giuliomoro thanks for your continued help... will check all this!
Problem compiling simpleFX_Analog.dsp
OK let's see where we are now.
root@bela:~/Bela# grep distcc Makefile
CLANG_PATH=distcc-clang
root@bela:~/Bela#
reference command line build on bela works (without specifying architecture):
root@bela:~/Bela/resources/network# distcc-clang -v -c udp-client.c
clang version 3.9.1-9 (tags/RELEASE_391/rc2)
Target: armv7l-unknown-linux-gnueabihf
Thread model: posix
InstalledDir: /usr/bin
Found candidate GCC installation: /usr/bin/../lib/gcc/arm-linux-gnueabihf/6
Found candidate GCC installation: /usr/bin/../lib/gcc/arm-linux-gnueabihf/6.3.0
Found candidate GCC installation: /usr/lib/gcc/arm-linux-gnueabihf/6
Found candidate GCC installation: /usr/lib/gcc/arm-linux-gnueabihf/6.3.0
Selected GCC installation: /usr/bin/../lib/gcc/arm-linux-gnueabihf/6.3.0
Candidate multilib: .;@m32
Selected multilib: .;@m32
"/usr/lib/llvm-3.9/bin/clang" -cc1 -triple armv7-unknown-linux-gnueabihf -E -disable-free -disable-llvm-verifier -discard-value-names -main-file-name udp-client.c -mrelocation-model static -mthread-model posix -mdisable-fp-elim -fmath-errno -masm-verbose -mconstructor-aliases -fuse-init-array -target-cpu cortex-a8 -target-abi aapcs-linux -mfloat-abi hard -v -dwarf-column-info -debugger-tuning=gdb -resource-dir /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1 -internal-isystem /usr/local/include -internal-isystem /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1/include -internal-externc-isystem /usr/include/arm-linux-gnueabihf -internal-externc-isystem /include -internal-externc-isystem /usr/include -fdebug-compilation-dir /root/Bela/resources/network -ferror-limit 19 -fmessage-length 80 -fallow-half-arguments-and-returns -fno-signed-char -fobjc-runtime=gcc -fdiagnostics-show-option -fcolor-diagnostics -o - -x c udp-client.c
clang -cc1 version 3.9.1 based upon LLVM 3.9.1 default target armv7l-unknown-linux-gnueabihf
ignoring nonexistent directory "/include"
#include "..." search starts here:
#include <...> search starts here:
/usr/local/include
/usr/include
End of search list.
clang version 3.9.1-19ubuntu1 (tags/RELEASE_391/rc2)
Thread model: posix
"/usr/lib/llvm-3.9/bin/clang" -cc1 -triple armv7-unknown-linux-gnueabihf -emit-obj -mrelax-all -disable-free -disable-llvm-verifier -discard-value-names -main-file-name distccd_ba396596.i -mrelocation-model static -mthread-model posix -mdisable-fp-elim -fmath-errno -masm-verbose -mconstructor-aliases -target-cpu cortex-a8 -target-abi aapcs-linux -mfloat-abi hard -v -dwarf-column-info -debugger-tuning=gdb -coverage-file /tmp/distccd_ba666596.o -resource-dir /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1 -fdebug-compilation-dir /tmp -ferror-limit 19 -fmessage-length 0 -fallow-half-arguments-and-returns -fno-signed-char -fobjc-runtime=gcc -fdiagnostics-show-option -o /tmp/distccd_ba666596.o -x cpp-output /tmp/distccd_ba396596.i
clang -cc1 version 3.9.1 based upon LLVM 3.9.1 default target x86_64-pc-linux-gnu
End of search list.
reference build works with specifying architecture:
root@bela:~/Bela/resources/network# distcc-clang -c -v ~/Bela/resources/network/udp-client.c -march=armv7-a
Thread model: posix
"/usr/lib/llvm-3.9/bin/clang" -cc1 -triple armv7-unknown-linux-gnueabihf -E -disable-free -disable-llvm-verifier -discard-value-names -main-file-name udp-client.c -mrelocation-model static -mthread-model posix -mdisable-fp-elim -fmath-errno -masm-verbose -mconstructor-aliases -fuse-init-array -target-cpu cortex-a8 -target-abi aapcs-linux -mfloat-abi hard -v -dwarf-column-info -debugger-tuning=gdb -resource-dir /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1 -internal-isystem /usr/local/include -internal-isystem /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1/include -internal-externc-isystem /usr/include/arm-linux-gnueabihf -internal-externc-isystem /include -internal-externc-isystem /usr/include -fdebug-compilation-dir /root/Bela/resources/network -ferror-limit 19 -fmessage-length 80 -fallow-half-arguments-and-returns -fno-signed-char -fobjc-runtime=gcc -fdiagnostics-show-option -fcolor-diagnostics -o - -x c /root/Bela/resources/network/udp-client.c
/usr/local/include
/usr/include
End of search list.
Thread model: posix
"/usr/lib/llvm-3.9/bin/clang" -cc1 -triple armv7-unknown-linux-gnueabihf -emit-obj -mrelax-all -disable-free -disable-llvm-verifier -discard-value-names -main-file-name distccd_ff4c663b.i -mrelocation-model static -mthread-model posix -mdisable-fp-elim -fmath-errno -masm-verbose -mconstructor-aliases -target-cpu cortex-a8 -target-abi aapcs-linux -mfloat-abi hard -v -dwarf-column-info -debugger-tuning=gdb -coverage-file /tmp/distccd_fcec663b.o -resource-dir /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1 -fdebug-compilation-dir /tmp -ferror-limit 19 -fmessage-length 0 -fallow-half-arguments-and-returns -fno-signed-char -fobjc-runtime=gcc -fdiagnostics-show-option -o /tmp/distccd_fcec663b.o -x cpp-output /tmp/distccd_ff4c663b.i
End of search list.
Here's the distcclog from the Ubuntu machine:
distccd[14752] (dcc_check_client) connection from 192.168.7.2:59770
distccd[14752] (check_address_inet) match client 0x207a8c0, value 0x207a8c0, mask 0xffffffff
distccd[14752] (dcc_r_token_int) got DIST00000001
distccd[14752] (dcc_r_token_int) got ARGC00000006
distccd[14752] (dcc_r_argv) reading 6 arguments from job submission
distccd[14752] (dcc_r_token_int) got ARGV0000000d
distccd[14752] (dcc_r_token_string) got 'clang-3.9-arm'
distccd[14752] (dcc_r_argv) argv[0] = "clang-3.9-arm"
distccd[14752] (dcc_r_token_int) got ARGV00000002
distccd[14752] (dcc_r_token_string) got '-v'
distccd[14752] (dcc_r_argv) argv[1] = "-v"
distccd[14752] (dcc_r_token_string) got '-c'
distccd[14752] (dcc_r_argv) argv[2] = "-c"
distccd[14752] (dcc_r_token_int) got ARGV0000000c
distccd[14752] (dcc_r_token_string) got 'udp-client.c'
distccd[14752] (dcc_r_argv) argv[3] = "udp-client.c"
distccd[14752] (dcc_r_token_string) got '-o'
distccd[14752] (dcc_r_argv) argv[4] = "-o"
distccd[14752] (dcc_r_token_string) got 'udp-client.o'
distccd[14752] (dcc_r_argv) argv[5] = "udp-client.o"
distccd[14752] (dcc_r_argv) got arguments: clang-3.9-arm -v -c udp-client.c -o udp-client.o
distccd[14752] (dcc_scan_args) scanning arguments: clang-3.9-arm -v -c udp-client.c -o udp-client.o
distccd[14752] (dcc_scan_args) found input file "udp-client.c"
distccd[14752] (dcc_scan_args) found object/output file "udp-client.o"
distccd[14752] compile from udp-client.c to udp-client.o
distccd[14752] (dcc_run_job) output file udp-client.o
distccd[14752] (dcc_input_tmpnam) input file udp-client.c
distccd[14752] (dcc_r_token_int) got DOTI00016dac
distccd[14752] (dcc_r_file) received 93612 bytes to file /tmp/distccd_ba396596.i
distccd[14752] (dcc_r_file_timed) 93612 bytes received in 0.011009s, rate 8304kB/s
distccd[14752] (dcc_set_input) changed input from "udp-client.c" to "/tmp/distccd_ba396596.i"
distccd[14752] (dcc_set_input) command after: clang-3.9-arm -v -c /tmp/distccd_ba396596.i -o udp-client.o
distccd[14752] (dcc_set_output) changed output from "udp-client.o" to "/tmp/distccd_ba666596.o"
distccd[14752] (dcc_set_output) command after: clang-3.9-arm -v -c /tmp/distccd_ba396596.i -o /tmp/distccd_ba666596.o
distccd[14752] (dcc_check_compiler_masq) /usr/local/bin/clang-3.9-arm is not a symlink
distccd[14752] (dcc_spawn_child) forking to execute: clang-3.9-arm -v -c /tmp/distccd_ba396596.i -o /tmp/distccd_ba666596.o
distccd[14752] (dcc_spawn_child) child started as pid32524
distccd[32524] (dcc_new_pgrp) entered process group
distccd[32524] (dcc_increment_safeguard) setting safeguard: _DISTCC_SAFEGUARD=1
distccd[14752] (dcc_collect_child) cc child 32524 terminated with status 0
distccd[14752] (dcc_collect_child) cc times: user 0.000000s, system 0.000000s, 0 minflt, 0 majflt
distccd[14752] (dcc_x_token_int) send DONE00000001
distccd[14752] (dcc_x_token_int) send STAT00000000
distccd[14752] (dcc_x_file) send 1002 byte file /tmp/distcc_b8066596.stderr with token SERR and compression 69
distccd[14752] (dcc_x_token_int) send SERR000003ea
distccd[14752] (dcc_x_file) send 0 byte file /tmp/distcc_b8246596.stdout with token SOUT and compression 69
distccd[14752] (dcc_x_token_int) send SOUT00000000
distccd[14752] (dcc_x_file) send 2192 byte file /tmp/distccd_ba666596.o with token DOTO and compression 69
distccd[14752] (dcc_x_token_int) send DOTO00000890
distccd[14752] clang-3.9-arm udp-client.c on localhost completed ok
distccd[14752] job complete
distccd[14752] (dcc_cleanup_tempfiles_inner) deleted 5 temporary files
distccd[14752] (dcc_job_summary) client: 192.168.7.2:59770 COMPILE_OK exit:0 sig:0 core:0 ret:0 time:318ms clang-3.9-arm udp-client.c
distccd[14753] (dcc_check_client) connection from 192.168.7.2:59772
distccd[14753] (check_address_inet) match client 0x207a8c0, value 0x207a8c0, mask 0xffffffff
distccd[14753] (dcc_r_token_int) got DIST00000001
distccd[14753] (dcc_r_token_int) got ARGC00000006
distccd[14753] (dcc_r_argv) reading 6 arguments from job submission
distccd[14753] (dcc_r_token_int) got ARGV0000000d
distccd[14753] (dcc_r_token_string) got 'clang-3.9-arm'
distccd[14753] (dcc_r_argv) argv[0] = "clang-3.9-arm"
distccd[14753] (dcc_r_token_int) got ARGV00000002
distccd[14753] (dcc_r_token_string) got '-c'
distccd[14753] (dcc_r_argv) argv[1] = "-c"
distccd[14753] (dcc_r_token_int) got ARGV00000029
distccd[14753] (dcc_r_token_string) got '/root/Bela/resources/network/udp-client.c'
distccd[14753] (dcc_r_argv) argv[2] = "/root/Bela/resources/network/udp-client.c"
distccd[14753] (dcc_r_token_int) got ARGV0000000e
distccd[14753] (dcc_r_token_string) got '-march=armv7-a'
distccd[14753] (dcc_r_argv) argv[3] = "-march=armv7-a"
distccd[14753] (dcc_r_token_string) got '-o'
distccd[14753] (dcc_r_argv) argv[4] = "-o"
distccd[14753] (dcc_r_token_int) got ARGV0000000c
distccd[14753] (dcc_r_token_string) got 'udp-client.o'
distccd[14753] (dcc_r_argv) argv[5] = "udp-client.o"
distccd[14753] (dcc_r_argv) got arguments: clang-3.9-arm -c /root/Bela/resources/network/udp-client.c -march=armv7-a -o udp-client.o
distccd[14753] (dcc_scan_args) scanning arguments: clang-3.9-arm -c /root/Bela/resources/network/udp-client.c -march=armv7-a -o udp-client.o
distccd[14753] (dcc_scan_args) found input file "/root/Bela/resources/network/udp-client.c"
distccd[14753] (dcc_scan_args) found object/output file "udp-client.o"
distccd[14753] compile from udp-client.c to udp-client.o
distccd[14753] (dcc_run_job) output file udp-client.o
distccd[14753] (dcc_input_tmpnam) input file /root/Bela/resources/network/udp-client.c
distccd[14753] (dcc_r_token_int) got DOTI00016eeb
distccd[14753] (dcc_r_file) received 93931 bytes to file /tmp/distccd_20816628.i
distccd[14753] (dcc_r_file_timed) 93931 bytes received in 0.012232s, rate 7499kB/s
distccd[14753] (dcc_set_input) changed input from "/root/Bela/resources/network/udp-client.c" to "/tmp/distccd_20816628.i"
distccd[14753] (dcc_set_input) command after: clang-3.9-arm -c /tmp/distccd_20816628.i -march=armv7-a -o udp-client.o
distccd[14753] (dcc_set_output) changed output from "udp-client.o" to "/tmp/distccd_20dc6628.o"
distccd[14753] (dcc_set_output) command after: clang-3.9-arm -c /tmp/distccd_20816628.i -march=armv7-a -o /tmp/distccd_20dc6628.o
distccd[14753] (dcc_check_compiler_masq) /usr/local/bin/clang-3.9-arm is not a symlink
distccd[14753] (dcc_spawn_child) forking to execute: clang-3.9-arm -c /tmp/distccd_20816628.i -march=armv7-a -o /tmp/distccd_20dc6628.o
distccd[14753] (dcc_spawn_child) child started as pid32547
distccd[32547] (dcc_new_pgrp) entered process group
distccd[32547] (dcc_increment_safeguard) setting safeguard: _DISTCC_SAFEGUARD=1
distccd[14753] (dcc_collect_child) cc child 32547 terminated with status 0
distccd[14753] (dcc_collect_child) cc times: user 0.000000s, system 0.000000s, 0 minflt, 0 majflt
distccd[14753] (dcc_x_token_int) send DONE00000001
distccd[14753] (dcc_x_token_int) send STAT00000000
distccd[14753] (dcc_x_file) send 0 byte file /tmp/distcc_27c16628.stderr with token SERR and compression 69
distccd[14753] (dcc_x_token_int) send SERR00000000
distccd[14753] (dcc_x_file) send 0 byte file /tmp/distcc_27996628.stdout with token SOUT and compression 69
distccd[14753] (dcc_x_token_int) send SOUT00000000
distccd[14753] (dcc_x_file) send 2192 byte file /tmp/distccd_20dc6628.o with token DOTO and compression 69
distccd[14753] (dcc_x_token_int) send DOTO00000890
distccd[14753] clang-3.9-arm /root/Bela/resources/network/udp-client.c on localhost completed ok
distccd[14753] job complete
distccd[14753] (dcc_cleanup_tempfiles_inner) deleted 5 temporary files
distccd[14753] (dcc_job_summary) client: 192.168.7.2:59772 COMPILE_OK exit:0 sig:0 core:0 ret:0 time:286ms clang-3.9-arm /root/Bela/resources/network/udp-client.c
distccd[14754] (dcc_check_client) connection from 192.168.7.2:59774
distccd[14754] (check_address_inet) match client 0x207a8c0, value 0x207a8c0, mask 0xffffffff
distccd[14754] (dcc_r_token_int) got DIST00000001
distccd[14754] (dcc_r_token_int) got ARGC00000007
distccd[14754] (dcc_r_argv) reading 7 arguments from job submission
distccd[14754] (dcc_r_token_int) got ARGV0000000d
distccd[14754] (dcc_r_token_string) got 'clang-3.9-arm'
distccd[14754] (dcc_r_argv) argv[0] = "clang-3.9-arm"
distccd[14754] (dcc_r_token_int) got ARGV00000002
distccd[14754] (dcc_r_token_string) got '-c'
distccd[14754] (dcc_r_argv) argv[1] = "-c"
distccd[14754] (dcc_r_token_string) got '-v'
distccd[14754] (dcc_r_argv) argv[2] = "-v"
distccd[14754] (dcc_r_token_int) got ARGV00000029
distccd[14754] (dcc_r_token_string) got '/root/Bela/resources/network/udp-client.c'
distccd[14754] (dcc_r_argv) argv[3] = "/root/Bela/resources/network/udp-client.c"
distccd[14754] (dcc_r_token_int) got ARGV0000000e
distccd[14754] (dcc_r_token_string) got '-march=armv7-a'
distccd[14754] (dcc_r_argv) argv[4] = "-march=armv7-a"
distccd[14754] (dcc_r_token_string) got '-o'
distccd[14754] (dcc_r_argv) argv[5] = "-o"
distccd[14754] (dcc_r_token_int) got ARGV0000000c
distccd[14754] (dcc_r_token_string) got 'udp-client.o'
distccd[14754] (dcc_r_argv) argv[6] = "udp-client.o"
distccd[14754] (dcc_r_argv) got arguments: clang-3.9-arm -c -v /root/Bela/resources/network/udp-client.c -march=armv7-a -o udp-client.o
distccd[14754] (dcc_scan_args) scanning arguments: clang-3.9-arm -c -v /root/Bela/resources/network/udp-client.c -march=armv7-a -o udp-client.o
distccd[14754] (dcc_scan_args) found input file "/root/Bela/resources/network/udp-client.c"
distccd[14754] (dcc_scan_args) found object/output file "udp-client.o"
distccd[14754] compile from udp-client.c to udp-client.o
distccd[14754] (dcc_run_job) output file udp-client.o
distccd[14754] (dcc_input_tmpnam) input file /root/Bela/resources/network/udp-client.c
distccd[14754] (dcc_r_token_int) got DOTI00016eeb
distccd[14754] (dcc_r_file) received 93931 bytes to file /tmp/distccd_ff4c663b.i
distccd[14754] (dcc_r_file_timed) 93931 bytes received in 0.011458s, rate 8006kB/s
distccd[14754] (dcc_set_input) changed input from "/root/Bela/resources/network/udp-client.c" to "/tmp/distccd_ff4c663b.i"
distccd[14754] (dcc_set_input) command after: clang-3.9-arm -c -v /tmp/distccd_ff4c663b.i -march=armv7-a -o udp-client.o
distccd[14754] (dcc_set_output) changed output from "udp-client.o" to "/tmp/distccd_fcec663b.o"
distccd[14754] (dcc_set_output) command after: clang-3.9-arm -c -v /tmp/distccd_ff4c663b.i -march=armv7-a -o /tmp/distccd_fcec663b.o
distccd[14754] (dcc_check_compiler_masq) /usr/local/bin/clang-3.9-arm is not a symlink
distccd[14754] (dcc_spawn_child) forking to execute: clang-3.9-arm -c -v /tmp/distccd_ff4c663b.i -march=armv7-a -o /tmp/distccd_fcec663b.o
distccd[14754] (dcc_spawn_child) child started as pid32551
distccd[32551] (dcc_new_pgrp) entered process group
distccd[32551] (dcc_increment_safeguard) setting safeguard: _DISTCC_SAFEGUARD=1
distccd[14754] (dcc_collect_child) cc child 32551 terminated with status 0
distccd[14754] (dcc_collect_child) cc times: user 0.000000s, system 0.000000s, 0 minflt, 0 majflt
distccd[14754] (dcc_x_token_int) send DONE00000001
distccd[14754] (dcc_x_token_int) send STAT00000000
distccd[14754] (dcc_x_file) send 1002 byte file /tmp/distcc_f203663b.stderr with token SERR and compression 69
distccd[14754] (dcc_x_token_int) send SERR000003ea
distccd[14754] (dcc_x_file) send 0 byte file /tmp/distcc_f22c663b.stdout with token SOUT and compression 69
distccd[14754] (dcc_x_token_int) send SOUT00000000
distccd[14754] (dcc_x_file) send 2192 byte file /tmp/distccd_fcec663b.o with token DOTO and compression 69
distccd[14754] (dcc_x_token_int) send DOTO00000890
distccd[14754] clang-3.9-arm /root/Bela/resources/network/udp-client.c on localhost completed ok
distccd[14754] job complete
distccd[14754] (dcc_cleanup_tempfiles_inner) deleted 5 temporary files
distccd[14754] (dcc_job_summary) client: 192.168.7.2:59774 COMPILE_OK exit:0 sig:0 core:0 ret:0 time:320ms clang-3.9-arm /root/Bela/resources/network/udp-client.c
Now trying "faust2bela" from the Ubuntu machine. /usr/Bela/Makefile still references distcc.
gary@audio-workstation:~/faust/examples/bela$ faust2bela -tobela -gui FXChaine2.dsp
Send to bela
/home/gary/faust/examples/bela/FXChaine2
Start communication with bela
FXChaine2
Stop running process...
Run bela now
uploadBuildRun START
Copying new source files to BeagleBone...Using rsync...
PID=`grep bela-audio /proc/xenomai/sched/stat | cut -d " " -f 5 | sed s/\s//g`; if [ -z $PID ]; then [ true = true ] || echo "No process to kill"; else [ true = true ] || echo "Killing old Bela process $PID"; kill -2 $PID; sleep 0.2; kill -9 $PID 2> /dev/null; fi; screen -X -S Bela quit > /dev/null; exit 0;
echo 'Building render.cpp...'
distcc-clang++ -I/root/Bela/projects/FXChaine2 -I./include -I./build/pru/ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBALT__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEBUG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -std=c++11 -Wno-varargs -DNDEBUG -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/projects/FXChaine2/build/render.d" -o "/root/Bela/projects/FXChaine2/build/render.o" "/root/Bela/projects/FXChaine2/render.cpp"
distcc[5035] ERROR: compile /root/Bela/projects/FXChaine2/render.cpp on 192.168.7.1 failed
distcc[5035] (dcc_build_somewhere) Warning: remote compilation of '/root/Bela/projects/FXChaine2/render.cpp' failed, retrying locally
distcc[5035] (dcc_build_somewhere) Warning: failed to distribute and fallbacks are disabled
/usr/bin/ld: unrecognised emulation mode: armelf_linux_eabi
Supported emulations: elf_x86_64 elf32_x86_64 elf_i386 elf_iamcu i386linux elf_l1om elf_k1om i386pep i386pe
Makefile:434: recipe for target '/root/Bela/projects/FXChaine2/build/render.o' failed
make: *** [/root/Bela/projects/FXChaine2/build/render.o] Error 1
This still seems to be the failure:
This link takes us to some hints on that error message, which seem to culminate in "install the toolchain". The question is in the context of Android NDK though so I don't know if it applies here.
Here's the distcc log from this step:
distccd[14755] (dcc_check_client) connection from 192.168.7.2:59776
distccd[14755] (check_address_inet) match client 0x207a8c0, value 0x207a8c0, mask 0xffffffff
distccd[14755] (dcc_r_token_int) got DIST00000001
distccd[14755] (dcc_r_token_int) got ARGC00000013
distccd[14755] (dcc_r_argv) reading 19 arguments from job submission
distccd[14755] (dcc_r_token_int) got ARGV0000000f
distccd[14755] (dcc_r_token_string) got 'clang++-3.9-arm'
distccd[14755] (dcc_r_argv) argv[0] = "clang++-3.9-arm"
distccd[14755] (dcc_r_token_int) got ARGV0000000e
distccd[14755] (dcc_r_token_string) got '-march=armv7-a'
distccd[14755] (dcc_r_argv) argv[1] = "-march=armv7-a"
distccd[14755] (dcc_r_token_int) got ARGV0000000a
distccd[14755] (dcc_r_token_string) got '-mfpu=vfp3'
distccd[14755] (dcc_r_argv) argv[2] = "-mfpu=vfp3"
distccd[14755] (dcc_r_token_int) got ARGV0000001c
distccd[14755] (dcc_r_token_string) got '-fasynchronous-unwind-tables'
distccd[14755] (dcc_r_argv) argv[3] = "-fasynchronous-unwind-tables"
distccd[14755] (dcc_r_token_int) got ARGV00000003
distccd[14755] (dcc_r_token_string) got '-O3'
distccd[14755] (dcc_r_argv) argv[4] = "-O3"
distccd[14755] (dcc_r_argv) argv[5] = "-march=armv7-a"
distccd[14755] (dcc_r_token_int) got ARGV00000010
distccd[14755] (dcc_r_token_string) got '-mtune=cortex-a8'
distccd[14755] (dcc_r_argv) argv[6] = "-mtune=cortex-a8"
distccd[14755] (dcc_r_token_string) got '-mfloat-abi=hard'
distccd[14755] (dcc_r_argv) argv[7] = "-mfloat-abi=hard"
distccd[14755] (dcc_r_token_string) got '-mfpu=neon'
distccd[14755] (dcc_r_argv) argv[8] = "-mfpu=neon"
distccd[14755] (dcc_r_token_string) got '-ftree-vectorize'
distccd[14755] (dcc_r_argv) argv[9] = "-ftree-vectorize"
distccd[14755] (dcc_r_token_int) got ARGV0000000b
distccd[14755] (dcc_r_token_string) got '-ffast-math'
distccd[14755] (dcc_r_argv) argv[10] = "-ffast-math"
distccd[14755] (dcc_r_token_string) got '-std=c++11'
distccd[14755] (dcc_r_argv) argv[11] = "-std=c++11"
distccd[14755] (dcc_r_token_int) got ARGV0000000c
distccd[14755] (dcc_r_token_string) got '-Wno-varargs'
distccd[14755] (dcc_r_argv) argv[12] = "-Wno-varargs"
distccd[14755] (dcc_r_token_int) got ARGV00000005
distccd[14755] (dcc_r_token_string) got '-Wall'
distccd[14755] (dcc_r_argv) argv[13] = "-Wall"
distccd[14755] (dcc_r_token_int) got ARGV00000002
distccd[14755] (dcc_r_token_string) got '-c'
distccd[14755] (dcc_r_argv) argv[14] = "-c"
distccd[14755] (dcc_r_token_int) got ARGV00000012
distccd[14755] (dcc_r_token_string) got '-fmessage-length=0'
distccd[14755] (dcc_r_argv) argv[15] = "-fmessage-length=0"
distccd[14755] (dcc_r_token_string) got '-o'
distccd[14755] (dcc_r_argv) argv[16] = "-o"
distccd[14755] (dcc_r_token_int) got ARGV0000002c
distccd[14755] (dcc_r_token_string) got '/root/Bela/projects/FXChaine2/build/render.o'
distccd[14755] (dcc_r_argv) argv[17] = "/root/Bela/projects/FXChaine2/build/render.o"
distccd[14755] (dcc_r_token_int) got ARGV00000028
distccd[14755] (dcc_r_token_string) got '/root/Bela/projects/FXChaine2/render.cpp'
distccd[14755] (dcc_r_argv) argv[18] = "/root/Bela/projects/FXChaine2/render.cpp"
distccd[14755] (dcc_r_argv) got arguments: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /root/Bela/projects/FXChaine2/build/render.o /root/Bela/projects/FXChaine2/render.cpp
distccd[14755] (dcc_scan_args) scanning arguments: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /root/Bela/projects/FXChaine2/build/render.o /root/Bela/projects/FXChaine2/render.cpp
distccd[14755] (dcc_scan_args) found object/output file "/root/Bela/projects/FXChaine2/build/render.o"
distccd[14755] (dcc_scan_args) found input file "/root/Bela/projects/FXChaine2/render.cpp"
distccd[14755] compile from render.cpp to render.o
distccd[14755] (dcc_run_job) output file /root/Bela/projects/FXChaine2/build/render.o
distccd[14755] (dcc_input_tmpnam) input file /root/Bela/projects/FXChaine2/render.cpp
distccd[14755] (dcc_r_token_int) got DOTI0019610a
distccd[14755] (dcc_r_file) received 1663242 bytes to file /tmp/distccd_261c6794.ii
distccd[14755] (dcc_r_file_timed) 1663242 bytes received in 0.150477s, rate 10794kB/s
distccd[14755] (dcc_set_input) changed input from "/root/Bela/projects/FXChaine2/render.cpp" to "/tmp/distccd_261c6794.ii"
distccd[14755] (dcc_set_input) command after: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /root/Bela/projects/FXChaine2/build/render.o /tmp/distccd_261c6794.ii
distccd[14755] (dcc_set_output) changed output from "/root/Bela/projects/FXChaine2/build/render.o" to "/tmp/distccd_27a96794.o"
distccd[14755] (dcc_set_output) command after: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /tmp/distccd_27a96794.o /tmp/distccd_261c6794.ii
distccd[14755] (dcc_check_compiler_masq) /usr/local/bin/clang++-3.9-arm is not a symlink
distccd[14755] (dcc_spawn_child) forking to execute: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /tmp/distccd_27a96794.o /tmp/distccd_261c6794.ii
distccd[14755] (dcc_spawn_child) child started as pid32659
distccd[32659] (dcc_new_pgrp) entered process group
distccd[32659] (dcc_increment_safeguard) setting safeguard: _DISTCC_SAFEGUARD=1
distccd[14755] (dcc_collect_child) cc child 32659 terminated with status 0x100
distccd[14755] (dcc_collect_child) cc times: user 0.000000s, system 0.000000s, 0 minflt, 0 majflt
distccd[14755] (dcc_x_token_int) send DONE00000001
distccd[14755] (dcc_x_token_int) send STAT00000100
distccd[14755] (dcc_x_file) send 248 byte file /tmp/distcc_58bf6794.stderr with token SERR and compression 69
distccd[14755] (dcc_x_token_int) send SERR000000f8
distccd[14755] (dcc_x_file) send 0 byte file /tmp/distcc_5b7e6794.stdout with token SOUT and compression 69
distccd[14755] (dcc_x_token_int) send SOUT00000000
distccd[14755] (dcc_x_token_int) send DOTO00000000
distccd[14755] clang++-3.9-arm /root/Bela/projects/FXChaine2/render.cpp on localhost failed
distccd[14755] job complete
distccd[14755] (dcc_cleanup_tempfiles_inner) deleted 5 temporary files
distccd[14755] (dcc_job_summary) client: 192.168.7.2:59776 COMPILE_ERROR exit:1 sig:0 core:0 ret:0 time:1109ms clang++-3.9-arm /root/Bela/projects/FXChaine2/render.cpp
This is very confusing to me. The error message you get seems to be about the linker, ld
, and it seems to come from the host, because of the list of supported emulations. The weird thing about this is that distcc
should never attempt to run the linker on the host (only the compiler), and also that the line that fails really has nothing to do with the linker.
So this is the line that is run on the host and fails:
Digital-Larry distccd[14755] (dcc_spawn_child) forking to execute: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /tmp/distccd_27a96794.o /tmp/distccd_261c6794.ii
As you see, it tries to compile the pre-processed file /tmp/distccd_261c6794.ii
into the object file /tmp/distccd_27a96794.o
. The pre-processed file is generated by distcc
on the client (Bela), where it runs cpp
(the C-preprocessor) on the file to bring in all the includes and apply all the defines and resolve the macros, generating a stand-alone C++ file that has no dependency on any external files.
Let's troubleshoot this with incremental steps. Create a simple C++ file with no includes on the host:
- Create a simple C++ file with no includes on the HOST: create a file called
test.ii
and then run the same command as above (except for the file paths at the end) :int func() { return 0; }
if this is successful, make sure the generated fileclang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o ./test.o ./test.ii
test.o
is indeed an ARM binary:$ file test.o test.o: ELF 32-bit LSB relocatable, ARM, version 1 (SYSV), not stripped
- if the above worked fine, then copy the
test.ii
file to the board and run ON THE BOARD:
and if this is successful, check that the generated file is indeed an ARM binary:distcc-clang++ -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o ./test.o ./test.ii
- if this is still good, then rename
test.ii
totest.cpp
and run the same line again, this time withtest.cpp
at the end:distcc-clang++ -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o ./test.o ./test.cpp
- if this is still good, still on the board, do
cd /root/Bela/
and there try to re-run the full line that was failing while building your project:
does this successfully generated the filedistcc-clang++ -I/root/Bela/projects/FXChaine2 -I./include -I./build/pru/ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBALT__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEBUG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -std=c++11 -Wno-varargs -DNDEBUG -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/projects/FXChaine2/build/render.d" -o "/root/Bela/projects/FXChaine2/build/render.o" "/root/Bela/projects/FXChaine2/render.cpp"
? And is it an ARM binary?
giuliomoro first step fails.
gary@audio-workstation:~/test$ clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o ./test.o ./test.ii
gary@audio-workstation:~/test$ cat test.ii
int func()
return 0;
gary@audio-workstation:~/test$ which clang++-3.9-arm
gary@audio-workstation:~/test$ cat /usr/local/bin/clang++-3.9-arm
#!/bin/bash
/usr/bin/clang++-3.9 -target armv7l-unknown-linux-gnueabihf --sysroot ~/arm $0
Calling that compiler throws the error with no parameters given at all! [edit - it's calling the script which does add parameters] So maybe that is broken somehow. I used apt to install it.
gary@audio-workstation:~/test$ sudo apt list | grep ^clang-3.9
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
clang-3.9/bionic,now 1:3.9.1-19ubuntu1 amd64 [installed]
clang-3.9-doc/bionic,bionic 1:3.9.1-19ubuntu1 all
clang-3.9-examples/bionic 1:3.9.1-19ubuntu1 amd64
gary@audio-workstation:~/test$ sudo dpkg -s clang-3.9
Package: clang-3.9
Status: install ok installed
Priority: optional
Section: devel
Installed-Size: 140661
Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
Architecture: amd64
Source: llvm-toolchain-3.9
Version: 1:3.9.1-19ubuntu1
Replaces: clang-3.1, clang-3.2, clang-3.3, clang-3.4 (<< 1:3.4.2-7~exp1), clang-3.5 (<< 1:3.5~+rc1-3~exp1), clang-include-fixer-3.9, compiler-rt
Provides: c++-compiler, c-compiler, objc-compiler
Depends: libc6 (>= 2.14), libclang1-3.9 (= 1:3.9.1-19ubuntu1), libgcc1 (>= 1:3.4), libjsoncpp1 (>= 1.7.4), libllvm3.9 (>= 1:3.9.1-6~), libstdc++6 (>= 5.2), libstdc++-7-dev, libgcc-7-dev, libobjc-7-dev, libclang-common-3.9-dev (= 1:3.9.1-19ubuntu1), libc6-dev, binutils
Recommends: llvm-3.9-dev, python
Suggests: gnustep, gnustep-devel, clang-3.9-doc
Breaks: clang-3.1, clang-3.2, clang-3.3, clang-3.4 (<< 1:3.4.2-7~exp1), clang-3.5 (<< 1:3.5~+rc1-3~exp1), clang-include-fixer-3.9, compiler-rt
Description: C, C++ and Objective-C compiler (LLVM based)
Clang project is a C, C++, Objective C and Objective C++ front-end
for the LLVM compiler. Its goal is to offer a replacement to the GNU Compiler
Collection (GCC).
Clang fully implements all published ISO C++ standards including C++11, as
well as the upcoming C++14 standard, and some parts of the fledgling C++1z
standard, and is considered a production-quality C++ compiler.
Original-Maintainer: LLVM Packaging Team <pkg-llvm-team@lists.alioth.debian.org>
Homepage: http://www.llvm.org/
Some other random tests to see what exactly we are calling and the simplest command to generate the error.
#!/bin/bash
gary@audio-workstation:~/test$ /usr/bin/clang++-3.9
clang: error: no input files
gary@audio-workstation:~/test$ /usr/bin/clang++-3.9 -target armv7l-unknown-linux-gnueabihf
gary@audio-workstation:~/test$ /usr/bin/clang++-3.9 -target armv7l-unknown-linux-gnueabihf ./test.ii
gary@audio-workstation:~/test$ /usr/bin/clang++-6.0 -target armv7l-unknown-linux-gnueabihf ./test.ii
gary@audio-workstation:~/test$ /usr/bin/clang++ -target armv7l-unknown-linux-gnueabihf ./test.ii
right, what about ls -l /usr/bin/clang++-3.9
? is it a symlink to something?
Further to this, you could try running
and remove one option at a time until it succeeds (or better: start with just clang++-3.9-arm -march=armv7-a ./test.o ./test.ii
, is it successful? Then add more and more options until it fails .
I am wondering whether maybe your clang-3.9
does not support hard-float, in which case the failing option should be -mfloat-abi=hard
. Can you dpkg -l | grep clang
and perhaps then dpkg --info <names of the 3.9 packages from the previous result>
I used the -### command with just clang++ (the 6.0 version installed by default, but the error is the same so far regardless of the compiler version used, 3.9 or 6.0):
gary@audio-workstation:~/test$ /usr/bin/clang++ -### -target armv7l-unknown-linux-gnueabihf ./test.ii
clang version 6.0.0-1ubuntu2 (tags/RELEASE_600/final)
Thread model: posix
"/usr/lib/llvm-6.0/bin/clang" "-cc1" "-triple" "armv7-unknown-linux-gnueabihf" "-emit-obj" "-mrelax-all" "-disable-free" "-disable-llvm-verifier" "-discard-value-names" "-main-file-name" "test.ii" "-mrelocation-model" "static" "-mthread-model" "posix" "-mdisable-fp-elim" "-fmath-errno" "-masm-verbose" "-mconstructor-aliases" "-fuse-init-array" "-target-cpu" "generic" "-target-abi" "aapcs-linux" "-mfloat-abi" "hard" "-fallow-half-arguments-and-returns" "-dwarf-column-info" "-debugger-tuning=gdb" "-resource-dir" "/usr/lib/llvm-6.0/lib/clang/6.0.0" "-fdeprecated-macro" "-fdebug-compilation-dir" "/home/gary/test" "-ferror-limit" "19" "-fmessage-length" "80" "-fno-signed-char" "-fobjc-runtime=gcc" "-fcxx-exceptions" "-fexceptions" "-fdiagnostics-show-option" "-fcolor-diagnostics" "-o" "/tmp/test-dc97e4.o" "-x" "c++-cpp-output" "./test.ii"
"/usr/bin/ld" "-z" "relro" "-X" "--hash-style=gnu" "--eh-frame-hdr" "-m" "armelf_linux_eabi" "-dynamic-linker" "/lib/ld-linux-armhf.so.3" "-o" "a.out" "crt1.o" "crti.o" "crtbegin.o" "-L/usr/lib/llvm-6.0/bin/../lib" "-L/lib/../lib" "-L/usr/lib/../lib" "-L/usr/lib/llvm-6.0/bin/../lib" "-L/lib" "-L/usr/lib" "/tmp/test-dc97e4.o" "-lstdc++" "-lm" "-lgcc_s" "-lgcc" "-lc" "-lgcc_s" "-lgcc" "crtend.o" "crtn.o"
giuliomoro yes there is a symlink there that appears to be from the installation (I didn't do it).
gary@audio-workstation:~/test$ ls -l /usr/bin/clang++-3.9
lrwxrwxrwx 1 root root 27 Dec 26 2017 /usr/bin/clang++-3.9 -> ../lib/llvm-3.9/bin/clang++
gary@audio-workstation:~/test$ clang++-3.9-arm -march=armv7-a ./test.o ./test.ii
gary@audio-workstation:~/test$ dpkg -l | grep clang
ii clang 1:6.0-41~exp5~ubuntu1 amd64 C, C++ and Objective-C compiler (LLVM based)
ii clang-3.9 1:3.9.1-19ubuntu1 amd64 C, C++ and Objective-C compiler (LLVM based)
ii clang-6.0 1:6.0-1ubuntu2 amd64 C, C++ and Objective-C compiler
ii libclang-common-3.9-dev 1:3.9.1-19ubuntu1 amd64 clang library - Common development package
ii libclang-common-6.0-dev 1:6.0-1ubuntu2 amd64 clang library - Common development package
ii libclang1-3.9:amd64 1:3.9.1-19ubuntu1 amd64 C interface to the clang library
ii libclang1-6.0:amd64 1:6.0-1ubuntu2 amd64 C interface to the clang library
dpkg --info doesn't show anything but apt show does:
gary@audio-workstation:~/test$ apt show clang-3.9
Package: clang-3.9
Priority: optional
Section: universe/devel
Origin: Ubuntu
Bugs: https://bugs.launchpad.net/ubuntu/+filebug
Installed-Size: 144 MB
Download-Size: 37.4 MB
APT-Manual-Installed: yes
APT-Sources: http://us.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
Collection (GCC).
gary@audio-workstation:~/test$ apt show libclang-common-3.9-dev
Package: libclang-common-3.9-dev
Priority: optional
Section: universe/libdevel
Origin: Ubuntu
Installed-Size: 39.1 MB
Depends: libc6 (>= 2.15), libgcc1 (>= 1:3.4), libstdc++6 (>= 5.2), libtinfo5 (>= 6), libllvm3.9 (= 1:3.9.1-19ubuntu1)
Download-Size: 2,575 kB
APT-Manual-Installed: no
Description: clang library - Common development package
Collection (GCC).
This package contains the clang generic headers and some libraries
(profiling, etc).
gary@audio-workstation:~/test$ apt show libclang1-3.9
Package: libclang1-3.9
Priority: optional
Origin: Ubuntu
Installed-Size: 22.9 MB
Depends: libc6 (>= 2.14), libgcc1 (>= 1:3.4), libllvm3.9 (>= 1:3.9.1-6~), libstdc++6 (>= 5.2)
Download-Size: 5,950 kB
Description: C interface to the clang library
Collection (GCC).
This package contains the clang library.
The C Interface to Clang provides a relatively small API that exposes
facilities for parsing source code into an abstract syntax tree (AST),
loading already-parsed ASTs, traversing the AST, associating physical source
locations with elements within the AST, and other facilities that support
Clang-based development tools.
Digital-Larry gary@audio-workstation:~/test$ /usr/bin/clang++-3.9 -target armv7l-unknown-linux-gnueabihf ./test.ii
you nee -c
otherwise it will attempt to use the linker.
or better: start with justclang++-3.9-arm -march=armv7-a ./test.o ./test.ii
, is it successful?
I forgot -c
, too, and also -o
so try:
clang++-3.9-arm -march=armv7-a -c -o ./test.o ./test.ii
if that succeeds, add one option at a time until it fails ..
gary@audio-workstation:~/test$ clang++-3.9-arm -march=armv7-a -c -o ./test.o ./test.ii
and with -###
gary@audio-workstation:~/test$ /usr/bin/clang++-3.9 -### -march=arm7-a -c -o ./test.o ./test.ii
Target: x86_64-pc-linux-gnu
Thread model: posix
"/usr/lib/llvm-3.9/bin/clang" "-cc1" "-triple" "x86_64-pc-linux-gnu" "-emit-obj" "-mrelax-all" "-disable-free" "-disable-llvm-verifier" "-discard-value-names" "-main-file-name" "test.ii" "-mrelocation-model" "static" "-mthread-model" "posix" "-mdisable-fp-elim" "-fmath-errno" "-masm-verbose" "-mconstructor-aliases" "-munwind-tables" "-fuse-init-array" "-target-cpu" "arm7-a" "-dwarf-column-info" "-debugger-tuning=gdb" "-coverage-file" "/home/gary/test/./test.o" "-resource-dir" "/usr/lib/llvm-3.9/bin/../lib/clang/3.9.1" "-fdeprecated-macro" "-fdebug-compilation-dir" "/home/gary/test" "-ferror-limit" "19" "-fmessage-length" "80" "-fobjc-runtime=gcc" "-fcxx-exceptions" "-fexceptions" "-fdiagnostics-show-option" "-fcolor-diagnostics" "-o" "./test.o" "-x" "c++-cpp-output" "./test.ii"
sorry, hang on, swimming in stuff here...
gary@audio-workstation:~/test$ clang++-3.9-arm -### -march=armv7-a -c -o ./test.o ./test.ii
I added the "-###" right in the clang++-3.9-arm script itself (I also tried adding "-fno-autolink"):
gary@audio-workstation:~/test$ sh -x /usr/local/bin/clang++-3.9-arm -### -march=armv7-a -c -o ./test.o ./test.ii
+ /usr/bin/clang++-3.9 -### -target armv7l-unknown-linux-gnueabihf -fno-autolink --sysroot /home/gary/arm /usr/local/bin/clang++-3.9-arm
Thread model: posix
"/usr/bin/ld" "--sysroot=/home/gary/arm" "-X" "--eh-frame-hdr" "-m" "armelf_linux_eabi" "-dynamic-linker" "/lib/ld-linux-armhf.so.3" "-o" "a.out" "crt1.o" "crti.o" "crtbegin.o" "/usr/local/bin/clang++-3.9-arm" "-lstdc++" "-lm" "-lgcc_s" "-lgcc" "-lc" "-lgcc_s" "-lgcc" "crtend.o" "crtn.o"
OK after that last one I found it! It wasn't until I ran the script with "sh -x" that I saw the wrong command line substitution. The last thing on the command line should be the source file name, but it is the script file name!
In this file, I had "$0" instead of "$@" - I changed it and it works!!!!
gary@audio-workstation:~/faust/examples/bela$ cat /usr/local/bin/clang++-3.9-arm
#!/bin/bash
/usr/bin/clang++-3.9 -target armv7l-unknown-linux-gnueabihf --sysroot ~/arm $@
Giuilo thanks so much for your patient help. Sorry it was so difficult but maybe it helps the next guy. At this point I think Faust on Bela is a very viable idea. Hopefully my next questions and comments will be more on the implementation side.
It ended up well! So, was this the problem all along?
giuliomoro I think so. At least, I see it shown in some of the things I posted a day or two ago. Just very hard to see! One question I have which I will defer answering for now is whether clang 3.9 is really needed on the Ubuntu system or whether "clang" as installed (which by now is at 6.0) is OK. I understand that the distcc as being called by faust2bela may be making the specific reference to 3.9. Lots of different interacting parts here.
Linker problem
One issue of 3.9 vs 6.0 is that linking is always done on the board by calling clang++-3.9
, and so if there is any incompatibility between the .o
files generated by 6.0
and the way clang++-3.9
calls the ld
linker, or the way the older ld
linker on the board deals with object files, then you could have some issues. I guess this is unlikely to happen, but I am not sure what guarantees clang
and ld
give about interoperability of different versions.
Compiler problem
Another issue is that different versions of clang
may decide to pack structs (or at least ARM intrinsics) in different ways, for instance:
giuliomoro What is surprising is that while alignof(float32x4_t) is 16 bytes on clang-3.9, it is actually 8 bytes on gcc-6.3 and clang-6.0.
and
giuliomoro However, I am wondering where that difference comes from, as the arm_neon.h files for the two versions of clang provide identical definition for all the neon vector types.
More in general, there would be a problem if you have object files that both include some .h
file that is interpreted differently by the two versions of the compiler, and you compile the two objects with different versions of the compiler. Again, I am not sure what backward/forward compatibility guarantees clang
provides. Clearly, if you ALWAYS use distcc
to build all the files on Bela, there would be no problem. The problem only comes up (potentially) if you are intermixing .o
files compiled with different versions of the compiler.
For instance - in you current situation - you built all the Bela core/
files with the local version of clang-3.9
the first time you built the first program. If you switch to using clang-6.0
, I'd recommend you do a make -C ~/Bela clean
on the board, so that those files are re-built next time you build a project.
giuliomoro ah well never mind, all that stuff gives me a headache! I'm OK leaving 3.9 installed. Thanks for the detailed explanation.
