giuliomoro the comment in the code is by Victor Lazzarini - it would be great if you contacted him about this (on the Bela at least) bug. It does confirm that the console is reporting this fact (feature? bug?) when the .csd is loaded and it reports that diskin2 has loaded the sample "sp_hellorcb.aif" - when the soundin opcode is used in the .csd file - but, then... there is silence, no sound, as if the file is loaded and there is no 'error' but the rest of the instrument can't find it. curious. I am sure Victor will have a suggestion and an explanation.
giuliomoro testing 615-bela5 now.
Awesome.
All seems to be working very very well. THANKS!
(I will report on the Trills in the next post - my Trill Craft is soldered and ready, but that test will wait until tomorrow)
Here are some details (30 or so models tested - NoteList, Generative, MIDI, Audio Processing, MIDI with Audio)
Warnings in the console about missing libraries - gone! - check
Audio IN - check
MIDI IN - check
- even Multiple Simultaneous MIDI controllers plugged into a USB HUB (are powered and working) - check
(when using the: -Ma command line flag)
MIDI and Audio at the same time - check (controlling Audio FX from MIDI sliders and knobs)
now, in some MIDI instruments, there do still seem to be an ever-increasing number of mode switching in the audio thread happening, especially when I am using real-time MIDI in, and even more when I have Multiple MIDI in set (-Ma), or without -Ma, but when I am playing lots of notes from my controller keyboard.
? do I need to "uninstall" portMIDI ?
- if so, how do I do this
Finally, for now, as you know, the soundin opcode is still not working correctly,
- maybe it will not work on the Bela?
- maybe this is by design and is related to memory issues and buffering issues?
BUT WOW - this is a really wonderful update. THANKS.
- I will be making you some model instruments (for testing and sharing)
    csounder now, in some MIDI instruments, there do still seem to be an ever-increasing number of mode switching in the audio thread happening, especially when I am using real-time MIDI in, and even more when I have Multiple MIDI in set (-Ma), or without -Ma, but when I am playing lots of notes from my controller keyboard
    Please send me the very code that shows this issue.
    To uninstall portmidi try
    dpkg -r libportmidi0
      doing some sound design with this MIDI instrument with reverb - quite a lot of mode switching still - and some crickets too. Try it out. You might need to change your CC numbers. I am using the Novation LaunchKey mini and it is set up for controllers 21 - 28 by default
      324559 mode switches detected on the audio thread.
      327326 mode switches detected on the audio thread.
      330092 mode switches detected on the audio thread.
      332858 mode switches detected on the audio thread.
      335625 mode switches detected on the audio thread.
      ; Adam Boulanger
      ; MIDI added to Hans Mikelson's 'River' instrument from The Csound Catalog
      <CsoundSynthesizer>
      <CsOptions>
      -Mhw:1,0,0 --daemon -dm0
      </CsOptions>
      <CsInstruments>
      sr     = 44100
      ksmps  = 16
      nchnls = 2
      0dbfs  = 1
      maxalloc 1, 6
      	ctrlinit 1, 21, 110, 22,110, 23,120, 24,1, 25,0, 26,64
      garvb		init	0
      			instr 	1
      iamp		ampmidi .75
      kcps		cpsmidib 1
      icps        cpsmidi
      kvol        midic7  21, 0,1
      kcut1		midic7	22, 50,800						;Added:Tune reson filters
      kcut2		midic7	23, 50,800
      kcut3		midic7	24, 440,880
      kmod		midic7	25, .6, 1.4
      krvbsend	midic7	26, 0,.5
      klfo		lfo		kmod, .02+rnd(.09)
      aplk		pluck 	iamp, kcps+klfo, icps, 0, 1
      asig        dcblock2 aplk
      af1			reson	asig, kcut1+rnd(440), 80
      af2			reson	asig, kcut2+rnd(222), 80
      af3			reson	asig, kcut3+rnd(880), 80
      abalnc		balance af1+af2+af3, asig
      afinal		linenr	abalnc, .01, .4, .5
      adry		=		afinal*kvol
      			outs 	adry,adry
      			vincr	garvb, adry*krvbsend
      			endin
              	instr  	Reverb
      irevtm    	=       2.6
      ihidif    	=       0.2
              	denorm garvb
      aout      	reverb2	garvb, irevtm, ihidif     	; DELAY FOR TIME
                	out		aout            	 		; OUTPUT THE CHANNEL
      			clear	garvb
                	endin
      </CsInstruments>
      <CsScore>
      f0  z
      f1	0	16384	10	1							; sine wave
      i "Reverb" 0	-1
      </CsScore>
      </CsoundSynthesizer>
      giuliomoro for comparison, you might be interested in the fact that this instrument, that uses more CPU but does not have any reverb running, does not report and mode switching or dropped blocks
      <CsoundSynthesizer>
      <CsOptions>
      -Mhw:1,0,0 -+rtmidi=NULL --daemon -dm0
      </CsOptions>
      <CsInstruments>
      sr     = 44100
      ksmps  = 16
      nchnls = 2
      0dbfs  = 1
      maxalloc 1,6
      ; Initialize the global variables.
      ; Table #1 - initial position
      git1 ftgen 1, 0, 128, 7, 0, 64, 1, 64, 0
      ; Table #2 - masses
      git2 ftgen 2, 0, 128, -7, 1, 128, 1
      ; Table #3 - stiffness
      git3 ftgen 3, 0, 128, -7, 0, 64, 100, 64, 0
      ; Table #4 - damping
      git4 ftgen 4, 0, 128, -7, 1, 128, 1
      ; Table #5 - initial velocity
      git5 ftgen 5, 0, 128, -7, 0, 128, 0
      instr 1
        iamp ampmidi .75
        ipch cpsmidi
        kenv	madsr .1,.12,.68,.3
        ipos = 1
        imass = 2
        istiff = git3
        idamp = 4
        ivel = 5
        a1 scantable iamp, ipch, ipos, imass, git3, idamp, ivel
        a2 dcblock a1
        outs a2*kenv,a2*kenv
      endin
      </CsInstruments>
      <CsScore>
      f0 z
      </CsScore>
      giuliomoro I have not yet tested the Trill Craft, but this .csd is running the other 4 Trill Sensors in a Trill Hub and sensing Vertical from each and using it to control the pitches of 4 oscillators. You might want to try it out.
      - more to come, and more musical too!
      You need to enclose the code you paste with ``` (triple backticks)
      OK. I will try that now. Sorry for the clutter and confusion:
      <CsoundSynthesizer>
      <CsOptions>
      --daemon -dm0
      </CsOptions>
      <CsInstruments>
      sr       = 44100
      ksmps    = 8
      nchnls   = 2
      0dbfs    = 1
        instr 1
          iNumTouches = 1
      ;	iNumTouches = 5
          iTrillID0 = 0
          kactiveTouches0 init 0
          ktouchSizes0[] init iNumTouches
          ktouchVert0[] init iNumTouches
          ktouchHori0[] init iNumTouches
          iTrillID1 = 1
          kactiveTouches1 init 0
          ktouchSizes1[] init iNumTouches
          ktouchVert1[] init iNumTouches
          ktouchHori1[] init iNumTouches
          iTrillID2 = 2
          kactiveTouches2 init 0
          ktouchSizes2[] init iNumTouches
          ktouchVert2[] init iNumTouches
          ktouchHori2[] init iNumTouches
          iTrillID3 = 3
          kactiveTouches3 init 0
          ktouchSizes3[] init iNumTouches
          ktouchVert3[] init iNumTouches
          ktouchHori3[] init iNumTouches
          kactiveTouches0, ktouchSizes0, ktouchVert0, ktouchHori0 trill iNumTouches, iTrillID0
          kactiveTouches1, ktouchSizes1, ktouchVert1, ktouchHori1 trill iNumTouches, iTrillID1
          kactiveTouches2, ktouchSizes2, ktouchVert2, ktouchHori2 trill iNumTouches, iTrillID2
          kactiveTouches3, ktouchSizes3, ktouchVert3, ktouchHori3 trill iNumTouches, iTrillID3
       ;   printk2 kactiveTouches0
       ;   printk2 kactiveTouches1
       ;   printk2 kactiveTouches2
       ;   printk2 kactiveTouches3
      ;    ktrig_v0 changed2 ktouchVert0
      ;    ktrig_h0 changed2 ktouchHori0
      ;    ktrig0 = ktrig_v0 + ktrig_h0
      ;    ktrig_v1 changed2 ktouchVert1
      ;    ktrig_h1 changed2 ktouchHori1
      ;    ktrig1 = ktrig_v1 + ktrig_h1
      ;    ktrig_v2 changed2 ktouchVert2
      ;    ktrig_h2 changed2 ktouchHori2
      ;    ktrig2 = ktrig_v2 + ktrig_h2
      ;    ktrig_v3 changed2 ktouchVert3
      ;    ktrig_h3 changed2 ktouchHori3
      ;    ktrig3 = ktrig_v3 + ktrig_h3
       ;   printarray ktouchVert0, ktrig0, "", "Vertical0:"
       ;   printarray ktouchHori0, ktrig0, "", "Horizontal0:"
       ;   printarray ktouchVert1, ktrig1, "", "Vertical1:"
       ;   printarray ktouchHori1, ktrig1, "", "Horizontal1:"
       ;   printarray ktouchVert2, ktrig2, "", "Vertical2:"
       ;   printarray ktouchHori2, ktrig2, "", "Horizontal2:"
       ;   printarray ktouchVert3, ktrig3, "", "Vertical3:"
       ;   printarray ktouchHori3, ktrig3, "", "Horizontal3:"
      kval0	=	ktouchVert0[0]
      kval1	=	ktouchVert1[0]
      kval2	=	ktouchVert2[0]
      kval3	=	ktouchVert3[0]
       asig1	oscil .5, 200 * (kval0 * 7)
       asig2	oscil .6, 300 * (kval1 * 6)
       asig3	oscil .5, 500 * (kval2 * 5)
       asig4	oscil .6, 800 * (kval3 * 4)
       outs asig1+asig3, asig2+asig4
        endin
      </CsInstruments>
      <CsScore>
      i1 0 -1
      </CsScore>
      Worked great! You can edit your previous posts to fix it there too. I did edit some of the earlier ones already
        giuliomoro Yes - I will clean up some of the previous posts as well - and provide you (and others) with working examples that they can cut and paste.
