gary@audio-workstation:~$ ld -V
GNU ld (GNU Binutils for Ubuntu) 2.30
  Supported emulations:
   elf_x86_64
   elf32_x86_64
   elf_i386
   elf_iamcu
   i386linux
   elf_l1om
   elf_k1om
   i386pep
   i386pe
Digital-Larry By "the Bela Makefile" I presume that you mean the file /root/Bela/Makefile.
yes
Digital-Larry On host console I get:
I guess that's technically the "client" console (i.e.: what you see there is while you are logged in on Bela).
So it seems that the compiler is failing, and my guess is that it is because it is being passed -march=armv7-a but no -target armv7l-unknown-linux-gnueabihf, and this - I guess - is because you are not calling the wrapper but you are calling the vanilla compiler directly (through the symlink you created).
The point of the wrapper is exactly to automatically add -target armv7l-unknown-linux-gnueabihf to all calls.
I think what is happening is what I mentioned in the other thread:
giuliomoro But if you do put some symlinks there, they should be pointing NOT to the regular clang, but to the clang-3.9-arm and clang++-3.9-arm files you created in /usr/local/bin/, and they will eventually call clang with the appropriate option -target armv7l-unknown-linux-gnueabihf, to tell it to build code for ARM.
Digital-Larry gary@audio-workstation:/usr/local/lib$ ls -l distcc/
total 0
lrwxrwxrwx 1 root root 14 May 28 17:45 clang-3.9-arm -> /usr/bin/clang
lrwxrwxrwx 1 root root 16 May 28 17:45 clang++-3.9-arm -> /usr/bin/clang++
Is this working? I find it surprising, but I guess it may depend on how you clang has been built. This way you are simply using the regular clang on your computer, but it should need a -target armv7l-unknown-linux-gnueabihf option in order to know it should build for arm (at least, it does with mine, which I installed with macports on Mac).
basically, remove your current symlinks from /usr/local/lib/distcc/ and make some new ones that point NOT to the vanilla clang/clang++, but to the wrapper clang-3.9-arm/clang++-3.9-arm you created:
sudo rm /usr/local/lib/distcc/*
sudo ln -s /usr/local/bin/clang-3.9-arm/ /usr/local/lib/distcc/
sudo ln -s /usr/local/bin/clang++-3.9-arm/ /usr/local/lib/distcc/
Digital-Larry However, this step works:
distcc-clang -c ~/Bela/resources/network/udp-client.c
I see now how that can easily give false positives: it just checks that the server can compile, but does not check the nature of the resulted file. If you were to do file a.out, it would probably say it's an x86 file and not an ARM one.
So the test should probably be amended to :
distcc-clang -c ~/Bela/resources/network/udp-client.c -march=armv7-a
This should then fail similarly to the how the Bela project is failing in your current configuration, and should be fixed with the updated symlinks.
    OK let's see where we are now.
    root@bela:~/Bela# grep distcc Makefile
      CLANG_PATH=distcc-clang
    root@bela:~/Bela#
    reference command line build on bela works (without specifying architecture):
    root@bela:~/Bela/resources/network# distcc-clang -v -c udp-client.c
    clang version 3.9.1-9 (tags/RELEASE_391/rc2)
    Target: armv7l-unknown-linux-gnueabihf
    Thread model: posix
    InstalledDir: /usr/bin
    Found candidate GCC installation: /usr/bin/../lib/gcc/arm-linux-gnueabihf/6
    Found candidate GCC installation: /usr/bin/../lib/gcc/arm-linux-gnueabihf/6.3.0
    Found candidate GCC installation: /usr/lib/gcc/arm-linux-gnueabihf/6
    Found candidate GCC installation: /usr/lib/gcc/arm-linux-gnueabihf/6.3.0
    Selected GCC installation: /usr/bin/../lib/gcc/arm-linux-gnueabihf/6.3.0
    Candidate multilib: .;@m32
    Selected multilib: .;@m32
     "/usr/lib/llvm-3.9/bin/clang" -cc1 -triple armv7-unknown-linux-gnueabihf -E -disable-free -disable-llvm-verifier -discard-value-names -main-file-name udp-client.c -mrelocation-model static -mthread-model posix -mdisable-fp-elim -fmath-errno -masm-verbose -mconstructor-aliases -fuse-init-array -target-cpu cortex-a8 -target-abi aapcs-linux -mfloat-abi hard -v -dwarf-column-info -debugger-tuning=gdb -resource-dir /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1 -internal-isystem /usr/local/include -internal-isystem /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1/include -internal-externc-isystem /usr/include/arm-linux-gnueabihf -internal-externc-isystem /include -internal-externc-isystem /usr/include -fdebug-compilation-dir /root/Bela/resources/network -ferror-limit 19 -fmessage-length 80 -fallow-half-arguments-and-returns -fno-signed-char -fobjc-runtime=gcc -fdiagnostics-show-option -fcolor-diagnostics -o - -x c udp-client.c
    clang -cc1 version 3.9.1 based upon LLVM 3.9.1 default target armv7l-unknown-linux-gnueabihf
    ignoring nonexistent directory "/include"
    #include "..." search starts here:
    #include <...> search starts here:
     /usr/local/include
     /usr/include
    End of search list.
    clang version 3.9.1-19ubuntu1 (tags/RELEASE_391/rc2)
    Thread model: posix
     "/usr/lib/llvm-3.9/bin/clang" -cc1 -triple armv7-unknown-linux-gnueabihf -emit-obj -mrelax-all -disable-free -disable-llvm-verifier -discard-value-names -main-file-name distccd_ba396596.i -mrelocation-model static -mthread-model posix -mdisable-fp-elim -fmath-errno -masm-verbose -mconstructor-aliases -target-cpu cortex-a8 -target-abi aapcs-linux -mfloat-abi hard -v -dwarf-column-info -debugger-tuning=gdb -coverage-file /tmp/distccd_ba666596.o -resource-dir /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1 -fdebug-compilation-dir /tmp -ferror-limit 19 -fmessage-length 0 -fallow-half-arguments-and-returns -fno-signed-char -fobjc-runtime=gcc -fdiagnostics-show-option -o /tmp/distccd_ba666596.o -x cpp-output /tmp/distccd_ba396596.i
    clang -cc1 version 3.9.1 based upon LLVM 3.9.1 default target x86_64-pc-linux-gnu
    End of search list.
    reference build works with specifying architecture:
    root@bela:~/Bela/resources/network# distcc-clang -c -v ~/Bela/resources/network/udp-client.c -march=armv7-a
    Thread model: posix
     "/usr/lib/llvm-3.9/bin/clang" -cc1 -triple armv7-unknown-linux-gnueabihf -E -disable-free -disable-llvm-verifier -discard-value-names -main-file-name udp-client.c -mrelocation-model static -mthread-model posix -mdisable-fp-elim -fmath-errno -masm-verbose -mconstructor-aliases -fuse-init-array -target-cpu cortex-a8 -target-abi aapcs-linux -mfloat-abi hard -v -dwarf-column-info -debugger-tuning=gdb -resource-dir /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1 -internal-isystem /usr/local/include -internal-isystem /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1/include -internal-externc-isystem /usr/include/arm-linux-gnueabihf -internal-externc-isystem /include -internal-externc-isystem /usr/include -fdebug-compilation-dir /root/Bela/resources/network -ferror-limit 19 -fmessage-length 80 -fallow-half-arguments-and-returns -fno-signed-char -fobjc-runtime=gcc -fdiagnostics-show-option -fcolor-diagnostics -o - -x c /root/Bela/resources/network/udp-client.c
     /usr/local/include
     /usr/include
    End of search list.
    Thread model: posix
     "/usr/lib/llvm-3.9/bin/clang" -cc1 -triple armv7-unknown-linux-gnueabihf -emit-obj -mrelax-all -disable-free -disable-llvm-verifier -discard-value-names -main-file-name distccd_ff4c663b.i -mrelocation-model static -mthread-model posix -mdisable-fp-elim -fmath-errno -masm-verbose -mconstructor-aliases -target-cpu cortex-a8 -target-abi aapcs-linux -mfloat-abi hard -v -dwarf-column-info -debugger-tuning=gdb -coverage-file /tmp/distccd_fcec663b.o -resource-dir /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1 -fdebug-compilation-dir /tmp -ferror-limit 19 -fmessage-length 0 -fallow-half-arguments-and-returns -fno-signed-char -fobjc-runtime=gcc -fdiagnostics-show-option -o /tmp/distccd_fcec663b.o -x cpp-output /tmp/distccd_ff4c663b.i
    End of search list.
    Here's the distcclog from the Ubuntu machine:
    distccd[14752] (dcc_check_client) connection from 192.168.7.2:59770
    distccd[14752] (check_address_inet) match client 0x207a8c0, value 0x207a8c0, mask 0xffffffff
    distccd[14752] (dcc_r_token_int) got DIST00000001
    distccd[14752] (dcc_r_token_int) got ARGC00000006
    distccd[14752] (dcc_r_argv) reading 6 arguments from job submission
    distccd[14752] (dcc_r_token_int) got ARGV0000000d
    distccd[14752] (dcc_r_token_string) got 'clang-3.9-arm'
    distccd[14752] (dcc_r_argv) argv[0] = "clang-3.9-arm"
    distccd[14752] (dcc_r_token_int) got ARGV00000002
    distccd[14752] (dcc_r_token_string) got '-v'
    distccd[14752] (dcc_r_argv) argv[1] = "-v"
    distccd[14752] (dcc_r_token_string) got '-c'
    distccd[14752] (dcc_r_argv) argv[2] = "-c"
    distccd[14752] (dcc_r_token_int) got ARGV0000000c
    distccd[14752] (dcc_r_token_string) got 'udp-client.c'
    distccd[14752] (dcc_r_argv) argv[3] = "udp-client.c"
    distccd[14752] (dcc_r_token_string) got '-o'
    distccd[14752] (dcc_r_argv) argv[4] = "-o"
    distccd[14752] (dcc_r_token_string) got 'udp-client.o'
    distccd[14752] (dcc_r_argv) argv[5] = "udp-client.o"
    distccd[14752] (dcc_r_argv) got arguments: clang-3.9-arm -v -c udp-client.c -o udp-client.o
    distccd[14752] (dcc_scan_args) scanning arguments: clang-3.9-arm -v -c udp-client.c -o udp-client.o
    distccd[14752] (dcc_scan_args) found input file "udp-client.c"
    distccd[14752] (dcc_scan_args) found object/output file "udp-client.o"
    distccd[14752] compile from udp-client.c to udp-client.o
    distccd[14752] (dcc_run_job) output file udp-client.o
    distccd[14752] (dcc_input_tmpnam) input file udp-client.c
    distccd[14752] (dcc_r_token_int) got DOTI00016dac
    distccd[14752] (dcc_r_file) received 93612 bytes to file /tmp/distccd_ba396596.i
    distccd[14752] (dcc_r_file_timed) 93612 bytes received in 0.011009s, rate 8304kB/s
    distccd[14752] (dcc_set_input) changed input from "udp-client.c" to "/tmp/distccd_ba396596.i"
    distccd[14752] (dcc_set_input) command after: clang-3.9-arm -v -c /tmp/distccd_ba396596.i -o udp-client.o
    distccd[14752] (dcc_set_output) changed output from "udp-client.o" to "/tmp/distccd_ba666596.o"
    distccd[14752] (dcc_set_output) command after: clang-3.9-arm -v -c /tmp/distccd_ba396596.i -o /tmp/distccd_ba666596.o
    distccd[14752] (dcc_check_compiler_masq) /usr/local/bin/clang-3.9-arm is not a symlink
    distccd[14752] (dcc_spawn_child) forking to execute: clang-3.9-arm -v -c /tmp/distccd_ba396596.i -o /tmp/distccd_ba666596.o
    distccd[14752] (dcc_spawn_child) child started as pid32524
    distccd[32524] (dcc_new_pgrp) entered process group
    distccd[32524] (dcc_increment_safeguard) setting safeguard: _DISTCC_SAFEGUARD=1
    distccd[14752] (dcc_collect_child) cc child 32524 terminated with status 0
    distccd[14752] (dcc_collect_child) cc times: user 0.000000s, system 0.000000s, 0 minflt, 0 majflt
    distccd[14752] (dcc_x_token_int) send DONE00000001
    distccd[14752] (dcc_x_token_int) send STAT00000000
    distccd[14752] (dcc_x_file) send 1002 byte file /tmp/distcc_b8066596.stderr with token SERR and compression 69
    distccd[14752] (dcc_x_token_int) send SERR000003ea
    distccd[14752] (dcc_x_file) send 0 byte file /tmp/distcc_b8246596.stdout with token SOUT and compression 69
    distccd[14752] (dcc_x_token_int) send SOUT00000000
    distccd[14752] (dcc_x_file) send 2192 byte file /tmp/distccd_ba666596.o with token DOTO and compression 69
    distccd[14752] (dcc_x_token_int) send DOTO00000890
    distccd[14752] clang-3.9-arm udp-client.c on localhost completed ok
    distccd[14752] job complete
    distccd[14752] (dcc_cleanup_tempfiles_inner) deleted 5 temporary files
    distccd[14752] (dcc_job_summary) client: 192.168.7.2:59770 COMPILE_OK exit:0 sig:0 core:0 ret:0 time:318ms clang-3.9-arm udp-client.c
    distccd[14753] (dcc_check_client) connection from 192.168.7.2:59772
    distccd[14753] (check_address_inet) match client 0x207a8c0, value 0x207a8c0, mask 0xffffffff
    distccd[14753] (dcc_r_token_int) got DIST00000001
    distccd[14753] (dcc_r_token_int) got ARGC00000006
    distccd[14753] (dcc_r_argv) reading 6 arguments from job submission
    distccd[14753] (dcc_r_token_int) got ARGV0000000d
    distccd[14753] (dcc_r_token_string) got 'clang-3.9-arm'
    distccd[14753] (dcc_r_argv) argv[0] = "clang-3.9-arm"
    distccd[14753] (dcc_r_token_int) got ARGV00000002
    distccd[14753] (dcc_r_token_string) got '-c'
    distccd[14753] (dcc_r_argv) argv[1] = "-c"
    distccd[14753] (dcc_r_token_int) got ARGV00000029
    distccd[14753] (dcc_r_token_string) got '/root/Bela/resources/network/udp-client.c'
    distccd[14753] (dcc_r_argv) argv[2] = "/root/Bela/resources/network/udp-client.c"
    distccd[14753] (dcc_r_token_int) got ARGV0000000e
    distccd[14753] (dcc_r_token_string) got '-march=armv7-a'
    distccd[14753] (dcc_r_argv) argv[3] = "-march=armv7-a"
    distccd[14753] (dcc_r_token_string) got '-o'
    distccd[14753] (dcc_r_argv) argv[4] = "-o"
    distccd[14753] (dcc_r_token_int) got ARGV0000000c
    distccd[14753] (dcc_r_token_string) got 'udp-client.o'
    distccd[14753] (dcc_r_argv) argv[5] = "udp-client.o"
    distccd[14753] (dcc_r_argv) got arguments: clang-3.9-arm -c /root/Bela/resources/network/udp-client.c -march=armv7-a -o udp-client.o
    distccd[14753] (dcc_scan_args) scanning arguments: clang-3.9-arm -c /root/Bela/resources/network/udp-client.c -march=armv7-a -o udp-client.o
    distccd[14753] (dcc_scan_args) found input file "/root/Bela/resources/network/udp-client.c"
    distccd[14753] (dcc_scan_args) found object/output file "udp-client.o"
    distccd[14753] compile from udp-client.c to udp-client.o
    distccd[14753] (dcc_run_job) output file udp-client.o
    distccd[14753] (dcc_input_tmpnam) input file /root/Bela/resources/network/udp-client.c
    distccd[14753] (dcc_r_token_int) got DOTI00016eeb
    distccd[14753] (dcc_r_file) received 93931 bytes to file /tmp/distccd_20816628.i
    distccd[14753] (dcc_r_file_timed) 93931 bytes received in 0.012232s, rate 7499kB/s
    distccd[14753] (dcc_set_input) changed input from "/root/Bela/resources/network/udp-client.c" to "/tmp/distccd_20816628.i"
    distccd[14753] (dcc_set_input) command after: clang-3.9-arm -c /tmp/distccd_20816628.i -march=armv7-a -o udp-client.o
    distccd[14753] (dcc_set_output) changed output from "udp-client.o" to "/tmp/distccd_20dc6628.o"
    distccd[14753] (dcc_set_output) command after: clang-3.9-arm -c /tmp/distccd_20816628.i -march=armv7-a -o /tmp/distccd_20dc6628.o
    distccd[14753] (dcc_check_compiler_masq) /usr/local/bin/clang-3.9-arm is not a symlink
    distccd[14753] (dcc_spawn_child) forking to execute: clang-3.9-arm -c /tmp/distccd_20816628.i -march=armv7-a -o /tmp/distccd_20dc6628.o
    distccd[14753] (dcc_spawn_child) child started as pid32547
    distccd[32547] (dcc_new_pgrp) entered process group
    distccd[32547] (dcc_increment_safeguard) setting safeguard: _DISTCC_SAFEGUARD=1
    distccd[14753] (dcc_collect_child) cc child 32547 terminated with status 0
    distccd[14753] (dcc_collect_child) cc times: user 0.000000s, system 0.000000s, 0 minflt, 0 majflt
    distccd[14753] (dcc_x_token_int) send DONE00000001
    distccd[14753] (dcc_x_token_int) send STAT00000000
    distccd[14753] (dcc_x_file) send 0 byte file /tmp/distcc_27c16628.stderr with token SERR and compression 69
    distccd[14753] (dcc_x_token_int) send SERR00000000
    distccd[14753] (dcc_x_file) send 0 byte file /tmp/distcc_27996628.stdout with token SOUT and compression 69
    distccd[14753] (dcc_x_token_int) send SOUT00000000
    distccd[14753] (dcc_x_file) send 2192 byte file /tmp/distccd_20dc6628.o with token DOTO and compression 69
    distccd[14753] (dcc_x_token_int) send DOTO00000890
    distccd[14753] clang-3.9-arm /root/Bela/resources/network/udp-client.c on localhost completed ok
    distccd[14753] job complete
    distccd[14753] (dcc_cleanup_tempfiles_inner) deleted 5 temporary files
    distccd[14753] (dcc_job_summary) client: 192.168.7.2:59772 COMPILE_OK exit:0 sig:0 core:0 ret:0 time:286ms clang-3.9-arm /root/Bela/resources/network/udp-client.c
    distccd[14754] (dcc_check_client) connection from 192.168.7.2:59774
    distccd[14754] (check_address_inet) match client 0x207a8c0, value 0x207a8c0, mask 0xffffffff
    distccd[14754] (dcc_r_token_int) got DIST00000001
    distccd[14754] (dcc_r_token_int) got ARGC00000007
    distccd[14754] (dcc_r_argv) reading 7 arguments from job submission
    distccd[14754] (dcc_r_token_int) got ARGV0000000d
    distccd[14754] (dcc_r_token_string) got 'clang-3.9-arm'
    distccd[14754] (dcc_r_argv) argv[0] = "clang-3.9-arm"
    distccd[14754] (dcc_r_token_int) got ARGV00000002
    distccd[14754] (dcc_r_token_string) got '-c'
    distccd[14754] (dcc_r_argv) argv[1] = "-c"
    distccd[14754] (dcc_r_token_string) got '-v'
    distccd[14754] (dcc_r_argv) argv[2] = "-v"
    distccd[14754] (dcc_r_token_int) got ARGV00000029
    distccd[14754] (dcc_r_token_string) got '/root/Bela/resources/network/udp-client.c'
    distccd[14754] (dcc_r_argv) argv[3] = "/root/Bela/resources/network/udp-client.c"
    distccd[14754] (dcc_r_token_int) got ARGV0000000e
    distccd[14754] (dcc_r_token_string) got '-march=armv7-a'
    distccd[14754] (dcc_r_argv) argv[4] = "-march=armv7-a"
    distccd[14754] (dcc_r_token_string) got '-o'
    distccd[14754] (dcc_r_argv) argv[5] = "-o"
    distccd[14754] (dcc_r_token_int) got ARGV0000000c
    distccd[14754] (dcc_r_token_string) got 'udp-client.o'
    distccd[14754] (dcc_r_argv) argv[6] = "udp-client.o"
    distccd[14754] (dcc_r_argv) got arguments: clang-3.9-arm -c -v /root/Bela/resources/network/udp-client.c -march=armv7-a -o udp-client.o
    distccd[14754] (dcc_scan_args) scanning arguments: clang-3.9-arm -c -v /root/Bela/resources/network/udp-client.c -march=armv7-a -o udp-client.o
    distccd[14754] (dcc_scan_args) found input file "/root/Bela/resources/network/udp-client.c"
    distccd[14754] (dcc_scan_args) found object/output file "udp-client.o"
    distccd[14754] compile from udp-client.c to udp-client.o
    distccd[14754] (dcc_run_job) output file udp-client.o
    distccd[14754] (dcc_input_tmpnam) input file /root/Bela/resources/network/udp-client.c
    distccd[14754] (dcc_r_token_int) got DOTI00016eeb
    distccd[14754] (dcc_r_file) received 93931 bytes to file /tmp/distccd_ff4c663b.i
    distccd[14754] (dcc_r_file_timed) 93931 bytes received in 0.011458s, rate 8006kB/s
    distccd[14754] (dcc_set_input) changed input from "/root/Bela/resources/network/udp-client.c" to "/tmp/distccd_ff4c663b.i"
    distccd[14754] (dcc_set_input) command after: clang-3.9-arm -c -v /tmp/distccd_ff4c663b.i -march=armv7-a -o udp-client.o
    distccd[14754] (dcc_set_output) changed output from "udp-client.o" to "/tmp/distccd_fcec663b.o"
    distccd[14754] (dcc_set_output) command after: clang-3.9-arm -c -v /tmp/distccd_ff4c663b.i -march=armv7-a -o /tmp/distccd_fcec663b.o
    distccd[14754] (dcc_check_compiler_masq) /usr/local/bin/clang-3.9-arm is not a symlink
    distccd[14754] (dcc_spawn_child) forking to execute: clang-3.9-arm -c -v /tmp/distccd_ff4c663b.i -march=armv7-a -o /tmp/distccd_fcec663b.o
    distccd[14754] (dcc_spawn_child) child started as pid32551
    distccd[32551] (dcc_new_pgrp) entered process group
    distccd[32551] (dcc_increment_safeguard) setting safeguard: _DISTCC_SAFEGUARD=1
    distccd[14754] (dcc_collect_child) cc child 32551 terminated with status 0
    distccd[14754] (dcc_collect_child) cc times: user 0.000000s, system 0.000000s, 0 minflt, 0 majflt
    distccd[14754] (dcc_x_token_int) send DONE00000001
    distccd[14754] (dcc_x_token_int) send STAT00000000
    distccd[14754] (dcc_x_file) send 1002 byte file /tmp/distcc_f203663b.stderr with token SERR and compression 69
    distccd[14754] (dcc_x_token_int) send SERR000003ea
    distccd[14754] (dcc_x_file) send 0 byte file /tmp/distcc_f22c663b.stdout with token SOUT and compression 69
    distccd[14754] (dcc_x_token_int) send SOUT00000000
    distccd[14754] (dcc_x_file) send 2192 byte file /tmp/distccd_fcec663b.o with token DOTO and compression 69
    distccd[14754] (dcc_x_token_int) send DOTO00000890
    distccd[14754] clang-3.9-arm /root/Bela/resources/network/udp-client.c on localhost completed ok
    distccd[14754] job complete
    distccd[14754] (dcc_cleanup_tempfiles_inner) deleted 5 temporary files
    distccd[14754] (dcc_job_summary) client: 192.168.7.2:59774 COMPILE_OK exit:0 sig:0 core:0 ret:0 time:320ms clang-3.9-arm /root/Bela/resources/network/udp-client.c
    Now trying "faust2bela" from the Ubuntu machine. /usr/Bela/Makefile still references distcc.
    gary@audio-workstation:~/faust/examples/bela$ faust2bela -tobela -gui FXChaine2.dsp
    Send to bela
    /home/gary/faust/examples/bela/FXChaine2
    Start communication with bela
    FXChaine2
    Stop running process...
    Run bela now
    uploadBuildRun START
    Copying new source files to BeagleBone...Using rsync...
    PID=`grep bela-audio  /proc/xenomai/sched/stat | cut -d " " -f 5 | sed s/\s//g`; if [ -z $PID ]; then [ true = true ] || echo "No process to kill"; else [  true = true  ] || echo "Killing old Bela process $PID"; kill -2 $PID; sleep 0.2; kill -9 $PID 2> /dev/null; fi; screen -X -S Bela quit > /dev/null; exit 0;
    echo 'Building render.cpp...'
    distcc-clang++  -I/root/Bela/projects/FXChaine2 -I./include -I./build/pru/ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBALT__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEBUG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -std=c++11 -Wno-varargs -DNDEBUG  -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/projects/FXChaine2/build/render.d" -o "/root/Bela/projects/FXChaine2/build/render.o" "/root/Bela/projects/FXChaine2/render.cpp"
    distcc[5035] ERROR: compile /root/Bela/projects/FXChaine2/render.cpp on 192.168.7.1 failed
    distcc[5035] (dcc_build_somewhere) Warning: remote compilation of '/root/Bela/projects/FXChaine2/render.cpp' failed, retrying locally
    distcc[5035] (dcc_build_somewhere) Warning: failed to distribute and fallbacks are disabled
    /usr/bin/ld: unrecognised emulation mode: armelf_linux_eabi
    Supported emulations: elf_x86_64 elf32_x86_64 elf_i386 elf_iamcu i386linux elf_l1om elf_k1om i386pep i386pe
    Makefile:434: recipe for target '/root/Bela/projects/FXChaine2/build/render.o' failed
    make: *** [/root/Bela/projects/FXChaine2/build/render.o] Error 1
    This still seems to be the failure:
    This link takes us to some hints on that error message, which seem to culminate in "install the toolchain". The question is in the context of Android NDK though so I don't know if it applies here.
    https://stackoverflow.com/questions/52646860/ld-unrecognised-emulation-mode-armelf-linux-eabi-when-cross-compiling-with-a
    Here's the distcc log from this step:
    distccd[14755] (dcc_check_client) connection from 192.168.7.2:59776
    distccd[14755] (check_address_inet) match client 0x207a8c0, value 0x207a8c0, mask 0xffffffff
    distccd[14755] (dcc_r_token_int) got DIST00000001
    distccd[14755] (dcc_r_token_int) got ARGC00000013
    distccd[14755] (dcc_r_argv) reading 19 arguments from job submission
    distccd[14755] (dcc_r_token_int) got ARGV0000000f
    distccd[14755] (dcc_r_token_string) got 'clang++-3.9-arm'
    distccd[14755] (dcc_r_argv) argv[0] = "clang++-3.9-arm"
    distccd[14755] (dcc_r_token_int) got ARGV0000000e
    distccd[14755] (dcc_r_token_string) got '-march=armv7-a'
    distccd[14755] (dcc_r_argv) argv[1] = "-march=armv7-a"
    distccd[14755] (dcc_r_token_int) got ARGV0000000a
    distccd[14755] (dcc_r_token_string) got '-mfpu=vfp3'
    distccd[14755] (dcc_r_argv) argv[2] = "-mfpu=vfp3"
    distccd[14755] (dcc_r_token_int) got ARGV0000001c
    distccd[14755] (dcc_r_token_string) got '-fasynchronous-unwind-tables'
    distccd[14755] (dcc_r_argv) argv[3] = "-fasynchronous-unwind-tables"
    distccd[14755] (dcc_r_token_int) got ARGV00000003
    distccd[14755] (dcc_r_token_string) got '-O3'
    distccd[14755] (dcc_r_argv) argv[4] = "-O3"
    distccd[14755] (dcc_r_argv) argv[5] = "-march=armv7-a"
    distccd[14755] (dcc_r_token_int) got ARGV00000010
    distccd[14755] (dcc_r_token_string) got '-mtune=cortex-a8'
    distccd[14755] (dcc_r_argv) argv[6] = "-mtune=cortex-a8"
    distccd[14755] (dcc_r_token_string) got '-mfloat-abi=hard'
    distccd[14755] (dcc_r_argv) argv[7] = "-mfloat-abi=hard"
    distccd[14755] (dcc_r_token_string) got '-mfpu=neon'
    distccd[14755] (dcc_r_argv) argv[8] = "-mfpu=neon"
    distccd[14755] (dcc_r_token_string) got '-ftree-vectorize'
    distccd[14755] (dcc_r_argv) argv[9] = "-ftree-vectorize"
    distccd[14755] (dcc_r_token_int) got ARGV0000000b
    distccd[14755] (dcc_r_token_string) got '-ffast-math'
    distccd[14755] (dcc_r_argv) argv[10] = "-ffast-math"
    distccd[14755] (dcc_r_token_string) got '-std=c++11'
    distccd[14755] (dcc_r_argv) argv[11] = "-std=c++11"
    distccd[14755] (dcc_r_token_int) got ARGV0000000c
    distccd[14755] (dcc_r_token_string) got '-Wno-varargs'
    distccd[14755] (dcc_r_argv) argv[12] = "-Wno-varargs"
    distccd[14755] (dcc_r_token_int) got ARGV00000005
    distccd[14755] (dcc_r_token_string) got '-Wall'
    distccd[14755] (dcc_r_argv) argv[13] = "-Wall"
    distccd[14755] (dcc_r_token_int) got ARGV00000002
    distccd[14755] (dcc_r_token_string) got '-c'
    distccd[14755] (dcc_r_argv) argv[14] = "-c"
    distccd[14755] (dcc_r_token_int) got ARGV00000012
    distccd[14755] (dcc_r_token_string) got '-fmessage-length=0'
    distccd[14755] (dcc_r_argv) argv[15] = "-fmessage-length=0"
    distccd[14755] (dcc_r_token_string) got '-o'
    distccd[14755] (dcc_r_argv) argv[16] = "-o"
    distccd[14755] (dcc_r_token_int) got ARGV0000002c
    distccd[14755] (dcc_r_token_string) got '/root/Bela/projects/FXChaine2/build/render.o'
    distccd[14755] (dcc_r_argv) argv[17] = "/root/Bela/projects/FXChaine2/build/render.o"
    distccd[14755] (dcc_r_token_int) got ARGV00000028
    distccd[14755] (dcc_r_token_string) got '/root/Bela/projects/FXChaine2/render.cpp'
    distccd[14755] (dcc_r_argv) argv[18] = "/root/Bela/projects/FXChaine2/render.cpp"
    distccd[14755] (dcc_r_argv) got arguments: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /root/Bela/projects/FXChaine2/build/render.o /root/Bela/projects/FXChaine2/render.cpp
    distccd[14755] (dcc_scan_args) scanning arguments: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /root/Bela/projects/FXChaine2/build/render.o /root/Bela/projects/FXChaine2/render.cpp
    distccd[14755] (dcc_scan_args) found object/output file "/root/Bela/projects/FXChaine2/build/render.o"
    distccd[14755] (dcc_scan_args) found input file "/root/Bela/projects/FXChaine2/render.cpp"
    distccd[14755] compile from render.cpp to render.o
    distccd[14755] (dcc_run_job) output file /root/Bela/projects/FXChaine2/build/render.o
    distccd[14755] (dcc_input_tmpnam) input file /root/Bela/projects/FXChaine2/render.cpp
    distccd[14755] (dcc_r_token_int) got DOTI0019610a
    distccd[14755] (dcc_r_file) received 1663242 bytes to file /tmp/distccd_261c6794.ii
    distccd[14755] (dcc_r_file_timed) 1663242 bytes received in 0.150477s, rate 10794kB/s
    distccd[14755] (dcc_set_input) changed input from "/root/Bela/projects/FXChaine2/render.cpp" to "/tmp/distccd_261c6794.ii"
    distccd[14755] (dcc_set_input) command after: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /root/Bela/projects/FXChaine2/build/render.o /tmp/distccd_261c6794.ii
    distccd[14755] (dcc_set_output) changed output from "/root/Bela/projects/FXChaine2/build/render.o" to "/tmp/distccd_27a96794.o"
    distccd[14755] (dcc_set_output) command after: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /tmp/distccd_27a96794.o /tmp/distccd_261c6794.ii
    distccd[14755] (dcc_check_compiler_masq) /usr/local/bin/clang++-3.9-arm is not a symlink
    distccd[14755] (dcc_spawn_child) forking to execute: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /tmp/distccd_27a96794.o /tmp/distccd_261c6794.ii
    distccd[14755] (dcc_spawn_child) child started as pid32659
    distccd[32659] (dcc_new_pgrp) entered process group
    distccd[32659] (dcc_increment_safeguard) setting safeguard: _DISTCC_SAFEGUARD=1
    distccd[14755] (dcc_collect_child) cc child 32659 terminated with status 0x100
    distccd[14755] (dcc_collect_child) cc times: user 0.000000s, system 0.000000s, 0 minflt, 0 majflt
    distccd[14755] (dcc_x_token_int) send DONE00000001
    distccd[14755] (dcc_x_token_int) send STAT00000100
    distccd[14755] (dcc_x_file) send 248 byte file /tmp/distcc_58bf6794.stderr with token SERR and compression 69
    distccd[14755] (dcc_x_token_int) send SERR000000f8
    distccd[14755] (dcc_x_file) send 0 byte file /tmp/distcc_5b7e6794.stdout with token SOUT and compression 69
    distccd[14755] (dcc_x_token_int) send SOUT00000000
    distccd[14755] (dcc_x_token_int) send DOTO00000000
    distccd[14755] clang++-3.9-arm /root/Bela/projects/FXChaine2/render.cpp on localhost failed
    distccd[14755] job complete
    distccd[14755] (dcc_cleanup_tempfiles_inner) deleted 5 temporary files
    distccd[14755] (dcc_job_summary) client: 192.168.7.2:59776 COMPILE_ERROR exit:1 sig:0 core:0 ret:0 time:1109ms clang++-3.9-arm /root/Bela/projects/FXChaine2/render.cpp
      This is very confusing to me. The error message you get seems to be about the linker, ld, and it seems to come from the host, because of the list of supported emulations. The weird thing about this is that distcc should never attempt to run the linker on the host (only the compiler), and also that the line that fails really has nothing to do with the linker.
      So this is the line that is run on the host and fails:
      Digital-Larry distccd[14755] (dcc_spawn_child) forking to execute: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /tmp/distccd_27a96794.o /tmp/distccd_261c6794.ii
      As you see, it tries to compile the pre-processed file /tmp/distccd_261c6794.ii into the object file /tmp/distccd_27a96794.o. The pre-processed file is generated by distcc on the client (Bela), where it runs cpp (the C-preprocessor) on the file to bring in all the includes and apply all the defines and resolve the macros, generating a stand-alone C++ file that has no dependency on any external files.
      Let's troubleshoot this with incremental steps. Create a simple C++ file with no includes on the host:
      • Create a simple C++ file with no includes on the HOST: create a file called test.ii:
        int func()
            return 0;
        and then run the same command as above (except for the file paths at the end) :
        clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o ./test.o ./test.ii
        if this is successful, make sure the generated file test.o is indeed an ARM binary:
        $ file test.o
        test.o: ELF 32-bit LSB relocatable, ARM, version 1 (SYSV), not stripped
      • if the above worked fine, then copy the test.ii file to the board and run ON THE BOARD:
        distcc-clang++ -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o ./test.o ./test.ii
        and if this is successful, check that the generated file is indeed an ARM binary:
        $ file test.o
      • if this is still good, then rename test.ii to test.cpp and run the same line again, this time with test.cpp at the end:
        distcc-clang++ -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o ./test.o ./test.cpp
      • if this is still good, still on the board, do cd /root/Bela/ and there try to re-run the full line that was failing while building your project:
        does this successfully generated the file /root/Bela/projects/FXChaine2/build/render.o? And is it an ARM binary?
        giuliomoro first step fails.
        gary@audio-workstation:~/test$ clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o ./test.o ./test.ii
        gary@audio-workstation:~/test$ cat test.ii
        int func()
            return 0;
        gary@audio-workstation:~/test$ which clang++-3.9-arm
        gary@audio-workstation:~/test$ cat /usr/local/bin/clang++-3.9-arm
        #!/bin/bash
        /usr/bin/clang++-3.9 -target armv7l-unknown-linux-gnueabihf --sysroot ~/arm $0
        Calling that compiler throws the error with no parameters given at all! [edit - it's calling the script which does add parameters] So maybe that is broken somehow. I used apt to install it.
        gary@audio-workstation:~/test$ sudo apt list | grep ^clang-3.9
        WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
        clang-3.9/bionic,now 1:3.9.1-19ubuntu1 amd64 [installed]
        clang-3.9-doc/bionic,bionic 1:3.9.1-19ubuntu1 all
        clang-3.9-examples/bionic 1:3.9.1-19ubuntu1 amd64
        gary@audio-workstation:~/test$ sudo dpkg -s clang-3.9
        Package: clang-3.9
        Status: install ok installed
        Priority: optional
        Section: devel
        Installed-Size: 140661
        Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
        Architecture: amd64
        Source: llvm-toolchain-3.9
        Version: 1:3.9.1-19ubuntu1
        Replaces: clang-3.1, clang-3.2, clang-3.3, clang-3.4 (<< 1:3.4.2-7~exp1), clang-3.5 (<< 1:3.5~+rc1-3~exp1), clang-include-fixer-3.9, compiler-rt
        Provides: c++-compiler, c-compiler, objc-compiler
        Depends: libc6 (>= 2.14), libclang1-3.9 (= 1:3.9.1-19ubuntu1), libgcc1 (>= 1:3.4), libjsoncpp1 (>= 1.7.4), libllvm3.9 (>= 1:3.9.1-6~), libstdc++6 (>= 5.2), libstdc++-7-dev, libgcc-7-dev, libobjc-7-dev, libclang-common-3.9-dev (= 1:3.9.1-19ubuntu1), libc6-dev, binutils
        Recommends: llvm-3.9-dev, python
        Suggests: gnustep, gnustep-devel, clang-3.9-doc
        Breaks: clang-3.1, clang-3.2, clang-3.3, clang-3.4 (<< 1:3.4.2-7~exp1), clang-3.5 (<< 1:3.5~+rc1-3~exp1), clang-include-fixer-3.9, compiler-rt
        Description: C, C++ and Objective-C compiler (LLVM based)
         Clang project is a C, C++, Objective C and Objective C++ front-end
         for the LLVM compiler. Its goal is to offer a replacement to the GNU Compiler
         Collection (GCC).
         Clang fully implements all published ISO C++ standards including C++11, as
         well as the upcoming C++14 standard, and some parts of the fledgling C++1z
         standard, and is considered a production-quality C++ compiler.
        Original-Maintainer: LLVM Packaging Team <pkg-llvm-team@lists.alioth.debian.org>
        Homepage: http://www.llvm.org/
        Some other random tests to see what exactly we are calling and the simplest command to generate the error.
        #!/bin/bash
        gary@audio-workstation:~/test$ /usr/bin/clang++-3.9
        clang: error: no input files
        gary@audio-workstation:~/test$ /usr/bin/clang++-3.9 -target armv7l-unknown-linux-gnueabihf
        gary@audio-workstation:~/test$ /usr/bin/clang++-3.9 -target armv7l-unknown-linux-gnueabihf ./test.ii
        gary@audio-workstation:~/test$ /usr/bin/clang++-6.0 -target armv7l-unknown-linux-gnueabihf ./test.ii
        gary@audio-workstation:~/test$ /usr/bin/clang++ -target armv7l-unknown-linux-gnueabihf ./test.ii
          right, what about ls -l /usr/bin/clang++-3.9 ? is it a symlink to something?
          Further to this, you could try running
          and remove one option at a time until it succeeds (or better: start with just clang++-3.9-arm -march=armv7-a ./test.o ./test.ii, is it successful? Then add more and more options until it fails .
          I am wondering whether maybe your clang-3.9 does not support hard-float, in which case the failing option should be -mfloat-abi=hard. Can you dpkg -l | grep clang and perhaps then dpkg --info <names of the 3.9 packages from the previous result>?
            I used the -### command with just clang++ (the 6.0 version installed by default, but the error is the same so far regardless of the compiler version used, 3.9 or 6.0):
            gary@audio-workstation:~/test$ /usr/bin/clang++ -### -target armv7l-unknown-linux-gnueabihf ./test.ii
            clang version 6.0.0-1ubuntu2 (tags/RELEASE_600/final)
            Thread model: posix
             "/usr/lib/llvm-6.0/bin/clang" "-cc1" "-triple" "armv7-unknown-linux-gnueabihf" "-emit-obj" "-mrelax-all" "-disable-free" "-disable-llvm-verifier" "-discard-value-names" "-main-file-name" "test.ii" "-mrelocation-model" "static" "-mthread-model" "posix" "-mdisable-fp-elim" "-fmath-errno" "-masm-verbose" "-mconstructor-aliases" "-fuse-init-array" "-target-cpu" "generic" "-target-abi" "aapcs-linux" "-mfloat-abi" "hard" "-fallow-half-arguments-and-returns" "-dwarf-column-info" "-debugger-tuning=gdb" "-resource-dir" "/usr/lib/llvm-6.0/lib/clang/6.0.0" "-fdeprecated-macro" "-fdebug-compilation-dir" "/home/gary/test" "-ferror-limit" "19" "-fmessage-length" "80" "-fno-signed-char" "-fobjc-runtime=gcc" "-fcxx-exceptions" "-fexceptions" "-fdiagnostics-show-option" "-fcolor-diagnostics" "-o" "/tmp/test-dc97e4.o" "-x" "c++-cpp-output" "./test.ii"
             "/usr/bin/ld" "-z" "relro" "-X" "--hash-style=gnu" "--eh-frame-hdr" "-m" "armelf_linux_eabi" "-dynamic-linker" "/lib/ld-linux-armhf.so.3" "-o" "a.out" "crt1.o" "crti.o" "crtbegin.o" "-L/usr/lib/llvm-6.0/bin/../lib" "-L/lib/../lib" "-L/usr/lib/../lib" "-L/usr/lib/llvm-6.0/bin/../lib" "-L/lib" "-L/usr/lib" "/tmp/test-dc97e4.o" "-lstdc++" "-lm" "-lgcc_s" "-lgcc" "-lc" "-lgcc_s" "-lgcc" "crtend.o" "crtn.o"
            giuliomoro yes there is a symlink there that appears to be from the installation (I didn't do it).
            gary@audio-workstation:~/test$ ls -l /usr/bin/clang++-3.9
            lrwxrwxrwx 1 root root 27 Dec 26  2017 /usr/bin/clang++-3.9 -> ../lib/llvm-3.9/bin/clang++
            gary@audio-workstation:~/test$ clang++-3.9-arm -march=armv7-a ./test.o ./test.ii
            gary@audio-workstation:~/test$ dpkg -l | grep clang
            ii  clang                                      1:6.0-41~exp5~ubuntu1                        amd64        C, C++ and Objective-C compiler (LLVM based)
            ii  clang-3.9                                  1:3.9.1-19ubuntu1                            amd64        C, C++ and Objective-C compiler (LLVM based)
            ii  clang-6.0                                  1:6.0-1ubuntu2                               amd64        C, C++ and Objective-C compiler
            ii  libclang-common-3.9-dev                    1:3.9.1-19ubuntu1                            amd64        clang library - Common development package
            ii  libclang-common-6.0-dev                    1:6.0-1ubuntu2                               amd64        clang library - Common development package
            ii  libclang1-3.9:amd64                        1:3.9.1-19ubuntu1                            amd64        C interface to the clang library
            ii  libclang1-6.0:amd64                        1:6.0-1ubuntu2                               amd64        C interface to the clang library
            dpkg --info doesn't show anything but apt show does:
            gary@audio-workstation:~/test$ apt show clang-3.9
            Package: clang-3.9
            Priority: optional
            Section: universe/devel
            Origin: Ubuntu
            Bugs: https://bugs.launchpad.net/ubuntu/+filebug
            Installed-Size: 144 MB
            Download-Size: 37.4 MB
            APT-Manual-Installed: yes
            APT-Sources: http://us.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
             Collection (GCC).
            gary@audio-workstation:~/test$ apt show libclang-common-3.9-dev
            Package: libclang-common-3.9-dev
            Priority: optional
            Section: universe/libdevel
            Origin: Ubuntu
            Installed-Size: 39.1 MB
            Depends: libc6 (>= 2.15), libgcc1 (>= 1:3.4), libstdc++6 (>= 5.2), libtinfo5 (>= 6), libllvm3.9 (= 1:3.9.1-19ubuntu1)
            Download-Size: 2,575 kB
            APT-Manual-Installed: no
            Description: clang library - Common development package
             Collection (GCC).
             This package contains the clang generic headers and some libraries
             (profiling, etc).
            gary@audio-workstation:~/test$ apt show libclang1-3.9
            Package: libclang1-3.9
            Priority: optional
            Origin: Ubuntu
            Installed-Size: 22.9 MB
            Depends: libc6 (>= 2.14), libgcc1 (>= 1:3.4), libllvm3.9 (>= 1:3.9.1-6~), libstdc++6 (>= 5.2)
            Download-Size: 5,950 kB
            Description: C interface to the clang library
             Collection (GCC).
             This package contains the clang library.
             The C Interface to Clang provides a relatively small API that exposes
             facilities for parsing source code into an abstract syntax tree (AST),
             loading already-parsed ASTs, traversing the AST, associating physical source
             locations with elements within the AST, and other facilities that support
             Clang-based development tools.
            Digital-Larry gary@audio-workstation:~/test$ /usr/bin/clang++-3.9 -target armv7l-unknown-linux-gnueabihf ./test.ii
            you nee -c otherwise it will attempt to use the linker.
            I forgot -c, too, and also -o.
            so try:
            clang++-3.9-arm -march=armv7-a -c -o ./test.o ./test.ii
            if that succeeds, add one option at a time until it fails ..
              gary@audio-workstation:~/test$ clang++-3.9-arm -march=armv7-a -c -o ./test.o ./test.ii
              gary@audio-workstation:~/test$ /usr/bin/clang++-3.9 -###  -march=arm7-a -c -o ./test.o ./test.ii
              Target: x86_64-pc-linux-gnu
              Thread model: posix
               "/usr/lib/llvm-3.9/bin/clang" "-cc1" "-triple" "x86_64-pc-linux-gnu" "-emit-obj" "-mrelax-all" "-disable-free" "-disable-llvm-verifier" "-discard-value-names" "-main-file-name" "test.ii" "-mrelocation-model" "static" "-mthread-model" "posix" "-mdisable-fp-elim" "-fmath-errno" "-masm-verbose" "-mconstructor-aliases" "-munwind-tables" "-fuse-init-array" "-target-cpu" "arm7-a" "-dwarf-column-info" "-debugger-tuning=gdb" "-coverage-file" "/home/gary/test/./test.o" "-resource-dir" "/usr/lib/llvm-3.9/bin/../lib/clang/3.9.1" "-fdeprecated-macro" "-fdebug-compilation-dir" "/home/gary/test" "-ferror-limit" "19" "-fmessage-length" "80" "-fobjc-runtime=gcc" "-fcxx-exceptions" "-fexceptions" "-fdiagnostics-show-option" "-fcolor-diagnostics" "-o" "./test.o" "-x" "c++-cpp-output" "./test.ii"
              sorry, hang on, swimming in stuff here...
              gary@audio-workstation:~/test$ clang++-3.9-arm -### -march=armv7-a -c -o ./test.o ./test.ii
              I added the "-###" right in the clang++-3.9-arm script itself (I also tried adding "-fno-autolink"):
              gary@audio-workstation:~/test$ sh -x /usr/local/bin/clang++-3.9-arm -### -march=armv7-a -c -o ./test.o ./test.ii
              + /usr/bin/clang++-3.9 -### -target armv7l-unknown-linux-gnueabihf -fno-autolink --sysroot /home/gary/arm /usr/local/bin/clang++-3.9-arm
              Thread model: posix
               "/usr/bin/ld" "--sysroot=/home/gary/arm" "-X" "--eh-frame-hdr" "-m" "armelf_linux_eabi" "-dynamic-linker" "/lib/ld-linux-armhf.so.3" "-o" "a.out" "crt1.o" "crti.o" "crtbegin.o" "/usr/local/bin/clang++-3.9-arm" "-lstdc++" "-lm" "-lgcc_s" "-lgcc" "-lc" "-lgcc_s" "-lgcc" "crtend.o" "crtn.o"
              OK after that last one I found it! It wasn't until I ran the script with "sh -x" that I saw the wrong command line substitution. The last thing on the command line should be the source file name, but it is the script file name!
              In this file, I had "$0" instead of "$@" - I changed it and it works!!!!
              gary@audio-workstation:~/faust/examples/bela$ cat /usr/local/bin/clang++-3.9-arm
              #!/bin/bash
              /usr/bin/clang++-3.9 -target armv7l-unknown-linux-gnueabihf --sysroot ~/arm $@
              Giuilo thanks so much for your patient help. Sorry it was so difficult but maybe it helps the next guy. At this point I think Faust on Bela is a very viable idea. Hopefully my next questions and comments will be more on the implementation side.
