giuliomoro cool, willook into it. so you think autotune will work with that (probably fft for pitch estimation etc)?
    unfortunately, i cannot install all missing files, i get this if i run apt-get install:
    Err:1 http://cdn-fastly.deb.debian.org/debian stretch/main armhf libpng16-16 armhf 1.6.28-1
      404  Not Found [IP: 151.101.112.204 80]
    Err:2 http://cdn-fastly.deb.debian.org/debian stretch/main armhf libtiff5 armhf 4.0.8-2+deb9u2
    Err:3 http://cdn-fastly.deb.debian.org/debian stretch/main armhf libcups2 armhf 2.2.1-8+deb9u1
    Err:4 http://cdn-fastly.deb.debian.org/debian stretch/main armhf libxcursor1 armhf 1:1.1.14-1+deb9u1
    Err:5 http://cdn-fastly.deb.debian.org/debian stretch/main armhf libx11-xcb1 armhf 2:1.6.4-3
    Err:6 http://cdn-fastly.deb.debian.org/debian stretch/main armhf libjs-jquery all 3.1.1-2
    one of the apt suggestions is to do an apt get-update, but i am a bit hesitant, will this break anything on the bela side?
      lokki one of the apt suggestions is to do an apt get-update, but i am a bit hesitant, will this break anything on the bela side?
      apt-get update will only update the URLs that will be used to try and install the packages with apt-get install. It will not update any of the already installed packages, as far as I understand. Definitely try that.
      lokki so you think autotune will work with that (probably fft for pitch estimation etc)?
      This is a minimal host. While several plugins work with it, there are some features that are not implemented. I don't even know which ones they are, but I believe that lv2 allows for a "worker thread" to perform computation off of the audio thread. If your plugin uses FFT, you'd hope they'd be running off the audio thread, so maybe that feature is required. The only thing to do is try it out, it should fail at runtime if not all the required features are implemented by the host. You can also try and look up the docs for your plugin and see what features it requires.
      ok, that worked! thank you. i now have the example working. looking at it, i don't quite get, where i would put the plugin name in to test if mine works, all i see in render.cpp (and some of the other files i checked) is a URL mention of the plugins that it loads. so not sure where i would put in my plugin there.
      but, first things first, here is the GitHub of the autotune plugin:
      https://github.com/x42/fat1.lv2
      when i try to compile it on the BELA it drops a lot of missing library errors. i was able to install quite a few but i need a libpango-dev as well, i guess this is named differently on the BBB/Bela. any ideas?
      also, actually i would not need to compile all the graphics stuff of the plugin, but for the moment i am not sure how to do that...
        lokki URL mention of the plugins that it loads. so not sure where i would put in my plugin there.
        That's how it works with lv2: use lv2ls from the command line to retrieve the URI of the plugin and put it in there.
        lokki guess this is named differently on the BBB/Bela. any ideas
        The Bela distro is just regular Debian Stretch, nothing special about it. I don't know about this particular library though.
        lokki , actually i would not need to compile all the graphics stuff of the plugin, but for the moment i am not sure how to do that...
        That's usually the best solution. The plugin developer may have made available a flag to pass to the build system to avoid building the GUI. If reading the docs doesn't help then maybe inspecting the Makefile will
        ok, got that sorted out, compiles fine now and i have also found a arm-hf version on the x42-plugins site that should work :-)
        on to the next question, where do i set my plugin to be inserted into the lv2host? those URLs can't be it...
          sorry x-post. will try your advice, thanks!
          lokki ok, got that sorted out, compiles fine now and i have also found a arm-hf version on the x42-plugins site that should work :-)
          Good. Looking at the Makefile it looks like you can pass MOD=1 to make to disable the gui and standalone jack app.
          lokki those URLs can't be it...
          Yes! See above
          hmm, i get this:
          Port 0 has unsupported type
          Fat1.lv2 error: Host does not support urid:map
          error: Unable to instantiate plugin `http://gareus.org/oss/lv2/fat1'
          Segmentation fault
          Missing feature of the host. I will need to have a look. It seems that it is only used for performance reason, so maybe it is optional and there is a way to disable it in the plugin?
          no it doesn't look like it can be disabled, and it is required. Maybe some simple changes to the code of the plugin would fix that. But it's definitely easier and better to implement the feature on the host!
            maybe the host on the modduo devices could be used? that seems to support it.
            the sysmap.c file they have is where the mapping is implemented. This, in turn, is taken from jalv. I will see how to include it in our stuff.
              giuliomoro is the plan to amend the missing features to the new host or will you try to revive your jalv-port since that would probably be easier to integrate there? let me know if/when i can test something. thanks!
              I will try to have a look at adding the feature to our host next week. jalv should still build, although maybe it needs a couple of paths changed. The downside with jalv is that it is a single-plugin host.
                giuliomoro i see. thanks for the heads up! the modduo version is multi plugin as well, ir they load several instances...
                4 days later
                ok i have a go at compiling jalv on current bela. i could try then the plugin and see if it does even run on BELA. if not, no need to work on the new LV2host...
                as you said some libraries are missing but i think i fixed the paths. (i had to manually include Midi_c.h in the src directory, because it was not found otherwise.) i now get this error on ./waf build:
                [ 1/11] Compiling src/bela.c
                ../src/bela.c:41:1: error: unknown type name 'Midi'
                 Midi* midi;
                ../src/bela.c: In function 'render':
                ../src/bela.c:110:31: warning: implicit declaration of function 'Midi_availableMessages' [-Wimplicit-function-declaration]
                   if((availableMidiMessages = Midi_availableMessages(midi)) > 0)
                ../src/bela.c:136:27: warning: implicit declaration of function 'Midi_getMessage' [-Wimplicit-function-declaration]
                      unsigned char size = Midi_getMessage(midi, buf);
                ../src/bela.c: In function 'setup':
                ../src/bela.c:227:10: warning: implicit declaration of function 'Midi_new' [-Wimplicit-function-declaration]
                   midi = Midi_new(gMidiPort0);
                ../src/bela.c:227:8: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
                ../src/bela.c: In function 'cleanup':
                ../src/bela.c:260:3: warning: implicit declaration of function 'Midi_delete' [-Wimplicit-function-declaration]
                   Midi_delete(midi);
                  lokki that's a weird failure, as if Midi_c.h was empty. Is the #include still in place in src/bela.c ?
                    giuliomoro i think so. playing a concert now, will check later. can i include a Midi_c.h from within the BELA image? i couldn't find it and included one from the bela doc wiki (found via google)
