well.. good news and bad news.
the startup sequence works beautifully when i run it in the background, behind a simple OSC test Pd patch.
the OSC parsing still needs some attention, but it seems to work.
note that this is without audio, arrays for randomness etc.
however.
when i try to run my actual patch - the big one - i get this in the console:
Nov 03 17:16:48 bela stdbuf[254]: make: Warning: File 'libraries/OnePole/build/OnePole.d' has modification time 128404949 s in the future
Nov 03 17:16:48 bela stdbuf[254]: Running /root/Bela/projects/JukeBoxArrays/JukeBoxArrays -p64 -C4 -B16 -H0 -N1 -G1 -M0 -D0 -A0 --pga-gain-left=10 --pga-gain-right=10 -X0
Nov 03 17:16:48 bela stdbuf[254]: make: warning: Clock skew detected. Your build may be incomplete.
Nov 03 17:16:48 bela stdbuf[254]: make: Leaving directory '/root/Bela'
Nov 03 17:16:49 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
Nov 03 17:16:49 bela systemd[1]: Stopped Run Bela at boot.
Nov 03 17:16:49 bela systemd[1]: bela_startup.service: Start request repeated too quickly.
Nov 03 17:16:49 bela systemd[1]: Failed to start Run Bela at boot.
Nov 03 17:16:49 bela systemd[1]: bela_startup.service: Unit entered failed state.
Nov 03 17:16:49 bela systemd[1]: bela_startup.service: Failed with result 'start-limit-hit'.
not sure what that means, all i know is it doesn't work.
am i asking too much of the poor thing?
