FatJak - Do the 8 pots are physically LOG or LIN ? They didnβt appears in the "CURRENT BOM for Rev2". Because I want to know if I need [pow~ 2] in Pd to turn it LOG.
they are linear
FatJak "_ went back to 44100 Hz setting. Any ideas ?
it's a bug on applying those settings. In order to force applying them at boot you need to:
- set boot program to β’noneβ’
- set boot program back to your program
FatJak I see many "Underrun detected: 1 blocks dropped" errors on IDE when I run my patch. (In IDE/Project_settings, I have set the Block size (audio frames) to 128.) Why ?
You may be using too much CPU, either continuously or because of excess peak usage. How many do you get per second?
FatJak . How to remote the button that is on the Bela cape (which stop the running program and give you back access to the IDE) to the front panel for embedded use ? Is it a shortcut with buttons ? Or a hole in the panel with a new little button ?
Maybe the best option is to do no hardware change and instead the code so that pressing one of the buttons already on Pepper stops the currently running program. If you are using Pd, you can update your board to the latest version of the Bela code, you can send:
[stop(
[s bela_control]
to stop the program. So you can trigger that with some logic to one of the front-panel buttons.
FatJak
- Where to find the schematic of the Pepper Rev2 ?
https://github.com/BelaPlatform/bela-pepper/tree/master/Design%20Files/rev2b
