It is V3 !
lsusb :
Bus 001 Device 002: ID 2357:0109 TP-Link TL WN823N RTL8192EU
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg :
[ 0.000000] Linux version 4.14.108-ti-xenomai-r143 (giulio@builder) (gcc version 7.5.0 (GCC)) #1xross PREEMPT Thu Nov 4 22:48:35 UTC 2021
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 131072
[ 0.000000] free_area_init_node: node 0, pgdat c13d4ac8, node_mem_map dfb79000
[ 0.000000] Normal zone: 1152 pages used for memmap
[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] random: get_random_bytes called from start_kernel+0xac/0x3c8 with crng_init=0
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet
[ 0.000000] Memory: 498272K/524288K available (12288K kernel code, 962K rwdata, 3608K rodata, 1024K init, 843K bss, 26016K reserved, 0K cma-reserved, 0K highmem)
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0d00000 (13280 kB)
.init : 0xc1200000 - 0xc1300000 (1024 kB)
.data : 0xc1300000 - 0xc13f0af4 ( 963 kB)
.bss : 0xc13f2000 - 0xc14c4e54 ( 844 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000018] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000036] I-pipe, 24.000 MHz clocksource, wrap in 178956 ms
[ 0.000055] clocksource: ipipe_tsc: mask: 0xffffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000079] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000088] OMAP clocksource: timer1 at 24000000 Hz
[ 0.002148] timer_probe: no matching timers found
[ 0.002524] Interrupt pipeline (release #7)
[ 0.002863] Console: colour dummy device 80x30
[ 0.002917] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[ 0.021643] pid_max: default: 32768 minimum: 301
[ 0.021852] Security Framework initialized
[ 0.021869] Yama: becoming mindful.
[ 0.021914] AppArmor: AppArmor disabled by boot time parameter
[ 0.021984] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.021998] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.023008] CPU: Testing write buffer coherency: ok
[ 0.023077] CPU0: Spectre v2: using BPIALL workaround
[ 0.024058] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.024264] Hierarchical SRCU implementation.
[ 0.028692] devtmpfs: initialized
[ 0.047886] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.048349] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.048372] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.048723] xor: automatically using best checksumming function neon
[ 0.048737] pinctrl core: initialized pinctrl subsystem
[ 0.050939] NET: Registered protocol family 16
[ 0.052552] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.101640] omap_hwmod: debugss: _wait_target_disable failed
[ 0.151607] OMAP GPIO hardware version 0.1
[ 0.169032] No ATAGs?
[ 0.169055] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.180948] raid6: using algorithm neonx8 gen() 0 MB/s
[ 0.180962] raid6: .... xor() 0 MB/s, rmw enabled
[ 0.180971] raid6: using neon recovery algorithm
[ 0.190457] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.197013] SCSI subsystem initialized
[ 0.197331] usbcore: registered new interface driver usbfs
[ 0.197397] usbcore: registered new interface driver hub
[ 0.197570] usbcore: registered new device driver usb
[ 0.198415] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.198481] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c1_pins, deferring probe
[ 0.198529] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[ 0.198742] pps_core: LinuxPPS API ver. 1 registered
[ 0.198751] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.198776] PTP clock support registered
[ 0.199716] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.200485] Advanced Linux Sound Architecture Driver Initialized.
[ 0.201200] NetLabel: Initializing
[ 0.201213] NetLabel: domain hash size = 128
[ 0.201220] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.201322] NetLabel: unlabeled traffic allowed by default
[ 0.202027] clocksource: Switched to clocksource ipipe_tsc
[ 0.370904] VFS: Disk quotas dquot_6.6.0
[ 0.370995] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.384563] NET: Registered protocol family 2
[ 0.385480] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.385527] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.385568] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.385693] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.385712] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.385954] NET: Registered protocol family 1
[ 0.386844] RPC: Registered named UNIX socket transport module.
[ 0.386856] RPC: Registered udp transport module.
[ 0.386863] RPC: Registered tcp transport module.
[ 0.386870] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.387873] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 0.388008] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.389821] audit: initializing netlink subsys (disabled)
[ 0.391065] [Xenomai] scheduling class idle registered.
[ 0.391077] [Xenomai] scheduling class rt registered.
[ 0.391223] I-pipe: head domain Xenomai registered.
[ 0.392724] audit: type=2000 audit(0.392:1): state=initialized audit_enabled=0 res=1
[ 0.398996] [Xenomai] Cobalt v3.0.11 [DEBUG]
[ 0.399165] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.406616] zbud: loaded
[ 0.409772] NFS: Registering the id_resolver key type
[ 0.409823] Key type id_resolver registered
[ 0.409830] Key type id_legacy registered
[ 0.409852] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.410470] fuse init (API version 7.26)
[ 0.411172] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 0.421850] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.422312] io scheduler noop registered
[ 0.422323] io scheduler deadline registered
[ 0.422740] io scheduler cfq registered (default)
[ 0.422752] io scheduler mq-deadline registered
[ 0.422760] io scheduler kyber registered
[ 0.424761] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.425792] ------------[ cut here ]------------
[ 0.425832] WARNING: CPU: 0 PID: 1 at kernel/irq/chip.c:57 irq_set_chip+0xcc/0xdc
[ 0.425839] irqchip 44e07000.gpio is not pipeline-safe!
[ 0.425847] Modules linked in:
[ 0.425868] CPU: 0 PID: 1 Comm: swapper Not tainted 4.14.108-ti-xenomai-r143 #1xross
[ 0.425875] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 0.425881] I-pipe domain: Linux
[ 0.425923] [<c0110ad4>] (unwind_backtrace) from [<c010e098>] (show_stack+0x20/0x24)
[ 0.425940] [<c010e098>] (show_stack) from [<c0c3e7e4>] (dump_stack+0x24/0x28)
[ 0.425957] [<c0c3e7e4>] (dump_stack) from [<c013a780>] (__warn+0xf4/0x10c)
[ 0.425970] [<c013a780>] (__warn) from [<c013a7f0>] (warn_slowpath_fmt+0x58/0x74)
[ 0.425985] [<c013a7f0>] (warn_slowpath_fmt) from [<c0196554>] (irq_set_chip+0xcc/0xdc)
[ 0.426003] [<c0196554>] (irq_set_chip) from [<c0197870>] (irq_set_chip_and_handler_name+0x24/0x3c)
[ 0.426056] [<c0197870>] (irq_set_chip_and_handler_name) from [<c080a9e4>] (gpiochip_irq_map+0x50/0xc8)
[ 0.426075] [<c080a9e4>] (gpiochip_irq_map) from [<c019a380>] (irq_domain_associate+0x84/0x1f8)
[ 0.426090] [<c019a380>] (irq_domain_associate) from [<c019ad48>] (irq_create_mapping+0x144/0x1fc)
[ 0.426103] [<c019ad48>] (irq_create_mapping) from [<c080aa84>] (gpiochip_to_irq+0x28/0x58)
[ 0.426117] [<c080aa84>] (gpiochip_to_irq) from [<c0809e14>] (gpiod_to_irq+0x58/0x70)
[ 0.426136] [<c0809e14>] (gpiod_to_irq) from [<c0810af4>] (gpio_is_visible+0x8c/0xac)
[ 0.426160] [<c0810af4>] (gpio_is_visible) from [<c0392d10>] (internal_create_group+0xdc/0x30c)
[ 0.426177] [<c0392d10>] (internal_create_group) from [<c03933a0>] (sysfs_create_groups+0x54/0x90)
[ 0.426203] [<c03933a0>] (sysfs_create_groups) from [<c08c7630>] (device_add+0x4cc/0x614)
[ 0.426221] [<c08c7630>] (device_add) from [<c08c7948>] (device_create_groups_vargs+0xc4/0xd0)
[ 0.426236] [<c08c7948>] (device_create_groups_vargs) from [<c08c7a30>] (device_create_with_groups+0x44/0x60)
[ 0.426250] [<c08c7a30>] (device_create_with_groups) from [<c0811468>] (gpiod_export+0x178/0x39c)
[ 0.426265] [<c0811468>] (gpiod_export) from [<c080fce0>] (gpio_request_one+0x114/0x12c)
[ 0.426280] [<c080fce0>] (gpio_request_one) from [<c0809704>] (devm_gpio_request_one+0x58/0x90)
[ 0.426294] [<c0809704>] (devm_gpio_request_one) from [<c0811e28>] (gpio_of_helper_probe+0x19c/0x650)
[ 0.426314] [<c0811e28>] (gpio_of_helper_probe) from [<c08cd1b4>] (platform_drv_probe+0x60/0xbc)
[ 0.426328] [<c08cd1b4>] (platform_drv_probe) from [<c08cac14>] (driver_probe_device+0x298/0x47c)
[ 0.426342] [<c08cac14>] (driver_probe_device) from [<c08caf08>] (__driver_attach+0x110/0x12c)
[ 0.426356] [<c08caf08>] (__driver_attach) from [<c08c8634>] (bus_for_each_dev+0x70/0xd0)
[ 0.426371] [<c08c8634>] (bus_for_each_dev) from [<c08ca3b4>] (driver_attach+0x2c/0x30)
[ 0.426383] [<c08ca3b4>] (driver_attach) from [<c08c9d1c>] (bus_add_driver+0x1d0/0x274)
[ 0.426396] [<c08c9d1c>] (bus_add_driver) from [<c08cbcd4>] (driver_register+0x88/0x104)
[ 0.426410] [<c08cbcd4>] (driver_register) from [<c08cd0fc>] (__platform_driver_register+0x50/0x58)
[ 0.426436] [<c08cd0fc>] (__platform_driver_register) from [<c1245284>] (gpio_of_helper_driver_init+0x20/0x28)
[ 0.426454] [<c1245284>] (gpio_of_helper_driver_init) from [<c0101d70>] (do_one_initcall+0x64/0x19c)
[ 0.426474] [<c0101d70>] (do_one_initcall) from [<c1200f94>] (kernel_init_freeable+0x150/0x1ec)
[ 0.426493] [<c1200f94>] (kernel_init_freeable) from [<c0c55148>] (kernel_init+0x18/0x124)
[ 0.426513] [<c0c55148>] (kernel_init) from [<c0109918>] (ret_from_fork+0x18/0x24)
[ 0.426534] ---[ end trace 509102384f2d2d0f ]---
[ 0.427565] gpio-of-helper ocp:cape-universal: ready
[ 0.431096] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 0.432641] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.436267] console [ttyS0] disabled
[ 0.436369] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 38, base_baud = 3000000) is a 8250
[ 0.448179] console [ttyS0] enabled
[ 0.451455] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 0.534041] libphy: Fixed MDIO Bus: probed
[ 0.590093] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 0.590110] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 0.590745] MDIO: davinci_mdio: dt: updated phy_id[0] from phy_mask[fffffffe]
[ 0.592692] libphy: 4a101000.mdio: probed
[ 0.592717] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 0.593803] cpsw 4a100000.ethernet: Detected MACID = 20:d7:78:7d:7b:e6
[ 0.593933] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[ 0.593945] cpsw 4a100000.ethernet: ALE Table size 1024
[ 0.593994] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[ 0.598366] mmc1: new high speed MMC card at address 0001
[ 0.602446] mmcblk1: mmc1:0001 M62704 3.56 GiB
[ 0.602954] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.603006] ehci-platform: EHCI generic platform driver
[ 0.603389] ehci-omap: OMAP-EHCI Host Controller driver
[ 0.604252] usbcore: registered new interface driver usb-storage
[ 0.605931] mmcblk1boot0: mmc1:0001 M62704 partition 1 2.00 MiB
[ 0.606541] mmcblk1boot1: mmc1:0001 M62704 partition 2 2.00 MiB
[ 0.608256] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
[ 0.608680] mmcblk1rpmb: mmc1:0001 M62704 partition 3 512 KiB
[ 0.610435] mmcblk1: p1 p2
[ 0.616424] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 0.620909] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 0.620952] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 0.621329] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.621342] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.621351] usb usb1: Product: MUSB HDRC host driver
[ 0.621360] usb usb1: Manufacturer: Linux 4.14.108-ti-xenomai-r143 musb-hcd
[ 0.621369] usb usb1: SerialNumber: musb-hdrc.1
[ 0.622441] hub 1-0:1.0: USB hub found
[ 0.622549] hub 1-0:1.0: 1 port detected
[ 0.631725] mousedev: PS/2 mouse device common for all mice
[ 0.634582] omap_rtc 44e3e000.rtc: registered as rtc0
[ 0.635506] i2c /dev entries driver
[ 0.637202] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 0.640710] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.641448] ashmem: initialized
[ 0.641870] remoteproc remoteproc0: wkup_m3 is available
[ 0.649022] NET: Registered protocol family 10
[ 0.650789] Segment Routing with IPv6
[ 0.650878] mip6: Mobile IPv6
[ 0.650899] NET: Registered protocol family 17
[ 0.651023] Key type dns_resolver registered
[ 0.651034] mpls_gso: MPLS GSO support
[ 0.651294] omap_voltage_late_init: Voltage driver support not added
[ 0.658275] PM: Cannot get wkup_m3_ipc handle
[ 0.662863] ThumbEE CPU extension supported.
[ 0.663903] registered taskstats version 1
[ 0.664038] zswap: loaded using pool lzo/zbud
[ 0.666767] Btrfs loaded, crc32c=crc32c-generic
[ 0.668093] Key type encrypted registered
[ 0.701897] random: fast init done
[ 0.712968] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 0.713552] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.714257] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.714339] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.715950] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 400 kHz
[ 0.717807] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.718401] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.718815] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.719205] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.719273] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 400 kHz
[ 0.721117] remoteproc remoteproc0: powering up wkup_m3
[ 0.721252] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 0.724714] PM: Cannot get wkup_m3_ipc handle
[ 0.729459] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 0.729476] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ 0.730438] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 0.730454] of_cfs_init
[ 0.730590] of_cfs_init: OK
[ 0.731366] ALSA device list:
[ 0.731375] No soundcards found.
[ 0.734685] EXT4-fs (mmcblk1p2): INFO: recovery required on readonly filesystem
[ 0.734699] EXT4-fs (mmcblk1p2): write access will be enabled during recovery
[ 1.038223] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 1.187000] usb 1-1: New USB device found, idVendor=2357, idProduct=0109
[ 1.187019] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.187029] usb 1-1: Product: 802.11n NIC
[ 1.187037] usb 1-1: Manufacturer: Realtek
[ 1.187046] usb 1-1: SerialNumber: 00e04c000001
[ 1.189660] PM: bootloader does not support rtc-only!
[ 1.899852] EXT4-fs (mmcblk1p2): recovery complete
[ 1.901270] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.901379] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.902503] devtmpfs: mounted
[ 1.903988] Freeing unused kernel memory: 1024K
[ 2.149807] systemd[1]: System time before build time, advancing clock.
[ 2.208163] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.233195] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.236752] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.249561] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 2.250645] systemd[1]: Detected architecture arm.
[ 2.255951] systemd[1]: Set hostname to <bela>.
[ 2.464813] random: systemd-cryptse: uninitialized urandom read (16 bytes read)
[ 2.859544] systemd[1]: Listening on Syslog Socket.
[ 2.860684] systemd[1]: Listening on Journal Socket.
[ 2.861283] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.861776] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.862684] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.862898] systemd[1]: Reached target Paths.
[ 2.863799] systemd[1]: Listening on Journal Audit Socket.
[ 3.130727] rtdm_pruss_irq: loading out-of-tree module taints kernel.
[ 3.131528] rtdm_pruss_irq version 2 loaded
[ 3.218912] usbcore: registered new interface driver snd-usb-audio
[ 3.771712] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 4.263711] systemd-journald[101]: Received request to flush runtime journal from PID 1
[ 6.860413] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 8.461262] random: crng init done
[ 8.461288] random: 7 urandom warning(s) missed due to ratelimiting
[ 9.844562] usb 1-1: Vendor: Realtek
[ 9.844583] usb 1-1: Product: 802.11n NI
[ 9.844592] usb 1-1: Serial:
[ 9.844604] usb 1-1: rtl8192eu_parse_efuse: dumping efuse (0x200 bytes):
[ 9.844615] usb 1-1: 00: 29 81 00 7c 01 40 03 00
[ 9.844624] usb 1-1: 08: 40 74 04 50 14 00 00 00
[ 9.844634] usb 1-1: 10: 29 2a 2b 2c 2c 2c 2d 2d
[ 9.844643] usb 1-1: 18: 2d 2e 2e f2 ef ef ff ff
[ 9.844652] usb 1-1: 20: ff ff ff ff ff ff ff ff
[ 9.844661] usb 1-1: 28: ff ff ff ff ff ff ff ff
[ 9.844670] usb 1-1: 30: ff ff ff ff ff ff ff ff
[ 9.844679] usb 1-1: 38: ff ff 29 29 2a 2b 2b 2b
[ 9.844688] usb 1-1: 40: 2b 2b 2b 2b 2b f2 ef ef
[ 9.844697] usb 1-1: 48: ff ff ff ff ff ff ff ff
[ 9.844706] usb 1-1: 50: ff ff ff ff ff ff ff ff
[ 9.844715] usb 1-1: 58: ff ff ff ff ff ff ff ff
[ 9.844724] usb 1-1: 60: ff ff ff ff ff ff ff ff
[ 9.844733] usb 1-1: 68: ff ff ff ff ff ff ff ff
[ 9.844742] usb 1-1: 70: ff ff ff ff ff ff ff ff
[ 9.844751] usb 1-1: 78: ff ff ff ff ff ff ff ff
[ 9.844760] usb 1-1: 80: ff ff ff ff ff ff ff ff
[ 9.844769] usb 1-1: 88: ff ff ff ff ff ff ff ff
[ 9.844778] usb 1-1: 90: ff ff ff ff ff ff ff ff
[ 9.844787] usb 1-1: 98: ff ff ff ff ff ff ff ff
[ 9.844796] usb 1-1: a0: ff ff ff ff ff ff ff ff
[ 9.844805] usb 1-1: a8: ff ff ff ff ff ff ff ff
[ 9.844814] usb 1-1: b0: ff ff ff ff ff ff ff ff
[ 9.844823] usb 1-1: b8: a2 1f 1f 00 00 00 ff ff
[ 9.844832] usb 1-1: c0: ff 01 00 10 00 00 00 ff
[ 9.844841] usb 1-1: c8: 00 00 ff ff ff ff ff ff
[ 9.844849] usb 1-1: d0: 57 23 09 01 e7 47 02 54
[ 9.844858] usb 1-1: d8: af 97 fe 76 29 0a 03 52
[ 9.844867] usb 1-1: e0: 65 61 6c 74 65 6b 20 0e
[ 9.844876] usb 1-1: e8: 03 38 30 32 2e 31 31 6e
[ 9.844885] usb 1-1: f0: 20 4e 49 43 20 00 00 ff
[ 9.844894] usb 1-1: f8: ff ff ff ff ff ff ff ff
[ 9.844903] usb 1-1: 100: ff ff ff ff ff ff ff ff
[ 9.844913] usb 1-1: 108: ff ff ff ff ff ff ff ff
[ 9.844921] usb 1-1: 110: ff ff ff ff ff ff ff 0d
[ 9.844930] usb 1-1: 118: 03 00 05 00 30 00 00 00
[ 9.844939] usb 1-1: 120: 00 93 ff ff ff ff ff ff
[ 9.844948] usb 1-1: 128: ff ff ff ff ff ff ff ff
[ 9.844957] usb 1-1: 130: f6 a8 98 2d 03 92 98 00
[ 9.844966] usb 1-1: 138: fc 8c 00 11 9b 44 02 0a
[ 9.844975] usb 1-1: 140: ff ff ff ff ff ff ff ff
[ 9.844984] usb 1-1: 148: ff ff ff ff ff ff ff ff
[ 9.844993] usb 1-1: 150: ff ff ff ff ff ff ff ff
[ 9.845002] usb 1-1: 158: ff ff ff ff ff ff ff ff
[ 9.845011] usb 1-1: 160: ff ff ff ff ff ff ff ff
[ 9.845020] usb 1-1: 168: ff ff ff ff ff ff ff ff
[ 9.845029] usb 1-1: 170: ff ff ff ff ff ff ff ff
[ 9.845038] usb 1-1: 178: ff ff ff ff ff ff ff ff
[ 9.845047] usb 1-1: 180: ff ff ff ff ff ff ff ff
[ 9.845056] usb 1-1: 188: ff ff ff ff ff ff ff ff
[ 9.845065] usb 1-1: 190: ff ff ff ff ff ff ff ff
[ 9.845074] usb 1-1: 198: ff ff ff ff ff ff ff ff
[ 9.845083] usb 1-1: 1a0: ff ff ff ff ff ff ff ff
[ 9.845092] usb 1-1: 1a8: ff ff ff ff ff ff ff ff
[ 9.845101] usb 1-1: 1b0: ff ff ff ff ff ff ff ff
[ 9.845110] usb 1-1: 1b8: ff ff ff ff ff ff ff ff
[ 9.845119] usb 1-1: 1c0: ff ff ff ff ff ff ff ff
[ 9.845128] usb 1-1: 1c8: ff ff ff ff ff ff ff ff
[ 9.845137] usb 1-1: 1d0: ff ff ff ff ff ff ff ff
[ 9.845146] usb 1-1: 1d8: ff ff ff ff ff ff ff ff
[ 9.845155] usb 1-1: 1e0: ff ff ff ff ff ff ff ff
[ 9.845164] usb 1-1: 1e8: ff ff ff ff ff ff ff ff
[ 9.845173] usb 1-1: 1f0: ff ff ff ff ff ff ff ff
[ 9.845181] usb 1-1: 1f8: ff ff ff ff ff ff ff ff
[ 9.845196] usb 1-1: RTL8192EU rev B (SMIC) 2T2R, TX queues 3, WiFi=1, BT=0, GPS=0, HI PA=0
[ 9.845207] usb 1-1: RTL8192EU MAC: 54:af:97:fe:76:29
[ 9.845218] usb 1-1: rtl8xxxu: Loading firmware rtlwifi/rtl8192eu_nic.bin
[ 9.898512] usb 1-1: Firmware revision 19.0 (signature 0x92e1)
[ 12.063861] usbcore: registered new interface driver rtl8xxxu
[ 13.710943] using random self ethernet address
[ 13.710963] using random host ethernet address
[ 13.799582] using random self ethernet address
[ 13.799603] using random host ethernet address
[ 13.919365] Mass Storage Function, version: 2009/09/11
[ 13.919389] LUN: removable file: (no medium)
[ 14.606314] usb0: HOST MAC be:1a:78:7d:7b:e7
[ 14.606786] usb0: MAC be:1a:78:7d:7b:e8
[ 14.608067] usb1: HOST MAC be:1a:78:7d:7b:ea
[ 14.608267] usb1: MAC be:1a:78:7d:7b:eb
[ 14.836712] configfs-gadget gadget: high-speed config #1: c
[ 15.489154] net eth0: initializing cpsw version 1.12 (0)
[ 15.575487] SMSC LAN8710/LAN8720 4a101000.mdio:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[ 15.616061] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 16.412653] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 18.427030] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
