giuliomoro I meant exactly: are you still sending to it from the other thread (that is, readMPR121()).
There are three instances for readMPR121() - I see no doubles
For documentation::
-- line 77 says --internal stuff -- do not change
// ---- internal stuff -- do not change -----
I2C_MPR121 mpr121; // Object to handle MPR121 sensing
AuxiliaryTask i2cTask; // Auxiliary task to read I2C
int readCount = 0; // How long until we read again...
int readIntervalSamples = 0; // How many samples between reads
void readMPR121(void*);
-- line 389 - To have the data via i2c
i2cTask = Bela_createAuxiliaryTask(readMPR121, 50, "bela-mpr121");
-- line 776 - to connect NUM_TOUCH_PINS to sensorValue - so Pure Data can receive these values
for(int i = 0; i < NUM_TOUCH_PINS; i++) {
sensorValue[i] = -(mpr121.filteredData(i) - mpr121.baselineData(i));
sensorValue[i] -= threshold;
if(sensorValue[i] < 0)
sensorValue[i] = 0;
-- Full render.cpp as it is now
____ _____ _ _
| __ )| ____| | / \
| _ \| _| | | / _ \
| |_) | |___| |___ / ___ \
|____/|_____|_____/_/ \_\
http://bela.io
A project of the Augmented Instruments Laboratory within the
Centre for Digital Music at Queen Mary University of London.
http://www.eecs.qmul.ac.uk/~andrewm
(c) 2016 Augmented Instruments Laboratory: Andrew McPherson,
Astrid Bin, Liam Donovan, Christian Heinrichs, Robert Jack,
Giulio Moro, Laurel Pardue, Victor Zappi. All rights reserved.
The Bela software is distributed under the GNU Lesser General Public License
(LGPL 3.0), available here: https://www.gnu.org/licenses/lgpl-3.0.txt
* USING A CUSTOM RENDER.CPP FILE FOR PUREDATA PATCHES - LIBPD
* || OPEN THE ENCLOSED _main.pd PATCH FOR MORE INFORMATION ||
#include <cmath>
#include <stdio.h>
#include <libpd/z_libpd.h>
extern "C" {
#include <libpd/s_stuff.h>
#include <UdpServer.h>
#include <Midi.h>
#include <Scope.h>
#include <string>
#include <sstream>
#include "I2C_MPR121.h"
settings->interleave = 0;
* MODIFICATION
* MPR121 Stuff
// How many pins there are
#define NUM_TOUCH_PINS 12
// Define this to print data to terminal - function prints data from sensor
#define DEBUG_MPR121
// Change this to change how often the MPR121 is read (in Hz)
int readInterval = 50;
// Change this threshold to set the minimum amount of touch
int threshold = 40;
// This array holds the continuous sensor values
int sensorValue[NUM_TOUCH_PINS];
float* gInBuf;
float* gOutBuf;
#define PARSE_MIDI
void dumpMidi()
if(midi.size() == 0)
return;
"Num",
"Name",
"In",
"Out",
"Pd channels"
n,
gMidiPortNames[n].c_str(),
n * 16 + 1,
n * 16 + 16
Midi* newMidi;
newMidi = new Midi();
#ifdef PARSE_MIDI
newMidi->enableParser(true);
#else
newMidi->enableParser(false);
#endif /* PARSE_MIDI */
if(verboseSuccess)
if(newMidi->isInputEnabled())
if(verboseSuccess)
if(verboseError)
fprintf(stderr, "Failed to open MIDI device %s\n", name.c_str());
return nullptr;
} else {
return newMidi;
unsigned int port = 0;
while(*channel > 16){
*channel -= 16;
port += 1;
if(port >= midi.size()){
// if the port number exceeds the number of ports available, send out
// of the first port
port = 0;
return port;
midi[port]->writeNoteOn(channel, pitch, velocity);
midi[port]->writeControlChange(channel, controller, value);
midi[port]->writeProgramChange(channel, program);
midi[port]->writePitchBend(channel, value);
midi[port]->writeChannelPressure(channel, pressure);
midi[port]->writePolyphonicKeyPressure(channel, pitch, pressure);
if(port > (int)midi.size()){
port = 0;
midi[port]->writeOutput(byte);
rt_printf("%s", received);
libpd_float((char*)receiverName, (float)state);
// rt_printf("%s: %d\n", (char*)receiverName, state);
#define LIBPD_DIGITAL_OFFSET 11 // digitals are preceded by 2 audio and 8 analogs (even if using a different number of analogs)
if(strcmp(source, "bela_setMidi") == 0){
int num[3] = {0, 0, 0};
if(!libpd_is_float(&argv[n]))
fprintf(stderr, "Wrong format for Bela_setMidi, expected:[hw 1 0 0(");
return;
if(newMidi)
midi.push_back(newMidi);
dumpMidi();
return;
bool disable = false;
direction = INPUT;
direction = OUTPUT;
disable = true;
} else {
return;
if(argc == 0){
return;
return;
int channel = libpd_get_float(&argv[0]) - LIBPD_DIGITAL_OFFSET;
if(disable == true){
dcm.unmanage(channel);
return;
if(argc >= 2){
t_atom* a = &argv[1];
if(libpd_is_symbol(a)){
char *s = libpd_get_symbol(a);
if(strcmp(s, "~") == 0 || strncmp(s, "sig", 3) == 0){
isMessageRate = false;
return;
* MODIFICATION
* Empty
// the built-in digital receivers are of the form "bela_digitalOutXX" where XX is between 11 and 26
unsigned int channel = receiver - 11; // go back to the actual Bela digital channel number
if(channel < 16){ //16 is the hardcoded value for the number of digital channels
dcm.setValue(channel, value);
char receiverNames[16][21]={
{"bela_digitalIn11"},{"bela_digitalIn12"},{"bela_digitalIn13"},{"bela_digitalIn14"},{"bela_digitalIn15"},
{"bela_digitalIn16"},{"bela_digitalIn17"},{"bela_digitalIn18"},{"bela_digitalIn19"},{"bela_digitalIn20"},
{"bela_digitalIn21"},{"bela_digitalIn22"},{"bela_digitalIn23"},{"bela_digitalIn24"},{"bela_digitalIn25"},
{"bela_digitalIn26"}
// 2 audio + (up to)8 analog + (up to) 16 digital + 4 scope outputs
static const unsigned int gChannelsInUse = 30;
static const unsigned int gFirstAnalogInChannel = 2;
static const unsigned int gFirstAnalogOutChannel = 2;
static const unsigned int gFirstDigitalChannel = 10;
static const unsigned int gFirstScopeChannel = 26;
#ifdef PD_THREADED_IO
void fdLoop(void* arg){
t_pdinstance* pd_that = (t_pdinstance*)arg;
while(!gShouldStop){
sys_doio(pd_that);
usleep(3000);
#endif /* PD_THREADED_IO */
Scope scope;
unsigned int gScopeChannelsInUse = 4;
float* gScopeOut;
void* gPatch;
bool gDigitalEnabled = 0;
// Check Pd's version
int major, minor, bugfix;
return false;
return false;
gDigitalEnabled = 1;
* MODIFICATION
* MPR121 Stuff
if(!mpr121.begin(1, 0x5A)) {
rt_printf("Error initialising MPR121\n");
return false;
readIntervalSamples = context->audioSampleRate / readInterval;
char file[] = "_main.pd";
char folder[] = "./";
return false;
free(str);
if(context->analogInChannels > 8 || context->analogOutChannels > 8)
fprintf(stderr, "This project can run with a maximum of 8 analog channels\n");
// change LIBPD_DIGITAL_OFFSET if you want more
return false;
// analog setup
// digital setup
if(gDigitalEnabled)
if(context->digitalChannels > 0){
for(unsigned int ch = 0; ch < context->digitalChannels; ++ch){
dcm.setCallbackArgument(ch, receiverNames[ch]);
for(unsigned int n = 0; n < gMidiPortNames.size(); ++n)
unsigned int n = 0;
if(newMidi)
++n;
} else {
dumpMidi();
return false;
libpd_init();
gInBuf = get_sys_soundin();
gOutBuf = get_sys_soundout();
// Bind your receivers here
libpd_bind("bela_digitalOut11");
libpd_bind("bela_digitalOut12");
libpd_bind("bela_digitalOut13");
libpd_bind("bela_digitalOut14");
libpd_bind("bela_digitalOut15");
libpd_bind("bela_digitalOut16");
libpd_bind("bela_digitalOut17");
libpd_bind("bela_digitalOut18");
libpd_bind("bela_digitalOut19");
libpd_bind("bela_digitalOut20");
libpd_bind("bela_digitalOut21");
libpd_bind("bela_digitalOut22");
libpd_bind("bela_digitalOut23");
libpd_bind("bela_digitalOut24");
libpd_bind("bela_digitalOut25");
libpd_bind("bela_digitalOut26");
libpd_bind("bela_setMidi");
* MODIFICATION
* Empty
// open patch:
if(gPatch == NULL){
return false;
pdMultiplexerActive = true;
libpd_start_message(1);
sys_dontmanageio(1);
AuxiliaryTask fdTask;
fdTask = Bela_createAuxiliaryTask(fdLoop, 50, "libpd-fdTask", (void*)pd_this);
int num;
libpd_start_message(8);
for(int n = 0; n < 8; ++n)
libpd_add_float(sensorValue[n]);
libpd_finish_list("sensorValue");
#ifdef PARSE_MIDI
switch(message.getType()){
case kmmNoteOn:
break;
case kmmNoteOff:
* with a velocity of 0.
break;
case kmmControlChange:
break;
case kmmProgramChange:
break;
break;
case kmmChannelPressure:
break;
case kmmPitchBend:
int value = ((message.getDataByte(1) << 7)| message.getDataByte(0)) - 8192;
break;
case kmmSystem:
int byte = channel | status;
break;
case kmmNone:
case kmmAny:
break;
#else
int input;
libpd_midibyte(port, input);
//audio input
memcpy(
gInBuf + n * gLibpdBlockSize,
// analog input
memcpy(
// multiplexed analog input
if(pdMultiplexerActive)
unsigned int j;
unsigned int k;
float* p0;
float* p1;
// digital input
if(gDigitalEnabled)
// digital in at message-rate
// digital in at signal-rate
// digital outputs
if(gDigitalEnabled)
// digital out at signal-rate
// scope output
gScopeOut[k] = *p1;
* MODIFICATION
* MPR121 Stuff
// Keep this code: it schedules the touch sensor readings
if(++readCount >= readIntervalSamples) {
readCount = 0;
Bela_scheduleAuxiliaryTask(i2cTask);
// audio output
memcpy(
//analog output
memcpy(
for(auto a : midi)
delete a;
libpd_closefile(gPatch);
delete [] gScopeOut;
// Auxiliary task to read the I2C board
sensorValue[i] = 0;
#ifdef DEBUG_MPR121
rt_printf("%d ", sensorValue[i]); //prints the values of the sensor when DEBUG_MPR121 is define at beginning of programme
#endif
#ifdef DEBUG_MPR121
rt_printf("\n");
#endif
// You can use this to read binary on/off touch state more easily
//rt_printf("Touched: %x\n", mpr121.touched());
