCommand is not serializable"
| | "kUSBProductString" = "BRCM20702 Hub"
| | "kUSBVendorString" = "Apple Inc."
| | "IOClassNameOverride" = "IOUSBDevice"
| +-o Bluetooth USB Host Controller@14330000 <class AppleUSBDevice, id 0x1000003af, registered, matched, active, busy 0 (1 ms), retain 18>
| "sessionID" = 2136632231
| "idProduct" = 33423
| "iManufacturer" = 1
| "bDeviceClass" = 255
| "bMaxPacketSize0" = 64
| "bcdDevice" = 336
| "iProduct" = 2
| "iSerialNumber" = 0
| "USB Address" = 6
| "Built-In" = Yes
| "locationID" = 338886656
| "bDeviceSubClass" = 1
| "bcdUSB" = 512
| "USB Product Name" = "Bluetooth USB Host Controller"
| "PortNum" = 3
| "AppleUSBAlternateServiceRegistryID" = 4294968237
| "bDeviceProtocol" = 1
| "Device Speed" = 1
| "idVendor" = 1452
| "kUSBProductString" = "Bluetooth USB Host Controller"
+-o Bela@14100000 <class AppleUSBDevice, id 0x1000013a1, registered, matched, active, busy 0 (4 ms), retain 28>
"sessionID" = 9474465803965
"idProduct" = 260
"iManufacturer" = 1
"bDeviceClass" = 0
"bcdDevice" = 257
"iProduct" = 2
"iSerialNumber" = 3
"USB Address" = 18
"Built-In" = No
"locationID" = 336592896
"bcdUSB" = 512
"USB Product Name" = "Bela"
"PortNum" = 1
"non-removable" = "no"
"kUSBSerialNumberString" = "__bela__"
"AppleUSBAlternateServiceRegistryID" = 4294972319
"IOPowerManagement" = {"DevicePowerState"=0,"CurrentPowerState"=3,"CapabilityFlags"=65536,"MaxPowerState"=4,"DriverPowerState"=3}
"Device Speed" = 2
"USB Vendor Name" = "Augmented Instruments Ltd"
"idVendor" = 7531
"kUSBProductString" = "Bela"
"USB Serial Number" = "__bela__"
"kUSBVendorString" = "Augmented Instruments Ltd"
right, so everything is recognised as expected, the issue is probably that the IDE doesn't have CPU time left to show up while the program is running at boot (or better, it will take much longer for it to be ready). See instructions here on how to regain control of the board in this situation:
Hi again - same issue and I am spending too much time trying(!). I have had times when Bela has connected and thought all was OK but today I cannot get any success (am on my MacBook Air Monterey 12.2.1 which has been my only machine for Bela work). Have tried Firefox and Chrome and with bela.local/ I get the same result (and I confess I do not know what to check apart from the connection) as follows:
This site can’t be reached
bela.local’s server IP address could not be found.
Try:
Checking the connection
Checking the proxy, firewall and DNS configuration
ERR_NAME_NOT_RESOLVED
Hi again. Should have mentioned - same error with Bela Mini.
giuliomoro See instructions here on how to regain control of the board in this situation:
Did you try this ? Was it successful? Did you manage to take back control of the board at some point? And then you lost it again?
Sorry should have indicated that it simply worked at some point without recourse to this. Since writing the post I found a pc I could try and it worked fine. It makes me suspicious of the Mac - I get the impression that PCs are more robust with Bela perhaps?
david and I am spending too much time trying(
I know right!
david I get the impression that PCs are more robust with Bela perhaps?
Not that I am aware of...
david Sorry should have indicated that it simply worked at some point without recourse to this.
Is there still a program running on boot? If yes, I strongly recommend you follow the instructions above.
When you get the BELABOOT drive on your mac, can you open it and oepn the file "bela.version" with textedit? What is the version number reported in there?
Today it is not working on either computer so I looked at those instructions - my Bela is incorporated in a case with a number of connectors. A number of pins are mentioned to be grounded but I do not see them listed on the pin diagram (https://learn.bela.io/pin-diagram/). Where is the BELABOOT drive?
I have just tried with a brand new Bela board out of the box and it give the same error
'This site can’t be reached
bela.local’s server IP address could not be found.'
Does this still suggest I need to go through the process above?
david I have just tried with a brand new Bela board out of the box
good try!
david Does this still suggest I need to go through the process above?
First we need to figure out whether you are running a version of the Bela image that is compatible with your very new OS. That information is in bela.version
in BELABOOT.
david Where is the BELABOOT drive?
It should show up on your desktop or inside the /Volumes
folder. You can see the content of bela.version
after the board is connected to your computer by running:
in the terminal.
OK tried this and it returned:
dmh8@Davids-Air-10 ~ % cat /Volumes/BELABOOT/bela.version
BELA_IMAGE_VERSION=""
Not sure what to make of that!
