Knallberto file does not exist." (after the reboot). Is this of any importance
Not a problem.
Knallberto and it works fine with running PD on my laptop (the neopixel are reacting to the mic input)
Brilliant
Not a problem.
Brilliant
Okay, it is working perfectly! Thanks for your help!
Hi,
Can I use the above description to get neopixel(like) LEDs running on a Bela even though I use a multiplexer? Audio channels not needed, same as above...
Yes
Hi, I am trying to control neopixel strip from Bela mini and having issues. I am running O2L C++ on Belamini and sending OSC message from PD on desktop.
The symptoms are:
- just sending "g" led color with intensity 120 for first 8 led turns all the led in white/red/blue (and other funny colors, but the changing sequence matches with when I change the control message) when powered with 5V and signal from P2.25.
- When powered with 3.3V and signal from P2.25, it does not do anything.
I also tried external transistor to reverse the signal voltage, it somehow turns the first led to green and nothing else happens.
I have also tried changing "kSpiLeadingZerosNs" inside the AddressableLeds.h but no luck.
Any suggestions?
What board are you sending to?
Bela Mini, from PD running on mac
And what neopixel board?
it is a stripe >> https://www.adafruit.com/product/1507
do you know what chips it comes with ? I see that since June 2022 it ships with these https://cdn-shop.adafruit.com/product-files/1655/SKC6812RV__12VOP0274E_REV.A1_EN%2812%29.pdf
The timing of the low signal here is slightly different from what's in O2L. Try changing
{.min = 750, .max = 950}, // T0L
in AddressableLeds.h to
{.min = 850, .max = 1000}, // T0L
and change
static constexpr double kSpiLeadingZerosNs = 50000; // determined empirically
to
static constexpr double kSpiLeadingZerosNs = 220000; // determined empirically
See if that changes anything.
Now for the real stuff: according to the electric specs in the datasheet the power supply Vdd needs to be 3.7V < Vdd < 5.5V and the high "Input signal flip threshold" VIH has to be at least Vdd*0.7, so if you are powering it from 5V, the 3.3V signal from Bela will not be enough.
This means you need some way of providing an in-spec voltage. A few options:
if(value)
in AddressableLeds.cpp to
if(!value)
Thanks for the reply! Yes! it works
The first trick you've mentioned (changing the timing) did not work. It goes crazy when signals are not sent.
I inverted the signal with transistor (2N7000) with 1k resistor (see the attached schematic note).
From the code side, I changed on AddressableLeds.h
- {.min = 750, .max = 950}, // T0L to {.min = 850, .max = 1000}, // T0L
I changed the timing, but the original timing also works when signal is inverted
- static constexpr double kSpiLeadingZerosNs = 0;
and AddressableLeds.cpp
if(value) to if(!value)
I am feeding 3.3V to neopixel strip with signal level 3.3v and it is running very stable now.
On the oscilloscope, the inverted signal looks rounded, but it is working. I guess it is coming from the transistor (this one's Turn on delay time is 10ns). Maybe one can use faster transistor.
That's great news, thanks for coming back to us with your findings. The turn-on time is 2 orders of magnitude smaller than the rising time you are seeing, so it shouldn't be the main culprit here. To fix those smoothed edges I'd try adding a ceramic capacitor (100n or more) between 3.3V and GND very close to the 2N7000.
Hi @giuliomoro - in case analog I/O isn't needed, is it enough to just disable that from the project settings and then update main.cpp of O2L with PinmuxUtils::set("P9_18", "spi") to use the BBB SPI0 without having to bend pins?
yes that should work. However, I recommend you check out the "pixelbone" branch. That one uses P8.35 without sacrificing neither the analogs nor the audio ins.
giuliomoro It seems the BelaArduino library is missing, is that some custom port of the Arduino headers for Bela, similar to RasPiArduino? Also, is it still necessary to load the device tree overlay with the pixelbone version?
Try the latest commit from that branch, which removes that dependency.
giuliomoro Would you please elaborate a bit on how to use the pixelbone branch? For context im using ws2812b and was able to install O2L and setup program as service but was not able to test. I tried both example files and nothing happened, is P8.35 one below analogue input row? I intend to work in wiring as im not fimilar with pd or supercollider, would you pls share some insight on how that will work. Thanks
You can see it here, you have to count pins from the edge. Trying to align it to the analog headers is error-prone.
With the correct pin, just run the project, download the patch local.pd
to your computer and run it with Pd. That will use your computer's microphone to make a vumeter and send OSC to the board, which will translate them to the neopixel.
