• GeneralSolved
  • Controlling an LED with variable colours using Bela and SuperCollider
are these Neopixel-type LED strips you are talking about ?
3 months later
hi @giuliomoro, i was wondering if you could share the solutions you mentioned above. I couldn't find any good tips for driving a NeoPixel-like RGB LED yet. Thank you!
Here's some example code. This assumes BelaMini is used and the neopixels are driven from pin P2.25. To enable that you'll need to run config-pin P2.25 spi after each reboot ( this can be automated later if needed).
#include <stdio.h>
#include <libraries/Spi/Spi.h>
#include <cmath>
#include <string.h>
Spi spi;
const unsigned int kSpiClock = 12000000;
const unsigned int kSpiMinTransferSize = 160; // min number of bytes to trigger DMA transfer
const unsigned int kSpiMaxTransferSize = 4096; // max number of bytes to be sent at once
const unsigned int kSpiWordLength = 32;
const uint8_t kSpiMsbFirst = 1;
const float kSpiInterWordTime = 200;
const float kSpiPeriodNs = 1000000000.0 / kSpiClock;
const uint8_t kBitsPerByte = 8;
// The specs (WS2812B-2020 datasheet) say:
// T0H 0 code, high voltage time 220ns~380ns
// T1H 1 code, high voltage time 580ns~1µs
// T0L 0 code, low voltage time 580ns~1µs
// T1L 1 code, low voltage time 220ns~420ns
// RES Frame unit, low voltage time >280µs
// WS2812B v1.0 on the other hand says:
// TH+TL = 1.25µs ± 600ns
// T0H 0 code, high voltage time 0.4us ±150ns
// T1H 1 code, high voltage time 0.8us ±150ns
// T0L 0 code, low voltage time 0.85us ±150ns
// T1L 1 code, low voltage time 0.45us ±150ns
// More recent datasheets say
// We pick below some conservative values for WS2812B
typedef struct {
	float min;
	float max;
} T_t;
const T_t TH[2] = {
	{.min = 200, .max = 400}, // T0H
	{.min = 700, .max = 900}, // T1H
const T_t TL[2] = {
	{.min = 750, .max = 950}, // T0L
	{.min = 350, .max = 550}, // T1L
// Additionally, there is need for adding a long enough "0" output before we start clocking out data.
// The SPI peripheral in use seems to always set the MOSI high when not clocking out data, so we have
// to start clocking out some zeros first.
// Skipping this will result in 1-bit offset in the bit shifting. If you see random flashes
// in your LEDs strip and/or the first LED remaning on when set to off
// and/or the others have the colors "slightly" wrong, this could be the reason.
// This could be avoided if the MOSI was to be LOW when idle, but this would require
// an external transistor to invert it.
const double kSpiLeadingZerosNs = 10000; // determined empirically
const unsigned int kSpiLeadingZeros = std::ceil((kSpiLeadingZerosNs / kSpiPeriodNs));
bool readBitField(uint8_t* data, uint32_t offset) {
	uint8_t position = offset % kBitsPerByte;
	unsigned int i = offset / kBitsPerByte;
	return data[i] & (1 << position);
void writeBitField(uint8_t* data, uint32_t offset, bool value) {
	if(value)
		data[i] |= 1 << position;
	else
		data[i] &= ~(1 << position);
ssize_t rgbToClk(uint8_t* rgb, size_t numRgb, uint8_t* out, size_t numOut)
	memset(out, 0, numOut * sizeof(out[0]));
	// writeBitField(out, 0, 1);
	uint32_t clk = 0;
	// emsure we have complete RGB sets
	numRgb = numRgb - (numRgb % 3);
	for(uint32_t inBit = 0; inBit < numRgb * kBitsPerByte; ++inBit) {
		// data comes in as RGB but needs to be shuffled into GRB for the WS2812B
		uint32_t actualInBit;
		uint8_t remainder = inBit % (3 * kBitsPerByte);
		if(remainder < kBitsPerByte)
			actualInBit = inBit + kBitsPerByte;
		else if(remainder < kBitsPerByte * 2)
			actualInBit = inBit - kBitsPerByte;
		else
			actualInBit = inBit;
		bool value = readBitField(rgb, actualInBit);
		const T_t* Ts[2] = {TH, TL};
		for(unsigned int t = 0; t < 2; ++t) {
			const T_t* T = Ts[t];
			bool highLow = (0 == t) ? true : false;
			float time = 0;
			while(time < T[value].min) {
				bool wordEnd = (kSpiWordLength - 1 == clk);
				writeBitField(out, clk, highLow);
				time += kSpiPeriodNs;
				if(wordEnd)
					time += kSpiInterWordTime;
				++clk;
				if(clk / kBitsPerByte > numOut)
					return -1;
			if(time > T[value].max) {
				printf("Error: expected %f but got %f\n", T[value].max, time);
				return 0;
	ssize_t numBytes = ((clk + kSpiWordLength - 1) / kSpiWordLength) * kSpiWordLength / kBitsPerByte; // round up to the next word
	if(numBytes > numOut) // just in case numOut was not a multiple, we now no longer fit
		return -1;
	return numBytes;
void sendSpi(uint8_t* data, size_t length)
	if(length < kSpiMinTransferSize)
		length = kSpiMinTransferSize;
    if (spi.transfer(data, NULL, length) == 0)
        printf("SPI: Transaction Complete. Sent %d bytes\n", length);
    else
        printf("SPI: Transaction Failed\r\n");
#include <vector>
// rgb triplets, can be resized to match number of LEDs _before_ `task()` starts.
// after that, its content (but not size!) can be changed from anywhere
std::vector<uint8_t> colors = {{
	0x00, 0xC0, 0x00,
	0xC0, 0x00, 0x00,
	0x00, 0x00, 0xC0,
	0x00, 0x00, 0x00,
const uint8_t kBytesPerRgb = 3;
void task(void*) {
	std::vector<uint8_t> data(kSpiMaxTransferSize);
	// uint8_t kNumColors = colors.size() / kBytesPerRgb;
	uint8_t kNumLeds = 16;
	std::vector<uint8_t> rgb(kNumLeds * kBytesPerRgb);
	for (unsigned int n = 0; n < 100 && !Bela_stopRequested(); ++n) {
		for(unsigned int l = 0; l < kNumLeds; ++l) {
			printf("RGB[%d]: ", l);
			for(unsigned int b = 0;  b < kBytesPerRgb; ++b) {
				uint8_t val = colors[(( n + l) * kBytesPerRgb + b) % colors.size()];;
				rgb[l * kBytesPerRgb + b] = val;
				printf("%#02x ", val);
			printf("\n");
		printf("data: ");
		for(unsigned int n = 0; n < kNumLeds * kBytesPerRgb; ++n) {
			if(0 == (n % 3))
				printf("\n");
			printf("%#02x ", rgb[n]);
		printf("\n");
		ssize_t len = kSpiLeadingZeros + rgbToClk(rgb.data(), rgb.size(), data.data() + kSpiLeadingZeros, data.size() - kSpiLeadingZeros);
		if(len < 0) {
			fprintf(stderr, "Error: message too long\n");
			break;
		} else {
			printf("Data is %d\n", len);
		// print data as it will be sent out
		unsigned int k = 0;
		for(unsigned int n = 0; n < len; ++n) {
			for(unsigned int c = 0; c < kBitsPerByte; ++c) {
				printf("%d", (bool)(data[n] & (1 << c)));
				++k;
				if(0 == (k % kBitsPerByte))
					printf(" ");
				if(0 == (k % kSpiWordLength))
					printf("| ");
		printf("\n");
		// format data
		// SPI transmits the most significant byte first ("right justified in each word")
		// so if we have more than 1 byte per word we need to shuffle them around so that
		// they are output in the correct order
		unsigned int bytesPerWord = kSpiWordLength / kBitsPerByte;
		for(unsigned int n = 0; n < len; n += bytesPerWord) {
			for(unsigned int b = 0; b < bytesPerWord / 2; ++b) {
				uint8_t tmp = data[n + b];
				data[n + b] = data[n + bytesPerWord - 1 - b];
				data[n + bytesPerWord - 1 - b] = tmp;
		if(kSpiMsbFirst) {
				data[n] = __builtin_bitreverse8(data[n]);
		sendSpi(data.data(), data.size());
		usleep(100000);
	spi.setup({.device = "/dev/spidev2.1", // Device to open
		.speed = kSpiClock, // Clock speed in Hz
		.delay = 0, // Delay after last transfer before deselecting the device, won't matter
		.numBits = kSpiWordLength, // No. of bits per transaction word,
		.mode = Spi::MODE3 // SPI mode
	size_t numLeds = 12; // TODO: adjust depending on num of leds in use
	colors.resize(kBytesPerRgb * numLeds);
	Bela_runAuxiliaryTask(task, 90);
// TODO: set elements of `colors`
  • noah replied to this.
    wow, thanks a lot for the example code @giuliomoro!
    I am using the BelaMini and also uploaded your SPI_Library to the project but I am still getting some errors.
    First of all I had change #include <libraries/SPI/SPI.h> to #include <SPI.h> to use the library but I've still got the following error messages:
    unknown type name 'SPI' column: 1, line: 6
    use of undeclared identifier 'SPI' column: 3, line: 208
    use of undeclared identifier 'SPI' column: 3, line: 211
    I checked the example code in the SPI_Library and changed SPI::SS_LOW to SPI_SS_LOW and SPI::MODE3 to SPI_MODE3 so that they are recognized.
    Now I get "use of undeclared identifier" for spi.transfer and spi.setup.
    Any idea how to fix these?
    Right, the code I posted was for an older version of the Spi library. I now tested and amended it and it should work out of the box on your board.
    now it runs perfectly, thank you!
    hi, sorry for bothering again. I tried to "set elements of colors" but I don't have too much experience with C++. Is there any chance that you include an example in the code which shows how to do that? I would really appreciate it.
    I would then try and set the color of the LED from PD. To do that I can follow the OLED example to receive OSC messages from PD.
    the global variable colors contains triplets of colors that are sent to each LED. When you start the program, the variable's content looks like this:
    	0x00, 0xC0, 0x00,
    	0xC0, 0x00, 0x00,
    	0x00, 0x00, 0xC0,
    	0x00, 0x00, 0x00,
    So it drives four LED: green, red, blue, dark.
    If you have more than 4 LEDs, edit this:
    Once you have adjusted that, from within setup() or render() or even task() you can adjust the colors of the LEDs. This code will, for example, have all RED leds with increasing brightness
    for(unsigned int n = 0; n < colors.size() / kBytesPerRgb; n++)
        float relative = n / float(colors.size() / kBytesPerRgb);
        colors[n * kBytesPerRgb] = 0xff * relative;  // LED n, red
        colors[n * kBytesPerRgb + 1] = 0;  // LED n, green
        colors[n * kBytesPerRgb + 2] = 0;  // LED n, blue
    wow, you have the best support. Thanks a lot!
    4 days later
    Thanks for the code. After some adjustments for the leds i have, it work fine.
    i have encapsulate them in a class for easy usage :
    LedStripSpi  : send Strip Led (like WS2812) data
    with the SPI MOSI output
    To enable that you'll need to run 'config-pin P2.25 spi' after each reboot
    // For led YF923-F5-F8 (aliexpress) :
    // T0H 0 code, high voltage time 0.3us ±150ns
    // T1H 1 code, high voltage time 0.6us ±150ns
    // T0L 0 code, low voltage time 0.6us ±150ns
    // T1L 1 code, low voltage time 0.3us ±150ns
    // RES Frame unit, low voltage time >50µs
    #ifndef LEDSTRIPSPI_H
    #define LEDSTRIPSPI_H
    #include <stdio.h>
    #include <cmath>
    #include <string.h>
    class LedStripSpi
    	public:
    		enum LedType{
    		    WS2812B = 0,
    		    YF923F5F8
        protected:
            const uint8_t		kSpiWordLength = 32;
            const int8_t		kBytesPerRgb = 3;
            typedef struct {
                float min;
                float max;
            } T_t;
            bool            fReverseByte;
            bool            fGRB_Mode;
            float           fSpiInterWordTime;
            T_t             fTH[2];
            T_t             fTL[2];
            Spi             fSpi;
            Spi::Mode       fSpiMode;
            unsigned int    fNbrLeds;
            uint8_t*        fLedBuffers[2];
            uint8_t*        fDataBuffer;
            uint8_t         fCurrentSendingLedBuffer;
            uint8_t         fCurrentEditingLedBuffer;
            bool			fBufferSwitched;
            void SetType(LedType type)
                // We pick below some conservative values for Led Type
                switch(type) {
                    case WS2812B:
                        fTH[0].min = 200;
                        fTH[0].max = 400; // T0H
                        fTH[1].min = 700;
                        fTH[1].max = 900; // T1H
                        fTL[0].min = 750;
                        fTL[0].max = 950; // T0L
                        fTL[1].min = 350;
                        fTL[1].max = 550; // T1L
                        fReverseByte = false;
                        fGRB_Mode = true;
                        fSpiInterWordTime = 200;
                        fSpiMode = Spi::MODE3;
                        break;
                    case YF923F5F8:
                        fTH[0].min = 200;
                        fTH[0].max = 450; // T0H
                        fTH[1].min = 500;
                        fTH[1].max = 750; // T1H
                        fTL[0].min = 500;
                        fTL[0].max = 750; // T0L
                        fTL[1].min = 200;
                        fTL[1].max = 450; // T1L
                        fReverseByte = true;
                        fGRB_Mode = false;
                        fSpiInterWordTime = 0;
                        fSpiMode = Spi::MODE2;
                        break;
                    default:
                    	break;
                if(value)
                else
                uint32_t clk = 0;
                    if(fGRB_Mode) {   // data comes in as RGB but needs to be shuffled into GRB for the WS2812B
                        else
                    } else {
                    const T_t* Ts[2] = {fTH, fTL};
                        float time = 0;
                            if(wordEnd)
                                time += fSpiInterWordTime;
                            ++clk;
                                return -1;
                            return 0;
                    return -1;
                return numBytes;
            void SendSpi(uint8_t* data, size_t length)
                if (fSpi.transfer(data, NULL, length) != 0)
            void SendBufferToLeds(uint8_t* buffer, ssize_t buffersize, uint8_t* out, ssize_t outsize)
                ssize_t len = kSpiLeadingZeros + rgbToClk(buffer, buffersize, out + kSpiLeadingZeros, outsize - kSpiLeadingZeros);
                if(len < 0) {
                    return;
                        uint8_t tmp = out[n + b];
                        out[n + b] = out[n + bytesPerWord - 1 - b];
                        out[n + bytesPerWord - 1 - b] = tmp;
                if(kSpiMsbFirst) {
                        out[n] = __builtin_bitreverse8(out[n]);
                SendSpi(out, outsize);
        public:
            LedStripSpi()
                SetType(WS2812B);
                fNbrLeds = 0;
                fDataBuffer = new uint8_t[kSpiMaxTransferSize];
                fCurrentSendingLedBuffer = 1;
                fCurrentEditingLedBuffer = 0;
                fLedBuffers[0] = NULL;
                fLedBuffers[1] = NULL;
                fBufferSwitched = false;
            bool Init(LedType ledtype, unsigned int nbrleds)
                if(fNbrLeds > 0) // we don't call init sevelal times
                    return false;
                SetType(ledtype);
                if(fSpi.setup({ .device = "/dev/spidev2.1", // Device to open
                            .mode = fSpiMode // SPI mode
                }) != 0) {
                    printf("SPI: Initialisation Failed\r\n");
                    return false;
                // Led buffers initialisation
                fNbrLeds = nbrleds;
                ssize_t buffersize = fNbrLeds*kBytesPerRgb;
                fLedBuffers[0] = new uint8_t[buffersize];
                memset(fLedBuffers[0] ,0,buffersize);
                fLedBuffers[1] = new uint8_t[buffersize];
                memset(fLedBuffers[1] ,0,buffersize);
            void Draw()
                if(!fDataBuffer || !fLedBuffers[fCurrentSendingLedBuffer] || !fBufferSwitched) //draw only if new buffer
                    return;
                uint8_t* buffer = fLedBuffers[fCurrentSendingLedBuffer];
                SendBufferToLeds(buffer, fNbrLeds*kBytesPerRgb, fDataBuffer, kSpiMaxTransferSize);
            void Begin()
                memset(fLedBuffers[fCurrentEditingLedBuffer] ,0,fNbrLeds*kBytesPerRgb);
            void SetLedColor(int idxled, uint8_t red, uint8_t green, uint8_t blue)
               if(idxled >= fNbrLeds)
                   return;
               uint8_t* buffer = fLedBuffers[fCurrentEditingLedBuffer];
               buffer[idxled * kBytesPerRgb] = (fReverseByte ==  true) ? __builtin_bitreverse8(red) : red;
               buffer[idxled * kBytesPerRgb + 1] = (fReverseByte ==  true) ? __builtin_bitreverse8(green) : green;
               buffer[idxled * kBytesPerRgb + 2] = (fReverseByte ==  true) ? __builtin_bitreverse8(blue) : blue;
            void SetAllLedsBlack()
            void End()
               uint8_t tmp = fCurrentEditingLedBuffer;
               fCurrentEditingLedBuffer = fCurrentSendingLedBuffer;
               fCurrentSendingLedBuffer = tmp;
               fBufferSwitched = true;
            ~LedStripSpi()
                delete fLedBuffers[0];
                delete fLedBuffers[1];
                delete fDataBuffer;
                fDataBuffer = NULL;
    #endif
    here a sample usage with a trill bar :
    #include "ledstripspi.h"
    Trill gTouchSensor;
    LedStripSpi gLedStrip;
    unsigned int gNbrLeds = 12;
    unsigned int gRefreshRate = 50000;
    unsigned int gTrillRefreshRate = 100000;
    void LedStripTask(void*)
    	while(!Bela_stopRequested()) {
    		gLedStrip.Draw();
    		usleep(gRefreshRate);
    	//Back to black
    	gLedStrip.Begin();
    	gLedStrip.End();
    	gLedStrip.Draw();
    // set the leds colors in funtion of the position (0 to 1)
    void RenderBarGraph(float position)
        position = position * gNbrLeds;
        float luminosity = 1;
        for(int i = 0; i < gNbrLeds; i++) {
        	if((position - i) < 1)
        		luminosity = position - i;
        	else if(position < i)
        		luminosity = 0 ;
        	else luminosity = 1;
        	gLedStrip.SetLedColor(	i,
        							0x20*(float) (i/ (float) gNbrLeds)*luminosity,
        							0x14*(float) ((gNbrLeds-i)/ (float) gNbrLeds)*luminosity,
        							0*luminosity);
    //Take the position of the trill bar and render the bar graph
    void TrillBarTask(void*)
    	float Position;
            gTouchSensor.readI2C();
            int ActiveTouches = gTouchSensor.getNumTouches();
            if( ActiveTouches > 0) {
                Position = gTouchSensor.compoundTouchLocation();
                gLedStrip.Begin();
                RenderBarGraph(Position);
                gLedStrip.End();
            usleep(gTrillRefreshRate);
    	if(!gLedStrip.Init(LedStripSpi::YF923F5F8,gNbrLeds)) {
    		fprintf(stderr, "Unable to initialise LedStrip\n");
    		return false;
        //trill
        if(gTouchSensor.setup(1, Trill::BAR) != 0) {
    		fprintf(stderr, "Unable to initialise Trill Bar\n");
    		return false;
    	Bela_runAuxiliaryTask(LedStripTask, 90);
        Bela_runAuxiliaryTask(TrillBarTask, 90);
      4 days later
      Hi @PFaivre, thanks for your contribution, what part numbers does YF923F5F8 refer to?
      11 days later
      giuliomoro This assumes BelaMini is used and the neopixels are driven from pin P2.25. To enable that you'll need to run config-pin P2.25 spi after each reboot ( this can be automated later if needed).
      Hi, Could you maybe elaborate on automating this? I could not get this to work with the "user command line arguments"...
        you'd need to do something along the lines of what you see here.
        is that clear enough?
        noah automating this?
        The solution linked above is probably the easiest if you are using supercollider or Pd or Csound. But if you are using C++, you can do it in a simpler way.
        Put this line at the top of the file:
        #include <stdlib.h>
        and then in setup() add this:
        	system("config-pin P2.25 spi");
        Perfect, thanks so much!
        6 months later
        Hijacking this thread again:
        I've got some WS2812B 4x4 matrices and I've basically got them running quite well on a Bela mini, however, I still do get the occasional quirks (random single LEDs flashing in random colors every 20 or so seconds). I do think it's not HW related, as I have checked all connections, but it could still be some GND issue I assume.
        I also don't know the exact manufacturer of the matrices, so I don't have a datasheet, but I think the standard WS2812B times you also used are working well.
        I slowly don't know how to approach this issue anymore. @giuliomoro you wrote about the leading zeros and resulting random flashing if not done correctly. How did you determine those numbers (e.g. kSpiLeadingZerosNs)? I tried playing around a bit with those and I do think there are improvements, but as long as there are random flashes it's really hard to tell a difference between improvement and coincidence...
          How many LEDs are you driving at once? Where are they powered from?
          I'm driving 64 LEDs (usually not more than 32 at once). They're powered from a 5V/2A supply, Bela is currently powered from my Laptop, but was also already running powered from the same power supply. While bela is powered from my laptop, I have connected the supply's GND to Belas GND, this was necessary to get the SPI working correctly.
