giuliomoro,
this is amazingly helpful, thank you so much, I managed to get Cyclone working, hurray!
Unfortunately, I ran into an unexpected error with Ggee. When
make PD_INCLUDE=/usr/local/include/libpd
I got this:
cc -DPD -I. -I"/usr/local/include/libpd"/pd -Wall -W -g -DVERSION='"0.26"' -fPIC -O6 -funroll-loops -fomit-frame-pointer -o "control/constant.o" -c "control/constant.c"
control/constant.c:4:18: fatal error: m_pd.h: No such file or directory
#include <m_pd.h>
compilation terminated.
Makefile:165: recipe for target 'control/constant.o' failed
make: *** [control/constant.o] Error 1
I know, the 'm_pd.h' case has been discussed before but I don't know how to solve it here. Could you please help me?
Thank you so much for your time!
sorry I had left a couple of bullet points in there that I copied/pasted from the cyclone section, fixed now
Thank you. I hate to say it but I still cannot get it to work:
root@bela:~/ggee-0.26# make CFLAGS="-DPD -I. -I"/usr/local/include/libpd"/pd -Wall -W -g -DVERSION='"0.26"' -fPIC -O6 -funroll-loops -fomit-frame-pointer -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math"
cc -DPD -I. -I/usr/local/include/libpd/pd -Wall -W -g -DVERSION='0.26' -fPIC -O6 -funroll-loops -fomit-frame-pointer -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -o "control/constant.o" -c "control/constant.c"
#include <m_pd.h>
If I had an idea where to start figuring it out, I would...
Thank you!
I don't know how I left another typo in there, fixed again.
giuliomoro,
thank you so much for your time, help and patience with people who are as clueless as I am! It works and I am really happy!
6 months later
I feel quite efficient at Pd patching, but no real coding skills whatsoever (apart from basic arduino and processing coding). So I find it all terribly puzzling.
I need to install the Helmholtz~ external http://www.katjaas.nl/helmholtz/helmholtz.html#download
What I managed to do so far is that I created the Bela/projects/pd-externals/ with basic linux commands in the ide. The pd-externals also appears in a "project explorer" in the ide. What am I supposed to do now? I know I should build the projec on bela, but what exactly does it mean, step by step? Should I run the "Makefile" from the ide command line?
I know most of this stuff is not a rocket science for people with coding and linux experience, but for someone like me who is just patching stuff in pd, max, reaktor and such, this is really puzzling...
Here is how I compiled helmoltz~. As mentioned earlier, there is no standard way of compiling externals, and each and everyone of them will probably require inspecting the Makefile at some point to get it to build.
Steps:
- get the source code and copy it to the board:
scp -r helmoltz~ root@192.168.7.2:
- ssh to the board and navigate to the helmoltz~ folder:
ssh root@192.168.7.2
cd helmoltz~
  • inspect the files in the folder:
    • There are several pre-built externals in the folder, let's get rid of those manually:
      rm helmholtz~.dll helmholtz~.pd_* src/helmholtz~.pd_darwin
    • There is a file in src/include/m_pd.h which is the pd include. However, we should not compile against this (which - according to the docs - is from Pd0.42), but against the one that is installed on our board. So, first off let's delete this:
      src/include/m_pd.h
  • navigate to the src/ folder where there is a Makefile:
    cd src
  • for good measure, run make clean to get rid of any leftover pre-built files
  • try to run make and see if/how it fails
    root@bela:~/helmholtz~/src# make
    g++ -DPD -O3 -Wall -W -Wshadow -Wno-unused -Wno-parentheses -Wno-switch -fcheck-new -fvisibility=hidden -I ./include	 -c *.cpp
    g++ -bundle -undefined suppress -flat_namespace -o helmholtz~.pd_darwin *.o
    g++: error: suppress: No such file or directory
    g++: error: unrecognized command line option ‘-bundle’; did you mean ‘-Wundef’?
    g++: error: unrecognized command line option ‘-flat_namespace’; did you mean ‘-Wnamespaces’?
    Makefile:44: recipe for target 'helmholtz~.pd_darwin' failed
    So it seems it is trying to build a helmholtz~.pd_darwin external, which would be for macos. We need to rectify this. Open Makefile in your favourite text editor, and you will see the first target (which is the default target) is:
    current: pd_darwin
    Scroll down and you will see that there is a target called pd_linux.
    So the next thing to try is to run make with that target:
    root@bela:~/helmholtz~/src# make pd_linux
    g++ -msse -DPD -DUNIX -DICECAST -O3 -funroll-loops -fomit-frame-pointer -fcheck-new -fPIC -Wall -W -Wshadow -Wno-unused -Wno-parentheses -Wno-switch -fvisibility=hidden -I ./include -c *.cpp
    g++: error: unrecognized command line option ‘-msse’; did you mean ‘-fdse’?
    Makefile:23: recipe for target 'helmholtz~.pd_linux' failed
    make: *** [helmholtz~.pd_linux] Error 1
    The error her is that it is trying to use -msse, which instructs the compiler to use the sse instructions, but these are only available on Intel CPUs. So open the Makefile again, and see where these are defined:
    LINUXCFLAGS = -msse -DPD -DUNIX -DICECAST -O3 -funroll-loops -fomit-frame-pointer -fcheck-new -fPIC\
        -Wall -W -Wshadow \
    Now, with make, the internal variables can be overridden from the command-line, without editing the Makefile, so we can use this feature to remove the -msse option. Inspecting the current list of options, we see that many of those (those starting with -W) refer to warnings, so we can just remove them. While we are at it, we can add in the standard Bela optimization options (which can be found in ~/Bela/Makefile): -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math. Let's not remove the -D options (which define flags that are used by the code).
    The resulting LINUXCFLAGS variable should then contain: -DPD -DUNIX -DICECAST -O3 -funroll-loops -fomit-frame-pointer -fcheck-new -fPIC -fvisibility=hidden -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math. We can therefore execute the following command:
make pd_linux LINUXCFLAGS="-DPD -DUNIX -DICECAST -O3 -funroll-loops -fomit-frame-pointer -fcheck-new -fPIC -fvisibility=hidden -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math"
This fails like this:
In file included from Helmholtz.cpp:14:0:
./include/Helmholtz.h:53:18: fatal error: m_pd.h: No such file or directory
 #include "m_pd.h"
helmholtz~.cpp:12:18: fatal error: m_pd.h: No such file or directory
 #include "m_pd.h"
This means that we need to tell make where to find our m_pd.h file. This is in /usr/local/include/libpd. We can simply add -I/usr/local/include/libpd to the LINUXCFLAGS:
make pd_linux   LINUXCFLAGS="-DPD -DUNIX -DICECAST -O3 -funroll-loops -fomit-frame-pointer -fcheck-new -fPIC -fvisibility=hidden -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -I/usr/local/include/libpd"
This produces the following output:
g++ -DPD -DUNIX -DICECAST -O3 -funroll-loops -fomit-frame-pointer -fcheck-new -fPIC -fvisibility=hidden -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -I/usr/local/include/libpd -I ./include -c *.cpp
g++ -Wl -export-dynamic -shared -o helmholtz~.pd_linux *.o -lc -lm -lstdc++
g++: error: unrecognized command line option ‘-Wl’; did you mean ‘-W’?
The first line is the compiling step and it actually works ok. The second line is the linking stage and it fails because of the -Wl option. Not sure here what the original developer meant by that. Options starting with -Wl, normally contain flags to be passed to the linker, but this one is incomplete, so we can just remove it. Inspecting the Makefile once more, we see that the -Wl option is actually hardcoded in the recipe for pd_linux:, so we cannot override it from the command line and we have to delete it manually from the Makefile. Once that is done, we can re-run the command above and this time we obtain:
g++ -export-dynamic -shared -o helmholtz~.pd_linux *.o -lc -lm -lstdc++
rm -f *.o ../helmholtz~.pd_linux
cp helmholtz~.pd_linux ../helmholtz~.pd_linux
Success! The generated file is in ~/helmholtz~/src/helmholtz~.pd_linux, and also it is copied in /root/helmholtz~/helmholtz~.pd_linux. We now can copy this file to ~/Bela/projects/pd-externals, after creating the folder (in case it doesn't exist):
cp ~/helmholtz~/src/helmholtz~.pd_linux ~/Bela/projects/pd-externals/
    3 months later
    i thought i'd just pin my own problems onto this thread..
    trying to install the HCS library.
    i'm following your steps.. so i got the extra header files. done.
    created the pd-externals folder. done.
    got HCS-0.1 folder, copied it to the board.
    when i tried invoking make, i got this:
    which to me is very much like a menu from a chinese restaurant. in chinese. in china.
    anybody that has succesfully installed that library, by any chance?
    It may mean that the external requires a more recent version off Pd than the one that is installed (0.48-2). What does the README say about it? Also, provide a link to the repo pleaee
    hmm, i seem to have a mac os version installed on my laptop - one with .pd_darwin files, not .c files like in that download link. the mac folder doesn't contain a MakeFile.
    i'm quite sure that one was installed (or at least downloaded) with Deken.
    See if on deken there is an ARMv7 build available, or source code. I will not be able to look at this before thursday.
    Success! i think.
    okay, so i had a closer look at that log file..
    'classpath.c', causing the error, is an object from the library i don't need.
    so i removed that from the sources in the Makefile.
    tried the whole thing again.
    i ended up removing the [classpath] and [helppath] objects, since they both messed up the Make process.
    it looks like that did the trick - all the others are showing up in the externals project/folder in the IDE now!
    kinda eager to test, but need to sleep. tomorrow!
    hmm.
    the [folder_list] object i'm using still gives me an error when i try to run the patch on bela.
    IDE says:
    Jan 07 23:22:48 bela stdbuf[747]: folder_list
    Jan 07 23:22:48 bela stdbuf[747]: error: ... couldn't create
    Jan 07 23:22:48 bela stdbuf[747]: verbose(4): ... you might be able to track this down from the Find menu.
    do i still need to explicitly use [declare] (or similar) for bela to use the libraries in the externals folder?
    or is there still something not right with the install?
    Where are the externals located? If they are in the project folder or in /root/Bela/projects/pd-externals then they should be detected automatically. If this is a single-file library, then you may have to manually load the library ( I think [declare] is the right object
    they are in pd_externals/hcs.
    i guess i need to specify that subfolder as a path? and if so, how?
    ok, after much trial and error:
    adding a [declare -path /root/Bela/projects/pd-externals/hcs] object gets it to work.
    i tried just to [declare] relative paths instead of the full path but that wouldn't work for some reason.
    /// edit: of course, simply using [hcs/folder_list] works just as well. NEED NEW EYEBALLS.
    learning every day.
    and here was me thinking running a Pd file on hardware would be a no-brainer :/
    anyway, this is a relief. happy camper!
      Remork adding a [declare -path /root/Bela/projects/pd-externals/hcs] object gets it to work.
      Yeah that's normal for Pd too, however the "problem" is that in the desktop version you can set paths through the global options, so you don't need them in the patch itself
      so i noticed 🙂
      anyway, guess it should become a habit to declare used libs from within the patch.. can imagine that might come in handy when sharing or returning to patches anyway. seems good practice.
      onwards!
