silver2row The error states:
BELABOOT: There is a problem with this drive
this should not be an issue.
silver2row Yes Sir, it turned gray and had no errors.
than it's really puzzling that the project still does not build.
What error do you get when bulding?
silver2row Should I reflash the board?
If you want to reflash, you could just use this image: you will not need to do the manual update then.
