tkay
Hello!
I'm back trying to use the HC-SR-04 sensor, this time with a regular full size bela. However I'm getting some errors. I'm not sure if this:
giuliomoro this one instead.
was meant to be used with the mini only. I am now using the analog out instead and as instructed i commented out the #define ULTRASONIC_DISTANCE_DIGITAL_OUT I connected the echo in (with resistor divider of course) in digital in 8 (pd 19)
What am I missing?
Here's the full error message:
In file render.cpp: no matching function for call to 'sys_doio' column: 3, line: 656
In file render.cpp: call to function 'strcmp' that is neither visible in the template definition nor found by argument-dependent lookup column: 11, line: 59
/root/Bela/projects/FX/render.cpp:656:3: error: no matching function for call to 'sys_doio'
sys_doio();
/usr/local/include/libpd/s_stuff.h:243:12: note: candidate function not viable: requires single argument 'pd_that', but no arguments were provided
extern int sys_doio(struct _pdinstance* pd_that);
/root/Bela/projects/FX/render.cpp:59:11: error: call to function 'strcmp' that is neither visible in the template definition nor found by argument-dependent lookup
if(0 == strcmp(id, db[n].first.c_str()))
/root/Bela/projects/FX/render.cpp:544:13: note: in instantiation of function template specialization 'getIdxFromId<Trill *>' requested here
int idx = getIdxFromId(sensorId, gTouchSensors);
/usr/include/string.h:140:12: note: 'strcmp' should be declared prior to the call site
extern int strcmp (const char *s1, const char *s2)
2 errors generated.
make: *** [/root/Bela/projects/FX/build/render.o] Error 1
