giuliomoro So I assume that if you run hvcc in a terminal on your computer you'll get the error "command not found" ?
did you try this?
When I do pipx install -e .
(using pipx
from brew
), at the end I get:
⚠️ Note: '/Users/giulio/.local/bin' is not on your PATH environment variable. These apps will not be globally accessible until your PATH is updated. Run `pipx ensurepath` to automatically add it, or manually
modify your PATH in your shell's config file (i.e. ~/.bashrc).
I don't know if you got something similar when installing it. Try re-running it with --force
to force displaying this warning again. It's not like I recommend using pipx
, because it doesn't really work for me as it's missing daisy2json
at runtime (same for python -m pip install
btw), though a workaround for it is:
diff --git a/hvcc/__init__.py b/hvcc/__init__.py
index ab1d8c7..0035b52 100644
--- a/hvcc/__init__.py
+++ b/hvcc/__init__.py
@@ -29,7 +29,10 @@ from hvcc.generators.ir2c import ir2c
from hvcc.generators.ir2c import ir2c_perf
from hvcc.generators.c2fabric import c2fabric
from hvcc.generators.c2js import c2js
-from hvcc.generators.c2daisy import c2daisy
+try:
+ from hvcc.generators.c2daisy import c2daisy
+except ImportError:
+ print("Daisy disabled")
from hvcc.generators.c2dpf import c2dpf
from hvcc.generators.c2owl import c2owl
from hvcc.generators.c2pdext import c2pdext
