Hi - I have just tried the update again with the same result. I set it up with the zip file and it ran many scripts and then ended with the page above again. So I get this error. Is this the point I refresh the page - I tried with the Chrome refresh and it comes back to this page. I cannot find a way to get out of this error page in Bela. I do the update with a Bela starter board connected - might that be the issue? On this error page there is no console available as far as I can see. Is the error 'can't open binary files' meaning that I should have some other files available?
    david . I set it up with the zip file and it ran many script
    Did this process end successfully? Iff you run this again, send a screenshot of what that looks like when it ends.
    david I do the update with a Bela starter board connected - might that be the issue
    That's fine: you are supposed to do the update with a board connected.
    david . I cannot find a way to get out of this error page in Bela
    Press cancel then open the side tab by clicking on the + sign. There you'll see a list of the files in the project. Delete sine-generator.zip.
    Then you can drop the zip archive on the window again and it should prompt you to open it as a project.
    OK - something changed - I pressed the compile button a few times and it started to compete the sin wave demo which was the last program I had been using and it then ran OK. So somehow it seems to have sorted itself out I think - thanks for you time.
    a year later
    Hi after a long gap! I have a Bela Mini and I cannot get the bela/local to work on my MacBook Air. It works fine with the larger Bela board. Should it simply recognise a different board and run? The Bela Mini does have the 'heartbeat' flashing of its blue LED.
      It should just work. Did you change any of the network settings for this device in the System Preferences->Network panel? What version of the operating system are you on?
      5 days later
      o/s is Monterey 12.1 on a Macbook Air. It still is no coming up.
      Tried a Beast and it works. Is there something different one has to do for the Mini?
      a month later
      david Hi. Today I have the opposite issue - the MINI does boot but the BBB does not. I have tried rebooting the Mac, going to http://bela.local (which works for the MINI), and 192.168.6.2 or 192.168.7.2 a number of times with no success. Am I forgetting something?
        david the BBB does not [boot]
        Does that mean you see no flashing lights at all? Or is it that you see the "heartbeat" pattern but the network interface does not show up on the host? Does /Volume/BELABOOT appear?
        Sorry should have indicated that I have a steady and flashing blue lights on the Bela board (I have just tried again and it is the same). What is puzzling me is that the Bela Mini board comes up OK but the Bela BBB board does not. I am not familiar with /Volume/BELABOOT sorry.
          david I am not familiar with /Volume/BELABOOT sorry.
          If you open a finder window, on the left hand side you should see "Locations":
          do you see BELABOOT there?
          Additionally, can you post the output you get running each of the following commands in the terminal after the board has booted for more than one minute?
          ls /dev/tty.*
          ifconfig
          system_profiler SPUSBDataType
          ioreg -p IOUSB -w0 -l
          Is there a program set to run on boot on the board?
          Yes there is a BELABOOT in the finder window
          There is a bootable program on the board which is working in stand-alone mode
          Here are the terminal outputs (rather long ..):
          dmh8@Davids-Air-10 ~ % ls /dev/tty.*
          /dev/tty.Bluetooth-Incoming-Port	/dev/tty.usbmodem__bela__6
          dmh8@Davids-Air-10 ~ % ifconfig
          	inet6 ::1 prefixlen 128
          stf0: flags=0<> mtu 1280
          	options=400<CHANNEL_IO>
          	ether d0:81:7a:ac:9b:e0
          	inet6 fe80::454:f321:d4a9:a347%en0 prefixlen 64 secured scopeid 0x4
          	inet 192.168.8.106 netmask 0xffffff00 broadcast 192.168.8.255
          	inet6 fda8:e544:6171:4300:1806:6fe3:d011:14e1 prefixlen 64 autoconf secured
          	media: autoselect
          	status: active
          	ether 82:18:47:e5:fa:00
          	status: inactive
          	Configuration:
          		ipfilter disabled flags 0x0
          	        ifmaxaddr 0 port 5 priority 0 path cost 0
          	media: <unknown type>
          	status: inactive
          p2p0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 2304
          	ether 02:81:7a:ac:9b:e0
          	media: autoselect
          	status: inactive
          	ether be:2c:ed:4a:32:0d
          	inet6 fe80::bc2c:edff:fe4a:320d%awdl0 prefixlen 64 scopeid 0x8
          	media: autoselect
          	status: active
          	inet6 fe80::bc2c:edff:fe4a:320d%llw0 prefixlen 64 scopeid 0x9
          	media: autoselect
          	status: active
          	inet6 fe80::fb55:c84d:976d:844b%utun0 prefixlen 64 scopeid 0xa
          	inet6 fe80::d6e:d5e6:78be:588b%utun1 prefixlen 64 scopeid 0xb
          	inet6 fe80::ce81:b1c:bd2c:69e%utun2 prefixlen 64 scopeid 0xc
          utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1400
          en9: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
          	ether be:1a:b7:ce:8e:3a
          	media: autoselect (none)
          	status: inactive
          dmh8@Davids-Air-10 ~ % system_profiler SPUSBDataType
          2022-03-02 15:07:46.145 system_profiler[2739:77219] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
          2022-03-02 15:07:46.146 system_profiler[2739:77219] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
          USB:
              USB 3.0 Bus:
                Host Controller Driver: AppleUSBXHCIWPT
                PCI Device ID: 0x9cb1
                PCI Revision ID: 0x0003
                PCI Vendor ID: 0x8086
                  BRCM20702 Hub:
                    Product ID: 0x4500
                    Vendor ID: 0x0a5c  (Broadcom Corp.)
                    Version: 1.00
                    Manufacturer: Apple Inc.
                    Location ID: 0x14300000
                      Bluetooth USB Host Controller:
                        Product ID: 0x828f
                        Vendor ID: 0x05ac (Apple Inc.)
                        Version: 1.50
                        Location ID: 0x14330000
                  Bela:
                    Product ID: 0x0104
                    Vendor ID: 0x1d6b  (The Linux Foundation)
                    Version: 1.01
                    Serial Number: __bela__
                    Speed: Up to 480 Mb/s
                    Manufacturer: Augmented Instruments Ltd
                    Location ID: 0x14100000 / 18
                    Current Available (mA): 500
                    Current Required (mA): 500
                    Extra Operating Current (mA): 0
                    Media:
                      File-Stor Gadget:
                        Capacity: 70.6 MB (70,631,936 bytes)
                        Removable Media: Yes
                        BSD Name: disk2
                        Logical Unit: 0
                        Partition Map Type: Unknown
                        S.M.A.R.T. status: Verified
                        USB Interface: 4
          dmh8@Davids-Air-10 ~ % ioreg -p IOUSB -w0 -l
          +-o Root  <class IORegistryEntry, id 0x100000100, retain 17>
            |   "IOKitBuildVersion" = "Darwin Kernel Version 21.3.0: Wed Jan  5 21:37:58 PST 2022; root:xnu-8019.80.24~20/RELEASE_X86_64"
            |   "OS Build Version" = "21D62"
            |   "OSKernelCPUSubtype" = 3
            |   "OSKernelCPUType" = 16777223
            |   "OSPrelinkKextCount" = 18
            |   "IORegistryPlanes" = {"IOPower"="IOPower","IOService"="IOService","IO80211Plane"="IO80211Plane","IOUSB"="IOUSB","CoreCapture"="CoreCapture","IOACPIPlane"="IOACPIPlane","IODeviceTree"="IODeviceTree"}
            |   "IOConsoleLocked" = No
            |   "IOConsoleUsers" = ({"kCGSSessionOnConsoleKey"=Yes,"kCGSSessionLoginwindowSafeLogin"=No,"kSCSecuritySessionID"=100003,"kCGSessionLongUserNameKey"="David M Howard","kCGSSessionUserIDKey"=501,"kCGSSessionSystemSafeBoot"=No,"kCGSSessionUserNameKey"="dmh8","kCGSSessionIDKey"=257,"kCGSSessionGroupIDKey"=20,"kCGSessionLoginDoneKey"=Yes,"kCGSSessionAuditIDKey"=100003})
            |   "IOKitDiagnostics" = {"Instance allocation"=17308552,"Container allocation"=7099433,"Pageable allocation"=1080582144,"Classes"={"IONDRVFramebuffer"=0,"AppleSNBFBUserClient"=0,"IGAccelCommandQueue"=15,"IOHIDEventServiceFastPathUserClient"=0,"IONaturalMemoryCursor"=0,"IOKitDiagnosticsClient"=0,"IOAudioClientBufferSet"=0,"DspFuncBuzzKill"=0,"AppleUSBDiagnostics"=0,"IOUSBHostHIDDevice"=0,"AppleHDAMikeyInternalCS4208"=1,"AppleUSBRequest"=1,"AppleUSBXHCIIsochronousRequestPool"=1,"IOEventLink"=0,"IGAccelSharedUserClient"=30,"AppleASMedia1042USBXHCICommandRing"=0,"AppleHDATDM_Codec"=0,"IOUSBMassStorageDriverRequestTimer"=0,"IOUserBlockStorageDevice"=0,"IOHDACodecDevice"=2,"AppleAHCIWorkLoop"=1,"IOThunderboltDeficitCommandQueue"=1,"IORegistryEntry"=91,"IOUSBMassStorageUASDriver"=0,"AppleAHCIPort"=1,"AppleHDAWorkLoop"=2,"IORTC"=1,"IOHIDevice"=0,"IOPCIEventSource"=0,"AppleThunderboltNHIType4"=0,"com_apple_driver_AppleUSBCardReaderInterfaceNub"=0,"IOThunderboltAbstractMicro"=1,"DspFuncUserClient"=0,"IO80211DriverCommandDescriptor"=0,"AppleHDAHardwareConfigDriverLoader"=0,"AppleSmartBatteryManager"=1,"IOPMGR"=0,"AppleHDATDM_CS42L81"=0,"IOThunderboltXDPropertiesDirectory"=2,"IOMemoryCursor"=1,"IOBreaker"=0,"AppleIntelFramebuffer"=3,"AppleUSBUserHCIDevice"=0,"AppleHDAFunctionGroup_80862807"=0,"IOUSBLowLatencyCommandLegacy"=0,"AppleThunderboltIPReceiveCommand"=0,"AppleUSBUserHCITransferQueue"=0,"AppleUSB20HubPort"=3,"AppleHIDKeyboardEventDriver"=0,"AIDCircularBufferShared"=0,"AppleUSB20KeyboardHub"=0,"AppleThunderboltNHIReceiveRingManager"=1,"EFIData"=92,"AppleUSBXHCIPort"=2,"IOAccelCommandQueue"=1,"DspFunc4ChOutput"=0,"com_apple_driver_AppleUSBCardReaderUMC"=1,"IGRangeAllocator"=34,"IOSurfaceSharedEventNotification"=0,"AppleHDAFunctionGroupWM8800"=0,"AppleKeyStoreUserClient"=21,"HDCPCLASS"=0,"IOSMBusRequest"=0,"IntelFBClientControl"=1,"IOThunderboltSwitchType1"=0,"IOSkywalkPacket"=1,"DspFuncBeamFormer"=0,"hv_vmx_vcpua_t"=0,"SoundflowerEngine"=2,"CSRBluetoothHostControllerUSBTransport"=1,"AppleUpstreamUserClientDriver"=3,"IOHIDResourceQueue"=1,"IOStorage"=4,"AppleACPILid"=1,"IOPMServiceInterestNotifier"=123,"IOAccelSegmentResourceList"=0,"AppleUSBRequestPool"=2,"IOSerialStreamSync"=2,"IOHIDConsumer"=0,"IO80211AWDLMulticastPeer"=1,"AppleUSBHostCompositeDevice"=1,"IOAHCIBlockStorageDevice"=1,"IOThunderboltXDPropertiesEntry"=12,"IOHIDClientData"=4,"IOSharedInterruptController"=1,"IOBluetoothMemoryDescriptorRetainer"=0,"IOGraphicsWorkLoop"=2,"hv_vmx_vm_t"=0,"AppleHSSPIController"=1,"AppleHDATDMBusManagerCS4208"=0,"IGAccelVideoContextMedia"=0,"IOTimeSyncClockManagerUserClient"=1,"OSSerializer"=46,"IOUserEthernetResourceUserClient"=0,"AppleAHCIWatchdogTimer"=1,"IOThunderboltConfigMultiReadCommand"=1,"IOPCIMessagedInterruptController"=1,"OSCollection"=5,"IOThunderboltSet"=29,"IOUSBDeviceUserClientV2"=1,"SmbusHandler"=1,"AppleHDAEngineOutput"=1,"AIDReporters"=0,"AIDInterface"=0,"IOTimeSyncUnicastUDPv4PtPPort"=0,"_IOServiceNullNotifier"=1,"IOUserNetworkRxCompletionQueue"=1,"IOSkywalkMemorySegment"=69,"com_apple_driver_eficheckuserclient"=0,"IOBluetoothHCIUserClient"=1,"hv_vioapic_t"=0,"AppleUSB20InternalIntelHubClient"=0,"com_apple_driver_pm_cpu_reporter"=1,"AppleMultitouchEventDriverV2Wrapper"=1,"IOTimeSyncPortManager"=0,"AppleDisplay"=0,"IONetworkStackUserClient"=1,"AppleAPFSUserClient"=0,"_IOServiceNotifier"=612,"AppleHDAFunctionGroupGT216"=0,"IOInterleavedMemoryDescriptor"=0,"AppleUSBLegacyInterfaceUserClient"=0,"AppleUSBUserHCIResources"=1,"IOServiceStateNotificationEventSource"=0,"AppleGraphicsDevicePolicy"=1,"IGAccel2DContext"=3,"AppleHDAFunctionGroupCS4208"=1,"IOSkywalkEthernetInterface"=2,"IGScheduler"=1,"IOTimeSyncEthernetInterfaceAdapter"=0,"DspFuncVolume_4ch"=0,"AppleUSBXHCILPTCommandRing"=1,"IOUSBHostDevice"=14,"AppleHSBluetoothInterface"=0,"IOSubMemoryDescriptor"=6,"AppleUSBRequestCompleter"=1,"IOThunderboltXDPropertiesCache"=1,"IOSKArena"=13,"IOAVBNubUserClient"=0,"AppleThunderboltNHIIntelPCI"=1,"IOAHCIPortInterface"=1,"IOThunderboltXDomainLink"=0,"AppleFDEKeyStoreUserClient"=0,"AppleMultitouchTrackpadHIDEventDriver"=1,"IOServiceUserNotification"=503,"IOThunderboltConfigPrepareToSleepCommand"=1,"IO80211ThroughputCache"=0,"AppleUSBHostResourcesTypeCBPC"=0,"IO80211PacketDescriptor"=4096,"DspFuncPreGain"=0,"IOThunderboltControllerType4"=0,"IOSkywalkNetworkBSDClient"=2,"IOHIDReportElementQueue"=0,"AirPort_BrcmNIC_InputQueue"=1,"IOAccelDevice2"=1,"com_apple_filesystems_apfs"=0,"IGHardwareBlit3DContext"=16,"DigitizerTransducer"=0,"IOAccelCLContext2"=0,"IOBluetoothL2CAPInformationFrameMemoryBlock"=0,"AppleUSBUserHCITransferStructPool"=0,"AppleHDAController"=2,"IOMbufMemoryCursor"=1,"IOSKRegionMapper"=6,"IOSKMemoryArray"=0,"AppleThunderboltDPAdapterFamily"=1,"IOCPU"=1,"IOAccelMTLEvent2"=0,"IOAccelDisplayMachine"=1,"IOAccelEventMachineFast2"=1,"OSAction_IOUserNetworkEthernet__DataAvailable"=0,"AppleACPIEventPoller"=1,"IO80211ActionFrameDescriptor"=0,"IONetworkStack"=1,"DspFuncBiquad"=0,"CCDataPipeBlob"=0,"IOTimeSyncNetworkPortUserClient"=0,"ApplePlatformEnabler"=1,"IOThunderboltTransmitQueue"=1,"IOSlaveMemory"=0,"IOSCSIPeripheralDeviceType07"=0,"ACMKeybagKernelService"=0,"AppleHDAFunctionGroupATI_RS710"=0,"AppleUSBECMDataNC"=0,"ACMRestrictedModeAnalyticsKernelService"=1,"IO80211Interface"=1,"AppleUSBUserHCIIsochronousTransferQueue"=0,"IOSimpleReporter"=286,"AppleUSBXHCILPTHB"=0,"IOModemSerialStreamSync"=0,"AppleHDATDM_CS42L83"=0,"IOUSBMassStorageCBIDriverNub"=0,"IOHDIXControllerUserClient"=0,"com_apple_AppleFSCompression_AppleFSCompressionTypeZlib"=1,"AppleHDATDMAmpMAX98706"=0,"DspFunc2Dot2Crossover"=0,"AppleAHCIEventSource"=1,"AppleThunderboltNHIType2"=1,"IOUSBInterface"=1,"IOAccelChannel2"=1,"CCFaultReporter"=1,"AppleUSBLegacyRoot"=1,"IO80211EventSource"=1,"AppleHDAPathControl"=8,"AGPMClient"=0,"AppleHDATDMAmpTAS5764L"=0,"IOSCSIPrimaryCommandsDevice"=1,"IOTimeSyncDomainUserClient"=0,"IOAccelEventFence"=0,"IOAHCIPollerInterface"=1,"AppleSMBusControllerMCP"=0,"AppleMCCSControlGibraltar"=0,"IOThunderboltConfigWriteCommand"=3,"IOHIDProviderPropertyMerger"=0,"IOUSBDevice"=1,"IOGDiagnosticUserClient"=0,"IOThunderboltCommand"=5,"IOAccelVidMemory"=0,"AppleSEPControl"=0,"AppleHDAEngineInput"=1,"IOServiceNotificationDispatchSource"=0,"IOThunderboltCallbackEventSource"=5,"IOUSBMassStorageResourceUserClient"=0,"IOAccelDisplayPipeTransaction2"=2,"IOSkywalkNetworkInterface"=1,"IOHIDKeyboard"=0,"IOTimeSyncEdgeTimeCaptureUserClient"=0,"AIDQueueEventSourceWorkItem"=0,"IOACPIPlatformDevice"=162,"IOUserService"=2,"AppleSATAExpress"=0,"_IOServiceInterestNotifier"=149,"AppleUSBHostRequestCompleter"=14,"IOBluetoothLocalUtilityEventSource"=0,"IntelAccelerator"=1,"IOFramebufferI2CInterface"=3,"IOPowerConnection"=111,"IOFBController"=1,"AppleThunderboltIPTransmitCommand"=0,"SCSITaskUserClient"=0,"IOWatchDogTimer"=0,"IOThunderboltConfigPollQuadletCommand"=0,"IOEventSource"=22,"IOUserNetworkTxCompletionQueue"=1,"IODMACommand"=85,"IOMachPort"=6316,"IOPMinformeeList"=164,"IO80211AsyncUserClientParameters"=1,"IOThunderboltReceiveQueue"=1,"IO80211LinkRecovery"=0,"AppleCredentialManager"=1,"AppleUSB30XHCITypeCPort"=0,"MEIClientList"=1,"AppleACPIPowerResource"=0,"CCLogStream"=5,"IOThunderboltXDPropertiesImmediateValue"=8,"IOPCIHostBridgeData"=1,"AGDPUserClient"=1,"AppleUSBHostControllerIsochEndpoint"=0,"IOHIDEvent"=0,"IO80211AsyncEventUserClient"=1,"DspFuncNoiseCanceller"=1,"IOAccelTask"=1,"IOAccelGLContext2"=1,"OSDictionary"=18059,"AppleUSB20InternalHub"=1,"AppleMultitouchMouseHIDEventDriver"=0,"IGInterruptBridge"=1,"AppleUSBXHCIParkingCommandRing"=1,"IOHDACodecDeviceUserClient"=0,"AppleUSBHostBulkHIDDevice"=0,"IOAGPDevice"=0,"IODisplayWrangler"=1,"IGStolenMemoryPool"=1,"AppleFDEKeyStore"=1,"AppleUSB20InternalIntelHub"=0,"IOUSBMassStorageDriverUFIDevice"=0,"AppleUSBIORequest"=70,"IOThunderboltConfigXDomainROMChangedRequestCommand"=0,"_IOUserServerCheckInCancellationHandler"=0,"IOUSBPipeV2"=0,"DspFuncFIRdirect"=0,"AppleUSBHostLegacyClient"=14,"IOUSBMassStorageResource"=1,"IO80211HistogramReporter"=0,"AppleLMUClient"=3,"AppleHDATDMSinkDevice"=0,"IOTimeSyncUnicastUDPv6PtPPort"=0,"IGAccelSurface"=9,"IOAccelKernelMappedMemory"=69,"Dont_Steal_Mac_OS_X"=1,"IOAudioTimeIntervalFilterIIR"=0,"IOHIDEventSource"=4,"GTraceBuffer"=4,"OSSet"=4237,"AppleUSBUserHCIUserClient"=0,"AppleIntelPanel"=1,"IOAccelBlockFence"=0,"DspFuncCalibrationEQ"=0,"AppleUSB30XHCICardReaderPort"=1,"IOAudioEngineUserClient"=33,"AGPMHeuristic4"=0,"IOPCIHostBridge"=1,"HDCP2CLASS"=0,"AppleHDAWidget_80862805"=0,"DspFuncChOutput"=0,"IGSemaphoreWaitBufferQueue"=60,"AppleAHCIDiskDriver"=1,"IOCommand"=112,"AppleHDAWidgetAD1984"=0,"AppleUSB30GLHub"=0,"IOTimeSyncTranslationMach"=1,"IOAudioTimerEvent"=0,"CCDataPipe"=3,"DspPatchPoint"=32,"IOSCSIProtocolInterface"=2,"AppleTDMType00"=0,"IOTimeSyncNanosecondSnapshotService"=0,"AppleUSBXHCIAR"=0,"IOPlatformIO"=0,"IOAVBNub"=1,"IOBluetoothGamepadHIDDriver"=0,"com_apple_driver_AppleUSBCardReaderSBC"=1,"AppleHDAFunctionGroupALC885"=0,"IGAccelVideoContextMain"=0,"AppleHDAFunctionGroup"=1,"AppleHDAFunctionGroupExternalControl"=1,"IOGUIDPartitionScheme"=1,"AppleHDANode"=2,"IOUSBMassStorageUFIDriverNub"=0,"OSCollectionIterator"=14,"AppleEFIRuntime"=1,"IOFilterScheme"=0,"AppleMCCSIOController"=6,"AppleUSBHostResources"=1,"AppleAHCIRequestTimer"=1,"IOApplePartitionScheme"=0,"CamelliaTcon2"=0,"IOSurfaceRootUserClient"=37,"IOSkywalkInterface"=1,"IO80211PeerExtendedStats"=0,"IODisplay"=1,"IOTimeSyncTranslationPMGR"=0,"TDMConfig"=0,"IOHIDAsyncReportQueue"=0,"IOSkywalkPacketQueue"=5,"IOUserEthernetResource"=1,"IOThunderboltSwitch"=1,"IOBasicOutputQueue"=1,"AppleHDACodec"=1,"AppleUSBHostControllerListElement"=0,"AppleSEPIntelIOP"=0,"IOThunderboltConfigReadCommand"=4,"IOAccelSharedUserClient2"=1,"AppleGPUWranglerClient"=4,"IOFramebufferSharedUserClient"=1,"IOUSBControllerIsochListElement"=0,"IOPacketQueue"=1,"IOHITabletPointer"=0,"IGAccelDisplayPipe"=3,"IOAVBAudioLoader"=0,"IO80211PeerBssSteeringManager"=1,"IOUserClient"=41,"AppleUSBHostControllerIsochListElement"=0,"AppleUSB30HubPort"=0,"IOHIDEventSystemUserClient"=1,"AppleHDAWidgetFactory"=0,"IOHDIXHDDrive"=0,"DIDeviceRequestPool"=0,"AGPM"=1,"AppleSystemPolicy"=1,"IOSurfaceDescriptor"=0,"AppleUSB30Hub"=0,"IO80211AWDLPeer"=0,"IOTimeSyncWiFiControllerAdapter"=0,"AppleIPDormancyHandler"=1,"IOAccelEventMachine2"=1,"HIDSPIQueueEventSource"=3,"IOSlaveRelayCommandPool"=0,"IGGarbageCollector"=1,"DspFunc3ChOutput"=0,"IOAccelBufferMemoryDescriptorPool2"=1,"AppleMCCSControlModule"=3,"IO80211SimpleReporter"=23,"IOAccelContextEventFence"=0,"ACMKernelService"=5,"IOUSBHostPipe"=1,"IOPolledFilePollers"=1,"CoreAnalyticsTestUserClient"=0,"AppleHSSPINub"=1,"IO80211String"=0,"IOHDIXHDDriveOutKernelUserClient"=0,"IOUSBNotification"=0,"AppleHDAWidgetSTAC9220"=0,"IOEthernetAVBController"=0,"IOThunderboltSwitchI2CCommandQueue"=1,"AppleUSBUserHCIPipe"=0,"AppleIntelPAVPEventSource"=1,"AppleHDAMikeyInternal"=1,"IOSkywalkRxSubmissionQueue"=1,"IOSkywalkNetworkKDPPoller"=0,"AppleUSBHostDeviceUserClient"=2,"IOUSBInterfaceUserClient"=1,"IOAccelGPURestartReport2"=0,"IOFramebufferParameterHandler"=3,"IOSurface"=313,"IOGatedOutputQueue"=16,"IOThunderboltLinkController"=2,"AppleUSBRootHubDevice"=1,"com_apple_filesystems_lifs"=1,"AppleHDAFunctionGroupMCP89"=0,"com_cycling74_driver_SoundflowerDevice"=1,"IOReportLegend"=0,"AppleTDMControlLUN"=0,"IOTimeSyncPseudoStreamingInterfaceAdapter"=0,"IOThunderboltConfigCompareSwapCommand"=0,"AppleUSBXHCIEndpoint"=13,"IOSurfaceMTLSharedEventFence"=0,"IOHIDEventQueue"=0,"IOAccelShared2"=30,"AppleIntelUSBXHCICommandRing"=0,"AIDService"=0,"IOSurfaceSendRight"=0,"AppleAPICInterruptController"=1,"IOSkywalkNetworkController"=0,"IOTimeSyncService"=1,"AppleSMC"=1,"AppleXsanDriver"=0,"IOCommandPool"=11,"IOBlockStorageDevice"=2,"IGHardwarePerProcessPageTable64"=31,"AGPMHeuristic"=1,"IOPMrootDomain"=1,"IOAccelFenceMachine"=1,"AppleEffaceableStorage"=0,"AppleUSBNetworkingCommandPool"=0,"IO80211VirtualInterfaceNamer"=1,"IOUSBDeviceUserClient"=1,"OSUserMetaClass"=419,"KextAuditUserClient"=1,"AirPort_BrcmNIC_Interface"=1,"IOI2CInterfaceUserClient"=0,"IOThunderboltDispatchCallback"=1,"AppleHDAFunctionGroupAD1984"=0,"DspFuncControlFreak"=0,"AppleThunderboltDPInAdapter"=1,"IOHDIXCommandQueue"=0,"_IOOpenServiceIterator"=0,"IOCommandGate"=1011,"EventElementCollection"=0,"DspParameter"=106,"IOWorkGroup"=0,"AppleUSBNetworkingHostCommandPool"=0,"IOUSBMassStorageDriver"=2,"IOPMRequestQueue"=2,"IOThunderboltSwitchType6"=0,"IOSkywalkRxCompletionQueue"=1,"AppleECSMBusController"=1,"CamelliaTcon1"=0,"IOBlockStorageDriver"=3,"IOWatchdogx86"=1,"DspFuncThermalSpeakerProtection"=0,"AppleHDAWidgetALC262"=0,"IOHIDWorkLoop"=1,"IOThunderboltArray"=5,"IOBlockStorageServices"=2,"AirPort_BrcmNIC_P2PInterface"=2,"AppleACPIACAdapter"=1,"IOUSBInterfaceIterator"=0,"AppleThunderboltPCIDownAdapter"=4,"IODTPlatformExpert"=1,"AppleHDAControllerUserClient"=0,"IOBluetoothMemoryBlock"=0,"IOMbufBigMemoryCursor"=0,"IOTimeSyncLocalClockPort"=0,"AppleUSBXHCICommandRing"=1,"AppleUSBXHCIIsochronousEndpoint"=0,"AppleUSBXHCIInterrupter"=1,"IOSlaveMemoryBuffer"=0,"IOAppleLabelScheme"=0,"IOBluetoothHostControllerTransport"=1,"AppleUSBXHCIPCI"=1,"BroadcomBluetooth20703USBTransport"=1,"IO80211Peer"=1,"RootDomainUserClient"=98,"DspFuncSplineLimiter"=1,"IOThunderboltTimerCommand"=5,"AppleAPFSContainer"=1,"AppleThunderboltIPMSMInterface"=0,"AppleSEPDiscovery"=0,"DspFuncMozartCompressorDualBand"=1,"IONDRV"=0,"AppleHSBluetoothNub"=0,"AppleSATAExpressPort"=0,"IOPCIDevice"=26,"IOThunderboltConfigCommand"=9,"AppleUSB20XHCIPort"=3,"IOBluetoothInactivityTimerEventSource"=0,"IGAccelTask"=31,"IGAccelStatistics"=1,"IOAccelMemoryAllocator2"=0,"OSNumber"=46845,"AIDUserClientLogger"=0,"IOThunderboltConfigXDomainPathTeardownRequestCommand"=0,"AppleThunderboltNHITransmitRingManager"=1,"AppleThunderboltNHIMemoryBlock"=0,"IOThunderboltIECSNub"=0,"IOAHCIDiskQueueManager"=1,"CCFaultReport"=0,"AppleHDAFunctionGroupExternalControl_VirtualGPO"=0,"AppleUSBUserHCIPort"=0,"IOTimeSyncTimedEdgeGeneratorUserClient"=0,"IOGDiagnosticGTraceClient"=1,"AppleUSBXHCI"=1,"IOTimeSyncIntervalFilter"=0,"IOTimeSyncNetworkPort"=0,"MEIEventSource"=1,"AppleThunderboltNHITransmitRing"=12,"AppleUSBHostPacketFilter"=0,"AppleIntelCNLUSBXHCI"=0,"ACMFirstResponderKernelService"=1,"AppleHDAFunctionGroup_1002AAA0"=0,"IOThunderboltConfigErrorCommand"=1,"IOTimeSyncUnicastLinkLayerPtPPort"=0,"AppleIntelPchSeriesAHCIPort"=0,"IOHIDKeyboardDevice"=0,"IOThunderboltEEPROM"=2,"IOUserNotification"=2,"IOHDAStream"=2,"AppleGPUWrangler_GPUPostStartWorkItem"=0,"AppleUSBXHCILPT"=1,"com_apple_AppleFSCompression_AppleFSCompressionTypeDataless"=1,"AGPMHeuristic3"=0,"IOSurfaceSharedEventListener"=0,"IOThunderboltControlPathListener"=5,"AppleUSBXHCITransferRing"=13,"AppleThunderboltNHI"=1,"AppleAPFSSnapshot"=1,"IOWrappedMemoryDescriptor"=0,"AppleHDAFunctionGroupATI_Broadway"=0,"IOThunderboltHopSet"=18,"IOThunderboltXDPropertiesLeafData"=0,"IOUSBHubDevice"=0,"AppleUSBHostDeviceIdler"=3,"IOPMWorkQueue"=1,"IOTimeSyncFilteredService"=0,"AppleUSBACMData"=1,"AIDImageDownloader"=0,"AIDEventLogger"=0,"AppleSMBusControllerUserClient"=0,"AppleUSB30XHCIPort"=3,"IOGuardPageMemoryDescriptor"=0,"IOThunderboltTimerCommandQueue"=1,"IOSlaveProcessorUSBHostRelay"=0,"IODeblocker"=0,"AppleRTC"=1,"AppleUSBXHCISPT"=0,"IOTimeSyncWiFiInterfaceAdapter"=0,"AppleIntelSPIDevice"=1,"AppleThunderboltIPControlCommand"=0,"IOAccelDeviceShmem"=39,"X86PlatformShim"=1,"IOSharedDataQueue"=6,"IGCanonicalRangeAllocator"=30,"IOSyncer"=0,"AppleGPUWrangler_WorkItem"=0,"AppleDeviceManagementHIDEventService"=0,"AppleThunderboltIPConnection"=0,"IGHardwareRingBuffer"=3,"AppleUSBECMData"=0,"IORangeAllocator"=3,"HDCP1CLASS"=0,"IOKitRegistryCompatibility"=1,"IOMediaBSDClient"=7,"OSBoolean"=2,"AppleSEPCommand"=0,"OSAction"=10,"AppleUSBXHCIRequest"=31,"IOAccelSubmitter2"=2,"OSAction_IOHIDEventService__SetUserProperties"=0,"IOWorkQueue"=1,"ApplePlatformEnablerUserClient"=0,"CoreAnalyticsUserClient"=1,"DspFuncAutoGainControl"=0,"AppleACPIInterruptLink"=0,"LogManagerDevice"=3,"IOHIDInterface"=4,"IOPCI2PCIBridge"=11,"IOAppleBluetoothHIDDriver"=0,"IOSurfaceRoot"=1,"com_apple_BootCache"=1,"AppleHDA8086_9D70Controller"=0,"IOUSBInterfaceUserClientV3"=2,"IOMapper"=2,"IOUSBMassStorageUFIDriver"=0,"IOUSBHostStream"=0,"IOHIDSystem"=1,"IOThunderboltConfigWriteQuadletCommand"=2,"IOHIDDeviceElementContainer"=4,"AIDReporter"=0,"IOAccelRangeAllocator"=0,"IOUSBController"=1,"AppleHIDKeyboardEventDriverV2"=1,"com_apple_driver_eficheck"=1,"IOAccelFIFOChannel2"=1,"AppleHDAFunctionGroupATI_RS730"=0,"AppleHDAWidgetATI_Park"=0,"_IOServiceStateNotification"=0,"IOThunderboltSwitchType4"=0,"AppleBacklightParameterHandler"=1,"AppleACPICPU"=4,"AppleMCCSControlFamily"=1,"IONetworkInterface"=1,"KernelRelay"=0,"IOThunderboltConfigCMOverrideCommand"=1,"IGFence"=0,"IOBluetoothACLMemoryDescriptor"=0,"IOHIDOOBReportDescriptor"=0,"AppleASMediaUSBXHCIStreamingEndpoint"=0,"IONetworkUserClient"=0,"AppleThunderboltDPOutAdapter"=0,"IOReportUserClient"=4,"AppleUserHIDEventService"=0,"DspFunc2To4Splitter"=0,"IOThunderboltConfigXDomainResponseCommand"=6,"AppleUSBXHCIPipe"=13,"DspFuncDRC"=0,"IOServiceStateNotificationDispatchSource"=0,"IOHDACodecFunction"=1,"IOSkywalkLegacyEthernet"=1,"IOCharacterDevice"=3,"IOUSBNub"=2,"AppleUSBHostMergeProperties"=1,"_IOConfigThread"=0,"IOSkywalkRing"=4,"AppleMultitouchHIDEventDriverV2"=1,"AppleHDAEngine"=2,"AppleUSBXHCIARRequest"=0,"IOTimeSyncClockManager"=1,"IO80211FlowQueueDatabase"=3,"AppleHDAWidgetGK10X"=0,"IGHardwareContext"=22,"IGHardwareResolveContext"=24,"AppleUSBHostController"=1,"IODiskImageBlockStorageDeviceOutKernel"=0,"AppleMultitouchHIDService"=0,"IOThunderboltConfigModifyQuadletCommand"=0,"IOTimeSyncFDPtPPort"=0,"MEIDriverIOEventSource"=3,"AppleSEPXART"=0,"IOUSBMassStorageDriverUFIStorageServices"=0,"IOThunderboltPath"=0,"IOCPUInterruptController"=1,"AppleHDAFunctionGroupFactory"=0,"AppleThunderboltHAL"=1,"IO80211P2PInterface"=1,"CCLogPipeUserClient"=0,"IOUserServer"=7,"IOSkywalkKernelPipeBSDClient"=0,"AppleHDAFunctionGroupALC262"=0,"AppleIPAppenderUserClient"=0,"CoreAnalyticsHub"=1,"PMHaltWorker"=0,"AppleHDATDMDevice"=0,"IGHardwarePageTable"=2,"AppleMCCSUserClient"=0,"IOUserNetworkPacket"=21760,"IGStolenMemoryDescriptor"=282,"AppleHSBluetoothHIDDriver"=0,"SCSITaskUserClientIniter"=0,"AppleUpstreamUserClient"=0,"IOSlaveCPU"=0,"IOAudioTimeIntervalFilter"=0,"AppleUSBXHCIFL1100"=0,"AppleAHCIDiskQueueManager"=1,"AppleUSBTDMMassStorageClass"=0,"IOBootFramebuffer"=0,"IOHIDResourceDeviceUserClient"=1,"IOInterruptController"=5,"DspFunc"=5,"SMCPolledInterface"=1,"AppleASMediaUSBXHCI"=0,"IOSkywalkPacketPoller"=0,"IOEthernetInterface"=3,"AppleUSBHostResourcesClient"=1,"IOSerialATARequestFIS"=68,"AppleHDAFunctionGroup_80862805"=0,"IOTimeSyncTimeLineFilter"=0,"AppleHSSPIControllerUserClient"=0,"AppleUSBXHCIARIsochronousRequest"=0,"AGDCPlugin"=1,"IOMbufLittleMemoryCursor"=0,"AppleHDATDMBusManager"=0,"AppleUSBHubPolicyMaker"=1,"IGPagePool"=4,"IOGraphicsControllerWorkLoop"=1,"IOConditionLock"=0,"IO80211WorkLoop"=1,"AppleDiskImageDevice"=0,"AppleIntelLpssSpiController"=1,"IOUSBUserClientLegacy"=1,"AppleHDAFunctionGroupGK10X"=0,"AppleUSBHostIORequestPool"=13,"IOAccel2DContext2"=1,"AppleUSBHostFrameworkClient"=0,"com_apple_driver_pm_pch_reporter"=1,"DspFuncMultiBandDRC"=0,"IOAccelerator"=1,"IGGCObject"=1,"IOUserResources"=1,"AppleAPFSVolume"=6,"IOWatchdogUserClient"=1,"IOFenceTransaction"=0,"IOSkywalkStatisticsReporter"=0,"AppleUSBXHCISparseRequest"=0,"PMTraceWorker"=1,"IOAudioControl"=3,"IOSCSIBlockCommandsDevice"=1,"AppleSMBusControllerICH"=0,"IO80211QueueCall"=1,"ACMT208ProxyKernelService"=0,"IOI2CInterface"=1,"AppleHDAWidgetCS4206"=0,"AppleHDAHDMI_DPDriver"=0,"IO80211QueueDescriptor"=3,"IOAccelStatistics2"=1,"IODTNVRAMVariables"=0,"AppleHDAFunctionGroupSTAC9220"=0,"IOUSBHostIOSource"=1,"IONetworkController"=1,"AppleIntelLpssDmac"=1,"OSString"=35220,"CCIOReporterHub"=2,"AppleUSBHub"=1,"IOThunderboltAbstractPath"=0,"IntelBDWMemoryManager"=1,"ApplePMTGraphicsInformation"=0,"IOUserIterator"=10,"DspFunc2To6Splitter"=0,"AppleMCCSParameterHandler"=3,"IOSortableConfigurationDescriptor"=0,"AppleCamIn"=1,"IOThunderboltConfigXDomainROMReadRequestCommand"=0,"AppleMobileFileIntegrityUserClient"=0,"AppleAHCI"=1,"AppleUSBXHCIIsochronousRequest"=5,"OSOrderedSet"=340,"AppleUSBNCMData"=0,"AppleUSBACMControl"=1,"IGAccelCLContext"=0,"IOThunderboltString"=36,"PMSettingHandle"=6,"AppleUSBXHCIStream"=0,"IOHIDEventDriver"=2,"DspFuncClientGainAdjust"=1,"TSNWiFiControlInterface"=0,"IOAudioStream"=5,"com_apple_driver_pm_flex_reporter"=1,"IOAccelContext2"=2,"AppleIntelPchSeriesAHCI"=0,"IOThunderboltSwitchType2"=1,"IOThunderboltIECSCommand"=0,"IOThunderboltConfigXDomainUUIDRequestCommand"=1,"AppleAPFSMedia"=1,"IOSurfaceBufferMemoryDescriptorPool"=0,"IOSerialBSDClient"=2,"APFSCryptoContext"=576,"IGAccelGLContext"=6,"IOStateReporter"=30,"IOThunderboltReceiveCommand"=16,"AGPMHeuristic2"=3,"IOBluetoothL2CAPMemoryBlock"=0,"AIDLoggerUserClient"=0,"AppleHPET"=1,"IONotifier"=4,"AppleUSBXHCIPPT"=0,"AppleUSBPipe"=0,"IOTimeSyncTimeLineFilterIIR128"=0,"IGMappedBuffer"=32,"IOThunderboltPort"=9,"IOFilterInterruptEventSource"=7,"IOThunderboltConfigNotifyAckCommand"=0,"IOLittleMemoryCursor"=0,"DspFuncGain"=0,"IOUserNetworkPacketBufferPool"=5,"IOHIDPointingDevice"=0,"IOSkywalkTxSubmissionQueue"=1,"AppleUSBXHCIWPT"=1,"_IOFramebufferNotifier"=17,"AppleSEPIntelIOPNub"=0,"IOThunderboltTunnelDriver"=2,"IGHardwareRingBufferBlit"=16,"IOBluetoothDataQueue"=0,"IOHDAController"=1,"AppleIntelSlowAdaptiveClockingManager"=1,"AppleUSBHostRequest"=2,"IODisplayAssertionUserClient"=0,"IGHardwareRingBufferVEBox"=0,"IOMedia"=8,"IOSKRegion"=59,"IGAccelMemoryMap"=1,"IO80211VirtualInterface"=1,"IOHistogramReporter"=7,"IOHIDAction"=0,"IOPlatformPluginFamilyPriv"=1,"AppleHDAFunctionGroupExternalControlFactory"=0,"IO80211AWDLPeerManager"=1,"IOPerfControlWorkContext"=35,"AppleSMBusDevice"=0,"IGHardwareGlobalPageTable"=1,"IOBluetoothMemoryBlockQueue"=1,"EndpointSecurityDriverClient"=1,"OSSymbol"=20615,"IOSurfaceSharedEventNotificationPort"=0,"AppleUserHIDDevice"=0,"IOSMBusController"=1,"IOAHCIDevice"=1,"IO80211LinkQualityMonitor"=0,"OSEntitlements"=998,"AppleACPIPlatformExpert"=1,"IORegistryPlane"=7,"AirPort_BrcmNIC_Timer"=58,"AppleUSBCDCControl"=1,"AppleUSBHostUserClient"=2,"AppleIntelUSBXHCI"=1,"IOUSBMassStorageDriverNub"=2,"IOHIDLibUserClient"=1,"IGAccelSysMemory"=1,"IOThunderboltFrameList"=19,"AppleUSBInterfaceIterator"=0,"IOSlaveEndpoint"=0,"AppleHDAFunctionGroupExternalControl_GPIO"=2,"AppleSMBusController"=0,"CCDataPipeBlobOS"=0,"AppleUSBXHCIInterrupterMSI"=3,"IOInterruptEventSource"=97,"IOSkywalkPacketBufferPool"=2,"AudioAUUCDriver"=1,"IOAccelRemoteMemory"=0,"AppleUSBUserHCI"=0,"IO80211ServiceRequestDescriptor"=0,"OSObject"=180,"IOBluetoothSerialManager"=1,"AppleHDAMikeyInternalCS8409"=0,"IGHardwarePerProcessPageTable"=1,"IOHDIXController"=1,"IOStateNotificationItem"=3,"TSNAssistedInterface"=0,"AppleMEClientController"=1,"IOMbufNaturalMemoryCursor"=1,"IOWatchdog"=1,"AppleHDAPathSet"=4,"IOKDP"=0,"CCIOReporterDataStream"=1,"IOSlaveRelayEndpoint"=0,"IOFence"=0,"IO80211AssociationJoinSnapshot"=1,"IOAccelTraceStreamConnection"=4,"IOBluetoothHIDDriver"=0,"AppleUSBNetworkingCommand"=0,"IOGraphicsDevice"=1,"IOThunderboltNumber"=175,"IOUSBControllerListElement"=0,"IOResources"=1,"AppleUSB20Hub"=1,"IGHardwarePerProcessPageTable32"=0,"IOAccelNamespace"=62,"AppleHDAWidgetAD1988"=0,"IOGraphicsSystemWorkLoop"=1,"DspFuncMultiBandCompressor"=0,"GMetricsRecorder"=0,"DIDeviceCreatorUserClient"=0,"IOSCSIPeripheralDeviceNub"=1,"RSNSupplicant"=1,"AppleUSBXHCIARRequestPool"=0,"IOSurfaceDeviceCache"=289,"IOAccelLegacyDisplayPipe"=0,"IOThunderboltConfigReadQuadletCommand"=2,"AGPMController"=1,"AppleUSBXHCIRequestPool"=2,"IOThunderboltXDLocalPropertiesCache"=1,"CoreAnalyticsPipe"=1,"AppleGraphicsDeviceControlClient"=7,"IOUSBBus"=1,"IGHardwareRingBufferMain"=61,"AppleUSBLegacyDeviceUserClient"=1,"IOServicePM"=164,"IOBigMemoryCursor"=0,"AppleBusControllerCS8409"=0,"AppleSmartBattery"=1,"TSNInterface"=0,"AppleThunderboltNHIType3"=0,"IGAccelVideoContextVEBox"=0,"ACMRestrictedModeKernelService"=1,"AppleUSB30CameraKitHub"=0,"AppleUSBHostBusCurrentPool"=0,"AppleHDAWidgetMCP89"=0,"IOMemoryDescriptor"=3,"IOTimeSyncTimeSyncTimePort"=0,"IOAccelGLDrawableUserClient"=0,"AppleTDMAKSServices"=0,"AppleIntelLpssGspi"=1,"AppleHDAFunctionGroupATI_RS780"=0,"IOHIDActionQueue"=0,"IntelBDWAccelSysMemory"=8394,"IOUSBInterfaceUserClientV2"=1,"IGAccelFIFOChannel"=78,"AppleUSBInterface"=14,"IODMAController"=0,"IOThunderboltDictionary"=12,"IOUSBControllerV3"=1,"AppleGraphicsControl"=0,"IOBluetoothSCOMemoryDescriptorRetainer"=0,"EventQueue"=1,"IOThunderboltI2CCommand"=2,"AppleHDATDMBusManagerCS8409"=0,"AGPMEventSource"=1,"IGFenceAllocator"=1,"IOSystemStateNotification"=1,"DspFuncEQ"=2,"IOCatalogue"=1,"IOWorkLoop"=70,"IOThunderboltI2CCommandQueue"=1,"AppleSEPEndpointService"=0,"AppleUSBSerialUserClient"=0,"IODataQueue"=1,"AppleAPFSMediaBSDClient"=1,"AppleUSBUserHCIRequestPool"=0,"CCIOReporterLogStream"=1,"IOHIDDevice"=2,"ACMPersistentStoreKernelService"=1,"IOHDACodecDriver"=1,"IOSkywalkNetworkPacket"=2,"AppleHDAWidgetATI_RS730"=0,"IOBluetoothL2CAPChannel"=0,"CCStream"=2,"AppleUSBHostFrameworkInterfaceClient"=0,"AppleHDAWidgetATI_RS780"=0,"IOHIDElement"=1,"AppleUSBCardReaderBlockStorageServices"=1,"IO80211InfraInterface"=1,"_IOMemoryDescriptorMixedData"=12654,"IOReportHub"=1,"AppleThunderboltIntelPCIHAL"=1,"DspFunc6ChOutput"=0,"IO80211P2PDaemonUserClient"=1,"IO80211ScanManager"=1,"IGAccelDevice"=33,"IOEthernetController"=3,"DspFuncStereoEnhancer"=0,"IOSlowAdaptiveClockingDomain"=0,"IOThunderboltConfigXDomainRequestCommand"=0,"IOTimerEventSource"=303,"IOThunderboltCommandQueue"=8,"AppleHDAFunctionGroupCS8409"=0,"CryptoBufferDescriptor"=576,"IOSerialDriverSync"=0,"IOPCIConfigurator"=1,"com_apple_filesystems_hfs_encodings"=1,"AppleUSB20InternalIntelHubPort"=0,"Stopwatch"=10,"IO80211NetBootNub"=0,"IOTimeSyncEthernetConcreteControllerAdapter"=0,"IOSlaveRelayCommand"=0,"DspFunc2WayCrossover"=0,"CCLogPipe"=4,"AppleSMCClient"=4,"IOUserNetworkMemorySegment"=340,"IGHardwareBlit2DContext"=16,"IGAccelTraceStream"=4,"AppleUSBXHCIFL1100CommandRing"=0,"AIDReporterState"=0,"AppleHDAWidgetGT216"=0,"AppleUSBECMControl"=0,"AppleTDMAKSDriver"=0,"DspFuncVolume_3ch"=0,"IOTimeSyncUserClient"=1,"IOServiceMessageUserNotification"=221,"hv_vmx_vma_t"=0,"IOReporter"=3,"AppleXsanScheme"=0,"AppleUSBHostBusCurrentClient"=4,"IOMultiMemoryDescriptor"=3867,"IOAccelDrawable2"=0,"IOPlatformPluginFamily"=1,"IOSCSILogicalUnitNub"=2,"AppleHSSPIInterface"=3,"AppleLIFSUserClient"=0,"IOTimeSyncEthernetControllerAdapter"=0,"AppleHDAWidget_80862807"=0,"CamelliaBase"=0,"IGHardwareRingBufferMedia"=1,"IOSCSIHierarchicalLogicalUnit"=0,"AppleDiskImagesController"=1,"AppleHDATDMDeviceFactory"=0,"AppleSEPDeviceService"=0,"IOTimeSyncClockMapping"=1,"AIDCircularBuffer"=0,"IOAccelAllocationInfo"=0,"KDIURL"=0,"AGPMHeuristic1"=0,"IOPanicPlatform"=0,"IODMAEventSource"=0,"IOThunderboltConnectionManager"=1,"IOSCSIMultipathedLogicalUnit"=0,"AppleCamInUserClient"=1,"IOThunderboltSwitchOS"=0,"IOPlatformDevice"=3,"AppleHDAWidgetCS4208"=36,"AppleAHCIWorkLoopLock"=1,"IOThunderboltXDDirectory"=0,"AppleHIDTransportIODataQueue"=0,"DspFuncSum"=0,"AppleUSBHostDARTDMACommand"=0,"AIDLogger"=0,"DspFuncStereoToMono"=0,"AppleHDATDMAmpSSM3515"=0,"IOUserNetworkEthernet"=5,"AppleUSBHostResourcesTypeC"=0,"AppleUSB20CameraKitHub"=0,"AppleHDAAudioSelectorControlDP"=0,"CCCapture"=0,"AppleMultitouchHIDEventService"=0,"AppleUSBHostFrameworkDeviceClient"=0,"IOSurfaceWiredSendRight"=0,"AppleThunderboltDPPathManager"=2,"IO80211RangingManager"=1,"IOThunderboltData"=0,"IOUSBMassStorageUASDriverCommand"=0,"IOThunderboltCommandGate"=4,"IOSkywalkController"=0,"IOAudioControlUserClient"=166,"DspBuffer"=5,"AppleThunderboltNHIType1"=0,"IOStateNotificationListener"=0,"IOAudioEngine"=2,"AppleThunderboltGenericHAL"=1,"OSSerialize"=1,"AppleUSBDescriptorCache"=14,"IOAudioDevice"=2,"IOSurfaceSharedEventReference"=0,"IOAccelCommandBufferPool2"=57,"OSKext"=489,"AppleHSBluetoothDevice"=0,"AppleUSBDescriptor"=128,"AppleGPUWrangler_GPU"=1,"com_apple_driver_pm_msr_reporter"=1,"AppleSMBIOS"=1,"IOTimeSyncUnicastLinkLayerEtEPort"=0,"IOSkywalkTxCompletionQueue"=1,"IGTelemetryUsage"=78,"SMCWatchDogTimer"=1,"AppleHDAFunctionGroupAD1988"=0,"AppleUSBHostBouncedDMACommand"=0,"AGDPClientControl"=1,"IO80211InterfaceMonitor"=4,"_IOServiceJob"=0,"IOPMPowerStateQueue"=1,"AppleEmbeddedHIDEventService"=0,"IOUserNetworkPacketQueue"=4,"OSIterator"=2,"hv_vcpu_t"=0,"IOAccelerationUserClient"=1,"IOBluetoothTimerEventSource"=0,"IOThunderboltJTAG"=1,"AppleUSBHostBusCurrentAllocator"=9,"IO80211RangingManagerExt"=0,"DspFuncDelay"=0,"CCDataStream"=3,"IOMemoryMap"=4514,"AppleAHCIDiskPolledInterface"=1,"IOAudioToggleControl"=12,"com_apple_driver_pmtelemetry"=1,"AppleSEPTesting"=0,"IOThunderboltStatistics"=1,"SCSITask"=0,"AppleSmartBatteryManagerUserClient"=0,"IOBluetoothL2CAPSupervisoryFrameMemoryBlock"=0,"IOThunderboltLocalNode"=1,"AppleUSBXHCIDevice"=3,"IOHDIXHDDriveOutKernel"=0,"IOUSBMassStorageCBIDriver"=0,"IOUserUserClient"=2,"IGHardwareRenderCommandStreamer5"=1,"IO80211Controller"=1,"AppleHDAEngineUserClient"=0,"AppleMobileFileIntegrity"=1,"IOTimeSyncNotifier"=0,"IGHardwareExtendedContext"=4,"X86PlatformPlugin"=1,"AppleHDAFunctionGroupMCP79"=0,"AppleICH8AHCI"=0,"IOPCIDiagnosticsClient"=0,"IOHIDParamUserClient"=4,"IOPCIBridge"=2,"AppleASMediaUSBXHCIIsochronousRequestPool"=0,"IOBluetoothPacketLogger"=1,"AppleEffaceableStorageUserClient"=0,"OSData"=3245,"IORegistryIterator"=0,"AIDReporterSimple"=0,"IOGraphicsAccelerator2"=1,"IOHDIXCommandPool"=0,"IOThunderboltFindCapabilityCommand"=1,"IOThunderboltPacketLoggerNub"=0,"TransducerState"=0,"IOOutputQueue"=1,"AppleSEPUserClient"=0,"PMAssertionsTracker"=1,"EndpointSecurityExternalClient"=0,"AppleUSBHostDMACommand"=0,"AppleEmbeddedKeyboard"=1,"IOThunderboltTransmitCommand"=3,"IGHwCsStatsTracker"=4,"HSSPIIODataQueue_AppleHSSPIController"=0,"AppleIntelFBController"=1,"DspFuncCrossover"=0,"IGAccelVideoContext"=0,"IOThunderboltXDomainPath"=0,"IOSCSIPeripheralDeviceType00"=2,"IO80211PeerManager"=1,"IOHDIXHDDriveNub"=0,"AppleKeyStoreCommand"=2,"AppleThunderboltIPService"=1,"AppleACPIPlatformUserClient"=0,"IOHIDKeyboardEventDevice"=0,"IOSkywalkLegacyEthernetInterface"=1,"IOSCSITargetDevice"=0,"AppleBacklightDisplay"=1,"IOSlaveProcessorRelay"=0,"IORootParent"=1,"AppleUSB20HostController"=0,"AppleASMedia1042USBXHCI"=0,"com_apple_driver_pm_cstate_reporter"=1,"DspFuncMozartCompressor"=1,"IO80211PeerMonitor"=1,"AIDQueueEventSource"=0,"IOThunderboltSwitchLC"=1,"PMSettingObject"=6,"IODispatchSource"=1,"AppleUSBHostPortInterruptEventSource"=9,"TSNBSDInterface"=0,"IOUserNetworkRxSubmissionQueue"=5,"AppleKeyStore"=1,"AppleACPIPCI"=1,"IOUSBHostInterfaceIterator"=0,"AppleGPUWrangler_MatchNotificationWorkItem"=0,"IOThunderboltControlPath"=1,"IOPMinformee"=112,"IOSlowAdaptiveClockingManager"=1,"IOUSBCommand"=0,"IOTimeSyncReverseSync"=0,"IOAccelLegacySurface"=0,"hv_vmx_space_t"=0,"AppleUSBHostDMABufferMemoryDescriptor"=17,"IOPMPowerSource"=1,"EndpointSecurityDriver"=1,"IOTimeSyncEdgeTimeCapture"=0,"IOUSBLog"=1,"DspFuncLimiter"=0,"CCPipeUserClient"=0,"AppleUSBHostResourcesBusPowerClient"=2,"AHCISMARTUserClient"=0,"AppleHDAMikeyInternalFactory"=0,"AppleSEPManager"=0,"AppleThunderboltIPTransmitter"=0,"IOBluetoothDevice"=1,"DspFuncWithSharedMemory"=4,"IOTimeSyncTimedEdgeGenerator"=0,"IOTimeSyncgPTPManager"=0,"IOThunderboltWorkLoop"=1,"AppleIntelPanelA"=1,"IODisplayParameterHandler"=3,"AppleIntelDisplayPath"=3,"AppleBusPowerController"=0,"IOAccelSharedNamespace2"=30,"AppleIntelLpssSpiDevice"=1,"IOBufferMemoryDescriptor"=9172,"AppleUSBXHCILPTH"=0,"AppleACPIButton"=2,"IOAccelDisplayPipe"=1,"AppleHDADriverUserClient"=0,"IOThunderboltFamilyUserClient"=0,"CCPipe"=2,"AppleHDAWidgetCS8409"=0,"AppleHDAWidgetALC885"=0,"AppleSystemPolicyUserClient"=1,"IOHIDEventServiceUserClient"=4,"DspFunc2Dot1Crossover"=0,"DspFuncBeam2"=1,"AppleUSBHostInterfaceUserClient"=2,"IOThunderboltXDomainService"=0,"AppleMultitouchHIDEventDriver"=0,"IOPolledInterface"=5,"AppleThunderboltDPOutAdapterGFXPolicy1"=0,"IGMemoryManager"=1,"IONDRVDevice"=0,"IOAccelMemory"=1,"IOTimeSyncTimeLineFilter128"=0,"IGHardwareCommandStreamer5"=4,"OSKextSavedMutableSegment"=6,"IOUserSerialUserClient"=0,"IOHIDElementContainer"=1,"AppleUSBDevice"=15,"IOPlatformExpertDevice"=1,"IOTimeSyncEthernetLegacyInterfaceAdapter"=0,"IOUSBHubPolicyMaker"=1,"IOHIPointing"=0,"IOTimeSyncFDEtEPort"=0,"AIDUserClient"=0,"IOThunderboltController"=1,"IOBluetoothHCIController"=1,"AudioAUUC"=0,"AppleAPFSContainerScheme"=1,"IONetworkData"=22,"AppleHSSPIHIDDriver"=3,"IOAudioLevelControl"=519,"IOAccelLegacyDisplayMachine"=0,"IOECStateNotifier"=0,"AppleUSBXHCISPTLP"=0,"IOUSBCommandPool"=0,"IOTimeSyncAWDLInterfaceAdapter"=0,"AppleUSBSerial"=1,"AppleAPFSVolumeBSDClient"=6,"AppleMultitouchEventServiceWrapper"=0,"IntelBDWAccelMemoryMap"=6840,"IO80211FlowQueue"=0,"AppleLMUController"=1,"AppleHDADriver"=1,"AppleImage4UserClient"=0,"OSAction_IOHIDEventService__SetLED"=0,"IOPlatformPluginDevice"=2,"AppleTDMAKSCommand"=0,"IOKernelDebugger"=0,"IODTNVRAMDiags"=0,"IOBacklightDisplay"=1,"CoreAnalyticsMessenger"=0,"IOThunderboltNHIReceiveRing"=1,"IODispatchQueue"=10,"IONetworkMedium"=2,"IODisplayConnect"=1,"AppleAHCIPortPolledAdapter"=1,"IOSkywalkCloneableNetworkPacket"=0,"AppleHDAWidgetATI_RS710"=0,"IOTimeSyncTimeLineFilterIIR"=0,"IOHIDResource"=1,"AGPMHeuristic0"=0,"IGAccelDisplayMachine"=1,"AppleNVMeTranslationSMARTUserClient"=0,"BroadcomBluetoothHostControllerUSBTransport"=1,"AppleHDAWidgetWM8800"=0,"IOTimeSyncPort"=0,"AppleSATLSMARTUserClient"=0,"AppleBSDKextStarter"=1,"AppleUSBCDCCompositeDevice"=1,"IOUSBRootHubDevice"=0,"AppleUSBXHCISparseRequestPool"=0,"AppleMultitouchInputHIDEventDriver"=1,"IOSlaveRelayActionCommand"=0,"IOHIDPointingEventDevice"=0,"IOThunderboltXDPropertiesLeafText"=2,"IOTimeSyncgPTPManagerUserClient"=0,"IOHIDDeviceShim"=0,"IGScheduler5"=1,"IGAccelEventMachine"=1,"AppleHDAWidget_1002AAA0"=0,"IOBluetoothHostControllerUARTTransport"=1,"IOAHCIPort"=1,"IOTimeSyncTimeOfDayPort"=0,"IOThunderboltConfigXDomainPathSetupRequestCommand"=0,"IOBluetoothACPIMethods"=1,"AppleUSBXHCIARIsochronousRequestPool"=0,"AppleThunderboltIPPort"=1,"KernelRelayEndpoint"=0,"DspFuncVolume"=2,"IOBluetoothObject"=1,"AppleSCSISubsystemGlobals"=1,"AppleImage4"=1,"AppleGraphicsDeviceControl"=3,"IOAccelDisplayPipeGammaTable2"=1,"OSMetaClass"=0,"CCDataPipeBlobOD"=0,"IOUSBControllerV2"=1,"IOHIDPointing"=0,"IOAccelSurface"=1,"IOAudioSelectorControl"=2,"DspFuncAudioMeter"=0,"IOUserSerial"=1,"IOUserNetworkTxSubmissionQueue"=1,"CCDataSession"=0,"IO80211P2PSteeringManager"=1,"IOThunderboltIECSCommandQueue"=1,"IOSKMapper"=1,"IOThunderboltDispatchContext"=2,"IOSCSIProtocolServices"=2,"IOLWPool"=0,"IOHIDEventDummyService"=0,"AppleEFINVRAM"=1,"IOTimeSyncDomain"=0,"IOKitDiagnostics"=1,"AppleIntelLpssDmacChannel"=0,"AirPort_BrcmNIC"=1,"AppleMultitouchDeviceUserClient"=1,"IOHIDEventServiceQueue"=5,"IODTNVRAM"=1,"com_apple_driver_pm_reporter"=8,"AppleUSBXHCITDPool"=1,"IO80211P2PDFSProxyManager"=1,"AppleUSBHostDMACommandPool"=1,"AppleThunderboltHALType4"=0,"IOSurfaceMemoryRegion"=0,"AppleACPIEC"=1,"IGSharedMappedBuffer"=471,"IOAccelDisplayPipeUserClient2"=3,"AppleRTCUserClient"=0,"IO80211SkywalkInterface"=1,"DspFuncXTC"=0,"IO80211P2PSupervisor"=1,"AppleHDAWidgetMCP79"=0,"IOBluetoothHIDChannel"=0,"hv_vatpic_t"=0,"hv_vm_t"=0,"AppleSSE"=1,"IOPMRequest"=0,"IOECTimeSyncHandler"=0,"IOAccelMemoryMap"=1,"IOHIKeyboard"=0,"AppleGPUWrangler_BusyInterestWorkItem"=0,"IOHIDUserDevice"=1,"IGAccelResource"=4346,"AppleHDATDMAmpTAS5758L"=0,"AppleMCCSControlCello"=0,"AppleHDAFunctionGroupATI_Park"=0,"AppleXsanDevice"=0,"IOSurfaceSharedEvent"=0,"IOBluetoothHostControllerPCIeTransport"=1,"IORS232SerialStreamSync"=0,"IOService"=194,"AppleIntelMEIDriver"=1,"AppleHDAWidget_10DE0014"=0,"IOBluetoothWorkLoop"=0,"ACMAccessoryCacheKernelService"=1,"IOUserServerCheckInToken"=7,"IOHIDEventRepairDriver"=0,"AppleHDAFunctionGroup_10DE0014"=0,"IOAccelBlockFencePort2"=18,"IOSKMemoryBuffer"=35,"IOTimeSyncUnicastUDPv4EtEPort"=0,"KextAudit"=1,"IOAccelSysMemory"=1,"AppleSMCFamily"=1,"HIDAlwaysNotifyingIODataQueue"=1,"AppleIPAppender"=1,"IOFramebuffer"=1,"AppleMultitouchDevice"=1,"AppleUSBXHCIIsochronousTransferRing"=0,"IOPMCompletionQueue"=1,"AppleSEPCommandPool"=0,"DspFuncVirtualization"=0,"IOBluetoothHostControllerUSBTransport"=1,"IOTimeSyncUserFilteredService"=0,"AppleHV"=1,"AppleCredentialManagerUserClient"=3,"IOThunderboltNHI"=1,"AppleFileSystemDriver"=0,"mDNSOffloadUserClient"=0,"IOUSBHostInterfaceLegacyIterator"=0,"AppleUSBHostPort"=2,"IOThunderboltConnectionManagerType5"=0,"PassthruInterruptController"=0,"CCDataPipeUserClient"=0,"AppleUSBUserHCICommandQueue"=0,"AppleHDAWidget"=1,"IOAccelMemoryInfoUserClient"=0,"IOFDiskPartitionScheme"=0,"AppleMultitouchEventDriverWrapper"=1,"com_apple_filesystems_hfs"=1,"IODataQueueDispatchSource"=8,"AppleHDAFunctionGroupCS4206"=0,"OSAction_IOHIDDevice__CompleteReport"=0,"AppleUSBUserHCIRequest"=0,"AppleTDMEffaceableNORDriver"=0,"AppleUSBXHCITR"=0,"AppleUSBXHCIStreamingEndpoint"=0,"AppleHDACodecGeneric"=1,"AppleGPUWrangler_DeferredReleaseWorkItem"=0,"AirPort_Brcm43xxSkywalkPacketBufferPool"=1,"IOUSBMassStorageInterfaceNub"=1,"AppleSSEUserClient"=0,"KernelRelayHost"=0,"IOAccelResource2"=1,"IOPMPowerSourceList"=0,"AppleHDAEngineOutputDP"=0,"OSAction_IOUserClient_KernelCompletion"=0,"AppleUSB20InternalSMSCHub"=0,"IOThunderboltNub"=2,"mDNSHandoff"=1,"AppleLPC"=1,"IOAccelTraceStream2"=1,"AppleVTDDeviceMapper"=2,"IOTimeSyncEthernetSoftDMAInterfaceAdapter"=0,"AppleHDAStream"=3,"AppleIntelLpssI2C"=0,"IOUSBPipe"=0,"AppleACPICPUInterruptController"=1,"AppleAMDUSBXHCIPCI"=0,"IGHardwareDisplayContext"=1,"IOAVBControllerHelper"=0,"AppleVTD"=1,"AppleSEPEndpoint"=0,"IOPerfControlClient"=3,"IOAHCIBlockStorageDriver"=1,"EupDSP"=0,"AppleHSSPIDevice"=1,"AppleBusControllerFactory"=0,"IOPlatformExpert"=1,"IOUserEthernetController"=0,"IOTimeSyncEthernetPort"=0,"IOAccelDisplayPipePostCSCGammaVID"=0,"IOUserSCSIPeripheralDeviceType00"=0,"com_apple_driver_pm_uncore_reporter"=1,"TSNWiFiInterface"=0,"AppleUSBController"=1,"IOTimeSyncUserFilteredServiceUserClient"=0,"IOPartitionScheme"=2,"IOTimeSyncIntervalFilter128"=0,"AppleAHCIPolledAdapter"=1,"AppleThunderboltDPInAdapterGFXPolicy1"=2,"AppleIntelSPIController"=1,"com_apple_driver_AppleUSBCardReaderDriverNub"=1,"IOSlaveFirmware"=0,"AppleASMedia3142USBXHCI"=0,"IOAccelExternalEvent"=0,"AppleHSSPICommand"=30,"IOHIDUserClient"=1,"LogManager"=1,"IOACPIPlatformExpert"=1,"IOThunderboltSwitchType3"=0,"hv_vlapic_t"=0,"IOThunderboltNHITransmitRing"=1,"IOThunderboltUserObjectExporter"=0,"IOAccelSharedEventFence"=0,"com_apple_driver_pm_cpu_mbox"=2,"IOAccelVideoContext2"=0,"IOUSBControllerIsochEndpoint"=0,"IOTimeSyncEthernetModernInterfaceAdapter"=0,"IOThunderboltConfigResetCommand"=2,"AppleIntelPAVP"=1,"AppleUSBNCMControl"=0,"DspFuncLoudness"=1,"IOSurfaceDeviceMemoryRegion"=0,"IOServiceCompatibility"=4,"AppleThunderboltDPOutAdapterUserClient"=0,"IOHIDEventService"=3,"IOAudioTimeIntervalFilterFIR"=0,"AppleASMediaUSBXHCIIsochronousRequest"=0,"AirPort_Brcm43xxSkywalkPacket"=4352,"IOAccelDisplayPipePreCSCLinearizationVID"=0,"IOUserEthernetInterface"=0,"IOTimeSyncIntervalFilterIIR128"=0,"IOAudioPort"=0,"IOThunderboltConfigXDomainLinkChangeRequestCommand"=0,"IOInterruptDispatchSource"=0,"IOSkywalkPacketBuffer"=128,"IOHIKeyboardMapper"=0,"AppleUSBBusPowerClient"=0,"IOTimeSyncUnicastUDPv6EtEPort"=0,"OSAction_IOHIDEventService__CopyEvent"=0,"ACMBridgeKernelService"=0,"KRActionCommandPool"=0,"IOUSBHostInterface"=14,"com_apple_driver_pm_msr_limits_reporter"=1,"hv_vmx_vcpu_t"=0,"IOAHCIPortMultiplier"=0,"AppleGPUWrangler"=1,"IOTimeSyncIntervalFilterIIR"=0,"OSArray"=17106,"IOGeneralMemoryDescriptor"=2955,"IOSkywalkBSDClient"=1,"IOThunderboltConfigXDomainLinkStatusRequestCommand"=0,"IOUSBIsocCommand"=0,"IOEthernetAVBInterface"=0,"STUCWorkLoopLock"=0,"IOAccelSurfaceMTL"=0,"IOThunderboltDispatchQueue"=11,"IO80211FlowQueueLegacy"=0,"IOSlaveProcessor"=0,"IGAccelSegmentResourceList"=0,"DIDeviceIOUserClient"=0,"AppleUSBHubPort"=1,"IO80211ControllerMonitor"=1,"IOTimeSyncClockTestUserClient"=0,"IOThunderboltPortMicro"=0,"IOUSBWorkLoop"=1,"AppleUSB20HubExpressCardPort"=0,"IOSurfaceClient"=365,"IOAudioEngineEntry"=0,"AppleThunderboltNHIReceiveRing"=12,"com_apple_driver_pm_ltr_reporter"=1,"IOConfigurationDescriptorOrderedSet"=0,"IOThunderboltProtocolListener"=1,"AppleBusController"=0,"AIDSerialLogger"=0,"AHCIRequest"=33,"MEICompletion"=0,"AppleGraphicsDeviceControlPlugin"=1,"IOThunderboltConfigXDomainCommand"=2,"AppleIntelICLUSBXHCI"=0,"IOCancelationWrapper"=0,"IO80211CommandQueue"=10,"DspFuncManager"=2,"IOAccelExternalEventFence"=0,"AppleUSB20XHCITypeCPort"=0,"DspFuncSplitBand"=0,"IOBootNDRV"=0,"IOHIDElementPrivate"=1372,"AppleHDAPath"=4,"AppleSSEInterface"=1,"AGDCPluginDisplayMetrics"=1,"IOHITablet"=0,"AppleTDMBlockStorageServices"=0,"AirPort_Brcm43xxLLSkywalkInterface"=1,"AppleACPIEventController"=1,"IOFramebufferUserClient"=3},"IOMalloc allocation"=104863798}
            +-o AppleUSBXHCI Root Hub Simulation@14000000  <class AppleUSBRootHubDevice, id 0x10000036c, registered, matched, active, busy 0 (0 ms), retain 13>
              |   "idProduct" = 32775
              |   "bNumConfigurations" = 1
              |   "Built-In" = Yes
              |   "bDeviceClass" = 9
              |   "bMaxPacketSize0" = 8
              |   "iManufacturer" = 0
              |   "iProduct" = 0
              |   "iSerialNumber" = 0
              |   "USB Product Name" = "AppleUSBXHCI Root Hub Simulation"
              |   "IOPowerManagement" = {"DevicePowerState"=0,"CurrentPowerState"=4,"CapabilityFlags"=32768,"MaxPowerState"=4,"DriverPowerState"=4}
              |   "IOUserClientClass" = "AppleUSBLegacyDeviceUserClient"
              |   "locationID" = 335544320
              |   "bDeviceSubClass" = 255
              |   "bcdUSB" = 256
              |   "non-removable" = "yes"
              |   "IOCFPlugInTypes" = {"9dc7b780-9ec0-11d4-a54f-000a27052861"="IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle"}
              |   "bDeviceProtocol" = 3
              |   "Device Speed" = 3
              |   "USB Vendor Name" = "Apple Inc."
              |   "idVendor" = 1452
              |   "IOClassNameOverride" = "IOUSBRootHubDevice"
              +-o BRCM20702 Hub@14300000  <class AppleUSBDevice, id 0x100000389, registered, matched, active, busy 0 (0 ms), retain 12>
              | |   "sessionID" = 1794934537
              | |   "idProduct" = 17664
              | |   "iManufacturer" = 1
              | |   "bDeviceClass" = 9
              | |   "bcdDevice" = 256
              | |   "iProduct" = 2
              | |   "iSerialNumber" = 0
              | |   "Bus Power Available" = 250
              | |   "USB Address" = 3
              | |   "Built-In" = Yes
              | |   "locationID" = 338690048
              | |   "bDeviceSubClass" = 0
              | |   "bcdUSB" = 512
              | |   "USB Product Name" = "BRCM20702 Hub"
              | |   "PortNum" = 3
              | |   "AppleUSBAlternateServiceRegistryID" = 4294968199
              | |   "bDeviceProtocol" = 0
              | |   "IOCFPlugInTypes" = {"9dc7b780-9ec0-11d4-a54f-000a27052861"="IOUSBHostFamily.kext/Contents/PlugIns/IOUSBLib.bundle"}
              | |   "IOPowerManagement" = {"DevicePowerState"=2,"CurrentPowerState"=3,"CapabilityFlags"=65536,"MaxPowerState"=4,"DriverPowerState"=3}
              | |   "kUSBCurrentConfiguration" = 1
              | |   "Device Speed" = 1
              | |   "idVendor" = 2652
              | |   "IOGeneralInterest" = "IOCommand is not serializable"
              | |   "kUSBProductString" = "BRCM20702 Hub"
              | |   "kUSBVendorString" = "Apple Inc."
              | |   "IOClassNameOverride" = "IOUSBDevice"
              | +-o Bluetooth USB Host Controller@14330000  <class AppleUSBDevice, id 0x1000003af, registered, matched, active, busy 0 (1 ms), retain 18>
              |       "sessionID" = 2136632231
              |       "idProduct" = 33423
              |       "iManufacturer" = 1
              |       "bDeviceClass" = 255
              |       "bMaxPacketSize0" = 64
              |       "bcdDevice" = 336
              |       "iProduct" = 2
              |       "iSerialNumber" = 0
              |       "USB Address" = 6
              |       "Built-In" = Yes
              |       "locationID" = 338886656
              |       "bDeviceSubClass" = 1
              |       "bcdUSB" = 512
              |       "USB Product Name" = "Bluetooth USB Host Controller"
              |       "PortNum" = 3
              |       "AppleUSBAlternateServiceRegistryID" = 4294968237
              |       "bDeviceProtocol" = 1
              |       "Device Speed" = 1
              |       "idVendor" = 1452
              |       "kUSBProductString" = "Bluetooth USB Host Controller"
              +-o Bela@14100000  <class AppleUSBDevice, id 0x1000013a1, registered, matched, active, busy 0 (4 ms), retain 28>
                    "sessionID" = 9474465803965
                    "idProduct" = 260
                    "iManufacturer" = 1
                    "bDeviceClass" = 0
                    "bcdDevice" = 257
                    "iProduct" = 2
                    "iSerialNumber" = 3
                    "USB Address" = 18
                    "Built-In" = No
                    "locationID" = 336592896
                    "bcdUSB" = 512
                    "USB Product Name" = "Bela"
                    "PortNum" = 1
                    "non-removable" = "no"
                    "kUSBSerialNumberString" = "__bela__"
                    "AppleUSBAlternateServiceRegistryID" = 4294972319
                    "IOPowerManagement" = {"DevicePowerState"=0,"CurrentPowerState"=3,"CapabilityFlags"=65536,"MaxPowerState"=4,"DriverPowerState"=3}
                    "Device Speed" = 2
                    "USB Vendor Name" = "Augmented Instruments Ltd"
                    "idVendor" = 7531
                    "kUSBProductString" = "Bela"
                    "USB Serial Number" = "__bela__"
                    "kUSBVendorString" = "Augmented Instruments Ltd"
          right, so everything is recognised as expected, the issue is probably that the IDE doesn't have CPU time left to show up while the program is running at boot (or better, it will take much longer for it to be ready). See instructions here on how to regain control of the board in this situation:
          https://learn.bela.io/using-bela/about-bela/troubleshooting-guide/#program-running-at-boot-and-board-not-showing-up
            19 days later
            Hi again - same issue and I am spending too much time trying(!). I have had times when Bela has connected and thought all was OK but today I cannot get any success (am on my MacBook Air Monterey 12.2.1 which has been my only machine for Bela work). Have tried Firefox and Chrome and with bela.local/ I get the same result (and I confess I do not know what to check apart from the connection) as follows:
            This site can’t be reached
            bela.local’s server IP address could not be found.
            Try:
            Checking the connection
            Checking the proxy, firewall and DNS configuration
            ERR_NAME_NOT_RESOLVED
              Hi again. Should have mentioned - same error with Bela Mini.
              Sorry should have indicated that it simply worked at some point without recourse to this. Since writing the post I found a pc I could try and it worked fine. It makes me suspicious of the Mac - I get the impression that PCs are more robust with Bela perhaps?
                david and I am spending too much time trying(
                I know right!
                david I get the impression that PCs are more robust with Bela perhaps?
                Not that I am aware of...
                david Sorry should have indicated that it simply worked at some point without recourse to this.
                Is there still a program running on boot? If yes, I strongly recommend you follow the instructions above.
                When you get the BELABOOT drive on your mac, can you open it and oepn the file "bela.version" with textedit? What is the version number reported in there?
                Today it is not working on either computer so I looked at those instructions - my Bela is incorporated in a case with a number of connectors. A number of pins are mentioned to be grounded but I do not see them listed on the pin diagram (https://learn.bela.io/pin-diagram/). Where is the BELABOOT drive?
