Hi, I used to be able to connect to my bela but it was a while ago since I used it. Now I was going to try again but I can't seem to access the IDE. I'm using macOs Monterey 12.5.
Here are the steps I've taken:
  1. Flashed the latest bela image using balena etcher. (I've also tried the next latest build)
  2. Connect bela through the mini usb port, to a usb B to C connector.
  3. Tried bela.local, 192.168.7.2, and 192.168.6.2 in Google Chrome latest build.
  4. Downloaded the drivers for Mac, although I can only allow the installer in system prefs, the developer can't be allowed. And in system information it says this developer is blocked. I tried starting in recovery mode and allowing the developer in the terminal but it still says its blocked after restart.
According to the guide you're supposed to be able to connect without these drivers when using the latest bela build. Any ideas what else to try?
Best,
Fabian
    Monterey should work fine only with Bela images shipped after May 2020. If your board has an old image on it, you'll need to upgrade it. The easiest way to do that is to flash the latest image on it. If you have data on the SD card that you'd like to recover before flashing the new image, things are more complicated, but I can assist with that.
    Hi! Thanks for the answer, as I said in the first post I've already flashed the latest image on it, I also tried flashing the next latest if there would have been any new bugs.
    OK, can you run each of the following commands in your mac's terminal 1 minute or more after the board has been connected and show the output you get?
    ifconfig
    ls /Volumes/BELABOOT
    ls /dev/tty*bela*
    ioreg -p IOUSB -w0 -l
    Hmm now I notice the Bela is not showing up as a volume, thus the terminal spits out:
    ls: /Volumes/BELABOOT: No such file or directory
    This must be the problem. I tried two different usb C adapters now with no luck. It should work to power it only with the usb cable right? Or would I need the 5v adapter plugged in as well?
    The bela lights up like usual so it looks like its fine. Perhaps I could try connecting it directly to a router and logging in via the network?
      USB is enough, no need for the barrel jack. Could it be that you are using a charging-only USB cable?
      Connecting it via ethernet to a home router should just work™.
      2 months later
      So I've tried multiple USB cables and flashing the latest image on the bela SD card again, as well as pluggin it into my router via a network cable, but still no luck reaching the IDE. If there are any other suggestions to try I'd love to hear it.
        bamsehopp The bela lights up like usual so it looks like its fin
        Describe that in more detail or better send a video please.
        bamsehopp pluggin it into my router via a network cable,
        Did you see the leds on the ethernet port blink when you plugged it in? Look at your router's list of connected devices, does it show up there? With what IP? If trying to reach it over the ethernet connection, bela.local may work, the IP assigned to it by your router should work and none of 192.168.7.2/192.168.6.2 will work.
        So the only leds that are lighting up is the PWR led (full glow) and the rightmost led (D2) is blinking in a heartbeat pattern. I'm not able to log into my router right now but will try tonight to see if I can get a list of devices from there.
          i've recently had a very similar experience with a Bela Mini - lights on, but not able to connect. not sure anymore if the disk image showed up. anyway, i had tried to access a friends wifi the week before, and tampered with network settings.
          took a while to remember that, but turning preferences>network>location back to 'automatic' fixed the issue.
          not sure if that'll work for you, but worth checking?
            bamsehopp So the only leds that are lighting up is the PWR led (full glow) and the rightmost led (D2) is blinking in a heartbeat pattern
            Well I assume that's a few seconds after boot. As soon as it boots there should be more activity across all LEDs, then it should stabilize on the pattern you are describing.
            bamsehopp Flashed the latest bela image using balena etcher. (I've also tried the next latest build)
            Right, seeing how you have a very old cape, you may well have a very old image on the BBB, so I am wondering if it is booting from the SD card at all.
            Try to remove the cape and use the S1 button to force boot from the sd card then if successful follow instructions to wipe off the emmc. See https://learn.bela.io/using-bela/bela-techniques/managing-your-sd-card/#booting-bela-from-the-sd-card
              Remork thanks for the suggestion, although mine is already at automatic 🙁
              giuliomoro Yes that sounds logical! This is actually the kickstarter bela so yes its very old. I will try this tonight!
              I tried it and it worked perfectly! Thank you so much, I had almost lost all hopes on my board so really happy for the support!!
