as to how to "wait for the WiFi", I would try
while sleep 0.1; do
ifconfig $INTERFACENAME | grep $IPADDRESS && break
done
#....scsynth or sclang
while sleep 0.1; do
done
Thanks for the pointers! (only now see your answer, somehow didn't get notified...)
for later; if I want to switch between projects, how can I create a project would run a custom script with these settings (e.g. starting scsynth and doing something else...)?
Not sure I understand the requirements for your script. What should it do ? Is it something you could achieve by simply editing ~/Bela_startup.sh
LFSaw (only now see your answer, somehow didn't get notified...)
Yeah not sure what is happening, I am not getting email notifications either, but yesterday we made a test post to verify this and it worked just fine.
giuliomoro Not sure I understand the requirements for your script. What should it do ? Is it something you could achieve by simply editing ~/Bela_startup.sh?
I want to switch between projects with
make --no-print-directory -C /root/Bela PROJECT=$BBB_PROJECT_NAME startup
resp.
set_startup.sh -s projectname
sorry I still don't get it
ok, I'll try it again:
I would like to have two setups for the BELA I want to swap between.
My question is: How can I create two projects (as in the stuff that resides in ~/Bela/projects
that contain this functionality?
Just writing something to ~/Bela_startup.sh
will not work since, as I understand it, set_startup.sh -s projectname
will write straight over it.
So,
LFSaw Just writing something to
~/Bela_startup.sh
will not work since, as I understand it,set_startup.sh -s projectname
set_startup.sh
(or setting a program to startup from the IDE) will overwrite ~/Bela_startup.sh
. However, I assume you are not using any of the above, given that you are using scsynth
directly, therefore there would be no problem in overwriting the file with your own stuff.
On the other hand, if you want to be 100% sure, you could just place it in another file and then call that file by editing /etc/init.d/bela
. This is where ~/Bela_startup.sh
is called.
You probably want to run the scsynth
and your custom serial (or OSC) scripts each in a screen
LFSaw I would like to have two setups for the BELA I want to swap between.
How would you select one or the other script?
giuliomoro How would you select one or the other script?
in a perfect world, I can configure/define my script in the .json
file in the project and select by using set_startup.sh -s <projectname>
(see above).
Well there is not supported way of doing this through the scripts right now. I guess your best option would be to keep two versions of Bela_startup.sh
on your computer and scp
them over when you need one or the other (instead of calling set_startup.sh
https://github.com/BelaPlatform/Bela/commit/3f4c1c7b9d9780f25f51e1b1c85df9e561283d27
Put a file called run.sh
in your project and it will be invoked when you do "run" from the IDE or when you set that project to startup using the IDE or set_startup.sh
will try, thanks!
