hey,
I have a friend who's a crack at C and he had a look at the code of the render.cpp I had
Here's an outline what he proposed:
in the original code, libpd start message is at the beginning of render:
	int num;
libpd_start_message(8); //get data from all 8 MPR121 pins
	for(int n = 0; n < 8; ++n)
    	libpd_add_float(sensorValue[n]);
libpd_finish_list("sensorValue");
His proposal:
"Try to combine the 'float' and add_float from with the code in render, and put it at the VERY END of render() but inside render, remove the for loop from readMPR121."
    for(int n = 0; n < 8; ++n){
        libpd_add_float((float)n);
    libpd_finish_list("sensorIndex");
OLD read at the end of render.cpp:
void readMPR121(void*)
	for(int i = 0; i < NUM_TOUCH_PINS; i++) {
		sensorValue[i] = -(mpr121.filteredData(i) - mpr121.baselineData(i));
		sensorValue[i] -= threshold;
		if(sensorValue[i] < 0)
			sensorValue[i] = 0;
		libpd_float("sensorIndex", (float)i);
		//rt_printf("%d ", sensorIndex[i]); //error: use of undeclared identifier 'sensorIndex'
		libpd_float("sensorValue", (float)sensorValue[i]);
#ifdef DEBUG_MPR121
		rt_printf("%d ", sensorValue[i]); //prints the values of the sensor when DEBUG_MPR121 is define at beginning of programme
#endif
#ifdef DEBUG_MPR121
	rt_printf("\n");
#endif
// You can use this to read binary on/off touch state more easily
//rt_printf("Touched: %x\n", mpr121.touched());
-----> NEW read:
void readMPR121(void*){
            sensorValue[i] = 0;
#ifdef DEBUG_MPR121
#endif
#ifdef DEBUG_MPR121
    rt_printf("\n");
#endif
It WORKS!
Also with the little piece of handwoven e-textile (80% polyester, 20%stainless steel)
(image is green because of curtains - heatwave)
Latest render.cpp is here - it desperately needs a clean-up.
https://framabin.org/p/?79ecd118364dce6a#PgFmcFomCItZkIJRkx5azj8hnZuxZs4f76OEgMIOefk=
(you need javascript to decrypt)
End of August - beginning of September I will write about this in full detail and post the project.
    dywen remove the for loop from readMPR121."
    hmm:
    giuliomoro proper way is to move the message sending to the render() function.
    I guess that "move" here was the key word, also
    giuliomoro IMPORTANT: are you sending something else?
    I meant exactly: are you still sending to it from the other thread (that is, readMPR121()).
    dywen "Try to combine the 'float' and add_float from with the code in render, a
    that would not work (libpd_float() and libpd_add_float() cannot be combined), and in fact it is not what you have done.
    dywen
    You don't really need to send the sensorIndex at this point, you can just assume that the elements of the list are in order. So you don't need the second message.
    This line does nothing and should be removed.
    So, after removing this line and the useless "sensorIndex" message, you end up with exactly this:
    giuliomoro libpd_start_message(8);
    which I sent you a few days ago.
    dywen d put it at the VERY END of render()
    This would work, but it adds one block of latency with respect to having it at the beginning of render().
      giuliomoro dywen remove the for loop from readMPR121."
      hmm:
      Yes, indeed
      (I removed the old code and put in the new one ;-)
      Honestly, I don't know
      With the code on Midi - this render.cpp is too hard to read for me (I'm a linguist/artist - who did a quarter of a moog on coding - time money and parenthood limiting me at this moment from doing more)
      dywen
      libpd_finish_message("pd", "dsp");if("undefined"!==typeof hljs)hljs.ha();else if("undefined"===typeof hljsLoading){hljsLoading=1;var a=document.getElementsByTagName("head")[0],e=document.createElement("link");e.type="text/css";e.rel="stylesheet";e.href="//cdnjs.cloudflare.com/ajax/libs/highlight.js/9.4.0/styles/default.min.css";a.appendChild(e);e=document.createElement("script");e.type="text/javascript";e.onload=function(){var d={},f=0;hljs.hb=function(b){b.removeAttribute("data-hljs");var c=b.innerHTML;c in d?b.innerHTML=d[c]🙁7<++f&&(d={},f=0),hljs.highlightBlock(b.firstChild),d[c]=b.innerHTML)};hljs.ha=function(){for(var b=document.querySelectorAll("pre[data-hljs]"),c=b.length;0<c😉hljs.hb(b.item(--c))};hljs._ha()};e.async=!0;e.src="//cdnjs.cloudflare.com/ajax/libs/highlight.js/9.4.0/highlight.min.js";a.appendChild(e)}
      True, but I did not know what to remove :-/
      So I was conservative on deletion. I am over my head on this job (I never estimated it would become so complex to be able to have several audio files playing simultaneously)
      Ok! nose back to the grind stone!
      By the way I really like the responsiveness & console feedback of the Bela Ide whilst editing render.cpp
      giuliomoro I meant exactly: are you still sending to it from the other thread (that is, readMPR121()).
      There are three instances for readMPR121() - I see no doubles
      For documentation::
      -- line 77 says --internal stuff -- do not change
      // ---- internal stuff -- do not change -----
      I2C_MPR121 mpr121;			// Object to handle MPR121 sensing
      AuxiliaryTask i2cTask;		// Auxiliary task to read I2C
      int readCount = 0;			// How long until we read again...
      int readIntervalSamples = 0; // How many samples between reads
      void readMPR121(void*);
      -- line 389 - To have the data via i2c
      	i2cTask = Bela_createAuxiliaryTask(readMPR121, 50, "bela-mpr121");
      -- line 776 - to connect NUM_TOUCH_PINS to sensorValue - so Pure Data can receive these values
                  sensorValue[i] = 0;
      -- Full render.cpp as it is now
       ____  _____ _        _
      | __ )| ____| |      / \
      |  _ \|  _| | |     / _ \
      | |_) | |___| |___ / ___ \
      |____/|_____|_____/_/   \_\
      http://bela.io
      A project of the Augmented Instruments Laboratory within the
      Centre for Digital Music at Queen Mary University of London.
      http://www.eecs.qmul.ac.uk/~andrewm
      (c) 2016 Augmented Instruments Laboratory: Andrew McPherson,
      	Astrid Bin, Liam Donovan, Christian Heinrichs, Robert Jack,
      	Giulio Moro, Laurel Pardue, Victor Zappi. All rights reserved.
      The Bela software is distributed under the GNU Lesser General Public License
      (LGPL 3.0), available here: https://www.gnu.org/licenses/lgpl-3.0.txt
       *	USING A CUSTOM RENDER.CPP FILE FOR PUREDATA PATCHES - LIBPD
       *  || OPEN THE ENCLOSED _main.pd PATCH FOR MORE INFORMATION ||
      #include <cmath>
      #include <stdio.h>
      #include <libpd/z_libpd.h>
      extern "C" {
      #include <libpd/s_stuff.h>
      #include <UdpServer.h>
      #include <Midi.h>
      #include <Scope.h>
      #include <string>
      #include <sstream>
      #include "I2C_MPR121.h"
      	settings->interleave = 0;
       *  MODIFICATION
       *  MPR121 Stuff
      // How many pins there are
      #define NUM_TOUCH_PINS 12
      // Define this to print data to terminal - function prints data from sensor
      #define DEBUG_MPR121
      // Change this to change how often the MPR121 is read (in Hz)
      int readInterval = 50;
      // Change this threshold to set the minimum amount of touch
      int threshold = 40;
      // This array holds the continuous sensor values
      int sensorValue[NUM_TOUCH_PINS];
      float* gInBuf;
      float* gOutBuf;
      #define PARSE_MIDI
      void dumpMidi()
      	if(midi.size() == 0)
      		return;
      			"Num",
      			"Name",
      			"In",
      			"Out",
      			"Pd channels"
      			n,
      			gMidiPortNames[n].c_str(),
      			n * 16 + 1,
      			n * 16 + 16
      	Midi* newMidi;
      	newMidi = new Midi();
      #ifdef PARSE_MIDI
      	newMidi->enableParser(true);
      #else
      	newMidi->enableParser(false);
      #endif /* PARSE_MIDI */
      		if(verboseSuccess)
      	if(newMidi->isInputEnabled())
      		if(verboseSuccess)
      		if(verboseError)
      			fprintf(stderr, "Failed to open  MIDI device %s\n", name.c_str());
      		return nullptr;
      	} else {
      		return newMidi;
      	unsigned int port = 0;
      	while(*channel > 16){
      		*channel -= 16;
      		port += 1;
      	if(port >= midi.size()){
      		// if the port number exceeds the number of ports available, send out
      		// of the first port
      		port = 0;
      	return port;
      	midi[port]->writeNoteOn(channel, pitch, velocity);
      	midi[port]->writeControlChange(channel, controller, value);
      	midi[port]->writeProgramChange(channel, program);
      	midi[port]->writePitchBend(channel, value);
      	midi[port]->writeChannelPressure(channel, pressure);
      	midi[port]->writePolyphonicKeyPressure(channel, pitch, pressure);
      	if(port > (int)midi.size()){
      		port = 0;
      	midi[port]->writeOutput(byte);
      	rt_printf("%s", received);
      	libpd_float((char*)receiverName, (float)state);
      //	rt_printf("%s: %d\n", (char*)receiverName, state);
      #define LIBPD_DIGITAL_OFFSET 11 // digitals are preceded by 2 audio and 8 analogs (even if using a different number of analogs)
      	if(strcmp(source, "bela_setMidi") == 0){
      		int num[3] = {0, 0, 0};
      			if(!libpd_is_float(&argv[n]))
      				fprintf(stderr, "Wrong format for Bela_setMidi, expected:[hw 1 0 0(");
      				return;
      		if(newMidi)
      			midi.push_back(newMidi);
      		dumpMidi();
      		return;
      		bool disable = false;
      			direction = INPUT;
      			direction = OUTPUT;
      			disable = true;
      		} else {
      			return;
      		if(argc == 0){
      			return;
      			return;
      		int channel = libpd_get_float(&argv[0]) - LIBPD_DIGITAL_OFFSET;
      		if(disable == true){
      			dcm.unmanage(channel);
      			return;
      		if(argc >= 2){
      			t_atom* a = &argv[1];
      			if(libpd_is_symbol(a)){
      				char *s = libpd_get_symbol(a);
      				if(strcmp(s, "~") == 0  || strncmp(s, "sig", 3) == 0){
      					isMessageRate = false;
      		return;
      	 *  MODIFICATION
      	 *  Empty
      // the built-in digital receivers are of the form "bela_digitalOutXX" where XX is between 11 and 26
      			unsigned int channel = receiver - 11; // go back to the actual Bela digital channel number
      			if(channel < 16){ //16 is the hardcoded value for the number of digital channels
      				dcm.setValue(channel, value);
      char receiverNames[16][21]={
      	{"bela_digitalIn11"},{"bela_digitalIn12"},{"bela_digitalIn13"},{"bela_digitalIn14"},{"bela_digitalIn15"},
      	{"bela_digitalIn16"},{"bela_digitalIn17"},{"bela_digitalIn18"},{"bela_digitalIn19"},{"bela_digitalIn20"},
      	{"bela_digitalIn21"},{"bela_digitalIn22"},{"bela_digitalIn23"},{"bela_digitalIn24"},{"bela_digitalIn25"},
      	{"bela_digitalIn26"}
      // 2 audio + (up to)8 analog + (up to) 16 digital + 4 scope outputs
      static const unsigned int gChannelsInUse = 30;
      static const unsigned int gFirstAnalogInChannel = 2;
      static const unsigned int gFirstAnalogOutChannel = 2;
      static const unsigned int gFirstDigitalChannel = 10;
      static const unsigned int gFirstScopeChannel = 26;
      #ifdef PD_THREADED_IO
      void fdLoop(void* arg){
      	t_pdinstance* pd_that = (t_pdinstance*)arg;
      	while(!gShouldStop){
      		sys_doio(pd_that);
      		usleep(3000);
      #endif /* PD_THREADED_IO */
      Scope scope;
      unsigned int gScopeChannelsInUse = 4;
      float* gScopeOut;
      void* gPatch;
      bool gDigitalEnabled = 0;
      	// Check Pd's version
      	int major, minor, bugfix;
      		return false;
      		return false;
      	gDigitalEnabled = 1;
       *  MODIFICATION
       *  MPR121 Stuff
      if(!mpr121.begin(1, 0x5A)) {
      	rt_printf("Error initialising MPR121\n");
      	return false;
      readIntervalSamples = context->audioSampleRate / readInterval;
      char file[] = "_main.pd";
      char folder[] = "./";
      	return false;
      free(str);
      if(context->analogInChannels > 8 || context->analogOutChannels > 8)
      	fprintf(stderr, "This project can run with a maximum of 8 analog channels\n");
      	// change LIBPD_DIGITAL_OFFSET if you want more
      	return false;
      // analog setup
      // digital setup
      if(gDigitalEnabled)
      	if(context->digitalChannels > 0){
      		for(unsigned int ch = 0; ch < context->digitalChannels; ++ch){
      			dcm.setCallbackArgument(ch, receiverNames[ch]);
      for(unsigned int n = 0; n < gMidiPortNames.size(); ++n)
      unsigned int n = 0;
      	if(newMidi)
      		++n;
      	} else {
      dumpMidi();
      	return false;
      libpd_init();
      gInBuf = get_sys_soundin();
      gOutBuf = get_sys_soundout();
      // Bind your receivers here
      libpd_bind("bela_digitalOut11");
      libpd_bind("bela_digitalOut12");
      libpd_bind("bela_digitalOut13");
      libpd_bind("bela_digitalOut14");
      libpd_bind("bela_digitalOut15");
      libpd_bind("bela_digitalOut16");
      libpd_bind("bela_digitalOut17");
      libpd_bind("bela_digitalOut18");
      libpd_bind("bela_digitalOut19");
      libpd_bind("bela_digitalOut20");
      libpd_bind("bela_digitalOut21");
      libpd_bind("bela_digitalOut22");
      libpd_bind("bela_digitalOut23");
      libpd_bind("bela_digitalOut24");
      libpd_bind("bela_digitalOut25");
      libpd_bind("bela_digitalOut26");
      libpd_bind("bela_setMidi");
       *  MODIFICATION
       *  Empty
      // open patch:
      if(gPatch == NULL){
      	return false;
      	pdMultiplexerActive = true;
      	libpd_start_message(1);
      	sys_dontmanageio(1);
      	AuxiliaryTask fdTask;
      	fdTask = Bela_createAuxiliaryTask(fdLoop, 50, "libpd-fdTask", (void*)pd_this);
      	int num;
      #ifdef PARSE_MIDI
      			switch(message.getType()){
      				case kmmNoteOn:
      					break;
      				case kmmNoteOff:
      					 * with a velocity of 0.
      	//				int velocity = message.getDataByte(1); // would be ignored by Pd
      					break;
      				case kmmControlChange:
      					break;
      				case kmmProgramChange:
      					break;
      					break;
      				case kmmChannelPressure:
      					break;
      				case kmmPitchBend:
      					int value =  ((message.getDataByte(1) << 7)| message.getDataByte(0)) - 8192;
      					break;
      				case kmmSystem:
      					int byte = channel | status;
      					break;
      				case kmmNone:
      				case kmmAny:
      					break;
      #else
      	int input;
      			libpd_midibyte(port, input);
      	//audio input
      		memcpy(
      			gInBuf + n * gLibpdBlockSize,
      	// analog input
      		memcpy(
      	// multiplexed analog input
      	if(pdMultiplexerActive)
      	unsigned int j;
      	unsigned int k;
      	float* p0;
      	float* p1;
      	// digital input
      	if(gDigitalEnabled)
      		// digital in at message-rate
      		// digital in at signal-rate
      	// digital outputs
      	if(gDigitalEnabled)
      		// digital out at signal-rate
      	// scope output
      			gScopeOut[k] = *p1;
      	 *  MODIFICATION
      	 *  MPR121 Stuff
      	// Keep this code: it schedules the touch sensor readings
      	if(++readCount >= readIntervalSamples) {
      		readCount = 0;
      		Bela_scheduleAuxiliaryTask(i2cTask);
      	// audio output
      		memcpy(
      	//analog output
      		memcpy(
      	for(auto a : midi)
      		delete a;
      	libpd_closefile(gPatch);
      	delete [] gScopeOut;
      // Auxiliary task to read the I2C board
                  sensorValue[i] = 0;
      #ifdef DEBUG_MPR121
      #endif
      #ifdef DEBUG_MPR121
          rt_printf("\n");
      #endif
      2 months later
      Awesome! I've just seen this now, sorry, but thanks both for fixing stuff. I'll update my code when I get a chance to.
      8 months later
      Greetings. is anybody else having a serious lag on the responsiveness using this render.cpp? tried rearranging and loosing extra baggage, yet i has not helped at all. The capSense example is of course flawless. Is it possible to get the same responsiveness when generating sound in pd, using the mpr121 readings? Thanks.
        eccot are you using heavy compiled pd patches or standard pd files? the latter has some latency inherent since it is not compiled code.
          lokki are you using heavy compiled pd patches or standard pd files? the latter has some latency inherent since it is not compiled code.
          There is no inherent latency in Pd (I mean, yes, the minimum block size we set is 16 samples per block), but there should be intrinsic latency when reading these sensors. However, if the CPU usage of the audio thread (or of the Scope) is fairly high, then the sensor readings will come in less often, and this could be the cause of the latency you perceive.
          So, what is the CPU usage of the patch, as displayed by the IDE? If it's above 50%, try closing the Scope tab, if it's open, and see if that improves the situation.
            giuliomoro There is no inherent latency in Pd
            sorry my bad. i was under the impression that pd patches run with higher latency.
            2 years later
            Hello, guys! I want to follow up on this thread!
            I'm using all the files form dywen (thank you so much!) to establish connection between MPR and PD patch.
            Everything works the way I need. However, I'm experiencing some sort of latency. When I'm pressing my touch points one by one, the sound only happens with an interval of about half a second. Basically I can't play anything fast.
            Is this limitation written in code? (unfortunately I don't know how to read it)
            I tried to change block size, it didn't do anything...
            Here is my PD patch and the picture of touch panel
            https://github.com/basswoman/bela
            Thank you for your help!
              this looks nice https://github.com/basswoman/bela/blob/main/image%20of%20touch%20panel.png !
              basswoman Is this limitation written in code? (unfortunately I don't know how to read it)
              As far as I can see from the C++ code, the sensor is read every 25ms (or as fast as possible if it actually takes more than that) and the data is sent to Pd immediately after that, so I'd suspect any additional latency to come from the Pd patch itself, although it is not immediate for me to see where that would happen. I would encourage you to try out the C++ example on Bela: Sensors/MPR121 and see if you notice a similar latency there.
              2 years later
              Hello everyone, I'm trying according to the file uploaded by dywen in 2018, but because I'm a novice in programming, the following errors have occurred in Bela ide. The first few errors can be replaced directly. I don't know how to solve this later? Thank you!
                Thank you for your reply.It's this link.
                Later on, I saw the MPR121 example in Bela that you mentioned earlier. After I connected the copper board, although I didn't understand C++very well, at least it made a sound......
