9 months later
Hi
I am going through the same steps as Robin, but seem to have a dead end with the
ifup wlan0; ifdown wlan0; command.
It results in No DHCPOFFERS received, and then when I run
ip a
wlan0 shows up as
5: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 8c:3b:ad:2f:39:26 brd ff:ff:ff:ff:ff:ff
No IP address as it should have if working. Any ideas what is wrong?
bEst,
Andreas
Did you set the username and password for the wifi as described here ? Sometimes you need to do ifup wlan0, ifdown wlan0, ifup wlan0 a couple of times
if you did it, can you post the output of cat /etc/wpa_supplicant/wpa_supplicant.conf?
I tried the ifup wlan; ifdown wlan; several times, and then checked the wpa config file:
network={
ssid="VIBRA_network"
#psk="my_p*****rd"
psk=f4ac1785d3c96383b93b26e76c39862d97fecae0ac36b9468ce8eb903f9c00c3
I still don't have an IP, but only:
3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc mq state DOWN group default qlen 1000
    right. Try to run
    iwlist wlan0 scanning
    that should return a list of the available networks.
    Yes, long list with 32 "Cells". Entries like:
    Cell 02 - Address: 00:22:07:4F:AE:16
    ESSID:"NextGenTel_AE17"
    Protocol:IEEE 802.11bgn
    Mode:Master
    Frequency:2.437 GHz (Channel 6)
    Encryption key:on
    Bit Rates:144 Mb/s
    Extra:rsn_ie=30140100000fac040100000fac040100000fac020c00
    IE: IEEE 802.11i/WPA2 Version 1
    Group Cipher : CCMP
    Pairwise Ciphers (1) : CCMP
    Authentication Suites (1) : PSK
    IE: Unknown: DD7C0050F204104A0001101044000102103B00010310470010EB49E6C9A8BBE97568B118CC59F10CCC1021000842726F6164636F6D1023000842726F6164636F6D1024000631323334353610420004313233341054000800060050F204000110110006496E74656E6F100800022008103C0001011049000600372A000120
    Quality=93/100 Signal level=-65 dBm
    Extra:fm=0003
    Seems to match the list on available networks on my mac fairly well.
    So it seems that it is scanning somehow, but still no IP when I do ip a, only
    3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
    is the network you are trying to connect to listed among those?
    There is also the possibility that you somehow mistyped the path to /etc/wpa_supplicant/wpa_supplicant.conf ?
    5 days later
    So, I haven't tried to connect to anything. I thought that the first step was getting an IP in the list of network devices. But, yes - there are a few of the networks listed that I can connect to.
    Does it mean I can connect to them?
    If the network you want to connect to is listed there, and you have appropriately set the network name and passphrase in /etc/wpa_supplicant/wpa_supplicant.conf, and there are no typos involved, then doing ifup wlan0 should try to connect to the network, and, upon success, obtain an IP address.
    Another thing to check is that your network router actually has a DHCP server on it to assign IP addresses. This is normally the default on home networks. If your computer can connect to this network and work properly without a special configuration, then it's probably safe to assume the DHCP is working fine.
    Hi
    So I put in some quotation marks (") since I had a space in the network name, and the printout from the ifup/down has changed:
    root@bela:~# ifup wlan0; ifdown wlan0;
    Internet Systems Consortium DHCP Client 4.3.5
    Copyright 2004-2016 Internet Systems Consortium.
    All rights reserved.
    For info, please visit https://www.isc.org/software/dhcp/
    Listening on LPF/wlan0/8c:3b:ad:2f:39:26
    Sending on LPF/wlan0/8c:3b:ad:2f:39:26
    Sending on Socket/fallback
    DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 3
    DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8
    DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 16
    DHCPREQUEST of 192.168.0.102 on wlan0 to 255.255.255.255 port 67
    DHCPOFFER of 192.168.0.102 from 192.168.0.1
    DHCPACK of 192.168.0.102 from 192.168.0.1
    bound to 192.168.0.102 -- renewal in 25 seconds.
    Killed old client process
    DHCPRELEASE on wlan0 to 192.168.0.1 port 67
    Still, i don't get any ip address when I do ip a. (I get: 3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc mq state DOWN group default qlen 1000
    link/ether 8c:3b:ad:2f:39:26 brd ff:ff:ff:ff:ff:ff)
    Does it mean that it is still not connected?
      Hmmm that's weird:
      would indicate that you are actually successfully connected.
      not sure about the
      part ...
      Did you retry ifup wlan0; ifup wlan0 ?
      Hi,
      so I did only
      and got
      DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 9
      bound to 192.168.0.102 -- renewal in 31 seconds.
      and now I finally got an IP when I do ip a. So, I guess it finally worked! Thanks for all the help
      best,
      Andreas
      Great!
      andreasb So I put in some quotation marks (") since I had a space in the network name, and the printout from the ifup/down
      hmm, that was not the case here
      andreasb ssid="VIBRA_network"
      13 days later
      I have a strange problem since i tried to install the wifi dongle as explained above.
      I got it to install the files, it took some time and finished telling there were time skew errors.
      Then i rebooted bela, since then it is not recognized by the Windows PC anymore when i plug the
      USB connector. No sound of new connected device, no bela partition in the explorer, bela IDE doesn't
      load in browser and ssh doesn't work either. i'm out of ideas.
      How did you shut down the board after installing the driver? If the shutdown was not graceful am afraid you may have a corrupted file /lib/modules/4.4.113-ti-xenomai-r148/modules.dep.bin (and possibly more), similarly to what happened here. If you don't have a UART device at hand (or a spare Bela, that is, then you may have to re-flash your card.
      The "date skew" error is normally not a problem, though you can avoid it by loading up the IDE before you start the process.
        Thanks for the fast diagnose!
        You nailed it probably, after installation i closed the terminal and power cycled (hard) for the reboot.
        No second Bela at hand and i got mine without the SD card early December.
        I was planning to get a second Bela anyway, so i'll take it a bit earlier than planned 😉
        Can you confirm that if i order a Bela now from the shop, that it will come with a never software version that has the netgear drivers pre-installed?
          bj_gzp Can you confirm that if i order a Bela now from the shop, that it will come with a never software version that has the netgear drivers pre-installed?
          No, you would still have to go through the manual installation process.
          bj_gzp I was planning to get a second Bela anyway, so i'll take it a bit earlier than planned 😉
          That's great. However, let me be clear: you don't actually need another Bela to get the first one to work. You can just get an SD card and flash it with the image and then follow the instructions to copy the content of the SD card to the eMMC. If you had another Bela, you would be able to use it as a UART adapter as explained at the link in the previous post (or you could use any other UART adapter you may have around). You would then:
          • remove the Bela cape
          • connect your UART adapter as explaineder here
          • login on to the board via UART: (e.g.: screen /dev/tty.usb... 115200)
          • once you get prompted for username, type root
          • once logged in, redo make install in your module
          • try to manually load the module in order to make sure that the dependencies file is working ok: modprobe -a rtl8812au
          • if this is all successful, gracefully reboot the board
          • everything should be back to normal, plus wifi should work
            I'll give the SD card method a try first.
              21 days later
              bj_gzp
              The SD restore procedure worked like a charm with v.0.3.6b!
              Thanks 🙂
