• Hardware
  • is anyone successfully using i2c OLED / LCD?
did you change the OSC2OLED4Bela program at all? I think you are not using the correct syntax and address.
I think in its original form it only responds to a handful of OSC addresses:
/osc-test + float, /tr + float + string, /param1 + float.
So the following should work (running it from Sc on the host), while OSC2OLED4Bela is running on Bela:
~displayOSC = NetAddr.new("192.168.7.2", 7562);
~displayOSC.sendMsg('/osc-test', 123.23);
~displayOSC.sendMsg('/tr', 123.23, 'mystr');
~displayOSC.sendMsg('/param1', 123.23);
    giuliomoro ok great, this is helpful thank u, ill test with this and im sure ill have some questions shortly!
    giuliomoro hi, i have two related questions that could be more SC syntax related but i thought id try here first...if i were to try and plot this line to oled
    Signal.sineFill(1000, 1.0/[1,2,3,4,5,6]).plot;
    do i use .asString to speak to OSC or .asRawOSC?
    and a similar question about printing changing values to oled,
    is printing the value of this slider related to .envirPairs?
    Window.closeAll;
    w = Window ("gui", Rect(20,20,150,30))
    .front
    .alwaysOnTop(true);
    ~sliderx = Slider(w, Rect(20,20,150,30))
    ~sliderx.action
    arg obj;
    w.view.background_(Color.black);
    obj.value.postln;
    thanks, trying to get a feel for the environment
      please use backticks ( ``` ) and not ' to enclose your code
      vivian if i were to try and plot this line to oled
      The currently supported functions are the ones above and they show the few types of prints you can get currently. U assume they display some basic text only, but I don't have a working display at hand, did you try them out? To obtain anything other than that, you'll need to write some custom C++ code. The available graphics functions are here https://github.com/giuliomoro/OSC2OLED4Bela/blob/master/SSD1306_OLED.h#L151-L165
      Looking at the names there, you'd probably to use drawPixel(). I don't actually know how to handle bundles in OSC neither from the Sc side or the C side, so I'll assume for simplicity that you are sending some float values and you want to show those, but there is definitely room for improvements!
      For instance, I expect that if you add this to the body of int parseMessage(oscpkt::Message msg, void* arg):
      	oscpkt::Message::ArgReader args = msg.match("/values");
          if(args)
      		const unsigned int nValues = args.nbArgRemaining();
          	float values[nValues];
          	for(unsigned int n = 0; n < nValues; ++n)
          		if(args.isFloat())
      	    		args.popFloat(values[n]);
          		} else if(args.isInt32()) {
          			int i;
          			args.popInt32(i);
          			values[n] = i;
          		} else {
          			fprintf(stderr, "Wrong type at argument %d\n", n);
          			return -1;
          	// now tenValues contains the 10 values.
              // prepare a bitmap:
              printf("received: ");
              for(unsigned int n = 0; n < 10; ++n)
              	printf("%f ", values[n]);
              printf("\n");
              clearDisplay();
              for(unsigned int x = 0; x < SSD1306_LCDWIDTH; ++x)
              	// we interpret each value as the vertical displacement and
              	// we want to draw a series of horizontal lines at the specified points
              	unsigned int valIdx = x * float(nValues) / SSD1306_LCDWIDTH;
              	unsigned int y = values[valIdx] * SSD1306_LCDHEIGHT;
              	drawPixel(x, y, WHITE);
              Display();
      then you can send
      ~displayOSC.sendMsg('/values', 0, 0.1);
      or
      ~displayOSC.sendMsg('/values', 0, 0.1,0.2,0.3,0.4,0.5,0.6,0.7,0.8,0.9);
      to display n horizontal bars which are placed left-to-right at a relative vertical positiony, as specified by each of the float arguments (range 0 - 1). If you pass as many arguments as the number of horizontal pixels in the display ( typically 128), then each bar will be one pixel wide. There must be a better way of doing this from Sc than specifying the numbers as comma-separated values and probably using OSC bundles it would be a better idea.
      vivian do i use .asString to speak to OSC or .asRawOSC?
      no idea, sorry.
      vivian Window.closeAll;
      .front
      .alwaysOnTop(true);
      ~sliderx.action({
      arg obj;
      obj.value.postln;
      I am not sure what this does, but it would seem it's trying to create a slider in a GUI? There's no easy way to have the Sc GUI mirrored on the OLED display. You'll have to send dedicated commands which are parsed by the C++ file and sent to the display.
        5 days later
        not sure what you mean with "plot a graph behind "?
          giuliomoro sorry, similar to this example where there are pixel plots behind the float pixels
          also i cant find how i can change the thickness of the float pixels displayed
          Right, so this requires a bit more of work. The thickness of the pixel is always 1 (the drawPixel command writes one pixel at a time). Also, we transitioned to another library which is more flexible and works with more screens. Here it is: https://github.com/giuliomoro/O2O/ . You can run that example as it is and use /waveform to achieve the same that you are currently achieving with /values.
          Did you add any other code to the current version of the library?
            if you have an SSD1306 you'll need to replace this line in main.cpp:
            U8G2_SH1106_128X64_NONAME_F_HW_I2C_LINUX u8g2(U8G2_R0);
            with:
            class U8G2_SSD1306_128X64_NONAME_F_HW_I2C_LINUX : public U8G2 {
              public: U8G2_SSD1306_128X64_NONAME_F_HW_I2C_LINUX(const u8g2_cb_t *rotation) : U8G2() {
                u8g2_Setup_ssd1306_i2c_128x64_noname_f(&u8g2, rotation, u8x8_byte_linux_i2c, u8x8_linux_i2c_delay);
            U8G2_SSD1306_128X64_NONAME_F_HW_I2C_LINUX u8g2(U8G2_R0);
              giuliomoro this is weird but when i throw the zip in the ide and make the project and run the changed main.cpp i get this
              5 months later
              aha! ran into the same issue.
              might be good to add that to the 'Using an OLED Screen' knowledge base page?
              also, for Github noobs such as myself, 'the latest dev branch' is somewhat vague.
              i'm assuming it's dev-i2c, but if that turns out to be the working one, it was still a lucky guess.
                also, allow me to type
                No rule to make target '/root/Bela/projects/O2O-main/build/
                for community searching purposes. i kinda lucked out finding this thread.
                so i got lucky 🙂 and got the ascii BELA logo on my screen. wonderful!
                i had to change the
                [connect 192.168.6.2 7562 (
                message box in the included local.pd file to
                [connect 192.168.7.2 7562 (
                for everything to communicate correctly.
                yay!
                Remork also, for Github noobs such as myself, 'the latest dev branch' is somewhat vague.
                I literally meant the latest dev branch: the current version of the dev branch, sorry fpr the confusion.
                I would discourage using dev-i2c for anything as it's only randomly occasionally rebased on dev but otherwise unmaintained
