csounder 1. You might need to add a ksmps = 16 or ksmps = 8 to your 0-hello.world example.
Will do yes. Haven't touched the examples yet, actually I meant to ask you if you wanted to provide some that would work out of the box, to improve and enrich our currently scarce portfolio.
csounder - I know how to install into individual projects, but I am wondering how to install/update for all projects
(searching the forum now for advice on this)
The method I previously explained (drag on the IDE, and run in the console dpkg -i PROJECTNAME/*.deb actually installs the package globally.
    There might be an issue with audio in.
    - an instrument that previously worked with real-time audio input (coming from a mic in a mixer, for example),
    does not seem to be working now with Csound 6.15 V2
    • I have tried setting it with the -iadc commandline input flag (previously not necessary), and it still does not work.
      I will attach several .csd files for you to use in your tests.
      csounder - an instrument that previously worked with real-time audio input (coming from a mic in a mixer, for example),
      wow! who knows what I did there
      csounder I will attach several .csd files for you to use in your tests.
      thanks, looking forward to this
      giuliomoro Thanks! I have been doing this, and in the console, it does report that things are being unzipped, but then the previously working MIDI instruments are not working now. WAIT! I think I have it...
      In the past, (probably because it was using other MIDI drivers?), in the command-line, it was recommended that one set the following defaults:
      -Mhw:1,0,0 -+rtmidi=NULL --daemon -dm0
      it turns out that you do NOT want to set -+rtmidi=NULL any longer
      Once that is removed, all my previously running MIDI instruments are working AND...
      I am very happy to report that you are now supporting the connecting of multiple MIDI devices
      - I have a USB hub plugged into the Bela MINI
      - I have a Novation LaunchPad mini Mk3 PLUS a Korg NanoKontrol plugged into the hub
      - I am running my MIDI .csd with the following command-line arguments
      -Mhw:1,0,0 -Ma --daemon -dm0
      And both controllers are playing and controlling the instrument! (WONDERFUL)
      • You might need to make changes to the Csound examples, as I suggested to you previously
        using this as a default header for the .csd files
      sr = 44100
      ksmps = 16
      nchnls = 2
      0dbfs = 1
      and for MIDI instruments:
      Now to get to the bottom of why the audio input is not working on previous .csd files.
      - any suggestions about what might have changed, or what might now be required.
        csounder You might need to make changes to the Csound examples, as I suggested to you previously
        will do once the release is ready.
        csounder - any suggestions about what might have changed, or what might now be required.
        nothing as far as I know 🙁 send me an example passthrough patch and I can have a look
        When I comment out the RtMIDI=NULL from the 4-MIDI example, it runs, but...
        there are a lot of little clicks now (possibly data-lates as Barry Vercoe used to call them?)
        and the console does report a lot of dropouts and mode switches (which might explain the clicks)
        rtevent: T 12.251 TT 12.251 M: 0.06069 0.08127
        rtevent: T 12.263 TT 12.263 M: 0.04022 0.04759
        35608 mode switches detected on the audio thread.
        38370 mode switches detected on the audio thread.
        41137 mode switches detected on the audio thread.
        backtrace() returned 0 addresses
        Csound tidy up: Terminated
        make: *** [runide] Terminated
        inactive allocs returned to freespace
        end of score. overall amps: 0.15828 0.15978
        overall samples out of range: 0 0
        0 errors in performance
        Elapsed time at end of performance: real: 16.050s, CPU: 7.453s
        Bela stopped
        root@bela ~/Bela#
        I am using the following sample rate and krate settings
        sr = 44100
        ksmps = 8. or ksmps = 16
        nchnls = 2
        0dbfs = 1
        I see. Mode switches are happening.
        Was this not happening in the script you previously mentioned was working fine? If that's the case, could you send me the well behaving script?
          giuliomoro There were almost always "some" mode switches and dropped blocks, but never this many and never these little cricket clicks. I will send you a few files to test. Working on them now.
          sounds like this is not a viable solution then, and I may have to revert to the previous one. Can you send me some example code that uses multiple MIDI devices? Then I can figure out how to make it work with the "Bela" MIDI API.
            giuliomoroRunning multiple MIDI devices is not a top priority, but it would be nice to connect a hub to the bela and just use any of the controllers that one has connected.
            The strange thing now, is that realtime audio in does not work with the latest bela2 (it could be connected perhaps?)
            - and so, this might not be portMIDI related.
            in the examples, the audio loopback still works, but none of my 50+ audio examples work any longer
            - and the console does not report any issues.
            As a test example, you could just use the previous example with the 'ins' opcode
            - this works on the laptop and this worked previously
            I tried forcing the comandline with a -iadc and -odac and --realtime and --daemon, but this made no difference.
            <CsoundSynthesizer>
            <CsOptions>
            </CsOptions>
            <CsInstruments>
            sr       = 44100
            ksmps    = 16
            nchnls   = 2
            0dbfs    = 1
            instr    1 ; Stereo delay with normal and cross-feedback
            ilevl    = p4      ; Output level
            idelay1  = p5/1000 ; L delay in ms
            idelay2  = p6/1000 ; R delay in ms
            ifdbk1   = p7      ; L feedback
            ifdbk2   = p8      ; R feedback
            ifdbkx   = p9      ; X Feedback
            ifreq1   = p10     ; L cutoff
            ifreq2   = p11     ; R cutoff
            imix     = p12     ; Mix: 0=Dry 1=Delay
            afdbk1   init 0
            afdbk2   init 0
            ainL, ainR ins
            ain = ainL+ainR
            ;ain      soundin  "sp_hellorcb.aif"   ; Does NOT work on Bela
            ;ain     diskin "sp_hellorcb.aif", 1    ; WORKS on Bela
            ain1     = ain + afdbk1*ifdbk1 + afdbk2*ifdbkx
            ain2     = ain + afdbk2*ifdbk2 + afdbk1*ifdbkx
            adelay1  delay  ain1, idelay1
            adelay2  delay  ain2, idelay2
            adelay1  butterlp  adelay1, ifreq1
            adelay2  butterlp  adelay2, ifreq2
            afdbk1   = adelay1
            afdbk2   = adelay2
            aout1    = adelay1*imix + ain*(1 - imix)
            aout2    = adelay2*imix + ain*(1 - imix)
            outs1    aout1*ilevl
            outs2    aout2*ilevl
            endin
            </CsInstruments>
            <CsScore>
            ;Delay in ms, Filt in Hz. Total feedback should be <1?
            ;   Strt  Leng   Levl  DelyL DelyR FeedL FeedR XFeed FiltL FiltR Mix
            i1  0.00  10.00  1.00  500   400   0.40  0.40  0.40  2500  2500  0.50
            e
            </CsScore>
            </CsoundSynthesizer>
              csounder As a test example, you could just use the previous example with the 'ins' opcode
              which one please? I am not sure I understand which one you are referring to.
              In the meantime, you can try 6.15-bela3 release:
              • restores MIDI functionality (or at least it should, let me know)
              • adds support for Trill Craft. You have to specify 30 "touches", and the touch size for each will be the reading from each individual pad ( I think -- completely untested)
                giuliomoro I will try the latest version, and solder up my Trill Crafts for those tests too!
                Here is a working MIDI .csd, in the CsOptions section, you will see command lines for:
                previous Bela 6.15 (with no multiple MIDI support, but excellent MIDI)
                Bela 6.15 v2 (with multiple MIDI support, working!... but many Mode switches and Dropped blocks)
                the command line settings I use on the Mac, to run Csound with multiple MIDI devices in the terminal
                As you will see from the .csd below, it is reading MIDI CCs 1-9 (typically from my nanoControl)
                <CsoundSynthesizer>
                <CsOptions>
                ;-Mhw:1,0,0 -+rtmidi=NULL --daemon -dm0 ; Bela 6.15 v1
                ;-Mhw:1,0,0 --daemon -dm0 ; Bela 6.15 v2
                -Mhw:1,0,0 -Ma --daemon -dm0 ; Bela 6.15 v2 (multiple MIDI devices)
                ;csound -+rtaudio=pa_cb -iadc1 -odac1 -+rtmidi=portmidi -Ma --env:CSNOSTOP=yes ; Mac commandline
                </CsOptions>
                <CsInstruments>
                sr		= 44100
                ksmps	= 16
                nchnls	= 2
                0dbfs	= 1
                gaRvb	init 0
                ctrlinit	1,   1,100, 2,0, 3,0, 4,64, 5,1, 6,10, 7,100, 8,10, 9,76
                		instr	1
                icps	cpsmidi
                iamp	ampmidi .5
                kamp	midic7 1, 0,1
                kamp	port 	kamp,.1
                kcar	midic7 2, 1,4
                kcar	port 	kcar,.01
                kmod	midic7 3, 1,10
                kmod	port 	kmod,.01
                kindx	midic7 4, 1,13
                kindx	port	kindx,.01
                iatk	midic7 5, .001,1
                idec	midic7 6, .01,1
                isus	midic7 7, 0,1
                irel	midic7 8, .01,2
                kWet	midic7 9, 0,1
                asig	foscil	kamp*iamp, icps, kcar, 1+(kmod), kindx, 1
                kmgate	mxadsr	iatk, idec, isus, irel
                aDry	=	asig * kmgate
                		vincr 	gaRvb, aDry * kWet
                		outs		aDry, aDry
                		endin
                		instr 99
                		denorm	gaRvb
                awetL,awetR freeverb gaRvb, gaRvb, .9, .5
                		outs awetL, awetR
                		clear gaRvb
                		endin
                </CsInstruments>
                <CsScore>
                f1	0	16384	10	1
                i 1  0 z
                i 99 0 z
                </CsScore>
                giuliomoro to test and see/hear if realtime audio in is working again, you would use the version of the stereo-delay instrument that includes the two uncommented lines (and plug in your iPhone or a Microphone):
                ainL, ainR ins
                ain = ainL+ainR
                to test if the soundin opcode is working, you need to add your own mono sample to the project and uncomment
                the ain line with the soundin opcode.
                ;ain soundin "sp_hellorcb.aif" ; Does NOT work on Bela.
                • you should replace "sp_hellorcb.aif" with the name of your uploaded mono sample.
                  It can be either a wave or aiff - for instance
                ain soundin "sp_hellogiulio.wav"
                and if instead, you were to uncomment the line using diskin opcode, you will hear/see that it does work
                I will try your latest build now.
                Best,
                -dB
                  giuliomoro I would love to provide several additional example instruments that would show additional ways of working with the Bela and Csound - and that sound great too! I will pull them together and you can see which you might like to include.
                  giuliomoro I am trying the 6.15-bela3 release now.
                  Are these the messages that you would expect to appear in my terminal when updating?
                  apt install ~/Bela/projects/updateCsound/csound-6.0.0-Linux-bela3.deb
                  Reading package lists... Done
                  Building dependency tree
                  Reading state information... Done
                  Note, selecting 'csound:amd64' instead of '/root/Bela/projects/updateCsound/csound-6.0.0-Linux-bela3.deb'
                  The following packages will be REMOVED:
                  csound
                  The following NEW packages will be installed:
                  csound:amd64
                  0 upgraded, 1 newly installed, 1 to remove and 0 not upgraded.
                  Need to get 0 B/7531 kB of archives.
                  After this operation, 1024 B of additional disk space will be used.
                  Do you want to continue? [Y/n] Y
                  Get:1 /root/Bela/projects/updateCsound/csound-6.0.0-Linux-bela3.deb csound amd64 6.0.0 [7531 kB]
                  perl: warning: Setting locale failed.
                  perl: warning: Please check that your locale settings:
                  LANGUAGE = (unset),
                  LC_ALL = (unset),
                  LANG = "en_US.UTF-8"
                  are supported and installed on your system.
                  perl: warning: Falling back to the standard locale ("C").
                  locale: Cannot set LC_CTYPE to default locale: No such file or directory
                  locale: Cannot set LC_MESSAGES to default locale: No such file or directory
                  locale: Cannot set LC_ALL to default locale: No such file or directory
                  dpkg: error processing archive /root/Bela/projects/updateCsound/csound-6.0.0-Linux-bela3.deb (--unpack):
                  package architecture (amd64) does not match system (armhf)
                  E: Sub-process /usr/bin/dpkg returned an error code (1)
                  root@bela:~#
                    giuliomoro 6.15-bela3 release - initial test
                    1. not sure it was installed correctly? sorry
                    2. as I noted previously, in 6.15-bela2, realtime audio-in does not work so...
                      2a. I rolled back to 6.15-bela1, and... realtime audio-in WORKS (yes!) - in this version, and also...
                      2b. To my surprise, multiple MIDI inputs WORK with this older version (?)
                    with the following command line in the csOptions:
                    -Mhw:1,0,0 -Ma --daemon ; -dm0
                    The console still reports a lot of dropouts and a lot of ModeSwitch changes, but not as many as in 6.15 v2
                    Building project ...
                    Build finished
                    Running project ...
                    0"058.644| WARNING: [main] duplicate call from main program to xenomai_init() ignored
                    0"058.939| WARNING: [main] (xeno-config --no-auto-init disables implicit call)
                    0dBFS level = 32768.0
                    --Csound version 6.15 (float samples) Oct 15 2020
                    [commit: c329d91b2527e96f05ecb47837e2bfd3b68f5be7]
                    libsndfile-1.0.27
                    Device type: Bar (1)
                    Address: 0x20
                    Firmware version: 2
                    Device type: Square (2)
                    Address: 0x28
                    Firmware version: 2
                    Device type: Ring (4)
                    Address: 0x38
                    Firmware version: 2
                    Device type: Hex (5)
                    Address: 0x40
                    Firmware version: 2
                    realtime mode enabled
                    WARNING: [mcould not open library '/usr/lib/csound/plugins-6.0/libfluidOpcodes.so' (libfluidsynth.so.1: cannot open shared object file: No such file or directory)
                    WARNING: could not open library '/usr/lib/csound/plugins-6.0/libosc.so' (liblo.so.7: cannot open shared object file: No such file or directory)[m
                    [mUnifiedCSD: /root/Bela/projects/Oct25/MIDI-FMcc1-8.csd
                    STARTING FILE
                    Creating options
                    Creating orchestra
                    closing tag
                    Creating score
                    rtmidi: ALSA Raw MIDI module enabled
                    sorting score ...
                    ... done
                    setting dummy interface
                    midi channel 1 using instr 1
                    midi channel 2 using instr 1
                    midi channel 63 using instr 1
                    midi channel 64 using instr 1
                    displays suppressed
                    0dBFS level = 1.0
                    ALSA midi: Using all devices.
                    ALSA: opened MIDI input device 'hw:0,0'
                    ALSA: opened MIDI input device 'hw:1,0'
                    ALSA: opened MIDI input device 'hw:2,0'
                    orch now loaded
                    SECTION 1:
                    Initialising spinlock...
                    Starting realtime mode queue: 0xb5027010 thread: 0xdabb78
                    Underrun detected: 39 blocks dropped
                    2135 mode switches detected on the audio thread.
                    Und
                    10695 mode switches detected on the audio thread.
                    15004 mode switches detected on the audio thread.
                    end of score. overall amps: 0.41622 0.35189
                    Bela stopped
                    root@bela ~/Bela#
                    csounder Are these the messages that you would expect to appear in my terminal when updating?
                    no. Something was broken in the package. I uploaded another bela4 version that fixes that.
                    csounder
                    OK, I can reproduce that this doesn't work. In the source code of soundin I see a comment that says soundin now uses diskin2 VL 24-12-16. Not sure if that means anything to you?
                      giuliomoro the comment in the code is by Victor Lazzarini - it would be great if you contacted him about this (on the Bela at least) bug. It does confirm that the console is reporting this fact (feature? bug?) when the .csd is loaded and it reports that diskin2 has loaded the sample "sp_hellorcb.aif" - when the soundin opcode is used in the .csd file - but, then... there is silence, no sound, as if the file is loaded and there is no 'error' but the rest of the instrument can't find it. curious. I am sure Victor will have a suggestion and an explanation.
