is the network you are trying to connect to listed among those?
There is also the possibility that you somehow mistyped the path to /etc/wpa_supplicant/wpa_supplicant.conf ?
5 days later
So, I haven't tried to connect to anything. I thought that the first step was getting an IP in the list of network devices. But, yes - there are a few of the networks listed that I can connect to.
Does it mean I can connect to them?
If the network you want to connect to is listed there, and you have appropriately set the network name and passphrase in /etc/wpa_supplicant/wpa_supplicant.conf, and there are no typos involved, then doing ifup wlan0 should try to connect to the network, and, upon success, obtain an IP address.
Another thing to check is that your network router actually has a DHCP server on it to assign IP addresses. This is normally the default on home networks. If your computer can connect to this network and work properly without a special configuration, then it's probably safe to assume the DHCP is working fine.
Hi
So I put in some quotation marks (") since I had a space in the network name, and the printout from the ifup/down has changed:
root@bela:~# ifup wlan0; ifdown wlan0;
Internet Systems Consortium DHCP Client 4.3.5
Copyright 2004-2016 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/wlan0/8c:3b:ad:2f:39:26
Sending on LPF/wlan0/8c:3b:ad:2f:39:26
Sending on Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 3
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 16
DHCPREQUEST of 192.168.0.102 on wlan0 to 255.255.255.255 port 67
DHCPOFFER of 192.168.0.102 from 192.168.0.1
DHCPACK of 192.168.0.102 from 192.168.0.1
bound to 192.168.0.102 -- renewal in 25 seconds.
Killed old client process
DHCPRELEASE on wlan0 to 192.168.0.1 port 67
Still, i don't get any ip address when I do ip a. (I get: 3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 8c:3b:ad:2f:39:26 brd ff:ff:ff:ff:ff:ff)
Does it mean that it is still not connected?
    Hmmm that's weird:
    would indicate that you are actually successfully connected.
    not sure about the
    part ...
    Did you retry ifup wlan0; ifup wlan0 ?
    Hi,
    so I did only
    and got
    DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 9
    bound to 192.168.0.102 -- renewal in 31 seconds.
    and now I finally got an IP when I do ip a. So, I guess it finally worked! Thanks for all the help
    best,
    Andreas
    Great!
    andreasb So I put in some quotation marks (") since I had a space in the network name, and the printout from the ifup/down
    hmm, that was not the case here
    andreasb ssid="VIBRA_network"
    13 days later
    I have a strange problem since i tried to install the wifi dongle as explained above.
    I got it to install the files, it took some time and finished telling there were time skew errors.
    Then i rebooted bela, since then it is not recognized by the Windows PC anymore when i plug the
    USB connector. No sound of new connected device, no bela partition in the explorer, bela IDE doesn't
    load in browser and ssh doesn't work either. i'm out of ideas.
    How did you shut down the board after installing the driver? If the shutdown was not graceful am afraid you may have a corrupted file /lib/modules/4.4.113-ti-xenomai-r148/modules.dep.bin (and possibly more), similarly to what happened here. If you don't have a UART device at hand (or a spare Bela, that is, then you may have to re-flash your card.
    The "date skew" error is normally not a problem, though you can avoid it by loading up the IDE before you start the process.
      Thanks for the fast diagnose!
      You nailed it probably, after installation i closed the terminal and power cycled (hard) for the reboot.
      No second Bela at hand and i got mine without the SD card early December.
      I was planning to get a second Bela anyway, so i'll take it a bit earlier than planned 😉
      Can you confirm that if i order a Bela now from the shop, that it will come with a never software version that has the netgear drivers pre-installed?
        bj_gzp Can you confirm that if i order a Bela now from the shop, that it will come with a never software version that has the netgear drivers pre-installed?
        No, you would still have to go through the manual installation process.
        bj_gzp I was planning to get a second Bela anyway, so i'll take it a bit earlier than planned 😉
        That's great. However, let me be clear: you don't actually need another Bela to get the first one to work. You can just get an SD card and flash it with the image and then follow the instructions to copy the content of the SD card to the eMMC. If you had another Bela, you would be able to use it as a UART adapter as explained at the link in the previous post (or you could use any other UART adapter you may have around). You would then:
        • remove the Bela cape
        • connect your UART adapter as explaineder here
        • login on to the board via UART: (e.g.: screen /dev/tty.usb... 115200)
        • once you get prompted for username, type root
        • once logged in, redo make install in your module
        • try to manually load the module in order to make sure that the dependencies file is working ok: modprobe -a rtl8812au
        • if this is all successful, gracefully reboot the board
        • everything should be back to normal, plus wifi should work
          I'll give the SD card method a try first.
            21 days later
            bj_gzp
            The SD restore procedure worked like a charm with v.0.3.6b!
            Thanks 🙂
            2 months later
            giuliomoro Hello,
            my supervisor and I recently were trying to copy a package into Bela using scp. After that we tried to rename the folder which had the name of "???" to some other name (using the command mv). After doing that everything on the terminal stopped working as if the whole Bela operating system has been erased. It wouldn't recognize commands such as cd.. I don't know what went wrong but do the steps in the above post help in order to "restore" the board?
            Appreciate your advice.
            Thanks !
            It's very weird, not sure what you screwed up there. Is there anything on the board that you would like to recover or are you happy with just re-flashing it?
            a year later
            I have been throught all this post. Same adapter, i.e. NETGEAR A6100-100PES AC600 802.11AC
            Bela image, v0.3.7d, 11 March 2020
            root@bela:~# lsusb
            Bus 002 Device 002: ID 0846:9052 NetGear, Inc. A6100 AC600 DB Wireless Adapter [Realtek RTL8811AU]
            B
            After installing the driver, https://github.com/abperiasamy/rtl8812AU_8821AU_linux the device shows up when doing 'ip a'
            4: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
                link/ether bc:a5:11:38:49:a8 brd ff:ff:ff:ff:ff:ff
            Relevant lines from interfaces:
            # WiFi Example
            allow-hotplug wlan0
            iface wlan0 inet dhcp
            wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
            wpa_supplicant looks like follows:
            root@bela:~# cat /etc/wpa_supplicant/wpa_supplicant.conf
            network={
                    ssid="BelaRouter"
                    #psk="MyPassword"
                    psk=bbc878da83e4d2c83a69fe46f5a1aa2da38546faa7d822fa5b073f2daecb5615
            The router shows up correctly in the scan:
            root@bela:~# iwlist wlan0 scanning
            wlan0     Scan completed :
                     Cell 03 - Address: CC:32:E5:86:CA:DC
                                ESSID:"BelaRouter"
                                Protocol:IEEE 802.11bgn
                                Mode:Master
                                Frequency:2.462 GHz (Channel 11)
                                Encryption key:on
                                Bit Rates:144 Mb/s
                                Extra:rsn_ie=30140100000fac040100000fac040100000fac020000
                                IE: IEEE 802.11i/WPA2 Version 1
                                    Group Cipher : CCMP
                                    Pairwise Ciphers (1) : CCMP
                                    Authentication Suites (1) : PSK
                                IE: Unknown: DD8E0050F204104A0001101044000102103B0001031047001038833092309218839C77CC32E586CAC41021000754502D4C696E6B10230009544C2D57523834314E1024000431342E3010420003312E301054000800060050F20400011011001B576972656C657373204E20526F7574657220544C2D57523834314E10080002210C103C0001011049000600372A000120
                                Quality=96/100  Signal level=-45 dBm
                                Extra:fm=0003
            Cell 03 is the router i need to connect to. Model is
            TP-Link Wireless N Router WR841N
            Model No. TL-WR841N
            But when i try to get the connection up i get
            root@bela:~# ifdown wlan0; ifup wlan0;
            Listening on LPF/wlan0/bc:a5:11:38:49:a8
            Sending on   LPF/wlan0/bc:a5:11:38:49:a8
            DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
            DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 12
            No DHCPOFFERS received.
            No working leases in persistent database - sleeping.
            I have tried several times. I'm positive that the SSID and PassPhrase are spelled correctly...
            Any ideas of how I can proceed to get success ?
            Thank you,
            Hjalte
            Oh year,
            and DHCP is working fine on the router... i can connect my laptop, iPhone etc... I can also access Bela through the router if I connect it via ethernet cable...
            Router is running with WPA2-PSK AES encryption
            I have received a similar report a couple of weeks ago, related to this very same USB dongle. This was working in September 2018 (Bela image v0.3.5a). I don't think anything relevant has changed on the Bela image since, but it's possible. Several things have changed in the driver itself. You may want to try and roll back either or both and see where it stopped working
            I'll try some earlier versions of the driver first then. Thank you for your prompt reply !
            It's now working.
            Bela Image v0.3.7.b
            and checkout earlier driver:
            rtl8812AU_8821AU_linux-4d1726146fd96552c9fa5af05c75187027d6885b
            I have not tried any newer versions, but I might take the time to find the latest working driver and write which one in this thread 😉
            Thank you again!
