david and I am spending too much time trying(
I know right!
david I get the impression that PCs are more robust with Bela perhaps?
Not that I am aware of...
david Sorry should have indicated that it simply worked at some point without recourse to this.
Is there still a program running on boot? If yes, I strongly recommend you follow the instructions above.
When you get the BELABOOT drive on your mac, can you open it and oepn the file "bela.version" with textedit? What is the version number reported in there?
Today it is not working on either computer so I looked at those instructions - my Bela is incorporated in a case with a number of connectors. A number of pins are mentioned to be grounded but I do not see them listed on the pin diagram (https://learn.bela.io/pin-diagram/). Where is the BELABOOT drive?
    I have just tried with a brand new Bela board out of the box and it give the same error
    'This site can’t be reached
    bela.local’s server IP address could not be found.'
    Does this still suggest I need to go through the process above?
      david I have just tried with a brand new Bela board out of the box
      good try!
      david Does this still suggest I need to go through the process above?
      First we need to figure out whether you are running a version of the Bela image that is compatible with your very new OS. That information is in bela.version in BELABOOT.
      david Where is the BELABOOT drive?
      It should show up on your desktop or inside the /Volumes folder. You can see the content of bela.version after the board is connected to your computer by running:
      in the terminal.
      OK tried this and it returned:
      dmh8@Davids-Air-10 ~ % cat /Volumes/BELABOOT/bela.version
      BELA_IMAGE_VERSION=""
      Not sure what to make of that!
      Right, that's an old version so I think you need a newer image than the one you currently have in order to support Monterey.
      Just to confirm this is the case, could you please show the output of running ifconfig on your terminal?
      This is what I got:
      dmh8@Davids-Air-10 ~ % ifconfig
      inet6 ::1 prefixlen 128
      stf0: flags=0<> mtu 1280
      options=400<CHANNEL_IO>
      ether d0:81:7a:ac:9b:e0
      inet6 fe80::18e9:45e4:1756:9f5b%en0 prefixlen 64 secured scopeid 0x4
      inet 192.168.8.106 netmask 0xffffff00 broadcast 192.168.8.255
      inet6 fda8:e544:6171:4300:1806:6fe3:d011:14e1 prefixlen 64 autoconf secured
      media: autoselect
      status: active
      ether 82:18:47:e5:fa:00
      status: inactive
      bridge0: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
      Configuration:
      ipfilter disabled flags 0x0
      ifmaxaddr 0 port 5 priority 0 path cost 0
      media: <unknown type>
      status: inactive
      ether 02:81:7a:ac:9b:e0
      media: autoselect
      status: inactive
      ether ea:54:0d:0f:1b:34
      inet6 fe80::e854:dff:fe0f:1b34%awdl0 prefixlen 64 scopeid 0x8
      media: autoselect
      status: active
      inet6 fe80::e854:dff:fe0f:1b34%llw0 prefixlen 64 scopeid 0x9
      media: autoselect
      status: active
      inet6 fe80::f6c0:1246:8e03:2edd%utun0 prefixlen 64 scopeid 0xa
      inet6 fe80::10af:d46d:1a97:c522%utun1 prefixlen 64 scopeid 0xb
      inet6 fe80::ce81:b1c:bd2c:69e%utun2 prefixlen 64 scopeid 0xc
      utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1400
      en9: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
      ether be:1a:b7:96:bd:1c
      media: autoselect (none)
      status: inactive
      Let's get in touch via email and organise a zoom session like the one from 2 years ago so we can solve this more readily
      OK that sounds good. Would anytime on Monday work?
      2 years later
      Hi again. My last login issue simply resolved itself(!) and I am up and running again. Question: I work in Pd and have 64 oscillators working OK but when I try 72 it makes odd sounds (not sinewaves) on its own. Could this be asking too much for real-time operation?
        Sorry should have indicated this is on a Bela Beast.
        david K but when I try 72 it makes odd sounds (not sinewaves) on its own. Could this be asking too much for real-time operation?
        It could be, though it should be accompanied by dropout errors printed in the console. Try adding --high-performance-mode to the "User Command Line Arguments:" textbox in the settings tab to get some % of extra CPU. Note that when that's enabled - and exploited - you'll most likely need to press the button on the cape to stop the running program.
        Thanks, I shall try this.
