So,
LFSaw Just writing something to ~/Bela_startup.sh
will not work since, as I understand it, set_startup.sh -s projectname
will write straight over it.
set_startup.sh
(or setting a program to startup from the IDE) will overwrite ~/Bela_startup.sh
. However, I assume you are not using any of the above, given that you are using scsynth
directly, therefore there would be no problem in overwriting the file with your own stuff.
On the other hand, if you want to be 100% sure, you could just place it in another file and then call that file by editing /etc/init.d/bela
. This is where ~/Bela_startup.sh
is called.
You probably want to run the scsynth
and your custom serial (or OSC) scripts each in a screen
LFSaw I would like to have two setups for the BELA I want to swap between.
How would you select one or the other script?
