I'm sure you'll be fine ๐
Now that you have a FAT32 partition, ensure you always remove it safely from the host.
If you want you could also make it show up as a disk on the host when connecting Bela via USB. That is done by modifying /opt/Bela/bela_gadget.sh
. I must warn you that if anything goes bad while editing that file you will only be able to gain access to the board via UART.
Anyhow, if in there you edit this line:
echo ${THIS_DEVICE}p1 > functions/mass_storage.0/lun.0/file
so that instead of p1
you have p3
, that should be enough and "mostly harmless" (this way it will show up instead of BELABOOT
