Thank you so much for the clarification Giulio,
I finally managed to compile the heavy file!!
Heavy, Pd and Enzienaudio
As of today, I created a master-bela
branch on https://github.com/giuliomoro/hvcc where I merged a couple of fixes for MIDI (now MIDI outputs work) and for Xenomai (now you can compile with clang
instead of gcc
, so compilation time can get significantly faster). I will try to keep this as up to date as possible (that is: every fix I know of will go in there), so I'd recommend everyone on Bela to use this instead of https://github.com/enzienaudio/hvcc. However, please note that I am not the new maintainer of hvcc
, so please don't ask for features, as they will not be implemented (by me).
How do you get a PD patch compiled using RebelTech's on-line Heavy compiler to run on the Bela?
The code it's generated seems to be missing a render.cpp file. Does it need one? And what should be in it?
I have never used it, I think you may need this, however it depends on the "patch name" given to the compiler. If the patch name is not "bela", then the included file Heavy_bela.h
will not exist.
(my recommendations to use the Heavy compiler without relying on an online compiler are above.)
Hi Giuliomoro, thanks for replying!
I tried following your instructions. I got the render.cpp file you mentioned in your reply just now and made a Bela/scripts/hvresources directory and put it in there.
It looked like it nearly worked but had the following error while compiling:
/root/Bela/projects/WindchimeHeavy/render.cpp:85:13: error: ‘class Midi’ has no member named ‘isInputEnabled’
/root/Bela/projects/WindchimeHeavy/render.cpp:86:13: error: ‘class Midi’ has no member named ‘isOutputEnabled’
/root/Bela/projects/WindchimeHeavy/render.cpp: In function ‘Midi* openMidiDevice(std::string, bool, bool)’:
/root/Bela/projects/WindchimeHeavy/render.cpp:100:14: error: ‘class Midi’ has no member named ‘isOutputEnabled’
/root/Bela/projects/WindchimeHeavy/render.cpp:105:14: error: ‘class Midi’ has no member named ‘isInputEnabled’
if(newMidi->isInputEnabled())
/root/Bela/projects/WindchimeHeavy/render.cpp:110:15: error: ‘class Midi’ has no member named ‘isInputEnabled’
/root/Bela/projects/WindchimeHeavy/render.cpp:110:45: error: ‘class Midi’ has no member named ‘isOutputEnabled’
I've commented out the lines in render.cpp that reference isInputEnabled
and isOutputEnabled
and it seems to be compiling now.
I'm guessing I've got some kind of version mismatch between this render.cpp and what I've got installed on the Bela.
On your board,at the path /root/Bela/scripts/hvresources/render.cpp
you should have a wrapper for heavy that should be compatible with your version of the Bela core core.
giuliomoro Thanks for your instructions!
I am having some trouble installing the files from the requirements.txt on my laptop (I am working with ubuntu 18.04) could you help me?
I have python 2.7 and 3.6 on my laptop. (I set 2.7 as default).
i get the following errors:
ERROR: Command errored out with exit status 1:
command: /home/yannick/anaconda3/bin/python -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-c2abhcn_/enum/setup.py'"'"'; __file__='"'"'/tmp/pip-install-c2abhcn_/enum/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-install-c2abhcn_/enum/pip-egg-info
cwd: /tmp/pip-install-c2abhcn_/enum/
Complete output (11 lines):
Traceback (most recent call last):
File "<string>", line 1, in <module>
File "/home/yannick/.local/lib/python3.6/site-packages/setuptools/__init__.py", line 6, in <module>
import distutils.core
File "/home/yannick/anaconda3/lib/python3.6/distutils/core.py", line 16, in <module>
from distutils.dist import Distribution
File "/home/yannick/anaconda3/lib/python3.6/distutils/dist.py", line 9, in <module>
import re
File "/home/yannick/anaconda3/lib/python3.6/re.py", line 142, in <module>
class RegexFlag(enum.IntFlag):
AttributeError: module 'enum' has no attribute 'IntFlag'
ERROR: Command errored out with exit status 1: python setup.py egg_info
i tried installing jinja2 separately, it installs succesfully, but I still get an error:
ERROR: flask 1.0.2 has requirement Jinja2>=2.10, but you'll have jinja2 2.7.3 which is incompatible. (do you know if I could just try to upgrade jinja2 to a higher version, or I need to create a situation where I can run 2.7.3?)
I actually don't know. This seems python dependency hell ... I guess my best recommendation would be nuke the whole thing and start over.
BUT let's try to make some sense of it. All the errors refer to python3.6
, which makes me suspect there is something wrong in your path or default python? Maybe this could be a good starting point to investigate.
yannick (do you know if I could just try to upgrade jinja2 to a higher version, or I need to create a situation where I can run 2.7.3?)
I have no idea!
Sorry I can't be of much help.
thanks for your reply! so i restarted the whole process. on the board, the compiler seems to be running fine, i successfully compiled the basic (example) pd patch to the Bela. but in the project i'm workig on, i still get a lot of errors in the link process, (almost all of them got something to do with the render.cpp file, "undefined reference to 'libpd_...') i have recently updated my bela image to 0.3.7a .
root@bela:~/hvcc# make -C ~/Bela PROJECT=NonagonBar_HVCC COMPILER=gcc run
make: Entering directory '/root/Bela'
Killing old Bela process 4140
Building HvMessage.c...
/root/Bela/projects/NonagonBar_HVCC/HvMessage.c: In function 'msg_getHash':
/root/Bela/projects/NonagonBar_HVCC/HvMessage.c:151:7: warning: dereferencing ty pe-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
return *((hv_uint32_t *) &f);
...done
Building HvControlVar.c...
...done
Building HvTable.c...
...done
Building HvMessagePool.c...
...done
Building HvControlBinop.c...
...done
Building HvControlCast.c...
...done
Building HvControlDelay.c...
...done
Building HvControlPack.c...
...done
Building HvMessageQueue.c...
...done
Building HvControlPrint.c...
...done
Building HvUtils.c...
...done
Building HvControlSlice.c...
...done
Building HvLightPipe.c...
...done
Building HvControlSystem.c...
...done
Building render.cpp...
/root/Bela/projects/NonagonBar_HVCC/render.cpp: In function 'void render(BelaCon text*, void*)':
/root/Bela/projects/NonagonBar_HVCC/render.cpp:533:28: warning: comparison betwe en signed and unsigned integer expressions [-Wsign-compare]
for(unsigned int n = 0; n < touchSensorMain.numSensors(); ++n)
/root/Bela/projects/NonagonBar_HVCC/render.cpp:636:20: warning: comparison betwe en signed and unsigned integer expressions [-Wsign-compare]
/root/Bela/projects/NonagonBar_HVCC/render.cpp:646:20: warning: comparison betwe en signed and unsigned integer expressions [-Wsign-compare]
/root/Bela/projects/NonagonBar_HVCC/render.cpp:719:20: warning: comparison betwe en signed and unsigned integer expressions [-Wsign-compare]
/root/Bela/projects/NonagonBar_HVCC/render.cpp:729:20: warning: comparison betwe en signed and unsigned integer expressions [-Wsign-compare]
...done
Building HeavyContext.cpp...
...done
Building HvHeavy.cpp...
/root/Bela/projects/NonagonBar_HVCC/HvHeavy.cpp:24:0: warning: ignoring #pragma mark [-Wunknown-pragmas]
#pragma mark - Heavy Table
/root/Bela/projects/NonagonBar_HVCC/HvHeavy.cpp:45:0: warning: ignoring #pragma mark [-Wunknown-pragmas]
#pragma mark - Heavy Message
/root/Bela/projects/NonagonBar_HVCC/HvHeavy.cpp:127:0: warning: ignoring #pragma mark [-Wunknown-pragmas]
#pragma mark - Heavy Common
/root/Bela/projects/NonagonBar_HVCC/HvHeavy.cpp:294:0: warning: ignoring #pragma mark [-Wunknown-pragmas]
...done
Building Heavy_bela.cpp...
...done
Extracting dependencies of library Trill
Extracting dependencies of library UdpServer
Linking...
/root/Bela/projects/NonagonBar_HVCC/build/render.o: In function `fdLoop(void*)':
render.cpp:(.text+0x102): undefined reference to `sys_doio'
/root/Bela/projects/NonagonBar_HVCC/build/render.o: In function `render':
render.cpp:(.text+0x738): undefined reference to `libpd_start_message'
render.cpp:(.text+0x750): undefined reference to `libpd_add_float'
render.cpp:(.text+0x766): undefined reference to `libpd_finish_message'
render.cpp:(.text+0x964): undefined reference to `libpd_sysrealtime'
render.cpp:(.text+0x994): undefined reference to `libpd_pitchbend'
render.cpp:(.text+0x9ae): undefined reference to `libpd_aftertouch'
render.cpp:(.text+0x9c8): undefined reference to `libpd_programchange'
render.cpp:(.text+0x9e6): undefined reference to `libpd_controlchange'
render.cpp:(.text+0xa04): undefined reference to `libpd_polyaftertouch'
render.cpp:(.text+0xa96): undefined reference to `libpd_noteon'
render.cpp:(.text+0xab6): undefined reference to `libpd_noteon'
render.cpp:(.text+0xfa4): undefined reference to `libpd_process_sys'
render.cpp:(.text+0x14e8): undefined reference to `libpd_write_array'
/root/Bela/projects/NonagonBar_HVCC/build/render.o: In function `cleanup':
render.cpp:(.text+0x15ec): undefined reference to `libpd_closefile'
/root/Bela/projects/NonagonBar_HVCC/build/render.o: In function `Bela_messageHoo k(char const*, char const*, int, _atom*)':
render.cpp:(.text+0x1798): undefined reference to `libpd_get_float'
render.cpp:(.text+0x17c2): undefined reference to `libpd_is_float'
render.cpp:(.text+0x1834): undefined reference to `libpd_is_float'
render.cpp:(.text+0x183e): undefined reference to `libpd_get_float'
render.cpp:(.text+0x186e): undefined reference to `libpd_is_symbol'
render.cpp:(.text+0x1ff2): undefined reference to `libpd_get_symbol'
/root/Bela/projects/NonagonBar_HVCC/build/render.o: In function `setup':
render.cpp:(.text+0x23e2): undefined reference to `sys_getversion'
render.cpp:(.text+0x2690): undefined reference to `libpd_blocksize'
render.cpp:(.text+0x26ac): undefined reference to `libpd_set_printhook'
render.cpp:(.text+0x26b6): undefined reference to `libpd_set_floathook'
render.cpp:(.text+0x26c0): undefined reference to `libpd_set_messagehook'
render.cpp:(.text+0x26ca): undefined reference to `libpd_set_noteonhook'
render.cpp:(.text+0x26d4): undefined reference to `libpd_set_controlchangehook'
render.cpp:(.text+0x26de): undefined reference to `libpd_set_programchangehook'
render.cpp:(.text+0x26e8): undefined reference to `libpd_set_pitchbendhook'
render.cpp:(.text+0x26f2): undefined reference to `libpd_set_aftertouchhook'
render.cpp:(.text+0x26fc): undefined reference to `libpd_set_polyaftertouchhook'
render.cpp:(.text+0x2706): undefined reference to `libpd_set_midibytehook'
render.cpp:(.text+0x270a): undefined reference to `libpd_init'
render.cpp:(.text+0x2714): undefined reference to `libpd_add_to_search_path'
render.cpp:(.text+0x271e): undefined reference to `libpd_add_to_search_path'
render.cpp:(.text+0x2734): undefined reference to `libpd_init_audio'
render.cpp:(.text+0x2738): undefined reference to `get_sys_soundin'
render.cpp:(.text+0x2740): undefined reference to `get_sys_soundout'
render.cpp:(.text+0x274a): undefined reference to `libpd_start_message'
render.cpp:(.text+0x2752): undefined reference to `libpd_add_float'
render.cpp:(.text+0x2762): undefined reference to `libpd_finish_message'
render.cpp:(.text+0x2776): undefined reference to `libpd_bind'
render.cpp:(.text+0x278a): undefined reference to `libpd_bind'
render.cpp:(.text+0x2796): undefined reference to `libpd_bind'
render.cpp:(.text+0x279e): undefined reference to `libpd_openfile'
render.cpp:(.text+0x27ba): undefined reference to `sys_dontmanageio'
render.cpp:(.text+0x2892): undefined reference to `libpd_arraysize'
render.cpp:(.text+0x28b2): undefined reference to `libpd_start_message'
render.cpp:(.text+0x28be): undefined reference to `libpd_add_float'
render.cpp:(.text+0x28c8): undefined reference to `libpd_finish_message'
render.cpp:(.text+0x28d8): undefined reference to `libpd_float'
/root/Bela/projects/NonagonBar_HVCC/build/render.o: In function `sendDigitalMess age(bool, unsigned int, void*)':
render.cpp:(.text+0x76): undefined reference to `libpd_float'
Makefile.linkbela:42: recipe for target '/root/Bela/projects/NonagonBar_HVCC/Non agonBar_HVCC' failed
make[1]: *** [/root/Bela/projects/NonagonBar_HVCC/NonagonBar_HVCC] Error 1
Makefile:526: recipe for target '/root/Bela/projects/NonagonBar_HVCC/NonagonBar_ HVCC' failed
make: *** [/root/Bela/projects/NonagonBar_HVCC/NonagonBar_HVCC] Error 2
(Please enclose the pasted log in ``` so that it gets formatted properly (I edited your message above accordingly).
Can we see the content of the render.cpp
file? I suspect that it is a render.cpp
for libpd and not for heavy.
giuliomoro Ok sorry for the messyness here is the pasted render.cpp file:
#include <cmath>
#include <stdio.h>
#define PD_THREADED_IO
#include <libpd/z_libpd.h>
extern "C" {
#include <libpd/s_stuff.h>
#include <libraries/UdpServer/UdpServer.h>
#include <string>
#include <sstream>
#include <algorithm>
// MODIFICATION START
//Trill touchSensor;
Trill touchSensorMain;
// how often to try to read the
// cap sensors inputs. The cap sensor values are always sent to Pd once
// per block, regardless.
unsigned int touchSensorSleepIntervalUs = 5000;
void readCapSensorLoop(void*)
while(!gShouldStop)
//touchSensor.readI2C();
touchSensorMain.readI2C();
usleep(touchSensorSleepIntervalUs);
static unsigned int gScopeChannelsInUse = 4;
static unsigned int gFirstAnalogInChannel;
static unsigned int gFirstAnalogOutChannel;
settings->interleave = 0;
float* gInBuf;
float* gOutBuf;
#define PARSE_MIDI
void dumpMidi()
if(midi.size() == 0)
return;
"Num",
"Name",
"In",
"Out",
"Pd channels"
n,
gMidiPortNames[n].c_str(),
n * 16 + 1,
n * 16 + 16
Midi* newMidi;
newMidi = new Midi();
#ifdef PARSE_MIDI
newMidi->enableParser(true);
#else
newMidi->enableParser(false);
#endif /* PARSE_MIDI */
if(verboseSuccess)
if(verboseSuccess)
if(verboseError)
fprintf(stderr, "Failed to open MIDI device %s\n", name.c_str());
return nullptr;
} else {
return newMidi;
unsigned int port = 0;
while(*channel > 16){
*channel -= 16;
port += 1;
if(port >= midi.size()){
// if the port number exceeds the number of ports available, send out
// of the first port
port = 0;
return port;
midi[port]->writeNoteOn(channel, pitch, velocity);
midi[port]->writeControlChange(channel, controller, value);
midi[port]->writeProgramChange(channel, program);
midi[port]->writePitchBend(channel, value);
midi[port]->writeChannelPressure(channel, pressure);
midi[port]->writePolyphonicKeyPressure(channel, pitch, pressure);
if(port > (int)midi.size()){
port = 0;
midi[port]->writeOutput(byte);
rt_printf("%s", received);
libpd_float((const char*)receiverName, (float)state);
// rt_printf("%s: %d\n", (char*)receiverName, state);
if(strcmp(source, "bela_setMidi") == 0){
int num[3] = {0, 0, 0};
if(!libpd_is_float(&argv[n]))
fprintf(stderr, "Wrong format for Bela_setMidi, expected:[hw 1 0 0(");
return;
if(newMidi)
midi.push_back(newMidi);
dumpMidi();
return;
bool disable = false;
direction = INPUT;
direction = OUTPUT;
disable = true;
} else {
return;
if(argc == 0){
return;
return;
int channel = libpd_get_float(&argv[0]) - gLibpdDigitalChannelOffset;
if(disable == true){
dcm.unmanage(channel);
return;
if(argc >= 2){
t_atom* a = &argv[1];
if(libpd_is_symbol(a)){
char *s = libpd_get_symbol(a);
if(strcmp(s, "~") == 0 || strncmp(s, "sig", 3) == 0){
isMessageRate = false;
return;
// the built-in digital receivers are of the form "bela_digitalOutXX" where XX is between gLibpdDigitalChannelOffset and (gLibpdDigitalCHannelOffset+gDigitalChannelsInUse)
unsigned int channel = receiver - gLibpdDigitalChannelOffset; // go back to the actual Bela digital channel number
if(channel < gDigitalChannelsInUse){ //number of digital channels
dcm.setValue(channel, value);
std::vector<std::string> gReceiverInputNames;
std::vector<std::string> gReceiverOutputNames;
void generateDigitalNames(unsigned int numDigitals, unsigned int libpdOffset, std::vector<std::string>& receiverInputNames, std::vector<std::string>& receiverOutputNames)
std::string outBaseString = "bela_digitalOut";
receiverInputNames.push_back(inBaseString + std::to_string(i+libpdOffset));
receiverOutputNames.push_back(outBaseString + std::to_string(i+libpdOffset));
void printDigitalNames(std::vector<std::string>& receiverInputNames, std::vector<std::string>& receiverOutputNames)
printf("DIGITAL INPUTS\n");
for(unsigned int i=0; i<gDigitalChannelsInUse; i++)
printf("%s\n", receiverInputNames[i].c_str());
printf("DIGITAL OUTPUTS\n");
printf("%s\n", receiverOutputNames[i].c_str());
#ifdef PD_THREADED_IO
void fdLoop(void* arg){
while(!gShouldStop){
sys_doio();
usleep(3000);
#endif /* PD_THREADED_IO */
Scope scope;
float* gScopeOut;
void* gPatch;
bool gDigitalEnabled = 0;
// Check Pd's version
int major, minor, bugfix;
return false;
return false;
gDigitalEnabled = 1;
char file[] = "_main.pd";
char folder[] = "./";
return false;
free(str);
// analog setup
printf("Audio channels in use: %d\n", context->audioOutChannels);
printf("Analog channels in use: %d\n", gAnalogChannelsInUse);
printf("Digital channels in use: %d\n", gDigitalChannelsInUse);
// Channel distribution
gFirstAnalogInChannel = std::max(context->audioInChannels, context->audioOutChannels);
gFirstAnalogOutChannel = gFirstAnalogInChannel;
gFirstDigitalChannel = gFirstAnalogInChannel + std::max(context->analogInChannels, context->analogOutChannels);
gLibpdDigitalChannelOffset = gFirstDigitalChannel + 1;
// Create receiverNames for digital channels
generateDigitalNames(gDigitalChannelsInUse, gLibpdDigitalChannelOffset, gReceiverInputNames, gReceiverOutputNames);
// digital setup
if(gDigitalEnabled)
if(gDigitalChannelsInUse > 0){
dcm.setCallbackArgument(ch, (void*) gReceiverInputNames[ch].c_str());
unsigned int n = 0;
if(newMidi)
++n;
} else {
dumpMidi();
return false;
libpd_init();
gInBuf = get_sys_soundin();
gOutBuf = get_sys_soundout();
// start DSP:
// [; pd dsp 1(
libpd_start_message(1);
libpd_add_float(1.0f);
// Bind your receivers here
for(unsigned int i = 0; i < gDigitalChannelsInUse; i++)
libpd_bind(gReceiverOutputNames[i].c_str());
libpd_bind("bela_setMidi");
// open patch:
if(gPatch == NULL){
return false;
pdMultiplexerActive = true;
sys_dontmanageio(1);
AuxiliaryTask fdTask;
fdTask = Bela_createAuxiliaryTask(fdLoop, 50, "libpd-fdTask", NULL);
dcm.setVerbose(false);
//touchSensor.setup(1, 0x18, Trill::DIFF,20,2);
touchSensorMain.setup(1, 0x18, Trill::DIFF,2,2);
Bela_scheduleAuxiliaryTask(Bela_createAuxiliaryTask(readCapSensorLoop, 50, "touchSensorRead", NULL));
// MODIFICATION END
libpd_start_message(touchSensor.numSensors());
for(unsigned int n = 0; n < touchSensor.numSensors(); ++n)
libpd_add_float(touchSensor.rawData[n]/(2048.f));
// libpd_add_float(touchSensor.rawData[n]);
libpd_finish_message("bela_Trill", "list");
//main_sensor
libpd_start_message(touchSensorMain.numSensors());
libpd_add_float(touchSensorMain.rawData[n]/(2048.f));
libpd_finish_message("bela_Trill_main", "list");
// MODIFICATION END
int num;
#ifdef PARSE_MIDI
switch(message.getType()){
case kmmNoteOn:
break;
case kmmNoteOff:
* with a velocity of 0.
break;
case kmmControlChange:
break;
case kmmProgramChange:
break;
break;
case kmmChannelPressure:
break;
case kmmPitchBend:
int value = ((message.getDataByte(1) < 7)| message.getDataByte(0)) - 8192;
break;
case kmmSystem:
int byte = channel | status;
break;
case kmmNone:
case kmmAny:
break;
#else
int input;
libpd_midibyte(port, input);
//audio input
memcpy(
gInBuf + n * gLibpdBlockSize,
// analog input
memcpy(
// multiplexed analog input
if(pdMultiplexerActive)
unsigned int j;
unsigned int k;
float* p0;
float* p1;
// digital input
if(gDigitalEnabled)
// digital in at message-rate
// digital in at signal-rate
// digital outputs
if(gDigitalEnabled)
// digital out at signal-rate
// scope output
gScopeOut[k] = *p1;
// audio output
memcpy(
//analog output
memcpy(
for(auto a : midi)
delete a;
libpd_closefile(gPatch);
delete [] gScopeOut;
Ok, can you also tell me what is the output of grep v0 /etc/motd
, and how you updated your code last?
giuliomoro the output from grep v0 /etc/motd
is Bela image, v0.3.7a, 16 October 2019
. i did not update this code myself, so i can't answer this immediately.. @Fedde could you specify this further?
ok if it's the latest image, then I don't need further detail. Can you confirm if you have a _main.pd
file in the project folder?
giuliomoro yes i do have a _main.pd file in the project folder. (does it matter that it has a subpatch inside?)
yannick a _main.pd file in the project folder. (does it matter that it has a subpatch inside?)
it doesn't matter that it has a subpatch inside, as long as it is located in the project folder and not in a subdirectory of the project folder.
The above file compiles and runs fine for me. Try one of the following:
- If you are building with the IDE, go to the Settings tab and add to the
Make Parameters:
box the following:AT=
. - If you are building using the
scripts/build_project.sh
script from the host, add-m "AT="
at the end of the command line - if you are building directly with
make
on the board, simply appendAT=
to themake
line
The three actions above will give a more verbose output, please run one of them and paste the output here.
root@bela:~# make AT= -C ~/Bela PROJECT=NonagonBar_Heavy COMPILER=gcc run
`PID=`grep bela-audio /proc/xenomai/sched/stat | cut -d " " -f 5 | sed s/\s//g`; `if [ -z $PID ]; then [ false = true ] || echo "No process to kill"; else [ fal se = true ] || echo "Killing old Bela process $PID"; kill -2 $PID; sleep 0.2; k ill -9 $PID 2> /dev/null; fi; screen -X -S Bela quit > /dev/null; exit 0;
No process to kill
echo 'Building HvMessage.c...'
gcc -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./ build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv 7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje cts/NonagonBar_Heavy/build/HvMessage.d" -o "/root/Bela/projects/NonagonBar_Heavy /build/HvMessage.o" "/root/Bela/projects/NonagonBar_Heavy/HvMessage.c"
/root/Bela/projects/NonagonBar_Heavy/HvMessage.c: In function 'msg_getHash':
/root/Bela/projects/NonagonBar_Heavy/HvMessage.c:151:7: warning: dereferencing t ype-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
echo ' ...done'
...done
echo ' '
`echo 'Building HvControlVar.c...'
gcc -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./ build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv 7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje cts/NonagonBar_Heavy/build/HvControlVar.d" -o "/root/Bela/projects/NonagonBar_He avy/build/HvControlVar.o" "/root/Bela/projects/NonagonBar_Heavy/HvControlVar.c"
echo ' ...done'
...done
echo ' '
`echo 'Building HvTable.c...'
gcc -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./ build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv 7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje cts/NonagonBar_Heavy/build/HvTable.d" -o "/root/Bela/projects/NonagonBar_Heavy/b uild/HvTable.o" "/root/Bela/projects/NonagonBar_Heavy/HvTable.c"
echo ' ...done'
...done
echo ' '
`echo 'Building HvMessagePool.c...'
gcc -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./ build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv 7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje cts/NonagonBar_Heavy/build/HvMessagePool.d" -o "/root/Bela/projects/NonagonBar_H eavy/build/HvMessagePool.o" "/root/Bela/projects/NonagonBar_Heavy/HvMessagePool. c"
echo ' ...done'
...done
echo ' '
`echo 'Building HvControlBinop.c...'
gcc -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./ build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv 7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje cts/NonagonBar_Heavy/build/HvControlBinop.d" -o "/root/Bela/projects/NonagonBar_ Heavy/build/HvControlBinop.o" "/root/Bela/projects/NonagonBar_Heavy/HvControlBin op.c"
echo ' ...done'
...done
echo ' '
`echo 'Building HvControlCast.c...'
gcc -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./ build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv 7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje cts/NonagonBar_Heavy/build/HvControlCast.d" -o "/root/Bela/projects/NonagonBar_H eavy/build/HvControlCast.o" "/root/Bela/projects/NonagonBar_Heavy/HvControlCast. c"
echo ' ...done'
...done
echo ' '
`echo 'Building HvControlDelay.c...'
gcc -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./ build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv 7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje cts/NonagonBar_Heavy/build/HvControlDelay.d" -o "/root/Bela/projects/NonagonBar_ Heavy/build/HvControlDelay.o" "/root/Bela/projects/NonagonBar_Heavy/HvControlDel ay.c"
echo ' ...done'
...done
echo ' '
`echo 'Building HvControlPack.c...'
gcc -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./ build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv 7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje cts/NonagonBar_Heavy/build/HvControlPack.d" -o "/root/Bela/projects/NonagonBar_H eavy/build/HvControlPack.o" "/root/Bela/projects/NonagonBar_Heavy/HvControlPack. c"
echo ' ...done'
...done
echo ' '
`echo 'Building HvMessageQueue.c...'
gcc -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./ build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv 7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje cts/NonagonBar_Heavy/build/HvMessageQueue.d" -o "/root/Bela/projects/NonagonBar_ Heavy/build/HvMessageQueue.o" "/root/Bela/projects/NonagonBar_Heavy/HvMessageQue ue.c"
echo ' ...done'
...done
echo ' '
`echo 'Building HvControlPrint.c...'
gcc -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./ build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv 7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje cts/NonagonBar_Heavy/build/HvControlPrint.d" -o "/root/Bela/projects/NonagonBar_ Heavy/build/HvControlPrint.o" "/root/Bela/projects/NonagonBar_Heavy/HvControlPri nt.c"
echo ' ...done'
...done
echo ' '
`echo 'Building HvUtils.c...'
gcc -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./ build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv 7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje cts/NonagonBar_Heavy/build/HvUtils.d" -o "/root/Bela/projects/NonagonBar_Heavy/b uild/HvUtils.o" "/root/Bela/projects/NonagonBar_Heavy/HvUtils.c"
echo ' ...done'
...done
echo ' '
`echo 'Building HvControlSlice.c...'
gcc -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./ build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv 7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje cts/NonagonBar_Heavy/build/HvControlSlice.d" -o "/root/Bela/projects/NonagonBar_ Heavy/build/HvControlSlice.o" "/root/Bela/projects/NonagonBar_Heavy/HvControlSli ce.c"
echo ' ...done'
...done
echo ' '
`echo 'Building HvLightPipe.c...'
gcc -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./ build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv 7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje cts/NonagonBar_Heavy/build/HvLightPipe.d" -o "/root/Bela/projects/NonagonBar_Hea vy/build/HvLightPipe.o" "/root/Bela/projects/NonagonBar_Heavy/HvLightPipe.c"
echo ' ...done'
...done
echo ' '
`echo 'Building HvControlSystem.c...'
gcc -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./ build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv 7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=g nu11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje cts/NonagonBar_Heavy/build/HvControlSystem.d" -o "/root/Bela/projects/NonagonBar _Heavy/build/HvControlSystem.o" "/root/Bela/projects/NonagonBar_Heavy/HvControlS ystem.c"
echo ' ...done'
...done
echo ' '
`echo 'Building render.cpp...'
g++ -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./ build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv 7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=c ++11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje cts/NonagonBar_Heavy/build/render.d" -o "/root/Bela/projects/NonagonBar_Heavy/bu ild/render.o" "/root/Bela/projects/NonagonBar_Heavy/render.cpp"
/root/Bela/projects/NonagonBar_Heavy/render.cpp: In function 'void render(BelaCo ntext*, void*)':
/root/Bela/projects/NonagonBar_Heavy/render.cpp:531:28: warning: comparison betw een signed and unsigned integer expressions [-Wsign-compare]
/root/Bela/projects/NonagonBar_Heavy/render.cpp:634:20: warning: comparison betw een signed and unsigned integer expressions [-Wsign-compare]
/root/Bela/projects/NonagonBar_Heavy/render.cpp:644:20: warning: comparison betw een signed and unsigned integer expressions [-Wsign-compare]
/root/Bela/projects/NonagonBar_Heavy/render.cpp:717:20: warning: comparison betw een signed and unsigned integer expressions [-Wsign-compare]
/root/Bela/projects/NonagonBar_Heavy/render.cpp:727:20: warning: comparison betw een signed and unsigned integer expressions [-Wsign-compare]
echo ' ...done'
...done
echo ' '
`echo 'Building HeavyContext.cpp...'
g++ -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./ build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv 7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=c ++11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje cts/NonagonBar_Heavy/build/HeavyContext.d" -o "/root/Bela/projects/NonagonBar_He avy/build/HeavyContext.o" "/root/Bela/projects/NonagonBar_Heavy/HeavyContext.cpp "
echo ' ...done'
...done
echo ' '
`echo 'Building HvHeavy.cpp...'
g++ -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./ build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv 7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBAL T__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEB UG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=c ++11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/proje cts/NonagonBar_Heavy/build/HvHeavy.d" -o "/root/Bela/projects/NonagonBar_Heavy/b uild/HvHeavy.o" "/root/Bela/projects/NonagonBar_Heavy/HvHeavy.cpp"
/root/Bela/projects/NonagonBar_Heavy/HvHeavy.cpp:24:0: warning: ignoring #pragma mark [-Wunknown-pragmas]
`/root/Bela/projects/NonagonBar_Heavy/HvHeavy.cpp:45:0: warning: ignoring #pragma mark [-Wunknown-pragmas]
#pragma mark - Heavy Message`
`/root/Bela/projects/NonagonBar_Heavy/HvHeavy.cpp:127:0: warning: ignoring #pragma mark [-Wunknown-pragmas]
#pragma mark - Heavy Common`
`/root/Bela/projects/NonagonBar_Heavy/HvHeavy.cpp:294:0: warning: ignoring #pragma mark [-Wunknown-pragmas]
`echo ' ...done'
...done
echo ' '`
`echo 'Building Heavy_bela.cpp...'
g++ -I/root/Bela/projects/NonagonBar_Heavy -I./include/legacy -I./include -I./build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBALT__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEBUG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=c++11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/projects/NonagonBar_Heavy/build/Heavy_bela.d" -o "/root/Bela/projects/NonagonBar_Heavy/build/Heavy_bela.o" "/root/Bela/projects/NonagonBar_Heavy/Heavy_bela.cpp"
echo ' ...done'
...done
echo ' '`
`./resources/tools/detectlibraries.sh --project NonagonBar_Heavy
make -f Makefile.linkbela --no-print-directory /root/Bela/projects/NonagonBar_Heavy/NonagonBar_Heavy
echo 'Linking...'
Linking...
g++ -Llib/ -fno-pie -no-pie -pthread -o "/root/Bela/projects/NonagonBar_Heavy/NonagonBar_Heavy" build/core/FormatConvert.o build/core/OscillatorBank_routines.o build/core/math_runfast.o build/core/Gpio.o build/core/I2c_Codec.o build/core/RTAudio.o build/core/PruBinary.o build/core/RTAudioCommandLine.o build/core/AuxTaskNonRT.o build/core/JSONValue.o build/core/board_detect.o build/core/WSServer.o build/core/AuxiliaryTasks.o build/core/PRU.o build/core/AuxTaskRT.o build/core/IirFilter.o build/core/GPIOcontrol.o build/core/Spi_Codec.o build/core/DigitalChannelManager.o build/core/JSON.o ./build/core/default_main.o /root/Bela/projects/NonagonBar_Heavy/build/HvMessage.o /root/Bela/projects/NonagonBar_Heavy/build/HvControlVar.o /root/Bela/projects/NonagonBar_Heavy/build/HvTable.o /root/Bela/projects/NonagonBar_Heavy/build/HvMessagePool.o /root/Bela/projects/NonagonBar_Heavy/build/HvControlBinop.o /root/Bela/projects/NonagonBar_Heavy/build/HvControlCast.o /root/Bela/projects/NonagonBar_Heavy/build/HvControlDelay.o /root/Bela/projects/NonagonBar_Heavy/build/HvControlPack.o /root/Bela/projects/NonagonBar_Heavy/build/HvMessageQueue.o /root/Bela/projects/NonagonBar_Heavy/build/HvControlPrint.o /root/Bela/projects/NonagonBar_Heavy/build/HvUtils.o /root/Bela/projects/NonagonBar_Heavy/build/HvControlSlice.o /root/Bela/projects/NonagonBar_Heavy/build/HvLightPipe.o /root/Bela/projects/NonagonBar_Heavy/build/HvControlSystem.o /root/Bela/projects/NonagonBar_Heavy/build/render.o /root/Bela/projects/NonagonBar_Heavy/build/HeavyContext.o /root/Bela/projects/NonagonBar_Heavy/build/HvHeavy.o /root/Bela/projects/NonagonBar_Heavy/build/Heavy_bela.o libraries/Midi/build/Midi.o libraries/Midi/build/Midi_c.o libraries/Scope/build/Scope.o libraries/Trill/build/Trill.o libraries/UdpServer/build/UdpServer.o -lasound -lseasocks -lNE10 -Wl,--no-as-needed -L/usr/xenomai/lib -lcobalt -lmodechk -lpthread -lrt -lprussdrv -lstdc++ -Wl,--no-as-needed -L/usr/xenomai/lib -lcobalt -lmodechk -lpthread -lrt -lasound -lseasocks -lNE10 -lmathneon -lmathneon
/root/Bela/projects/NonagonBar_Heavy/build/render.o: In function `fdLoop(void*)':
/root/Bela/projects/NonagonBar_Heavy/build/render.o: In function `render':
/root/Bela/projects/NonagonBar_Heavy/build/render.o: In function `cleanup':
/root/Bela/projects/NonagonBar_Heavy/build/render.o: In function `Bela_messageHook(char const*, char const*, int, _atom*)':
/root/Bela/projects/NonagonBar_Heavy/build/render.o: In function `setup':
/root/Bela/projects/NonagonBar_Heavy/build/render.o: In function `sendDigitalMessage(bool, unsigned int, void*)':
`render.cpp:(.text+0x76): undefined reference to `libpd_float'
Makefile.linkbela:42: recipe for target '/root/Bela/projects/NonagonBar_Heavy/NonagonBar_Heavy' failed
make[1]: *** [/root/Bela/projects/NonagonBar_Heavy/NonagonBar_Heavy] Error 1
Makefile:526: recipe for target '/root/Bela/projects/NonagonBar_Heavy/NonagonBar_Heavy' failed
make: *** [/root/Bela/projects/NonagonBar_Heavy/NonagonBar_Heavy] Error 2
make: Leaving directory '/root/Bela'`
that line
suggests that there is no _main.pd
file in the project folder. Can you show the output of ls /root/Bela/projects/NonagonBar_Heavy
I still don't understand why you have all the files generated by the Heavy compiler, but you are using a render.cpp
file that is for libpd
. Could it be the case that you are trying to build a Heavy project, but including the wrong custom render.cpp
in it?
giuliomoro thanks a lot!! actually that's what happened. I am trying to make a heavy project out of my pd project. it compiles succesfully after i just used the render.cpp file from ~/Bela/scripts/hvresources/render.cpp
. Only i have to alter the render.cpp file, as it is now not reading the sensor values (it just prints zero's), also the setup function for the sensors has got to be in there i think (or should i add these in a different location?) . Is there any way to convert the libpd version of the render.cpp file to one that works with heavy? or do i have to do that manually? (the lib pd version of the functions i wish to add is marked with //MODIFICATION START and //MODIFICATION END in the pasted render.cpp file above.)could you give me some directions?
