here's some new info, I just tried to git clone the c language server while ssh'd and it seems I no longer have access to the internet on the unit:
git clone --depth=1 --recursive https://github.com/MaskRay/ccls
Cloning into 'ccls'...
fatal: unable to access 'https://github.com/MaskRay/ccls/': Could not resolve host: github.com
this is what my /etc/network/interfaces file looks like:
1 # This file describes the network interfaces available on your system
2 # and how to activate them. For more information, see interfaces(5).
3
4 # USB RNDIS gadget (Windows / Linux compatible)
5 auto usb0
6 iface usb0 inet dhcp
7
8 # iface usb0 inet static
9 # address 192.168.6.2
10 # netmask 255.255.255.0
11 # network 192.168.6.0
12
13 #�[m+USB NCM gadget (macOS / Linux compatible)
14 auto usb1
15 iface usb1 inet dhcp
16 # iface usb1 inet static
17 # address 192.168.7.2
18 # netmask 255.255.255.0
19 # network 192.168.7.0
20
21 # The loopback network interface
22 auto lo
23 iface lo inet loopback
24
25 # Ethernet
26 allow-hotplug eth0
27 iface eth0 inet dhcp
28 # Example to keep MAC address between reboots
29 #hwaddress ether DE:AD:BE:EF:CA:FE
30
31 # WiFi Example
32 allow-hotplug wlan0
33 iface wlan0 inet dhcp
34 wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
35 # The lines above should work if you have a wifi interface called wlan0.
36 # To see the actual name of your interface, run
37 # ip a
38 # and identify it among the ones listed then replace `wlan0` above with the name of your interface
39 # To provide credentials to your network, run the following at the command line:
40 # wpa_passphrase YourNetworkName YourNetworkPassword >>/etc/wpa_supplicant/wpa_supplicant.conf
41 # then:
42 # ifdown wlan0; ifup wlan0
43 # where `wlan0` is the name of your interface as found above.
44
This was working before
