giuliomoro Thanks for your instructions!
I am having some trouble installing the files from the requirements.txt on my laptop (I am working with ubuntu 18.04) could you help me?
I have python 2.7 and 3.6 on my laptop. (I set 2.7 as default).
i get the following errors:
 ERROR: Command errored out with exit status 1:
 command: /home/yannick/anaconda3/bin/python -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-c2abhcn_/enum/setup.py'"'"'; __file__='"'"'/tmp/pip-install-c2abhcn_/enum/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-install-c2abhcn_/enum/pip-egg-info
     cwd: /tmp/pip-install-c2abhcn_/enum/
Complete output (11 lines):
Traceback (most recent call last):
  File "<string>", line 1, in <module>
  File "/home/yannick/.local/lib/python3.6/site-packages/setuptools/__init__.py", line 6, in <module>
    import distutils.core
  File "/home/yannick/anaconda3/lib/python3.6/distutils/core.py", line 16, in <module>
    from distutils.dist import Distribution
  File "/home/yannick/anaconda3/lib/python3.6/distutils/dist.py", line 9, in <module>
    import re
  File "/home/yannick/anaconda3/lib/python3.6/re.py", line 142, in <module>
    class RegexFlag(enum.IntFlag):
AttributeError: module 'enum' has no attribute 'IntFlag'
ERROR: Command errored out with exit status 1: python setup.py egg_info
i tried installing jinja2 separately, it installs succesfully, but I still get an error:
ERROR: flask 1.0.2 has requirement Jinja2>=2.10, but you'll have jinja2 2.7.3 which is incompatible. (do you know if I could just try to upgrade jinja2 to a higher version, or I need to create a situation where I can run 2.7.3?)
    I actually don't know. This seems python dependency hell ... I guess my best recommendation would be nuke the whole thing and start over.
    BUT let's try to make some sense of it. All the errors refer to python3.6, which makes me suspect there is something wrong in your path or default python? Maybe this could be a good starting point to investigate.
    yannick (do you know if I could just try to upgrade jinja2 to a higher version, or I need to create a situation where I can run 2.7.3?)
    I have no idea!
    Sorry I can't be of much help.
    5 days later
    thanks for your reply! so i restarted the whole process. on the board, the compiler seems to be running fine, i successfully compiled the basic (example) pd patch to the Bela. but in the project i'm workig on, i still get a lot of errors in the link process, (almost all of them got something to do with the render.cpp file, "undefined reference to 'libpd_...') i have recently updated my bela image to 0.3.7a .
    root@bela:~/hvcc# make -C ~/Bela PROJECT=NonagonBar_HVCC COMPILER=gcc run
    make: Entering directory '/root/Bela'
    Killing old Bela process 4140
    Building HvMessage.c...
    /root/Bela/projects/NonagonBar_HVCC/HvMessage.c: In function 'msg_getHash':
    /root/Bela/projects/NonagonBar_HVCC/HvMessage.c:151:7: warning: dereferencing ty             pe-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
           return *((hv_uint32_t *) &f);
     ...done
    Building HvControlVar.c...
     ...done
    Building HvTable.c...
     ...done
    Building HvMessagePool.c...
     ...done
    Building HvControlBinop.c...
     ...done
    Building HvControlCast.c...
     ...done
    Building HvControlDelay.c...
     ...done
    Building HvControlPack.c...
     ...done
    Building HvMessageQueue.c...
     ...done
    Building HvControlPrint.c...
     ...done
    Building HvUtils.c...
     ...done
    Building HvControlSlice.c...
     ...done
    Building HvLightPipe.c...
     ...done
    Building HvControlSystem.c...
     ...done
    Building render.cpp...
    /root/Bela/projects/NonagonBar_HVCC/render.cpp: In function 'void render(BelaCon             text*, void*)':
    /root/Bela/projects/NonagonBar_HVCC/render.cpp:533:28: warning: comparison betwe             en signed and unsigned integer expressions [-Wsign-compare]
      for(unsigned int n = 0; n < touchSensorMain.numSensors(); ++n)
    /root/Bela/projects/NonagonBar_HVCC/render.cpp:636:20: warning: comparison betwe             en signed and unsigned integer expressions [-Wsign-compare]
    /root/Bela/projects/NonagonBar_HVCC/render.cpp:646:20: warning: comparison betwe             en signed and unsigned integer expressions [-Wsign-compare]
    /root/Bela/projects/NonagonBar_HVCC/render.cpp:719:20: warning: comparison betwe             en signed and unsigned integer expressions [-Wsign-compare]
    /root/Bela/projects/NonagonBar_HVCC/render.cpp:729:20: warning: comparison betwe             en signed and unsigned integer expressions [-Wsign-compare]
     ...done
    Building HeavyContext.cpp...
     ...done
    Building HvHeavy.cpp...
    /root/Bela/projects/NonagonBar_HVCC/HvHeavy.cpp:24:0: warning: ignoring #pragma              mark  [-Wunknown-pragmas]
     #pragma mark - Heavy Table
    /root/Bela/projects/NonagonBar_HVCC/HvHeavy.cpp:45:0: warning: ignoring #pragma              mark  [-Wunknown-pragmas]
     #pragma mark - Heavy Message
    /root/Bela/projects/NonagonBar_HVCC/HvHeavy.cpp:127:0: warning: ignoring #pragma              mark  [-Wunknown-pragmas]
     #pragma mark - Heavy Common
    /root/Bela/projects/NonagonBar_HVCC/HvHeavy.cpp:294:0: warning: ignoring #pragma              mark  [-Wunknown-pragmas]
     ...done
    Building Heavy_bela.cpp...
     ...done
    Extracting dependencies of library Trill
    Extracting dependencies of library UdpServer
    Linking...
    /root/Bela/projects/NonagonBar_HVCC/build/render.o: In function `fdLoop(void*)':
    render.cpp:(.text+0x102): undefined reference to `sys_doio'
    /root/Bela/projects/NonagonBar_HVCC/build/render.o: In function `render':
    render.cpp:(.text+0x738): undefined reference to `libpd_start_message'
    render.cpp:(.text+0x750): undefined reference to `libpd_add_float'
    render.cpp:(.text+0x766): undefined reference to `libpd_finish_message'
    render.cpp:(.text+0x964): undefined reference to `libpd_sysrealtime'
    render.cpp:(.text+0x994): undefined reference to `libpd_pitchbend'
    render.cpp:(.text+0x9ae): undefined reference to `libpd_aftertouch'
    render.cpp:(.text+0x9c8): undefined reference to `libpd_programchange'
    render.cpp:(.text+0x9e6): undefined reference to `libpd_controlchange'
    render.cpp:(.text+0xa04): undefined reference to `libpd_polyaftertouch'
    render.cpp:(.text+0xa96): undefined reference to `libpd_noteon'
    render.cpp:(.text+0xab6): undefined reference to `libpd_noteon'
    render.cpp:(.text+0xfa4): undefined reference to `libpd_process_sys'
    render.cpp:(.text+0x14e8): undefined reference to `libpd_write_array'
    /root/Bela/projects/NonagonBar_HVCC/build/render.o: In function `cleanup':
    render.cpp:(.text+0x15ec): undefined reference to `libpd_closefile'
    /root/Bela/projects/NonagonBar_HVCC/build/render.o: In function `Bela_messageHoo             k(char const*, char const*, int, _atom*)':
    render.cpp:(.text+0x1798): undefined reference to `libpd_get_float'
    render.cpp:(.text+0x17c2): undefined reference to `libpd_is_float'
    render.cpp:(.text+0x1834): undefined reference to `libpd_is_float'
    render.cpp:(.text+0x183e): undefined reference to `libpd_get_float'
    render.cpp:(.text+0x186e): undefined reference to `libpd_is_symbol'
    render.cpp:(.text+0x1ff2): undefined reference to `libpd_get_symbol'
    /root/Bela/projects/NonagonBar_HVCC/build/render.o: In function `setup':
    render.cpp:(.text+0x23e2): undefined reference to `sys_getversion'
    render.cpp:(.text+0x2690): undefined reference to `libpd_blocksize'
    render.cpp:(.text+0x26ac): undefined reference to `libpd_set_printhook'
    render.cpp:(.text+0x26b6): undefined reference to `libpd_set_floathook'
    render.cpp:(.text+0x26c0): undefined reference to `libpd_set_messagehook'
    render.cpp:(.text+0x26ca): undefined reference to `libpd_set_noteonhook'
    render.cpp:(.text+0x26d4): undefined reference to `libpd_set_controlchangehook'
    render.cpp:(.text+0x26de): undefined reference to `libpd_set_programchangehook'
    render.cpp:(.text+0x26e8): undefined reference to `libpd_set_pitchbendhook'
    render.cpp:(.text+0x26f2): undefined reference to `libpd_set_aftertouchhook'
    render.cpp:(.text+0x26fc): undefined reference to `libpd_set_polyaftertouchhook'
    render.cpp:(.text+0x2706): undefined reference to `libpd_set_midibytehook'
    render.cpp:(.text+0x270a): undefined reference to `libpd_init'
    render.cpp:(.text+0x2714): undefined reference to `libpd_add_to_search_path'
    render.cpp:(.text+0x271e): undefined reference to `libpd_add_to_search_path'
    render.cpp:(.text+0x2734): undefined reference to `libpd_init_audio'
    render.cpp:(.text+0x2738): undefined reference to `get_sys_soundin'
    render.cpp:(.text+0x2740): undefined reference to `get_sys_soundout'
    render.cpp:(.text+0x274a): undefined reference to `libpd_start_message'
    render.cpp:(.text+0x2752): undefined reference to `libpd_add_float'
    render.cpp:(.text+0x2762): undefined reference to `libpd_finish_message'
    render.cpp:(.text+0x2776): undefined reference to `libpd_bind'
    render.cpp:(.text+0x278a): undefined reference to `libpd_bind'
    render.cpp:(.text+0x2796): undefined reference to `libpd_bind'
    render.cpp:(.text+0x279e): undefined reference to `libpd_openfile'
    render.cpp:(.text+0x27ba): undefined reference to `sys_dontmanageio'
    render.cpp:(.text+0x2892): undefined reference to `libpd_arraysize'
    render.cpp:(.text+0x28b2): undefined reference to `libpd_start_message'
    render.cpp:(.text+0x28be): undefined reference to `libpd_add_float'
    render.cpp:(.text+0x28c8): undefined reference to `libpd_finish_message'
    render.cpp:(.text+0x28d8): undefined reference to `libpd_float'
    /root/Bela/projects/NonagonBar_HVCC/build/render.o: In function `sendDigitalMess             age(bool, unsigned int, void*)':
    render.cpp:(.text+0x76): undefined reference to `libpd_float'
    Makefile.linkbela:42: recipe for target '/root/Bela/projects/NonagonBar_HVCC/Non             agonBar_HVCC' failed
    make[1]: *** [/root/Bela/projects/NonagonBar_HVCC/NonagonBar_HVCC] Error 1
    Makefile:526: recipe for target '/root/Bela/projects/NonagonBar_HVCC/NonagonBar_             HVCC' failed
    make: *** [/root/Bela/projects/NonagonBar_HVCC/NonagonBar_HVCC] Error 2
    (Please enclose the pasted log in ``` so that it gets formatted properly (I edited your message above accordingly).
    Can we see the content of the render.cpp file? I suspect that it is a render.cpp for libpd and not for heavy.
      giuliomoro Ok sorry for the messyness 😛 here is the pasted render.cpp file:
      #include <cmath>
      #include <stdio.h>
      #define PD_THREADED_IO
      #include <libpd/z_libpd.h>
      extern "C" {
      #include <libpd/s_stuff.h>
      #include <libraries/UdpServer/UdpServer.h>
      #include <string>
      #include <sstream>
      #include <algorithm>
      // MODIFICATION START
      //Trill touchSensor;
      Trill touchSensorMain;
      // how often to try to read the
      // cap sensors inputs. The cap sensor values are always sent to Pd once
      // per block, regardless.
      unsigned int touchSensorSleepIntervalUs = 5000;
      void readCapSensorLoop(void*)
      	while(!gShouldStop)
      		//touchSensor.readI2C();
      		touchSensorMain.readI2C();
      		usleep(touchSensorSleepIntervalUs);
      static unsigned int gScopeChannelsInUse = 4;
      static unsigned int gFirstAnalogInChannel;
      static unsigned int gFirstAnalogOutChannel;
      	settings->interleave = 0;
      float* gInBuf;
      float* gOutBuf;
      #define PARSE_MIDI
      void dumpMidi()
      	if(midi.size() == 0)
      		return;
      			"Num",
      			"Name",
      			"In",
      			"Out",
      			"Pd channels"
      			n,
      			gMidiPortNames[n].c_str(),
      			n * 16 + 1,
      			n * 16 + 16
      	Midi* newMidi;
      	newMidi = new Midi();
      #ifdef PARSE_MIDI
      	newMidi->enableParser(true);
      #else
      	newMidi->enableParser(false);
      #endif /* PARSE_MIDI */
      		if(verboseSuccess)
      	if(newMidi->isInputEnabled())
      		if(verboseSuccess)
      		if(verboseError)
      			fprintf(stderr, "Failed to open  MIDI device %s\n", name.c_str());
      		return nullptr;
      	} else {
      		return newMidi;
      	unsigned int port = 0;
      	while(*channel > 16){
      		*channel -= 16;
      		port += 1;
      	if(port >= midi.size()){
      		// if the port number exceeds the number of ports available, send out
      		// of the first port
      		port = 0;
      	return port;
      	midi[port]->writeNoteOn(channel, pitch, velocity);
      	midi[port]->writeControlChange(channel, controller, value);
      	midi[port]->writeProgramChange(channel, program);
      	midi[port]->writePitchBend(channel, value);
      	midi[port]->writeChannelPressure(channel, pressure);
      	midi[port]->writePolyphonicKeyPressure(channel, pitch, pressure);
      	if(port > (int)midi.size()){
      		port = 0;
      	midi[port]->writeOutput(byte);
      	rt_printf("%s", received);
      	libpd_float((const char*)receiverName, (float)state);
      //	rt_printf("%s: %d\n", (char*)receiverName, state);
      	if(strcmp(source, "bela_setMidi") == 0){
      		int num[3] = {0, 0, 0};
      			if(!libpd_is_float(&argv[n]))
      				fprintf(stderr, "Wrong format for Bela_setMidi, expected:[hw 1 0 0(");
      				return;
      		if(newMidi)
      			midi.push_back(newMidi);
      		dumpMidi();
      		return;
      		bool disable = false;
      			direction = INPUT;
      			direction = OUTPUT;
      			disable = true;
      		} else {
      			return;
      		if(argc == 0){
      			return;
      			return;
      		int channel = libpd_get_float(&argv[0]) - gLibpdDigitalChannelOffset;
      		if(disable == true){
      			dcm.unmanage(channel);
      			return;
      		if(argc >= 2){
      			t_atom* a = &argv[1];
      			if(libpd_is_symbol(a)){
      				char *s = libpd_get_symbol(a);
      				if(strcmp(s, "~") == 0  || strncmp(s, "sig", 3) == 0){
      					isMessageRate = false;
      		return;
      	// the built-in digital receivers are of the form "bela_digitalOutXX" where XX is between gLibpdDigitalChannelOffset and (gLibpdDigitalCHannelOffset+gDigitalChannelsInUse)
      				unsigned int channel = receiver - gLibpdDigitalChannelOffset; // go back to the actual Bela digital channel number
      				if(channel < gDigitalChannelsInUse){ //number of digital channels
      					dcm.setValue(channel, value);
      std::vector<std::string> gReceiverInputNames;
      std::vector<std::string> gReceiverOutputNames;
      void generateDigitalNames(unsigned int numDigitals, unsigned int libpdOffset, std::vector<std::string>& receiverInputNames, std::vector<std::string>& receiverOutputNames)
      	std::string outBaseString = "bela_digitalOut";
      		receiverInputNames.push_back(inBaseString + std::to_string(i+libpdOffset));
      		receiverOutputNames.push_back(outBaseString + std::to_string(i+libpdOffset));
      void printDigitalNames(std::vector<std::string>& receiverInputNames, std::vector<std::string>& receiverOutputNames)
      	printf("DIGITAL INPUTS\n");
      	for(unsigned int i=0; i<gDigitalChannelsInUse; i++)
      		printf("%s\n", receiverInputNames[i].c_str());
      	printf("DIGITAL OUTPUTS\n");
      		printf("%s\n", receiverOutputNames[i].c_str());
      #ifdef PD_THREADED_IO
      void fdLoop(void* arg){
      	while(!gShouldStop){
      		sys_doio();
      		usleep(3000);
      #endif /* PD_THREADED_IO */
      Scope scope;
      float* gScopeOut;
      void* gPatch;
      bool gDigitalEnabled = 0;
      	// Check Pd's version
      	int major, minor, bugfix;
      		return false;
      		return false;
      		gDigitalEnabled = 1;
      	char file[] = "_main.pd";
      	char folder[] = "./";
      		return false;
      	free(str);
      	// analog setup
      	printf("Audio channels in use: %d\n", context->audioOutChannels);
      	printf("Analog channels in use: %d\n", gAnalogChannelsInUse);
      	printf("Digital channels in use: %d\n", gDigitalChannelsInUse);
      	// Channel distribution
      	gFirstAnalogInChannel = std::max(context->audioInChannels, context->audioOutChannels);
      	gFirstAnalogOutChannel = gFirstAnalogInChannel;
      	gFirstDigitalChannel = gFirstAnalogInChannel + std::max(context->analogInChannels, context->analogOutChannels);
      	gLibpdDigitalChannelOffset = gFirstDigitalChannel + 1;
      	// Create receiverNames for digital channels
      	generateDigitalNames(gDigitalChannelsInUse, gLibpdDigitalChannelOffset, gReceiverInputNames, gReceiverOutputNames);
      	// digital setup
      	if(gDigitalEnabled)
      		if(gDigitalChannelsInUse > 0){
      				dcm.setCallbackArgument(ch, (void*) gReceiverInputNames[ch].c_str());
      	unsigned int n = 0;
      		if(newMidi)
      			++n;
      		} else {
      	dumpMidi();
      		return false;
      	libpd_init();
      	gInBuf = get_sys_soundin();
      	gOutBuf = get_sys_soundout();
      	// start DSP:
      	// [; pd dsp 1(
      	libpd_start_message(1);
      	libpd_add_float(1.0f);
      	// Bind your receivers here
      	for(unsigned int i = 0; i < gDigitalChannelsInUse; i++)
      		libpd_bind(gReceiverOutputNames[i].c_str());
      	libpd_bind("bela_setMidi");
      	// open patch:
      	if(gPatch == NULL){
      		return false;
      		pdMultiplexerActive = true;
      	sys_dontmanageio(1);
      	AuxiliaryTask fdTask;
      	fdTask = Bela_createAuxiliaryTask(fdLoop, 50, "libpd-fdTask", NULL);
      	dcm.setVerbose(false);
      	//touchSensor.setup(1, 0x18, Trill::DIFF,20,2);
      	touchSensorMain.setup(1, 0x18, Trill::DIFF,2,2);
      	Bela_scheduleAuxiliaryTask(Bela_createAuxiliaryTask(readCapSensorLoop, 50, "touchSensorRead", NULL));
      // MODIFICATION END
      	libpd_start_message(touchSensor.numSensors());
      	for(unsigned int n = 0; n < touchSensor.numSensors(); ++n)
      		libpd_add_float(touchSensor.rawData[n]/(2048.f));
      		// libpd_add_float(touchSensor.rawData[n]);
      	libpd_finish_message("bela_Trill", "list");
      	//main_sensor
      	libpd_start_message(touchSensorMain.numSensors());
      		libpd_add_float(touchSensorMain.rawData[n]/(2048.f));
      	libpd_finish_message("bela_Trill_main", "list");
      // MODIFICATION END
      	int num;
      #ifdef PARSE_MIDI
      			switch(message.getType()){
      				case kmmNoteOn:
      					break;
      				case kmmNoteOff:
      					 * with a velocity of 0.
      	//				int velocity = message.getDataByte(1); // would be ignored by Pd
      					break;
      				case kmmControlChange:
      					break;
      				case kmmProgramChange:
      					break;
      					break;
      				case kmmChannelPressure:
      					break;
      				case kmmPitchBend:
      					int value =  ((message.getDataByte(1) < 7)| message.getDataByte(0)) - 8192;
      					break;
      				case kmmSystem:
      					int byte = channel | status;
      					break;
      				case kmmNone:
      				case kmmAny:
      					break;
      #else
      	int input;
      			libpd_midibyte(port, input);
      		//audio input
      			memcpy(
      				gInBuf + n * gLibpdBlockSize,
      		// analog input
      			memcpy(
      		// multiplexed analog input
      		if(pdMultiplexerActive)
      		unsigned int j;
      		unsigned int k;
      		float* p0;
      		float* p1;
      		// digital input
      		if(gDigitalEnabled)
      			// digital in at message-rate
      			// digital in at signal-rate
      		// digital outputs
      		if(gDigitalEnabled)
      			// digital out at signal-rate
      		// scope output
      				gScopeOut[k] = *p1;
      		// audio output
      			memcpy(
      		//analog output
      			memcpy(
      	for(auto a : midi)
      		delete a;
      	libpd_closefile(gPatch);
      	delete [] gScopeOut;
      Ok, can you also tell me what is the output of grep v0 /etc/motd, and how you updated your code last?
        giuliomoro the output from grep v0 /etc/motd is Bela image, v0.3.7a, 16 October 2019. i did not update this code myself, so i can't answer this immediately.. @Fedde could you specify this further?
        ok if it's the latest image, then I don't need further detail. Can you confirm if you have a _main.pd file in the project folder?
          giuliomoro yes i do have a _main.pd file in the project folder. (does it matter that it has a subpatch inside?)
            yannick a _main.pd file in the project folder. (does it matter that it has a subpatch inside?)
            it doesn't matter that it has a subpatch inside, as long as it is located in the project folder and not in a subdirectory of the project folder.
            The above file compiles and runs fine for me. Try one of the following:
            • If you are building with the IDE, go to the Settings tab and add to the Make Parameters: box the following: AT=.
            • If you are building using the scripts/build_project.sh script from the host, add -m "AT=" at the end of the command line
            • if you are building directly with make on the board, simply append AT= to the make line
            The three actions above will give a more verbose output, please run one of them and paste the output here.
              root@bela:~# make AT=  -C ~/Bela PROJECT=NonagonBar_Heavy COMPILER=gcc run
              `PID=`grep bela-audio  /proc/xenomai/sched/stat | cut -d " " -f 5 | sed s/\s//g`;        `if [ -z $PID ]; then [ false = true ] || echo "No process to kill"; else [  fal        se = true  ] || echo "Killing old Bela process $PID"; kill -2 $PID; sleep 0.2; k        ill -9 $PID 2> /dev/null; fi; screen -X -S Bela quit > /dev/null; exit 0;
              No process to kill
              echo 'Building HvMessage.c...'
              gcc  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./        build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv        7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL        T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a        -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB        UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g        nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje        cts/NonagonBar_Heavy/build/HvMessage.d" -o "/root/Bela/projects/NonagonBar_Heavy        /build/HvMessage.o" "/root/Bela/projects/NonagonBar_Heavy/HvMessage.c"
              /root/Bela/projects/NonagonBar_Heavy/HvMessage.c: In function 'msg_getHash':
              /root/Bela/projects/NonagonBar_Heavy/HvMessage.c:151:7: warning: dereferencing t        ype-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
              echo ' ...done'
               ...done
              echo ' '
              `echo 'Building HvControlVar.c...'
              gcc  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./        build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv        7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL        T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a        -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB        UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g        nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje        cts/NonagonBar_Heavy/build/HvControlVar.d" -o "/root/Bela/projects/NonagonBar_He        avy/build/HvControlVar.o" "/root/Bela/projects/NonagonBar_Heavy/HvControlVar.c"
              echo ' ...done'
               ...done
              echo ' '
              `echo 'Building HvTable.c...'
              gcc  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./        build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv        7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL        T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a        -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB        UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g        nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje        cts/NonagonBar_Heavy/build/HvTable.d" -o "/root/Bela/projects/NonagonBar_Heavy/b        uild/HvTable.o" "/root/Bela/projects/NonagonBar_Heavy/HvTable.c"
              echo ' ...done'
               ...done
              echo ' '
              `echo 'Building HvMessagePool.c...'
              gcc  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./        build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv        7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL        T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a        -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB        UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g        nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje        cts/NonagonBar_Heavy/build/HvMessagePool.d" -o "/root/Bela/projects/NonagonBar_H        eavy/build/HvMessagePool.o" "/root/Bela/projects/NonagonBar_Heavy/HvMessagePool.        c"
              echo ' ...done'
               ...done
              echo ' '
              `echo 'Building HvControlBinop.c...'
              gcc  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./        build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv        7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL        T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a        -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB        UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g        nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje        cts/NonagonBar_Heavy/build/HvControlBinop.d" -o "/root/Bela/projects/NonagonBar_        Heavy/build/HvControlBinop.o" "/root/Bela/projects/NonagonBar_Heavy/HvControlBin        op.c"
              echo ' ...done'
               ...done
              echo ' '
              `echo 'Building HvControlCast.c...'
              gcc  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./        build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv        7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL        T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a        -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB        UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g        nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje        cts/NonagonBar_Heavy/build/HvControlCast.d" -o "/root/Bela/projects/NonagonBar_H        eavy/build/HvControlCast.o" "/root/Bela/projects/NonagonBar_Heavy/HvControlCast.        c"
              echo ' ...done'
               ...done
              echo ' '
              `echo 'Building HvControlDelay.c...'
              gcc  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./        build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv        7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL        T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a        -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB        UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g        nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje        cts/NonagonBar_Heavy/build/HvControlDelay.d" -o "/root/Bela/projects/NonagonBar_        Heavy/build/HvControlDelay.o" "/root/Bela/projects/NonagonBar_Heavy/HvControlDel        ay.c"
              echo ' ...done'
               ...done
              echo ' '
              `echo 'Building HvControlPack.c...'
              gcc  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./        build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv        7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL        T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a        -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB        UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g        nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje        cts/NonagonBar_Heavy/build/HvControlPack.d" -o "/root/Bela/projects/NonagonBar_H        eavy/build/HvControlPack.o" "/root/Bela/projects/NonagonBar_Heavy/HvControlPack.        c"
              echo ' ...done'
               ...done
              echo ' '
              `echo 'Building HvMessageQueue.c...'
              gcc  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./        build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv        7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL        T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a        -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB        UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g        nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje        cts/NonagonBar_Heavy/build/HvMessageQueue.d" -o "/root/Bela/projects/NonagonBar_        Heavy/build/HvMessageQueue.o" "/root/Bela/projects/NonagonBar_Heavy/HvMessageQue        ue.c"
              echo ' ...done'
               ...done
              echo ' '
              `echo 'Building HvControlPrint.c...'
              gcc  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./        build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv        7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL        T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a        -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB        UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g        nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje        cts/NonagonBar_Heavy/build/HvControlPrint.d" -o "/root/Bela/projects/NonagonBar_        Heavy/build/HvControlPrint.o" "/root/Bela/projects/NonagonBar_Heavy/HvControlPri        nt.c"
              echo ' ...done'
               ...done
              echo ' '
              `echo 'Building HvUtils.c...'
              gcc  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./        build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv        7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL        T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a        -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB        UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g        nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje        cts/NonagonBar_Heavy/build/HvUtils.d" -o "/root/Bela/projects/NonagonBar_Heavy/b        uild/HvUtils.o" "/root/Bela/projects/NonagonBar_Heavy/HvUtils.c"
              echo ' ...done'
               ...done
              echo ' '
              `echo 'Building HvControlSlice.c...'
              gcc  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./        build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv        7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL        T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a        -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB        UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g        nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje        cts/NonagonBar_Heavy/build/HvControlSlice.d" -o "/root/Bela/projects/NonagonBar_        Heavy/build/HvControlSlice.o" "/root/Bela/projects/NonagonBar_Heavy/HvControlSli        ce.c"
              echo ' ...done'
               ...done
              echo ' '
              `echo 'Building HvLightPipe.c...'
              gcc  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./        build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv        7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL        T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a        -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB        UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g        nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje        cts/NonagonBar_Heavy/build/HvLightPipe.d" -o "/root/Bela/projects/NonagonBar_Hea        vy/build/HvLightPipe.o" "/root/Bela/projects/NonagonBar_Heavy/HvLightPipe.c"
              echo ' ...done'
               ...done
              echo ' '
              `echo 'Building HvControlSystem.c...'
              gcc  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./        build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv        7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL        T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a        -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB        UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g        nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje        cts/NonagonBar_Heavy/build/HvControlSystem.d" -o "/root/Bela/projects/NonagonBar        _Heavy/build/HvControlSystem.o" "/root/Bela/projects/NonagonBar_Heavy/HvControlS        ystem.c"
              echo ' ...done'
               ...done
              echo ' '
              `echo 'Building render.cpp...'
              g++  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./        build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv        7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL        T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a        -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB        UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=c        ++11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje        cts/NonagonBar_Heavy/build/render.d" -o "/root/Bela/projects/NonagonBar_Heavy/bu        ild/render.o" "/root/Bela/projects/NonagonBar_Heavy/render.cpp"
              /root/Bela/projects/NonagonBar_Heavy/render.cpp: In function 'void render(BelaCo        ntext*, void*)':
              /root/Bela/projects/NonagonBar_Heavy/render.cpp:531:28: warning: comparison betw        een signed and unsigned integer expressions [-Wsign-compare]
              /root/Bela/projects/NonagonBar_Heavy/render.cpp:634:20: warning: comparison betw        een signed and unsigned integer expressions [-Wsign-compare]
              /root/Bela/projects/NonagonBar_Heavy/render.cpp:644:20: warning: comparison betw        een signed and unsigned integer expressions [-Wsign-compare]
              /root/Bela/projects/NonagonBar_Heavy/render.cpp:717:20: warning: comparison betw        een signed and unsigned integer expressions [-Wsign-compare]
              /root/Bela/projects/NonagonBar_Heavy/render.cpp:727:20: warning: comparison betw        een signed and unsigned integer expressions [-Wsign-compare]
              echo ' ...done'
               ...done
              echo ' '
              `echo 'Building HeavyContext.cpp...'
              g++  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./        build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv        7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL        T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a        -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB        UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=c        ++11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje        cts/NonagonBar_Heavy/build/HeavyContext.d" -o "/root/Bela/projects/NonagonBar_He        avy/build/HeavyContext.o" "/root/Bela/projects/NonagonBar_Heavy/HeavyContext.cpp        "
              echo ' ...done'
               ...done
              echo ' '
              `echo 'Building HvHeavy.cpp...'
              g++  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./        build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv        7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL        T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a        -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB        UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=c        ++11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje        cts/NonagonBar_Heavy/build/HvHeavy.d" -o "/root/Bela/projects/NonagonBar_Heavy/b        uild/HvHeavy.o" "/root/Bela/projects/NonagonBar_Heavy/HvHeavy.cpp"
              /root/Bela/projects/NonagonBar_Heavy/HvHeavy.cpp:24:0: warning: ignoring #pragma mark  [-Wunknown-pragmas]
              `/root/Bela/projects/NonagonBar_Heavy/HvHeavy.cpp:45:0: warning: ignoring #pragma mark  [-Wunknown-pragmas]
               #pragma mark - Heavy Message`
              `/root/Bela/projects/NonagonBar_Heavy/HvHeavy.cpp:127:0: warning: ignoring #pragma mark  [-Wunknown-pragmas]
               #pragma mark - Heavy Common`
              `/root/Bela/projects/NonagonBar_Heavy/HvHeavy.cpp:294:0: warning: ignoring #pragma mark  [-Wunknown-pragmas]
              `echo ' ...done'
               ...done
              echo ' '`
              `echo 'Building Heavy_bela.cpp...'
              g++  -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy  -I./include -I./build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBALT__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEBUG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=c++11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/projects/NonagonBar_Heavy/build/Heavy_bela.d" -o "/root/Bela/projects/NonagonBar_Heavy/build/Heavy_bela.o" "/root/Bela/projects/NonagonBar_Heavy/Heavy_bela.cpp"
              echo ' ...done'
               ...done
              echo ' '`
              `./resources/tools/detectlibraries.sh --project NonagonBar_Heavy
              make -f Makefile.linkbela --no-print-directory /root/Bela/projects/NonagonBar_Heavy/NonagonBar_Heavy
              echo 'Linking...'
              Linking...
              g++  -Llib/     -fno-pie -no-pie -pthread -o "/root/Bela/projects/NonagonBar_Heavy/NonagonBar_Heavy" build/core/FormatConvert.o build/core/OscillatorBank_routines.o build/core/math_runfast.o build/core/Gpio.o build/core/I2c_Codec.o build/core/RTAudio.o build/core/PruBinary.o build/core/RTAudioCommandLine.o build/core/AuxTaskNonRT.o build/core/JSONValue.o build/core/board_detect.o build/core/WSServer.o build/core/AuxiliaryTasks.o build/core/PRU.o build/core/AuxTaskRT.o build/core/IirFilter.o build/core/GPIOcontrol.o build/core/Spi_Codec.o build/core/DigitalChannelManager.o build/core/JSON.o ./build/core/default_main.o   /root/Bela/projects/NonagonBar_Heavy/build/HvMessage.o /root/Bela/projects/NonagonBar_Heavy/build/HvControlVar.o /root/Bela/projects/NonagonBar_Heavy/build/HvTable.o /root/Bela/projects/NonagonBar_Heavy/build/HvMessagePool.o /root/Bela/projects/NonagonBar_Heavy/build/HvControlBinop.o /root/Bela/projects/NonagonBar_Heavy/build/HvControlCast.o /root/Bela/projects/NonagonBar_Heavy/build/HvControlDelay.o /root/Bela/projects/NonagonBar_Heavy/build/HvControlPack.o /root/Bela/projects/NonagonBar_Heavy/build/HvMessageQueue.o /root/Bela/projects/NonagonBar_Heavy/build/HvControlPrint.o /root/Bela/projects/NonagonBar_Heavy/build/HvUtils.o /root/Bela/projects/NonagonBar_Heavy/build/HvControlSlice.o /root/Bela/projects/NonagonBar_Heavy/build/HvLightPipe.o /root/Bela/projects/NonagonBar_Heavy/build/HvControlSystem.o /root/Bela/projects/NonagonBar_Heavy/build/render.o /root/Bela/projects/NonagonBar_Heavy/build/HeavyContext.o /root/Bela/projects/NonagonBar_Heavy/build/HvHeavy.o /root/Bela/projects/NonagonBar_Heavy/build/Heavy_bela.o libraries/Midi/build/Midi.o libraries/Midi/build/Midi_c.o libraries/Scope/build/Scope.o libraries/Trill/build/Trill.o libraries/UdpServer/build/UdpServer.o   -lasound -lseasocks -lNE10   -Wl,--no-as-needed -L/usr/xenomai/lib -lcobalt -lmodechk -lpthread -lrt -lprussdrv -lstdc++  -Wl,--no-as-needed -L/usr/xenomai/lib -lcobalt -lmodechk -lpthread -lrt -lasound -lseasocks -lNE10 -lmathneon  -lmathneon
              /root/Bela/projects/NonagonBar_Heavy/build/render.o: In function `fdLoop(void*)':
              /root/Bela/projects/NonagonBar_Heavy/build/render.o: In function `render':
              /root/Bela/projects/NonagonBar_Heavy/build/render.o: In function `cleanup':
              /root/Bela/projects/NonagonBar_Heavy/build/render.o: In function `Bela_messageHook(char const*, char const*, int, _atom*)':
              /root/Bela/projects/NonagonBar_Heavy/build/render.o: In function `setup':
              /root/Bela/projects/NonagonBar_Heavy/build/render.o: In function `sendDigitalMessage(bool, unsigned int, void*)':
              `render.cpp:(.text+0x76): undefined reference to `libpd_float'
              Makefile.linkbela:42: recipe for target '/root/Bela/projects/NonagonBar_Heavy/NonagonBar_Heavy' failed
              make[1]: *** [/root/Bela/projects/NonagonBar_Heavy/NonagonBar_Heavy] Error 1
              Makefile:526: recipe for target '/root/Bela/projects/NonagonBar_Heavy/NonagonBar_Heavy' failed
              make: *** [/root/Bela/projects/NonagonBar_Heavy/NonagonBar_Heavy] Error 2
              make: Leaving directory '/root/Bela'`
              that line
              suggests that there is no _main.pd file in the project folder. Can you show the output of ls /root/Bela/projects/NonagonBar_Heavy ?
              I still don't understand why you have all the files generated by the Heavy compiler, but you are using a render.cpp file that is for libpd. Could it be the case that you are trying to build a Heavy project, but including the wrong custom render.cpp in it?
                giuliomoro thanks a lot!! actually that's what happened. I am trying to make a heavy project out of my pd project. it compiles succesfully after i just used the render.cpp file from ~/Bela/scripts/hvresources/render.cpp. Only i have to alter the render.cpp file, as it is now not reading the sensor values (it just prints zero's), also the setup function for the sensors has got to be in there i think (or should i add these in a different location?) . Is there any way to convert the libpd version of the render.cpp file to one that works with heavy? or do i have to do that manually? (the lib pd version of the functions i wish to add is marked with //MODIFICATION START and //MODIFICATION END in the pasted render.cpp file above.)could you give me some directions?
                The process has to be done manually and it consists in applying to the default heavy render.cpp the same changes you applied to the default libpd render file. Part of that is straightforward (e.g.: the trill code), but sending messages to heavy has a different API to that to send them to libpd. It is explained here.
                I tried to port your changes, see if it works: here
                Thanks!! It compiled succesfully, but it now gives me either 0 or 26 as output, instead of the desired floating point values. I probably forgot to include something, or forgot to mark some code i included. I'll have a good look at the scripts, ill let you know when it works (or doesn't work 😛)
                The way i understand my code, what the below is doing is creating a message with numSensors+1 elements. The first element of the message is the number of sensors, and the following elements are the readings for each of the elements, which is my understanding of what your code was also doing. But I may be wrong on both accounts.
                	int numElements = touchSensorMain.numSensors() + 1;
                	HvMessage *msg = (HvMessage *) hv_alloca(hv_msg_getByteSize(numElements));
                	hv_msg_init(msg, numElements, 0.0);
                	hv_msg_setFloat(msg, 0, touchSensorMain.numSensors());
                	double delayMs = 0.0;
                		hv_msg_setFloat(msg, 1 + n, touchSensorMain.rawData[n]/(2048.f));
                	hv_sendMessageToReceiver(gHeavyContext, bela_trill_main_hash, delayMs, msg);
                oh that makes so much sense now! i want to read 26 incoming signals and make a list out of it, this code actually added numSensors to that list as the first element. there is also a function which subtracts the highest incoming value from all elements in the list. because i only sent and printed the first value of the list to test if the code actually worked, it was always showing me 26 and (26-26)=0 :') when i altered the patch to send and print all incoming values, everything worked just fine. thank you so much for helping me through this process!
                no problem. Hopefully we will make it easier to modify the default heavy/libpd wrappers. For sure we are going to add Trill by default to these, so that you won't have to do this.
