I'm having trouble getting my Bela and CTAG Beast setup to upload anything from the IDE. Initially, attempted uploads returned:
audio frame 1267552, errorCode: 3
McASP unexpected transmit frame sync occurred)
I found this discussion on the forum
https://forum.bela.io/d/4657-mcasp-unexpected-transmit-frame-sync-occurred
I double checked my stack and everything is setup correctly according to this page:
https://learn.bela.io/using-bela/technical-explainers/configuring-ctag/
Now, when I try to run the code from the IDE, the upload process never ends and no error codes are returned. Instead, a solid red light appears on the Bela Cape (D6).
Very new to Bela. Any links or suggestions would be helpful, thanks.
Can you try swapping the two capes and reconfiguring the two sets of jumpers?
  • kmg replied to this.
    giuliomoro I could, but I have no experience soldering and I don't have my own tools for that. Are there other options besides swapping capes, or is that the first thing to do?
    There's no soldering involved. You can remove each cape as shown here:
    I separated the capes and ensured that the configuration had one leader and one follower. I double checked that the Bela Cape is working when attached to the BeagleBone Black (no FACE Capes attached) and it definitely is. When I have the Bela Cape on top of the stacked FACE Capes (bottom-top: BeagleBone Black, FACE (follower), FACE (master), Bela Cape), the code does not upload and the Bela Cape displays a solid red light.
    I just tried stacking the bela cape on top of the face capes and noticed the bela had the blinking blue light. ran the code and it worked for about two seconds. I readjusted the bela cape to see if it was just not connected securely, and the red light came back on and audio stopped. it's been displaying the solid red light since. any thoughts?
    When you get a red light, what do you get printed on the IDE console?
    Try updating your board to the latest dev branch (see here) and see if that works for you.
    I updated the board with this dev branch through the IDE. The red light still comes on and this is the new error.
    can you run this in the console at the bottom of the IDE?
    grep REG_ADC_CONTROL_2 core/Spi_Codec.cpp
    and show the result here
    since reconnecting bela after updating the board to the latest dev branch, i have not been able to access the IDE.
    i reflashed my sd card and updated my board with the latest master branch through terminal.
    after this point, still no IDE access despite macbook recognizing Bela board.
    That's weird. Can you run this from a terminal on your computer ? curl bela.local : what do you get? Also show the output of ifconfig.
    curl bela.local output:
    <!DOCTYPE html>
    <html>
    <head>
    <meta charset="utf-8">
    <title data-title>Bela IDE</title>
    <!-- <link rel="stylesheet" type="text/css" href="stylesheet.css?v=1" /> -->
    <link rel="stylesheet" type="text/css" href="/css/style.css" />
    <link rel="stylesheet" type="text/css" href="/css/goldenlayout-base.css" />
    <link rel="stylesheet" type="text/css" href="/css/goldenlayout-light-theme.css" />
    <script src="js/jquery.js"></script>
    </head>
    <body>
    <svg data-drag-svg></svg>
    <div class="upper" data-upper>
      <div class="file-status">
        <span class="project">Project: <span class="current" data-current-project>None</span></span>
        <span class="file">File: <span class="current" data-current-file>None</span></span>
        <span><span class="status" data-current-status-title></span> <span class="current" data-current-status></span></span>
        <div class="project read-only">THIS WINDOW IS IN READ-ONLY MODE. Click here to reload.</div>
      </div>
      <div class="toolbar" id="toolbar" data-toolbar>
        <div class="shutdown-parent">
          <span class="control-button-shutdown shutdown toolBar" data-toolbar-shutdown id="shutdown" data-func="shutdownBBB"></span>
        </div>
        <div class="logo">
          <img src="images/logo.png">
        </div>
        <!-- <div id="control-text-3" class="tool-text st-st" data-toolbar-controltext3></div> -->
        <div class="start-stop">
          <span class="control-button-runstop start run toolBar" data="Run project" id="run" data-toolbar-run data-func="run"></span>
          <span class="control-button-runstop start stop toolBar" data="Stop project" data-toolbar-stop id="stop" data-func="stop"></span>
        </div>
        <div id="control-text-1" class="tool-text st-st" data-toolbar-controltext1></div>
        <div class="toolbar-functions">
          <span class="scope-button toolBar" data-toolbar-scope data="Launch scope"></span>
          <span class="gui-button toolBar" data-toolbar-gui data="Launch GUI"></span>
          <span class="console-button toolBar" data-toolbar-console data="Clear console" data-func="clearConsole"></span>
        </div>
        <div id="control-text-2" class="tool-text st-st" data-toolbar-controltext2></div>
        <!-- <div class="tool-text other"></div> -->
        <!-- <span id="control-text-3" class="control-text tool-text" data-toolbar-controltext3></span> -->
        <!-- <div class="system-status-text bela">Bela: --%</div> -->
        <div class="system-status-text cpu" data-toolbar-bela-cpu>CPU: --%</div>
        <div class="system-status-text msw" data-toolbar-cpu-msw>MSW: --</div>
        <div class="syntax-status" data-toolbar-status></div>
      </div>
      <!-- media divs -->
      <div id="img-display-parent" data-img-display-parent>
        <img id="img-display" data-img-display />
      </div>
      <div id="pd-svg-parent" data-pd-svg-parent>
        <div id="pd-svg" data-pd-svg></div>
      </div>
      <div id="audio-parent" data-audio-parent>
        <audio id="audio" data-audio controls></audio>
      </div>
      <div id="editor-msg-parent" data-editor-msg-parent>
        <div id="editor-msg" data-editor-msg></div>
      </div>
      <pre id="editor" class="editor" data-editor></pre>
      <!-- tabs -->
      <div class="tabs" data-tabs>
        <div id="tab-menu" data-tab-menu>
          <ul class="tab-switches">
            <li id="open-tab" data-tab-open>
              <span class="tab-button">+</span>
            </li>
            <li class="explorer" data-tab-for="explorer" title="File explorer">
            </li>
            <li class="examples" data-tab-for="examples" title="Examples">
            </li>
            <li class="settings" data-tab-for="settings" title="Settings">
            </li>
            <li class="pins" data-tab-for="pins" title="Pin diagram">
            </li>
            <li class="refs" data-tab-for="refs" title="Documentation">
            </li>
            <li class="libraries" data-tab-for="libraries" title="Libraries">
            </li>
          </ul>
        </div>
        <!--  tab content  -->
        <div id="tab-content-area">
          <section id="tab-content" data-tab-content>
            <div class="tab-info" data-tab="explorer">
              <div class="title-container">
                <h1>Project Explorer<hr /></h1>
              </div>
              <span class="dropdown" data-projects>
                <button class="dropbtn" data-dropdown-for="project">Your projects</button>
                <div class="dropdown-content" data-dropdown="project">
                  <ul class="projectManager" id="projects" data-projects-select data-func="openProject">
                  </ul>
                  <!-- <select class="projectManager" id="projects" data-projects-select data-func="openProject" multiple>
                  </select> -->
                </div>
              </span>
              <button id="new" class="create-project projectManager" data-func="newProject">New Project</button>
              <div class="open-project">
                <p class="project">Current project: <span data-current-project>None</span></p>
              </div>
              <div class="project-actions">
                <button class="project-button project-save projectManager" data-func="saveAs" id="saveas" title="Save project as ..."></button>
                <button class="project-button project-new fileManager" data-func="newFile" title="Create new file"></button>
                <button class="project-button project-new-folder fileManager" data-func="newFolder" title="Create new folder"></button>
                <button class="button project-button project-upload fileManager" data-func="uploadFile" id="uploadFile" title="Upload file"></button>
                <a data-project-download href="/download" download><button class="project-button project-download fileManager" id="downloadProject" title="Download project"></button></a>
                <button class="project-button project-clean projectManager" id="cleanProject" data-func="cleanProject" title="Clean project"></button>
                <button class="project-button project-delete projectManager" id="deleteProject" data-func="deleteProject" title="Delete project"></button>
                <p class="project-text"></p>
              </div>
              <button class="accordion active" data-accordion-for="project-files" data-parent="explorer">Project contents</button>
              <div class="panel show" data-accordion="project-files">
                <div class="file-list" data-file-list>
                </div>
              </div>
              <button class="accordion" data-accordion-for="git" data-parent="explorer">Git manager</button>
              <div class="panel" data-accordion="git">
                <div class="git-no-repo" data-git-no-repo>
                  <button class="git-manager" data-func="init">Initialise Repo</button>
                </div>
                <div class="git-repo" data-git-repo>
                  <table class="gitTable">
                    <tr>
                      <td>
                        <button class="git-manager" data-func="command" data-command="status">Git status</button>
                        <button class="git-manager" data-func="command" data-command="log --pretty=oneline">Git log</button>
                      </td>
                    </tr>
                    <tr>
                      <td>
                        <select id="branches" class="git-manager" data-git-branches data-func="checkout"></select>
                        <button class="git-manager" data-func="branch">Create new branch</button>
                      </td>
                    </tr>
                    <tr>
                      <td>
                        <button class="git-manager" data-func="command" data-command="add -A">Stage all changes</button>
                        <button class="git-manager" data-func="commit" >Commit</button>
                        <button class="git-manager" data-func="command" data-command="checkout -- .">Discard changes</button>
                      </td>
                      <!--<button class="git-manager" data-func="command" data-command="revert HEAD">revert previous commit</button>-->
                    </tr>
                    <tr>
                      <td><select id="commits" class="git-manager" data-git-commits data-func="checkout"></select></td>
                    </tr>
                    <tr>
                      <td>
                        <form data-git-form class="git-manager">
                          <p>Git command: <input data-git-input type="text"></p>
                        </form>
                      </td>
                    </tr>
                  </table>
                </div>
              </div>
            </div>
            <div class="tab-info" data-tab="examples">
                <h1>Examples<hr /></h1>
              </div>
              <ul class="projectManager" data-examples data-func="openExample"></ul>
            </div>
            <div class="tab-info" data-tab="settings">
                <h1>Settings<hr /></h1>
              </div>
              <table class="tabTable choice boot">
              <tr>
                <td class="left-choice">Run project on boot:</td>
                <td class="right-choice">
                  <span class="mini-dropdown">
                    <select id="runOnBoot" class="small" data-run-on-boot></select>
                  </span>
                </td>
              </tr>
            </table>
              <button class="accordion active" data-accordion-for="project-settings" data-parent="settings">Project Settings</button>
              <div class="panel show" data-accordion="project-settings">
                <table class="tabTable choice">
                  <tr>
                    <td class="left-choice">Block size (audio frames):</td>
                        <select id="buffer-size" class="settingsManager small" data-func="setCLArg" data-key="-p">
                          <option value="2">2</option>
                          <option value="4">4</option>
                          <option value="8">8</option>
                          <option value="16">16</option>
                          <option value="32">32</option>
                          <option value="64">64</option>
                          <option value="128">128</option>
                          <option value="256">256</option>
                          <option value="512">512</option>
                          <option value="1024">1024</option>
                          <option value="2048">2048</option>
                          <option value="4096">4096</option>
                        </select>
                      </span>
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">Analog Channels:</td>
                        <select id="analog-channels" class="settingsManager small" data-func="setCLArg" data-key="-C">
                        </select>
                      </span>
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">Analog Sample Rate (Hz):</td>
                        <select id="analog-samplerate" class="settingsManager small" data-analog-samplerate data-func="setCLArg" data-key="-C">
                          <option value="2">88200</option>
                          <option value="4">44100</option>
                          <option value="8">22050</option>
                        </select>
                      </span>
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">Digital Channels:</td>
                        <select id="digital-channels" class="settingsManager small" data-func="setCLArg" data-key="-B">
                        </select>
                      </span>
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">Use Analog:</td>
                      <input type="checkbox" id="use-analog" class="settingsManager checkbox-slider" data-func="setCLArg" data-key="-N" value="1">
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">Use Digital:</td>
                      <input type="checkbox" id="use-digital" class="settingsManager checkbox-slider" data-func="setCLArg" data-key="-G" value="1"><span></span>
                    </td>
                  </tr>
                  <tr data-settings="mute-speaker">
                    <td class="left-choice">Mute Speaker:</td>
                      <input type="checkbox" id="mute-speaker" class="settingsManager checkbox-slider" data-func="setCLArg" data-key="-M" value="1">
                    </td>
                  </tr>
                  <tr data-settings="disable-led">
                    <td class="left-choice">Disable LED:</td>
                      <input type="checkbox" class="settingsManager checkbox-slider" data-func="setCLArg" data-key="--disable-led" value="0">
                    </td>
                  </tr>
    <script>
    function generateNumberBoxes(preTitle, postTitle, flag, dataSettings, count, min, max, step) {
    let out = '';
    for (let c = 0; c < count; ++c) {
    let text = <tr data-settings="${dataSettings}${c}">
    <td class="left-choice">${preTitle} ${c} ${postTitle}:</td>
    <span class="number-picker" data-number-picker>
    <button class="settingsManager input-number-decrement" data-func="setCLArg" data-key="${flag}${c}," data-number-picker-decrement>-</button>
    <input id="${flag}${c}," class="settingsManager input-number number-picker" data-func="setCLArg" type="text" min="${min}" max="${max}" step="${step}" data-key="${flag}${c}," data-number-picker-input></input>
    <button class="settingsManager input-number-increment" data-func="setCLArg" data-key="${flag}${c}," data-number-picker-increment>+</button>
    </span>
    </td>
    </tr>
    out += text;
    return out;
    function generateHp(numChannels) {
    return generateNumberBoxes('Headphone', 'level (dB)', '-H', 'headphone-level', numChannels, -63, 0, 1);
    document.write(generateHp(8));
    function generateInputGain(numChannels) {
    return generateNumberBoxes('Input ', 'gain (dB)', '-I', 'input-level', numChannels, -12, 60, 1);
    document.write(generateInputGain(8));
    </script>
    <tr data-settings="user-clargs">
    <td class="left-choice">User Command Line Arguments:</td>
    <textarea class="settingsManager" data-func="setCLArg" data-key="user"></textarea>
    </td>
    </tr>
    <tr data-settings="make-params">
    <td class="left-choice">Make Parameters:</td>
    <textarea class="settingsManager" data-func="setCLArg" data-key="make"></textarea>
    </td>
    </tr>
    </table>
    <button class="settingsManager settings-button" data-func="restoreDefaultCLArgs">Restore default project settings</button>
    </div>
              <button class="accordion" data-accordion-for="capelet-settings" data-parent="settings">Capelet Settings</button>
              <div class="panel" data-accordion="capelet-settings">
                <table class="tabTable capelet-settings choice">
                  <tr>
                    <td class="left-choice">Multiplexer Capelet:</td>
                        <select id="multiplexer-capelet" class="settingsManager small" data-func="setCLArg" data-key="-X">
                          <option value="0">Not Used</option>
                          <option value="2">16 Channels</option>
                          <option value="4">32 Channels</option>
                          <option value="8">64 Channels</option>
                        </select>
                      </span>
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">Audio Expander Capelet:</td>
                        <select id="audio-expander-capelet" class="settingsManager small" data-func="useAudioExpander" data-key="audioExpander">
                          <option value="1">Active</option>
                        </select>
                      </span>
                    </td>
                  </tr>
                </table>
                <p class="tab-subheading">Audio Expander channel toggles:</p>
                <table id="audioExpanderTable" data-audio-expander-table class="choice">
                  <tr>
                    <th class="left-choice">Channel</th>
                    <th class="right-choice half">Input</th>
                    <th class="right-choice half">Output</th>
                  </tr>
                  <tr>
                    <td class="left-choice">0</td>
                    <td class="right-choice half">
                      <input type="checkbox" class="audioExpanderCheck checkbox-slider" data-channel="0" data-func="input" value="0" >
                    </td>
                      <input type="checkbox" class="audioExpanderCheck checkbox-slider" data-channel="0" data-func="output" value="0" >
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">1</td>
                      <input type="checkbox" class="audioExpanderCheck checkbox-slider" data-channel="1" data-func="input" value="0" >
                    </td>
                      <input type="checkbox" class="audioExpanderCheck checkbox-slider" data-channel="1" data-func="output" value="0" >
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">2</td>
                      <input type="checkbox" class="audioExpanderCheck checkbox-slider" data-channel="2" data-func="input" value="0" >
                    </td>
                      <input type="checkbox" class="audioExpanderCheck checkbox-slider" data-channel="2" data-func="output" value="0" >
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">3</td>
                      <input type="checkbox" class="audioExpanderCheck checkbox-slider" data-channel="3" data-func="input" value="0" >
                    </td>
                      <input type="checkbox" class="audioExpanderCheck checkbox-slider" data-channel="3" data-func="output" value="0" >
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">4</td>
                      <input type="checkbox" class="audioExpanderCheck checkbox-slider" data-channel="4" data-func="input" value="0" >
                    </td>
                      <input type="checkbox" class="audioExpanderCheck checkbox-slider" data-channel="4" data-func="output" value="0" >
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">5</td>
                      <input type="checkbox" class="audioExpanderCheck checkbox-slider" data-channel="5" data-func="input" value="0" >
                    </td>
                      <input type="checkbox" class="audioExpanderCheck checkbox-slider" data-channel="5" data-func="output" value="0" >
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">6</td>
                      <input type="checkbox" class="audioExpanderCheck checkbox-slider" data-channel="6" data-func="input" value="0" >
                    </td>
                      <input type="checkbox" class="audioExpanderCheck checkbox-slider" data-channel="6" data-func="output" value="0" >
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">7</td>
                      <input type="checkbox" class="audioExpanderCheck checkbox-slider" data-channel="7" data-func="input" value="0" >
                    </td>
                      <input type="checkbox" class="audioExpanderCheck checkbox-slider" data-channel="7" data-func="output" value="0" >
                    </td>
                  </tr>
                </table>
              </div>
              <button class="accordion" data-accordion-for="ide-settings" data-parent="settings">IDE Settings</button>
              <div class="panel" data-accordion="ide-settings">
                  <tr>
                    <td class="left-choice">Autocomplete:</td>
                      <input type="checkbox" id="liveAutocompletion" class="settingsManager checkbox-slider" data-func="setIDESetting" data-key="liveAutocompletion" value="1" >
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">Syntax Checking:</td>
                      <input type="checkbox" id="liveSyntaxChecking" class="settingsManager checkbox-slider" data-func="setIDESetting" data-key="liveSyntaxChecking" value="1" >
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">Restart upon upload:</td>
                      <input type="checkbox" id="restartUponUpload" class="settingsManager checkbox-slider" data-func="setIDESetting" data-key="restartUponUpload" value="1" >
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">Verbose build errors:</td>
                      <input type="checkbox" id="verboseErrors" class="settingsManager checkbox-slider" data-func="setIDESetting" data-key="verboseErrors" value="1" >
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">CPU monitoring:</td>
                      <input type="checkbox" id="cpuMonitoring" class="settingsManager checkbox-slider" data-func="setIDESetting" data-key="cpuMonitoring" value="1" >
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">Xenomai stats:</td>
                      <input type="checkbox" id="cpuMonitoringVerbose" class="settingsManager checkbox-slider" data-func="setIDESetting" data-key="cpuMonitoringVerbose" value="1" >
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">Never delete console logs:</td>
                      <input type="checkbox" id="consoleDelete" class="settingsManager checkbox-slider" data-func="setIDESetting" data-key="consoleDelete" value="1" >
                    </td>
                  </tr>
                  <tr>
                    <td class="left-choice">View hidden files:</td>
                      <input type="checkbox" id="viewHiddenFiles" class="settingsManager checkbox-slider" data-func="setIDESetting" data-key="viewHiddenFiles" value="1" >
                    </td>
                  </tr>
                </table>
                <button class="settingsManager settings-button" data-func="restoreDefaultIDESettings">Restore default IDE settings</button>
              </div>
              <button class="accordion" data-accordion-for="feedback-panel" data-parent="settings">Feedback</button>
              <div class="panel" data-accordion="feedback-panel">
                <p>We listen to and rely on your feedback to make this IDE the best it can be. We would love to hear what you think - these forms take only a few mintues, and require an internet conneciton.</p>
                <p>Please fill out our general feedback form to share your thoughts and experiences with the new IDE:</p>
                <button class="general feedback"><a href="https://forms.gle/hHkLMTUaCELPD8bR7" target="_blank">Go to the General Feedback form</a></button>
                <p>Found a bug? Take some screenshots, and report it here:</p>
                <button class="bug feedback"><a href="https://forms.gle/wEpF7Tp5ZBV2Q3bY7" target="_blank">Go to the Bug Report form</a></button>
              </div>
              <button class="accordion" data-accordion-for="other-settings" data-parent="settings">Other system functions</button>
              <div class="panel" data-accordion="other-settings">
                <button class="settingsManager" data-func="shutdownBBB">Shutdown Bela</button>
                <br />
                <a href="download?all=all" download><button class="settingsManager">Download All Projects</button></a>
                <br />
                <button class="settingsManager" data-func="updateBela">Update Bela</button>
                <br />
                <button class="settingsManager" data-func="aboutPopup">About Bela</button>
                <br />
                <button class="settingsManager" data-func="versionPopup">Version details</button>
              </div>
            </div>
            <div class="tab-info" data-tab="pins">
                <h1>Pin Diagram<hr /></h1>
              </div>
              <tr>
                <td class="left-choice">Current diagram:</td>
                    <select id="activeBoard" class="small" data-board-select>
                      <option value="Bela">Bela</option>
                      <option value="BelaRevC">Bela Rev C</option>
                      <option value="BelaMini">Bela Mini</option>
                      <option value="BelaMiniMultiAudio">Bela Mini Multichannel</option>
                      <option value="CtagFace">CTAG FACE</option>
                      <option value="CtagFaceBela">CTAG FACE + Bela</option>
                      <option value="CtagBeast">CTAG BEAST</option>
                      <option value="CtagBeastBela">CTAG BEAST + Bela</option>
                    </select>
                  </span>
                </td>
              </tr>
            </table>
              <div id="pin_container">
                <!-- <p class="diagram-text">Hover over the coloured sections for more information.</p> -->
                <object data="belaDiagram/diagram.html" id="pin_diagram_object" data-pin-diagram>
                  Your browser doesn’t support the object tag.
                </object>
              </div>
            </div>
            <div class="tab-info" data-tab="refs">
                <h1>Documentation<hr /></h1>
              </div>
              <a href="documentation" target="_blank">
                <button class="doc-button">Launch full documentation</button>
              </a>
              <div id="docsParent" class="sections">
                  <button class="accordion" data-parent="refs" data-accordion-for="bela-context">The Bela Context</button>
                  <div class="panel" data-accordion="bela-context">
                    <ul class="subsections" data-docs-context>
                    </ul>
                  </div>
                  <button class="accordion" data-parent="refs" data-accordion-for="api">The API</button>
                  <div class="panel" data-accordion="api">
                    <ul class="subsections" data-docs-api>
                    </ul>
                  </div>
                  <button class="accordion" data-parent="refs" data-accordion-for="utilities">Utilities</button>
                  <div class="panel" data-accordion="utilities">
                    <ul class="subsections" data-docs-utility>
                    </ul>
                  </div>
              </div>
            </div>
            <div class="tab-info" data-tab="libraries">
                <h1>Libraries<hr /></h1>
              </div>
              <ul class="libraries-list-parent" data-libraries-list data-func="resources"></ul>
            </div>
          </section>
        </div>
      </div>
    </div>
    <div id="beaglert-console" data-console>
      <div id="beaglert-consoleWrapper" data-console-contents-wrapper></div>
      <form id="beaglert-consoleForm" data-console-form>
        <div id="beaglert-console-inputLeft">
          <div id="beaglert-consoleInput-pre" data-console-input-pre></div>
        </div>
        <div id="beaglert-console-inputRight">
          <input id="beaglert-consoleInput" type="text" autocomplete="off" data-console-input/>
        </div>
        <input type="submit" style="visibility: hidden; display: none;" />
      </form>
    </div>
    <div id="overlay" data-overlay>
    </div>
    <div id="popup" data-popup>
      <div id="popup-content" data-popup-content>
        <h1></h1>
        <h3></h3>
        <p></p>
        <code></code>
        <form>
        </form>
      </div>
    </div>
    <div id="popup-nointeraction" data-popup-nointeraction>
    </div>
    <script src="js/ace/ace.js"></script>
    <script src="js/ace/ext-language_tools.js"></script>
    <script src="socket.io/socket.io.js"></script>
    <script src="js/keypress.js"></script>
    <script src="js/pd-fileutils.js"></script>
    <script src="js/goldenlayout.js"></script>
    <script src="js/polyfill.js"></script>
    <script src="js/clipboard.min.js"></script>
    <script src="js/bundle.js"></script>
    <script src="js/interface.js"></script>
    </body>
    </html>
    ifconfig output (bela on en10):
    inet6 ::1 prefixlen 128
    stf0: flags=0<> mtu 1280
    en5: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 16000
    ether ac:de:48:00:11:22
    inet6 fe80::aede:48ff:fe00:1122%en5 prefixlen 64 scopeid 0x4
    status: active
    ap1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    options=6460<TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM>
    ether 96:be:db:5f:33:4a
    inet6 fe80::94be:dbff:fe5f:334a%ap1 prefixlen 64 scopeid 0x6
    media: autoselect (<unknown type>)
    status: inactive
    ether 1a:e7:53:42:ba:4d
    inet6 fe80::45a:b0fe:3c10:a966%en0 prefixlen 64 secured scopeid 0x7
    inet 192.168.0.81 netmask 0xffffff00 broadcast 192.168.0.255
    media: autoselect
    status: active
    awdl0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether 16:70:10:ce:4e:1c
    inet6 fe80::1470:10ff:fece:4e1c%awdl0 prefixlen 64 scopeid 0x8
    media: autoselect
    status: active
    options=400<CHANNEL_IO>
    inet6 fe80::1470:10ff:fece:4e1c%llw0 prefixlen 64 scopeid 0x9
    media: autoselect
    status: inactive
    ether 82:e5:9e:46:58:01
    status: inactive
    ether 82:e5:9e:46:58:00
    status: inactive
    en4: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    ether 82:e5:9e:46:58:04
    status: inactive
    en3: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    ether 82:e5:9e:46:58:05
    status: inactive
    Configuration:
    ipfilter disabled flags 0x0
    ifmaxaddr 0 port 10 priority 0 path cost 0
    ifmaxaddr 0 port 11 priority 0 path cost 0
    member: en3 flags=3<LEARNING,DISCOVER>
    ifmaxaddr 0 port 13 priority 0 path cost 0
    member: en4 flags=3<LEARNING,DISCOVER>
    ifmaxaddr 0 port 12 priority 0 path cost 0
    media: <unknown type>
    status: inactive
    utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1500
    inet6 fe80::85be:84b9:bdec:c9ee%utun0 prefixlen 64 scopeid 0xf
    utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
    inet6 fe80::bc3f:84a4:9d8e:e392%utun1 prefixlen 64 scopeid 0x10
    utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
    inet6 fe80::b79e:1dd5:de98:cfe4%utun2 prefixlen 64 scopeid 0x11
    utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1000
    inet6 fe80::ce81:b1c:bd2c:69e%utun3 prefixlen 64 scopeid 0x12
    en11: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether 8a:66:5a:bc:ff:b0
    inet6 fe80::7a:3f81:8f11:ff4e%en11 prefixlen 64 secured scopeid 0x13
    inet 169.254.127.170 netmask 0xffff0000 broadcast 169.254.255.255
    status: active
    en7: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether be:d7:ba:07:91:7e
    inet6 fe80::bcd7:baff:fe07:917e%en7 prefixlen 64 scopeid 0x14
    media: autoselect
    status: active
    en10: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether be:1a:24:83:1c:04
    inet6 fe80::c6a:d771:5cc0:ab0b%en10 prefixlen 64 secured scopeid 0x5
    inet 192.168.7.1 netmask 0xffffff00 broadcast 192.168.7.255
    status: active
    curl shows that the board can be reached, the IDE works and is up and running. ifconfig shows that you can use either bela.local or 192.168.7.2 .
    Good. Try accessing the board making explicit the http protocol: http://192.168.7.2 or http://bela.local
    okay. tried both explicit addresses again and still yields site as unreachable
    Is it possible that you have some extensions in your browser that prevent you from accessing http pages? Can you try a different browser, e.g.: Safari?
    yes, browser was preventing access. odd because i had access through chrome before and didn't change settings, but IDE comes up in safari.
    i ran "grep REG_ADC_CONTROL_2 core/Spi_Codec.cpp" in IDE console and received the same output as before (after latest dev upload)
    updating Bela with master zip file through IDE to test again
