giuliomoro THANK YOU!!!!! The updated library files made a bunch of difference. However I had to copy them to /usr/lib as /usr/local/lib did not work. OMG I can see the GUI! I'm even using remote access software so I'm viewing the Bela attached to my Linux box downstairs on USB while I'm upstairs using Windows. Tonight I will try out some audio tests!
    Digital-Larry However I had to copy them to /usr/lib as /usr/local/lib did not work.
    hmmm not sure why that would be the case. Possibly it just needed running ldconfig ... Or possibly, the linker would find the file libHTTPDFaust.a you previously had in /usr/local/lib and looked no further? Not sure.
      not sure really. However I have an explanation as to why it worked with the shared library (.so) and not with the static (.a) one:
      a static library is simply an archive of object files, while a shared library - among other things - has been linked with all the libraries it depends upon. So when using the static library, in order for that to work, you need to explicitly pass to the linker the library(ies) that your your static library depends upon (in this case: -lmicrohttpd), so that the external symbols in the objects files that make up the .a file can be resolved. When using the shared library, instead, these symbols have been already resolved when it was linked together in a .so file, so there is no need to explicitly state it again.
      Still having trouble at this step.
      Using distcc by default on Bela
      Make the following edit to the Bela Makefile:
      By "the Bela Makefile" I presume that you mean the file /root/Bela/Makefile. Sorry, it wasn't obvious to me.
      I found the lines and made the change.
      echo 'Building render.cpp...'
      distcc-clang++  -I/root/Bela/projects/delay01 -I./include -I./build/pru/ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBALT__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEBUG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -std=c++11 -Wno-varargs -DNDEBUG  -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/projects/delay01/build/render.d" -o "/root/Bela/projects/delay01/build/render.o" "/root/Bela/projects/delay01/render.cpp"
      distcc[2855] ERROR: nonblocking connect to 192.168.7.1:3632 failed: Connection refused
      distcc[2855] (dcc_build_somewhere) Warning: failed to distribute and fallbacks are disabled
      Makefile:434: recipe for target '/root/Bela/projects/delay01/build/render.o' failed
      make: *** [/root/Bela/projects/delay01/build/render.o] Error 103
      gary@audio-workstation:~/faust/examples/bela$
        OK the distccd wasn't running. Now that I started that, I get:
        distccd[14751] (dcc_standalone_server) not detaching
        distccd[14751] (dcc_new_pgrp) already a process group leader
        distccd[14751] (dcc_log_daemon_started) preforking daemon started (3.3.2 x86_64-pc-linux-gnu, built May 26 2019 14:11:45)
        distccd[14751] (dcc_create_kids) up to 1 children
        distccd[14751] (dcc_create_kids) up to 2 children
        distccd[14751] (dcc_create_kids) up to 3 children
        distccd[14751] (dcc_create_kids) up to 4 children
        distccd[14751] (dcc_create_kids) up to 5 children
        distccd[14751] (dcc_create_kids) up to 6 children
        distccd[14752] (dcc_check_client) connection from 192.168.7.2:59746
        distccd[14752] (check_address_inet) match client 0x207a8c0, value 0x207a8c0, mask 0xffffffff
        distccd[14752] (dcc_r_token_int) got DIST00000001
        distccd[14752] (dcc_r_token_int) got ARGC00000013
        distccd[14752] (dcc_r_argv) reading 19 arguments from job submission
        distccd[14752] (dcc_r_token_int) got ARGV0000000f
        distccd[14752] (dcc_r_token_string) got 'clang++-3.9-arm'
        distccd[14752] (dcc_r_argv) argv[0] = "clang++-3.9-arm"
        distccd[14752] (dcc_r_token_int) got ARGV0000000e
        distccd[14752] (dcc_r_token_string) got '-march=armv7-a'
        distccd[14752] (dcc_r_argv) argv[1] = "-march=armv7-a"
        distccd[14752] (dcc_r_token_int) got ARGV0000000a
        distccd[14752] (dcc_r_token_string) got '-mfpu=vfp3'
        distccd[14752] (dcc_r_argv) argv[2] = "-mfpu=vfp3"
        distccd[14752] (dcc_r_token_int) got ARGV0000001c
        distccd[14752] (dcc_r_token_string) got '-fasynchronous-unwind-tables'
        distccd[14752] (dcc_r_argv) argv[3] = "-fasynchronous-unwind-tables"
        distccd[14752] (dcc_r_token_int) got ARGV00000003
        distccd[14752] (dcc_r_token_string) got '-O3'
        distccd[14752] (dcc_r_argv) argv[4] = "-O3"
        distccd[14752] (dcc_r_argv) argv[5] = "-march=armv7-a"
        distccd[14752] (dcc_r_token_int) got ARGV00000010
        distccd[14752] (dcc_r_token_string) got '-mtune=cortex-a8'
        distccd[14752] (dcc_r_argv) argv[6] = "-mtune=cortex-a8"
        distccd[14752] (dcc_r_token_string) got '-mfloat-abi=hard'
        distccd[14752] (dcc_r_argv) argv[7] = "-mfloat-abi=hard"
        distccd[14752] (dcc_r_token_string) got '-mfpu=neon'
        distccd[14752] (dcc_r_argv) argv[8] = "-mfpu=neon"
        distccd[14752] (dcc_r_token_string) got '-ftree-vectorize'
        distccd[14752] (dcc_r_argv) argv[9] = "-ftree-vectorize"
        distccd[14752] (dcc_r_token_int) got ARGV0000000b
        distccd[14752] (dcc_r_token_string) got '-ffast-math'
        distccd[14752] (dcc_r_argv) argv[10] = "-ffast-math"
        distccd[14752] (dcc_r_token_string) got '-std=c++11'
        distccd[14752] (dcc_r_argv) argv[11] = "-std=c++11"
        distccd[14752] (dcc_r_token_int) got ARGV0000000c
        distccd[14752] (dcc_r_token_string) got '-Wno-varargs'
        distccd[14752] (dcc_r_argv) argv[12] = "-Wno-varargs"
        distccd[14752] (dcc_r_token_int) got ARGV00000005
        distccd[14752] (dcc_r_token_string) got '-Wall'
        distccd[14752] (dcc_r_argv) argv[13] = "-Wall"
        distccd[14752] (dcc_r_token_int) got ARGV00000002
        distccd[14752] (dcc_r_token_string) got '-c'
        distccd[14752] (dcc_r_argv) argv[14] = "-c"
        distccd[14752] (dcc_r_token_int) got ARGV00000012
        distccd[14752] (dcc_r_token_string) got '-fmessage-length=0'
        distccd[14752] (dcc_r_argv) argv[15] = "-fmessage-length=0"
        distccd[14752] (dcc_r_token_string) got '-o'
        distccd[14752] (dcc_r_argv) argv[16] = "-o"
        distccd[14752] (dcc_r_token_int) got ARGV0000002a
        distccd[14752] (dcc_r_token_string) got '/root/Bela/projects/delay01/build/render.o'
        distccd[14752] (dcc_r_argv) argv[17] = "/root/Bela/projects/delay01/build/render.o"
        distccd[14752] (dcc_r_token_int) got ARGV00000026
        distccd[14752] (dcc_r_token_string) got '/root/Bela/projects/delay01/render.cpp'
        distccd[14752] (dcc_r_argv) argv[18] = "/root/Bela/projects/delay01/render.cpp"
        distccd[14752] (dcc_r_argv) got arguments: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /root/Bela/projects/delay01/build/render.o /root/Bela/projects/delay01/render.cpp
        distccd[14752] (dcc_scan_args) scanning arguments: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /root/Bela/projects/delay01/build/render.o /root/Bela/projects/delay01/render.cpp
        distccd[14752] (dcc_scan_args) found object/output file "/root/Bela/projects/delay01/build/render.o"
        distccd[14752] (dcc_scan_args) found input file "/root/Bela/projects/delay01/render.cpp"
        distccd[14752] compile from render.cpp to render.o
        distccd[14752] (dcc_run_job) output file /root/Bela/projects/delay01/build/render.o
        distccd[14752] (dcc_input_tmpnam) input file /root/Bela/projects/delay01/render.cpp
        distccd[14752] (dcc_r_token_int) got DOTI0018d9d3
        distccd[14752] (dcc_r_file) received 1628627 bytes to file /tmp/distccd_1db50d83.ii
        distccd[14752] (dcc_r_file_timed) 1628627 bytes received in 0.146217s, rate 10877kB/s
        distccd[14752] (dcc_set_input) changed input from "/root/Bela/projects/delay01/render.cpp" to "/tmp/distccd_1db50d83.ii"
        distccd[14752] (dcc_set_input) command after: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /root/Bela/projects/delay01/build/render.o /tmp/distccd_1db50d83.ii
        distccd[14752] (dcc_set_output) changed output from "/root/Bela/projects/delay01/build/render.o" to "/tmp/distccd_1dc50d83.o"
        distccd[14752] (dcc_set_output) command after: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /tmp/distccd_1dc50d83.o /tmp/distccd_1db50d83.ii
        distccd[14752] (dcc_check_compiler_masq) /usr/local/bin/clang++-3.9-arm is not a symlink
        distccd[14752] (dcc_spawn_child) forking to execute: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /tmp/distccd_1dc50d83.o /tmp/distccd_1db50d83.ii
        distccd[14752] (dcc_spawn_child) child started as pid14971
        distccd[14971] (dcc_new_pgrp) entered process group
        distccd[14971] (dcc_increment_safeguard) setting safeguard: _DISTCC_SAFEGUARD=1
        distccd[14752] (dcc_collect_child) cc child 14971 terminated with status 0x100
        distccd[14752] (dcc_collect_child) cc times: user 0.000000s, system 0.000000s, 0 minflt, 0 majflt
        distccd[14752] (dcc_x_token_int) send DONE00000001
        distccd[14752] (dcc_x_token_int) send STAT00000100
        distccd[14752] (dcc_x_file) send 248 byte file /tmp/distcc_161f0d83.stderr with token SERR and compression 69
        distccd[14752] (dcc_x_token_int) send SERR000000f8
        distccd[14752] (dcc_x_file) send 0 byte file /tmp/distcc_16d70d83.stdout with token SOUT and compression 69
        distccd[14752] (dcc_x_token_int) send SOUT00000000
        distccd[14752] (dcc_x_token_int) send DOTO00000000
        distccd[14752] clang++-3.9-arm /root/Bela/projects/delay01/render.cpp on localhost failed
        distccd[14752] job complete
        distccd[14752] (dcc_cleanup_tempfiles_inner) deleted 5 temporary files
        distccd[14752] (dcc_job_summary) client: 192.168.7.2:59746 COMPILE_ERROR exit:1 sig:0 core:0 ret:0 time:988ms clang++-3.9-arm /root/Bela/projects/delay01/render.cpp
        in the distcc log.
        On host console I get:
        distcc[3031] ERROR: compile /root/Bela/projects/delay01/render.cpp on 192.168.7.1 failed
        distcc[3031] (dcc_build_somewhere) Warning: remote compilation of '/root/Bela/projects/delay01/render.cpp' failed, retrying locally
        distcc[3031] (dcc_build_somewhere) Warning: failed to distribute and fallbacks are disabled
        /usr/bin/ld: unrecognised emulation mode: armelf_linux_eabi
        Supported emulations: elf_x86_64 elf32_x86_64 elf_i386 elf_iamcu i386linux elf_l1om elf_k1om i386pep i386pe
          Think you were talking about this before, but not sure I understood.
          ary@audio-workstation:~/faust/examples/bela$ cat /usr/local/bin/*arm
          #!/bin/bash
          /usr/bin/clang -target armv7l-unknown-linux-gnueabihf --sysroot ~/arm $@
          #!/bin/bash
          /usr/bin/clang++ -target armv7l-unknown-linux-gnueabihf --sysroot ~/arm $0
          These don't currently point to clang-3.9. They just point to clang which is actually version 6. I think you were saying that it has to be version 3.9?
          However, this step works:
          distcc-clang -c ~/Bela/resources/network/udp-client.c
            gary@audio-workstation:~$ ld -V
            GNU ld (GNU Binutils for Ubuntu) 2.30
               elf_x86_64
               elf32_x86_64
               elf_i386
               elf_iamcu
               i386linux
               elf_l1om
               elf_k1om
               i386pep
               i386pe
            Digital-Larry By "the Bela Makefile" I presume that you mean the file /root/Bela/Makefile.
            yes
            Digital-Larry On host console I get:
            I guess that's technically the "client" console (i.e.: what you see there is while you are logged in on Bela).
            So it seems that the compiler is failing, and my guess is that it is because it is being passed -march=armv7-a but no -target armv7l-unknown-linux-gnueabihf, and this - I guess - is because you are not calling the wrapper but you are calling the vanilla compiler directly (through the symlink you created).
            The point of the wrapper is exactly to automatically add -target armv7l-unknown-linux-gnueabihf to all calls.
            I think what is happening is what I mentioned in the other thread:
            giuliomoro But if you do put some symlinks there, they should be pointing NOT to the regular clang, but to the clang-3.9-arm and clang++-3.9-arm files you created in /usr/local/bin/, and they will eventually call clang with the appropriate option -target armv7l-unknown-linux-gnueabihf, to tell it to build code for ARM.
            Digital-Larry gary@audio-workstation:/usr/local/lib$ ls -l distcc/
            total 0
            lrwxrwxrwx 1 root root 14 May 28 17:45 clang-3.9-arm -> /usr/bin/clang
            lrwxrwxrwx 1 root root 16 May 28 17:45 clang++-3.9-arm -> /usr/bin/clang++
            Is this working? I find it surprising, but I guess it may depend on how you clang has been built. This way you are simply using the regular clang on your computer, but it should need a -target armv7l-unknown-linux-gnueabihf option in order to know it should build for arm (at least, it does with mine, which I installed with macports on Mac).
            basically, remove your current symlinks from /usr/local/lib/distcc/ and make some new ones that point NOT to the vanilla clang/clang++, but to the wrapper clang-3.9-arm/clang++-3.9-arm you created:
            sudo rm /usr/local/lib/distcc/*
            sudo ln -s /usr/local/bin/clang-3.9-arm/ /usr/local/lib/distcc/
            sudo ln -s /usr/local/bin/clang++-3.9-arm/ /usr/local/lib/distcc/
            Digital-Larry However, this step works:
            I see now how that can easily give false positives: it just checks that the server can compile, but does not check the nature of the resulted file. If you were to do file a.out, it would probably say it's an x86 file and not an ARM one.
            So the test should probably be amended to :
            distcc-clang -c ~/Bela/resources/network/udp-client.c -march=armv7-a
            This should then fail similarly to the how the Bela project is failing in your current configuration, and should be fixed with the updated symlinks.
              OK let's see where we are now.
              root@bela:~/Bela# grep distcc Makefile
                CLANG_PATH=distcc-clang
              root@bela:~/Bela#
              reference command line build on bela works (without specifying architecture):
              root@bela:~/Bela/resources/network# distcc-clang -v -c udp-client.c
              clang version 3.9.1-9 (tags/RELEASE_391/rc2)
              Target: armv7l-unknown-linux-gnueabihf
              Thread model: posix
              InstalledDir: /usr/bin
              Found candidate GCC installation: /usr/bin/../lib/gcc/arm-linux-gnueabihf/6
              Found candidate GCC installation: /usr/bin/../lib/gcc/arm-linux-gnueabihf/6.3.0
              Found candidate GCC installation: /usr/lib/gcc/arm-linux-gnueabihf/6
              Found candidate GCC installation: /usr/lib/gcc/arm-linux-gnueabihf/6.3.0
              Selected GCC installation: /usr/bin/../lib/gcc/arm-linux-gnueabihf/6.3.0
              Candidate multilib: .;@m32
              Selected multilib: .;@m32
               "/usr/lib/llvm-3.9/bin/clang" -cc1 -triple armv7-unknown-linux-gnueabihf -E -disable-free -disable-llvm-verifier -discard-value-names -main-file-name udp-client.c -mrelocation-model static -mthread-model posix -mdisable-fp-elim -fmath-errno -masm-verbose -mconstructor-aliases -fuse-init-array -target-cpu cortex-a8 -target-abi aapcs-linux -mfloat-abi hard -v -dwarf-column-info -debugger-tuning=gdb -resource-dir /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1 -internal-isystem /usr/local/include -internal-isystem /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1/include -internal-externc-isystem /usr/include/arm-linux-gnueabihf -internal-externc-isystem /include -internal-externc-isystem /usr/include -fdebug-compilation-dir /root/Bela/resources/network -ferror-limit 19 -fmessage-length 80 -fallow-half-arguments-and-returns -fno-signed-char -fobjc-runtime=gcc -fdiagnostics-show-option -fcolor-diagnostics -o - -x c udp-client.c
              clang -cc1 version 3.9.1 based upon LLVM 3.9.1 default target armv7l-unknown-linux-gnueabihf
              ignoring nonexistent directory "/include"
              #include "..." search starts here:
              #include <...> search starts here:
               /usr/local/include
               /usr/include
              End of search list.
              clang version 3.9.1-19ubuntu1 (tags/RELEASE_391/rc2)
              Thread model: posix
               "/usr/lib/llvm-3.9/bin/clang" -cc1 -triple armv7-unknown-linux-gnueabihf -emit-obj -mrelax-all -disable-free -disable-llvm-verifier -discard-value-names -main-file-name distccd_ba396596.i -mrelocation-model static -mthread-model posix -mdisable-fp-elim -fmath-errno -masm-verbose -mconstructor-aliases -target-cpu cortex-a8 -target-abi aapcs-linux -mfloat-abi hard -v -dwarf-column-info -debugger-tuning=gdb -coverage-file /tmp/distccd_ba666596.o -resource-dir /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1 -fdebug-compilation-dir /tmp -ferror-limit 19 -fmessage-length 0 -fallow-half-arguments-and-returns -fno-signed-char -fobjc-runtime=gcc -fdiagnostics-show-option -o /tmp/distccd_ba666596.o -x cpp-output /tmp/distccd_ba396596.i
              clang -cc1 version 3.9.1 based upon LLVM 3.9.1 default target x86_64-pc-linux-gnu
              End of search list.
              reference build works with specifying architecture:
              root@bela:~/Bela/resources/network# distcc-clang -c -v ~/Bela/resources/network/udp-client.c -march=armv7-a
              Thread model: posix
               "/usr/lib/llvm-3.9/bin/clang" -cc1 -triple armv7-unknown-linux-gnueabihf -E -disable-free -disable-llvm-verifier -discard-value-names -main-file-name udp-client.c -mrelocation-model static -mthread-model posix -mdisable-fp-elim -fmath-errno -masm-verbose -mconstructor-aliases -fuse-init-array -target-cpu cortex-a8 -target-abi aapcs-linux -mfloat-abi hard -v -dwarf-column-info -debugger-tuning=gdb -resource-dir /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1 -internal-isystem /usr/local/include -internal-isystem /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1/include -internal-externc-isystem /usr/include/arm-linux-gnueabihf -internal-externc-isystem /include -internal-externc-isystem /usr/include -fdebug-compilation-dir /root/Bela/resources/network -ferror-limit 19 -fmessage-length 80 -fallow-half-arguments-and-returns -fno-signed-char -fobjc-runtime=gcc -fdiagnostics-show-option -fcolor-diagnostics -o - -x c /root/Bela/resources/network/udp-client.c
               /usr/local/include
               /usr/include
              End of search list.
              Thread model: posix
               "/usr/lib/llvm-3.9/bin/clang" -cc1 -triple armv7-unknown-linux-gnueabihf -emit-obj -mrelax-all -disable-free -disable-llvm-verifier -discard-value-names -main-file-name distccd_ff4c663b.i -mrelocation-model static -mthread-model posix -mdisable-fp-elim -fmath-errno -masm-verbose -mconstructor-aliases -target-cpu cortex-a8 -target-abi aapcs-linux -mfloat-abi hard -v -dwarf-column-info -debugger-tuning=gdb -coverage-file /tmp/distccd_fcec663b.o -resource-dir /usr/lib/llvm-3.9/bin/../lib/clang/3.9.1 -fdebug-compilation-dir /tmp -ferror-limit 19 -fmessage-length 0 -fallow-half-arguments-and-returns -fno-signed-char -fobjc-runtime=gcc -fdiagnostics-show-option -o /tmp/distccd_fcec663b.o -x cpp-output /tmp/distccd_ff4c663b.i
              End of search list.
              Here's the distcclog from the Ubuntu machine:
              distccd[14752] (dcc_check_client) connection from 192.168.7.2:59770
              distccd[14752] (dcc_r_token_int) got ARGC00000006
              distccd[14752] (dcc_r_argv) reading 6 arguments from job submission
              distccd[14752] (dcc_r_token_int) got ARGV0000000d
              distccd[14752] (dcc_r_token_string) got 'clang-3.9-arm'
              distccd[14752] (dcc_r_argv) argv[0] = "clang-3.9-arm"
              distccd[14752] (dcc_r_token_string) got '-v'
              distccd[14752] (dcc_r_argv) argv[1] = "-v"
              distccd[14752] (dcc_r_argv) argv[2] = "-c"
              distccd[14752] (dcc_r_token_string) got 'udp-client.c'
              distccd[14752] (dcc_r_argv) argv[3] = "udp-client.c"
              distccd[14752] (dcc_r_argv) argv[4] = "-o"
              distccd[14752] (dcc_r_token_string) got 'udp-client.o'
              distccd[14752] (dcc_r_argv) argv[5] = "udp-client.o"
              distccd[14752] (dcc_r_argv) got arguments: clang-3.9-arm -v -c udp-client.c -o udp-client.o
              distccd[14752] (dcc_scan_args) scanning arguments: clang-3.9-arm -v -c udp-client.c -o udp-client.o
              distccd[14752] (dcc_scan_args) found input file "udp-client.c"
              distccd[14752] (dcc_scan_args) found object/output file "udp-client.o"
              distccd[14752] compile from udp-client.c to udp-client.o
              distccd[14752] (dcc_run_job) output file udp-client.o
              distccd[14752] (dcc_input_tmpnam) input file udp-client.c
              distccd[14752] (dcc_r_token_int) got DOTI00016dac
              distccd[14752] (dcc_r_file) received 93612 bytes to file /tmp/distccd_ba396596.i
              distccd[14752] (dcc_r_file_timed) 93612 bytes received in 0.011009s, rate 8304kB/s
              distccd[14752] (dcc_set_input) changed input from "udp-client.c" to "/tmp/distccd_ba396596.i"
              distccd[14752] (dcc_set_input) command after: clang-3.9-arm -v -c /tmp/distccd_ba396596.i -o udp-client.o
              distccd[14752] (dcc_set_output) changed output from "udp-client.o" to "/tmp/distccd_ba666596.o"
              distccd[14752] (dcc_set_output) command after: clang-3.9-arm -v -c /tmp/distccd_ba396596.i -o /tmp/distccd_ba666596.o
              distccd[14752] (dcc_check_compiler_masq) /usr/local/bin/clang-3.9-arm is not a symlink
              distccd[14752] (dcc_spawn_child) forking to execute: clang-3.9-arm -v -c /tmp/distccd_ba396596.i -o /tmp/distccd_ba666596.o
              distccd[14752] (dcc_spawn_child) child started as pid32524
              distccd[32524] (dcc_new_pgrp) entered process group
              distccd[32524] (dcc_increment_safeguard) setting safeguard: _DISTCC_SAFEGUARD=1
              distccd[14752] (dcc_collect_child) cc child 32524 terminated with status 0
              distccd[14752] (dcc_x_token_int) send STAT00000000
              distccd[14752] (dcc_x_file) send 1002 byte file /tmp/distcc_b8066596.stderr with token SERR and compression 69
              distccd[14752] (dcc_x_token_int) send SERR000003ea
              distccd[14752] (dcc_x_file) send 0 byte file /tmp/distcc_b8246596.stdout with token SOUT and compression 69
              distccd[14752] (dcc_x_file) send 2192 byte file /tmp/distccd_ba666596.o with token DOTO and compression 69
              distccd[14752] (dcc_x_token_int) send DOTO00000890
              distccd[14752] clang-3.9-arm udp-client.c on localhost completed ok
              distccd[14752] (dcc_job_summary) client: 192.168.7.2:59770 COMPILE_OK exit:0 sig:0 core:0 ret:0 time:318ms clang-3.9-arm udp-client.c
              distccd[14753] (dcc_check_client) connection from 192.168.7.2:59772
              distccd[14753] (check_address_inet) match client 0x207a8c0, value 0x207a8c0, mask 0xffffffff
              distccd[14753] (dcc_r_token_int) got DIST00000001
              distccd[14753] (dcc_r_token_int) got ARGC00000006
              distccd[14753] (dcc_r_argv) reading 6 arguments from job submission
              distccd[14753] (dcc_r_token_int) got ARGV0000000d
              distccd[14753] (dcc_r_token_string) got 'clang-3.9-arm'
              distccd[14753] (dcc_r_argv) argv[0] = "clang-3.9-arm"
              distccd[14753] (dcc_r_token_int) got ARGV00000002
              distccd[14753] (dcc_r_token_string) got '-c'
              distccd[14753] (dcc_r_argv) argv[1] = "-c"
              distccd[14753] (dcc_r_token_int) got ARGV00000029
              distccd[14753] (dcc_r_token_string) got '/root/Bela/resources/network/udp-client.c'
              distccd[14753] (dcc_r_argv) argv[2] = "/root/Bela/resources/network/udp-client.c"
              distccd[14753] (dcc_r_token_int) got ARGV0000000e
              distccd[14753] (dcc_r_token_string) got '-march=armv7-a'
              distccd[14753] (dcc_r_argv) argv[3] = "-march=armv7-a"
              distccd[14753] (dcc_r_token_string) got '-o'
              distccd[14753] (dcc_r_argv) argv[4] = "-o"
              distccd[14753] (dcc_r_token_int) got ARGV0000000c
              distccd[14753] (dcc_r_token_string) got 'udp-client.o'
              distccd[14753] (dcc_r_argv) argv[5] = "udp-client.o"
              distccd[14753] (dcc_r_argv) got arguments: clang-3.9-arm -c /root/Bela/resources/network/udp-client.c -march=armv7-a -o udp-client.o
              distccd[14753] (dcc_scan_args) scanning arguments: clang-3.9-arm -c /root/Bela/resources/network/udp-client.c -march=armv7-a -o udp-client.o
              distccd[14753] (dcc_scan_args) found input file "/root/Bela/resources/network/udp-client.c"
              distccd[14753] (dcc_scan_args) found object/output file "udp-client.o"
              distccd[14753] compile from udp-client.c to udp-client.o
              distccd[14753] (dcc_run_job) output file udp-client.o
              distccd[14753] (dcc_input_tmpnam) input file /root/Bela/resources/network/udp-client.c
              distccd[14753] (dcc_r_token_int) got DOTI00016eeb
              distccd[14753] (dcc_r_file) received 93931 bytes to file /tmp/distccd_20816628.i
              distccd[14753] (dcc_r_file_timed) 93931 bytes received in 0.012232s, rate 7499kB/s
              distccd[14753] (dcc_set_input) changed input from "/root/Bela/resources/network/udp-client.c" to "/tmp/distccd_20816628.i"
              distccd[14753] (dcc_set_input) command after: clang-3.9-arm -c /tmp/distccd_20816628.i -march=armv7-a -o udp-client.o
              distccd[14753] (dcc_set_output) changed output from "udp-client.o" to "/tmp/distccd_20dc6628.o"
              distccd[14753] (dcc_set_output) command after: clang-3.9-arm -c /tmp/distccd_20816628.i -march=armv7-a -o /tmp/distccd_20dc6628.o
              distccd[14753] (dcc_check_compiler_masq) /usr/local/bin/clang-3.9-arm is not a symlink
              distccd[14753] (dcc_spawn_child) forking to execute: clang-3.9-arm -c /tmp/distccd_20816628.i -march=armv7-a -o /tmp/distccd_20dc6628.o
              distccd[14753] (dcc_spawn_child) child started as pid32547
              distccd[32547] (dcc_new_pgrp) entered process group
              distccd[32547] (dcc_increment_safeguard) setting safeguard: _DISTCC_SAFEGUARD=1
              distccd[14753] (dcc_collect_child) cc child 32547 terminated with status 0
              distccd[14753] (dcc_collect_child) cc times: user 0.000000s, system 0.000000s, 0 minflt, 0 majflt
              distccd[14753] (dcc_x_token_int) send DONE00000001
              distccd[14753] (dcc_x_token_int) send STAT00000000
              distccd[14753] (dcc_x_file) send 0 byte file /tmp/distcc_27c16628.stderr with token SERR and compression 69
              distccd[14753] (dcc_x_token_int) send SERR00000000
              distccd[14753] (dcc_x_file) send 0 byte file /tmp/distcc_27996628.stdout with token SOUT and compression 69
              distccd[14753] (dcc_x_token_int) send SOUT00000000
              distccd[14753] (dcc_x_file) send 2192 byte file /tmp/distccd_20dc6628.o with token DOTO and compression 69
              distccd[14753] (dcc_x_token_int) send DOTO00000890
              distccd[14753] clang-3.9-arm /root/Bela/resources/network/udp-client.c on localhost completed ok
              distccd[14753] job complete
              distccd[14753] (dcc_cleanup_tempfiles_inner) deleted 5 temporary files
              distccd[14753] (dcc_job_summary) client: 192.168.7.2:59772 COMPILE_OK exit:0 sig:0 core:0 ret:0 time:286ms clang-3.9-arm /root/Bela/resources/network/udp-client.c
              distccd[14754] (dcc_check_client) connection from 192.168.7.2:59774
              distccd[14754] (check_address_inet) match client 0x207a8c0, value 0x207a8c0, mask 0xffffffff
              distccd[14754] (dcc_r_token_int) got DIST00000001
              distccd[14754] (dcc_r_token_int) got ARGC00000007
              distccd[14754] (dcc_r_argv) reading 7 arguments from job submission
              distccd[14754] (dcc_r_token_int) got ARGV0000000d
              distccd[14754] (dcc_r_token_string) got 'clang-3.9-arm'
              distccd[14754] (dcc_r_argv) argv[0] = "clang-3.9-arm"
              distccd[14754] (dcc_r_token_int) got ARGV00000002
              distccd[14754] (dcc_r_token_string) got '-c'
              distccd[14754] (dcc_r_argv) argv[1] = "-c"
              distccd[14754] (dcc_r_token_string) got '-v'
              distccd[14754] (dcc_r_argv) argv[2] = "-v"
              distccd[14754] (dcc_r_token_int) got ARGV00000029
              distccd[14754] (dcc_r_token_string) got '/root/Bela/resources/network/udp-client.c'
              distccd[14754] (dcc_r_argv) argv[3] = "/root/Bela/resources/network/udp-client.c"
              distccd[14754] (dcc_r_token_int) got ARGV0000000e
              distccd[14754] (dcc_r_token_string) got '-march=armv7-a'
              distccd[14754] (dcc_r_argv) argv[4] = "-march=armv7-a"
              distccd[14754] (dcc_r_token_string) got '-o'
              distccd[14754] (dcc_r_argv) argv[5] = "-o"
              distccd[14754] (dcc_r_token_int) got ARGV0000000c
              distccd[14754] (dcc_r_token_string) got 'udp-client.o'
              distccd[14754] (dcc_r_argv) argv[6] = "udp-client.o"
              distccd[14754] (dcc_r_argv) got arguments: clang-3.9-arm -c -v /root/Bela/resources/network/udp-client.c -march=armv7-a -o udp-client.o
              distccd[14754] (dcc_scan_args) scanning arguments: clang-3.9-arm -c -v /root/Bela/resources/network/udp-client.c -march=armv7-a -o udp-client.o
              distccd[14754] (dcc_scan_args) found input file "/root/Bela/resources/network/udp-client.c"
              distccd[14754] (dcc_scan_args) found object/output file "udp-client.o"
              distccd[14754] compile from udp-client.c to udp-client.o
              distccd[14754] (dcc_run_job) output file udp-client.o
              distccd[14754] (dcc_input_tmpnam) input file /root/Bela/resources/network/udp-client.c
              distccd[14754] (dcc_r_token_int) got DOTI00016eeb
              distccd[14754] (dcc_r_file) received 93931 bytes to file /tmp/distccd_ff4c663b.i
              distccd[14754] (dcc_r_file_timed) 93931 bytes received in 0.011458s, rate 8006kB/s
              distccd[14754] (dcc_set_input) changed input from "/root/Bela/resources/network/udp-client.c" to "/tmp/distccd_ff4c663b.i"
              distccd[14754] (dcc_set_input) command after: clang-3.9-arm -c -v /tmp/distccd_ff4c663b.i -march=armv7-a -o udp-client.o
              distccd[14754] (dcc_set_output) changed output from "udp-client.o" to "/tmp/distccd_fcec663b.o"
              distccd[14754] (dcc_set_output) command after: clang-3.9-arm -c -v /tmp/distccd_ff4c663b.i -march=armv7-a -o /tmp/distccd_fcec663b.o
              distccd[14754] (dcc_check_compiler_masq) /usr/local/bin/clang-3.9-arm is not a symlink
              distccd[14754] (dcc_spawn_child) forking to execute: clang-3.9-arm -c -v /tmp/distccd_ff4c663b.i -march=armv7-a -o /tmp/distccd_fcec663b.o
              distccd[14754] (dcc_spawn_child) child started as pid32551
              distccd[32551] (dcc_new_pgrp) entered process group
              distccd[32551] (dcc_increment_safeguard) setting safeguard: _DISTCC_SAFEGUARD=1
              distccd[14754] (dcc_collect_child) cc child 32551 terminated with status 0
              distccd[14754] (dcc_collect_child) cc times: user 0.000000s, system 0.000000s, 0 minflt, 0 majflt
              distccd[14754] (dcc_x_token_int) send DONE00000001
              distccd[14754] (dcc_x_token_int) send STAT00000000
              distccd[14754] (dcc_x_file) send 1002 byte file /tmp/distcc_f203663b.stderr with token SERR and compression 69
              distccd[14754] (dcc_x_token_int) send SERR000003ea
              distccd[14754] (dcc_x_file) send 0 byte file /tmp/distcc_f22c663b.stdout with token SOUT and compression 69
              distccd[14754] (dcc_x_token_int) send SOUT00000000
              distccd[14754] (dcc_x_file) send 2192 byte file /tmp/distccd_fcec663b.o with token DOTO and compression 69
              distccd[14754] (dcc_x_token_int) send DOTO00000890
              distccd[14754] clang-3.9-arm /root/Bela/resources/network/udp-client.c on localhost completed ok
              distccd[14754] job complete
              distccd[14754] (dcc_cleanup_tempfiles_inner) deleted 5 temporary files
              distccd[14754] (dcc_job_summary) client: 192.168.7.2:59774 COMPILE_OK exit:0 sig:0 core:0 ret:0 time:320ms clang-3.9-arm /root/Bela/resources/network/udp-client.c
              Now trying "faust2bela" from the Ubuntu machine. /usr/Bela/Makefile still references distcc.
              gary@audio-workstation:~/faust/examples/bela$ faust2bela -tobela -gui FXChaine2.dsp
              Send to bela
              /home/gary/faust/examples/bela/FXChaine2
              Start communication with bela
              FXChaine2
              Stop running process...
              Run bela now
              uploadBuildRun START
              Copying new source files to BeagleBone...Using rsync...
              PID=`grep bela-audio  /proc/xenomai/sched/stat | cut -d " " -f 5 | sed s/\s//g`; if [ -z $PID ]; then [ true = true ] || echo "No process to kill"; else [  true = true  ] || echo "Killing old Bela process $PID"; kill -2 $PID; sleep 0.2; kill -9 $PID 2> /dev/null; fi; screen -X -S Bela quit > /dev/null; exit 0;
              distcc-clang++  -I/root/Bela/projects/FXChaine2 -I./include -I./build/pru/ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBALT__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEBUG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -std=c++11 -Wno-varargs -DNDEBUG  -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/projects/FXChaine2/build/render.d" -o "/root/Bela/projects/FXChaine2/build/render.o" "/root/Bela/projects/FXChaine2/render.cpp"
              distcc[5035] ERROR: compile /root/Bela/projects/FXChaine2/render.cpp on 192.168.7.1 failed
              distcc[5035] (dcc_build_somewhere) Warning: remote compilation of '/root/Bela/projects/FXChaine2/render.cpp' failed, retrying locally
              distcc[5035] (dcc_build_somewhere) Warning: failed to distribute and fallbacks are disabled
              Makefile:434: recipe for target '/root/Bela/projects/FXChaine2/build/render.o' failed
              make: *** [/root/Bela/projects/FXChaine2/build/render.o] Error 1
              This still seems to be the failure:
              This link takes us to some hints on that error message, which seem to culminate in "install the toolchain". The question is in the context of Android NDK though so I don't know if it applies here.
              https://stackoverflow.com/questions/52646860/ld-unrecognised-emulation-mode-armelf-linux-eabi-when-cross-compiling-with-a
              Here's the distcc log from this step:
              distccd[14755] (dcc_check_client) connection from 192.168.7.2:59776
              distccd[14755] (check_address_inet) match client 0x207a8c0, value 0x207a8c0, mask 0xffffffff
              distccd[14755] (dcc_r_token_int) got DIST00000001
              distccd[14755] (dcc_r_token_int) got ARGC00000013
              distccd[14755] (dcc_r_argv) reading 19 arguments from job submission
              distccd[14755] (dcc_r_token_int) got ARGV0000000f
              distccd[14755] (dcc_r_token_string) got 'clang++-3.9-arm'
              distccd[14755] (dcc_r_argv) argv[0] = "clang++-3.9-arm"
              distccd[14755] (dcc_r_token_int) got ARGV0000000e
              distccd[14755] (dcc_r_token_string) got '-march=armv7-a'
              distccd[14755] (dcc_r_argv) argv[1] = "-march=armv7-a"
              distccd[14755] (dcc_r_token_int) got ARGV0000000a
              distccd[14755] (dcc_r_token_string) got '-mfpu=vfp3'
              distccd[14755] (dcc_r_argv) argv[2] = "-mfpu=vfp3"
              distccd[14755] (dcc_r_token_int) got ARGV0000001c
              distccd[14755] (dcc_r_token_string) got '-fasynchronous-unwind-tables'
              distccd[14755] (dcc_r_argv) argv[3] = "-fasynchronous-unwind-tables"
              distccd[14755] (dcc_r_token_int) got ARGV00000003
              distccd[14755] (dcc_r_token_string) got '-O3'
              distccd[14755] (dcc_r_argv) argv[4] = "-O3"
              distccd[14755] (dcc_r_argv) argv[5] = "-march=armv7-a"
              distccd[14755] (dcc_r_token_int) got ARGV00000010
              distccd[14755] (dcc_r_token_string) got '-mtune=cortex-a8'
              distccd[14755] (dcc_r_argv) argv[6] = "-mtune=cortex-a8"
              distccd[14755] (dcc_r_token_string) got '-mfloat-abi=hard'
              distccd[14755] (dcc_r_argv) argv[7] = "-mfloat-abi=hard"
              distccd[14755] (dcc_r_token_string) got '-mfpu=neon'
              distccd[14755] (dcc_r_argv) argv[8] = "-mfpu=neon"
              distccd[14755] (dcc_r_token_string) got '-ftree-vectorize'
              distccd[14755] (dcc_r_argv) argv[9] = "-ftree-vectorize"
              distccd[14755] (dcc_r_token_int) got ARGV0000000b
              distccd[14755] (dcc_r_token_string) got '-ffast-math'
              distccd[14755] (dcc_r_argv) argv[10] = "-ffast-math"
              distccd[14755] (dcc_r_token_string) got '-std=c++11'
              distccd[14755] (dcc_r_argv) argv[11] = "-std=c++11"
              distccd[14755] (dcc_r_token_int) got ARGV0000000c
              distccd[14755] (dcc_r_token_string) got '-Wno-varargs'
              distccd[14755] (dcc_r_argv) argv[12] = "-Wno-varargs"
              distccd[14755] (dcc_r_token_int) got ARGV00000005
              distccd[14755] (dcc_r_token_string) got '-Wall'
              distccd[14755] (dcc_r_argv) argv[13] = "-Wall"
              distccd[14755] (dcc_r_token_int) got ARGV00000002
              distccd[14755] (dcc_r_token_string) got '-c'
              distccd[14755] (dcc_r_argv) argv[14] = "-c"
              distccd[14755] (dcc_r_token_int) got ARGV00000012
              distccd[14755] (dcc_r_token_string) got '-fmessage-length=0'
              distccd[14755] (dcc_r_argv) argv[15] = "-fmessage-length=0"
              distccd[14755] (dcc_r_token_string) got '-o'
              distccd[14755] (dcc_r_argv) argv[16] = "-o"
              distccd[14755] (dcc_r_token_int) got ARGV0000002c
              distccd[14755] (dcc_r_token_string) got '/root/Bela/projects/FXChaine2/build/render.o'
              distccd[14755] (dcc_r_argv) argv[17] = "/root/Bela/projects/FXChaine2/build/render.o"
              distccd[14755] (dcc_r_token_int) got ARGV00000028
              distccd[14755] (dcc_r_token_string) got '/root/Bela/projects/FXChaine2/render.cpp'
              distccd[14755] (dcc_r_argv) argv[18] = "/root/Bela/projects/FXChaine2/render.cpp"
              distccd[14755] (dcc_r_argv) got arguments: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /root/Bela/projects/FXChaine2/build/render.o /root/Bela/projects/FXChaine2/render.cpp
              distccd[14755] (dcc_scan_args) scanning arguments: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /root/Bela/projects/FXChaine2/build/render.o /root/Bela/projects/FXChaine2/render.cpp
              distccd[14755] (dcc_scan_args) found object/output file "/root/Bela/projects/FXChaine2/build/render.o"
              distccd[14755] (dcc_scan_args) found input file "/root/Bela/projects/FXChaine2/render.cpp"
              distccd[14755] compile from render.cpp to render.o
              distccd[14755] (dcc_run_job) output file /root/Bela/projects/FXChaine2/build/render.o
              distccd[14755] (dcc_input_tmpnam) input file /root/Bela/projects/FXChaine2/render.cpp
              distccd[14755] (dcc_r_token_int) got DOTI0019610a
              distccd[14755] (dcc_r_file) received 1663242 bytes to file /tmp/distccd_261c6794.ii
              distccd[14755] (dcc_r_file_timed) 1663242 bytes received in 0.150477s, rate 10794kB/s
              distccd[14755] (dcc_set_input) changed input from "/root/Bela/projects/FXChaine2/render.cpp" to "/tmp/distccd_261c6794.ii"
              distccd[14755] (dcc_set_input) command after: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /root/Bela/projects/FXChaine2/build/render.o /tmp/distccd_261c6794.ii
              distccd[14755] (dcc_set_output) changed output from "/root/Bela/projects/FXChaine2/build/render.o" to "/tmp/distccd_27a96794.o"
              distccd[14755] (dcc_set_output) command after: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /tmp/distccd_27a96794.o /tmp/distccd_261c6794.ii
              distccd[14755] (dcc_check_compiler_masq) /usr/local/bin/clang++-3.9-arm is not a symlink
              distccd[14755] (dcc_spawn_child) forking to execute: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /tmp/distccd_27a96794.o /tmp/distccd_261c6794.ii
              distccd[14755] (dcc_spawn_child) child started as pid32659
              distccd[32659] (dcc_new_pgrp) entered process group
              distccd[32659] (dcc_increment_safeguard) setting safeguard: _DISTCC_SAFEGUARD=1
              distccd[14755] (dcc_collect_child) cc child 32659 terminated with status 0x100
              distccd[14755] (dcc_collect_child) cc times: user 0.000000s, system 0.000000s, 0 minflt, 0 majflt
              distccd[14755] (dcc_x_token_int) send DONE00000001
              distccd[14755] (dcc_x_token_int) send STAT00000100
              distccd[14755] (dcc_x_file) send 248 byte file /tmp/distcc_58bf6794.stderr with token SERR and compression 69
              distccd[14755] (dcc_x_token_int) send SERR000000f8
              distccd[14755] (dcc_x_file) send 0 byte file /tmp/distcc_5b7e6794.stdout with token SOUT and compression 69
              distccd[14755] (dcc_x_token_int) send SOUT00000000
              distccd[14755] (dcc_x_token_int) send DOTO00000000
              distccd[14755] clang++-3.9-arm /root/Bela/projects/FXChaine2/render.cpp on localhost failed
              distccd[14755] job complete
              distccd[14755] (dcc_cleanup_tempfiles_inner) deleted 5 temporary files
              distccd[14755] (dcc_job_summary) client: 192.168.7.2:59776 COMPILE_ERROR exit:1 sig:0 core:0 ret:0 time:1109ms clang++-3.9-arm /root/Bela/projects/FXChaine2/render.cpp
                This is very confusing to me. The error message you get seems to be about the linker, ld, and it seems to come from the host, because of the list of supported emulations. The weird thing about this is that distcc should never attempt to run the linker on the host (only the compiler), and also that the line that fails really has nothing to do with the linker.
                So this is the line that is run on the host and fails:
                Digital-Larry distccd[14755] (dcc_spawn_child) forking to execute: clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o /tmp/distccd_27a96794.o /tmp/distccd_261c6794.ii
                As you see, it tries to compile the pre-processed file /tmp/distccd_261c6794.ii into the object file /tmp/distccd_27a96794.o. The pre-processed file is generated by distcc on the client (Bela), where it runs cpp (the C-preprocessor) on the file to bring in all the includes and apply all the defines and resolve the macros, generating a stand-alone C++ file that has no dependency on any external files.
                Let's troubleshoot this with incremental steps. Create a simple C++ file with no includes on the host:
                • Create a simple C++ file with no includes on the HOST: create a file called test.ii:
                  int func()
                      return 0;
                  and then run the same command as above (except for the file paths at the end) :
                  clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o ./test.o ./test.ii
                  if this is successful, make sure the generated file test.o is indeed an ARM binary:
                  $ file test.o
                  test.o: ELF 32-bit LSB relocatable, ARM, version 1 (SYSV), not stripped
                • if the above worked fine, then copy the test.ii file to the board and run ON THE BOARD:
                  distcc-clang++ -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o ./test.o ./test.ii
                  and if this is successful, check that the generated file is indeed an ARM binary:
                  $ file test.o
                • if this is still good, then rename test.ii to test.cpp and run the same line again, this time with test.cpp at the end:
                  distcc-clang++ -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o ./test.o ./test.cpp
                • if this is still good, still on the board, do cd /root/Bela/ and there try to re-run the full line that was failing while building your project:
                  does this successfully generated the file /root/Bela/projects/FXChaine2/build/render.o? And is it an ARM binary?
                  giuliomoro first step fails.
                  gary@audio-workstation:~/test$ clang++-3.9-arm -march=armv7-a -mfpu=vfp3 -fasynchronous-unwind-tables -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -std=c++11 -Wno-varargs -Wall -c -fmessage-length=0 -o ./test.o ./test.ii
                  gary@audio-workstation:~/test$ cat test.ii
                  int func()
                      return 0;
                  gary@audio-workstation:~/test$ which clang++-3.9-arm
                  gary@audio-workstation:~/test$ cat /usr/local/bin/clang++-3.9-arm
                  #!/bin/bash
                  /usr/bin/clang++-3.9 -target armv7l-unknown-linux-gnueabihf --sysroot ~/arm $0
                  Calling that compiler throws the error with no parameters given at all! [edit - it's calling the script which does add parameters] So maybe that is broken somehow. I used apt to install it.
                  gary@audio-workstation:~/test$ sudo apt list | grep ^clang-3.9
                  WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                  clang-3.9/bionic,now 1:3.9.1-19ubuntu1 amd64 [installed]
                  clang-3.9-doc/bionic,bionic 1:3.9.1-19ubuntu1 all
                  clang-3.9-examples/bionic 1:3.9.1-19ubuntu1 amd64
                  gary@audio-workstation:~/test$ sudo dpkg -s clang-3.9
                  Package: clang-3.9
                  Status: install ok installed
                  Priority: optional
                  Section: devel
                  Installed-Size: 140661
                  Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
                  Architecture: amd64
                  Source: llvm-toolchain-3.9
                  Version: 1:3.9.1-19ubuntu1
                  Replaces: clang-3.1, clang-3.2, clang-3.3, clang-3.4 (<< 1:3.4.2-7~exp1), clang-3.5 (<< 1:3.5~+rc1-3~exp1), clang-include-fixer-3.9, compiler-rt
                  Provides: c++-compiler, c-compiler, objc-compiler
                  Depends: libc6 (>= 2.14), libclang1-3.9 (= 1:3.9.1-19ubuntu1), libgcc1 (>= 1:3.4), libjsoncpp1 (>= 1.7.4), libllvm3.9 (>= 1:3.9.1-6~), libstdc++6 (>= 5.2), libstdc++-7-dev, libgcc-7-dev, libobjc-7-dev, libclang-common-3.9-dev (= 1:3.9.1-19ubuntu1), libc6-dev, binutils
                  Recommends: llvm-3.9-dev, python
                  Suggests: gnustep, gnustep-devel, clang-3.9-doc
                  Breaks: clang-3.1, clang-3.2, clang-3.3, clang-3.4 (<< 1:3.4.2-7~exp1), clang-3.5 (<< 1:3.5~+rc1-3~exp1), clang-include-fixer-3.9, compiler-rt
                  Description: C, C++ and Objective-C compiler (LLVM based)
                   Clang project is a C, C++, Objective C and Objective C++ front-end
                   for the LLVM compiler. Its goal is to offer a replacement to the GNU Compiler
                   Collection (GCC).
                   Clang fully implements all published ISO C++ standards including C++11, as
                   well as the upcoming C++14 standard, and some parts of the fledgling C++1z
                   standard, and is considered a production-quality C++ compiler.
                  Original-Maintainer: LLVM Packaging Team <pkg-llvm-team@lists.alioth.debian.org>
                  Homepage: http://www.llvm.org/
                  Some other random tests to see what exactly we are calling and the simplest command to generate the error.
                  #!/bin/bash
                  gary@audio-workstation:~/test$ /usr/bin/clang++-3.9
                  clang: error: no input files
                  gary@audio-workstation:~/test$ /usr/bin/clang++-3.9 -target armv7l-unknown-linux-gnueabihf
                  gary@audio-workstation:~/test$ /usr/bin/clang++-3.9 -target armv7l-unknown-linux-gnueabihf ./test.ii
                  gary@audio-workstation:~/test$ /usr/bin/clang++-6.0 -target armv7l-unknown-linux-gnueabihf ./test.ii
                  gary@audio-workstation:~/test$ /usr/bin/clang++ -target armv7l-unknown-linux-gnueabihf ./test.ii
                    right, what about ls -l /usr/bin/clang++-3.9 ? is it a symlink to something?
                    Further to this, you could try running
                    and remove one option at a time until it succeeds (or better: start with just clang++-3.9-arm -march=armv7-a ./test.o ./test.ii, is it successful? Then add more and more options until it fails .
                    I am wondering whether maybe your clang-3.9 does not support hard-float, in which case the failing option should be -mfloat-abi=hard. Can you dpkg -l | grep clang and perhaps then dpkg --info <names of the 3.9 packages from the previous result>?
                      I used the -### command with just clang++ (the 6.0 version installed by default, but the error is the same so far regardless of the compiler version used, 3.9 or 6.0):
                      gary@audio-workstation:~/test$ /usr/bin/clang++ -### -target armv7l-unknown-linux-gnueabihf ./test.ii
                      clang version 6.0.0-1ubuntu2 (tags/RELEASE_600/final)
                      Thread model: posix
                       "/usr/lib/llvm-6.0/bin/clang" "-cc1" "-triple" "armv7-unknown-linux-gnueabihf" "-emit-obj" "-mrelax-all" "-disable-free" "-disable-llvm-verifier" "-discard-value-names" "-main-file-name" "test.ii" "-mrelocation-model" "static" "-mthread-model" "posix" "-mdisable-fp-elim" "-fmath-errno" "-masm-verbose" "-mconstructor-aliases" "-fuse-init-array" "-target-cpu" "generic" "-target-abi" "aapcs-linux" "-mfloat-abi" "hard" "-fallow-half-arguments-and-returns" "-dwarf-column-info" "-debugger-tuning=gdb" "-resource-dir" "/usr/lib/llvm-6.0/lib/clang/6.0.0" "-fdeprecated-macro" "-fdebug-compilation-dir" "/home/gary/test" "-ferror-limit" "19" "-fmessage-length" "80" "-fno-signed-char" "-fobjc-runtime=gcc" "-fcxx-exceptions" "-fexceptions" "-fdiagnostics-show-option" "-fcolor-diagnostics" "-o" "/tmp/test-dc97e4.o" "-x" "c++-cpp-output" "./test.ii"
                       "/usr/bin/ld" "-z" "relro" "-X" "--hash-style=gnu" "--eh-frame-hdr" "-m" "armelf_linux_eabi" "-dynamic-linker" "/lib/ld-linux-armhf.so.3" "-o" "a.out" "crt1.o" "crti.o" "crtbegin.o" "-L/usr/lib/llvm-6.0/bin/../lib" "-L/lib/../lib" "-L/usr/lib/../lib" "-L/usr/lib/llvm-6.0/bin/../lib" "-L/lib" "-L/usr/lib" "/tmp/test-dc97e4.o" "-lstdc++" "-lm" "-lgcc_s" "-lgcc" "-lc" "-lgcc_s" "-lgcc" "crtend.o" "crtn.o"
                      giuliomoro yes there is a symlink there that appears to be from the installation (I didn't do it).
                      gary@audio-workstation:~/test$ ls -l /usr/bin/clang++-3.9
                      lrwxrwxrwx 1 root root 27 Dec 26  2017 /usr/bin/clang++-3.9 -> ../lib/llvm-3.9/bin/clang++
                      gary@audio-workstation:~/test$ clang++-3.9-arm -march=armv7-a ./test.o ./test.ii
                      gary@audio-workstation:~/test$ dpkg -l | grep clang
                      ii  clang                                      1:6.0-41~exp5~ubuntu1                        amd64        C, C++ and Objective-C compiler (LLVM based)
                      ii  clang-3.9                                  1:3.9.1-19ubuntu1                            amd64        C, C++ and Objective-C compiler (LLVM based)
                      ii  clang-6.0                                  1:6.0-1ubuntu2                               amd64        C, C++ and Objective-C compiler
                      ii  libclang-common-3.9-dev                    1:3.9.1-19ubuntu1                            amd64        clang library - Common development package
                      ii  libclang-common-6.0-dev                    1:6.0-1ubuntu2                               amd64        clang library - Common development package
                      ii  libclang1-3.9:amd64                        1:3.9.1-19ubuntu1                            amd64        C interface to the clang library
                      ii  libclang1-6.0:amd64                        1:6.0-1ubuntu2                               amd64        C interface to the clang library
